imx8ulp EVK-HID(W): LIBUSB_ERROR_PIPE (-9)
2,342件の閲覧回数
MadKEm
Hi, i am following up the Getting Started with the i.MX 8ULP EVK document. In the part of loading bsp image into board using uuu.exe, i get an error which is HID(W): LIBUSB_ERROR_PIPE (-9) . the commands ı tried to execute are : uuu -b emmc_all imx-boot-imx8ulpevk-sd.bin-flash_singleboot_m33 and uuu.exe LF_v6.12.20-2.0.0_images_IMX8ULPEVK.zip. In the both execute i get the same error and in the serial port of the linux core, it says: [ERROR] DFI error. Please check DDR configuration. What could be the reason and solution?
ラベル(3)
3 返答(返信)
2,283件の閲覧回数
MadKEm
I was able to program it currently. The problem was related to the released version of the packages. I downloaded the meta-imx Release - Linux 6.12.20-2.0.0 and extracted all the required files to build the flash image. Then it worked. The "ROM download failure" problem looks like it is related to u boot binaries.
2,287件の閲覧回数
MadKEm
Hello @pengyong_zhang
I even tried that but it didn't work. So, after all of this I downloaded Linux and followed the process below:
I downloaded the following packages and binaries to create the standalone image(flash.bin): uboot-imx.git, imx-atf.git,  firmware-sentinel-0.10.bin and  firmware-upower-1.3.0.bin. I have extracted all the required files from the mentioned packages to create the flash.bin. I used VSCode and imported evk9mimx8ulp_hello_world_cm33 project. I renamed the hello_world.bin to m33_image.bin. Then used imx-mkimage with the following command to generate the flash.bin "make SOC=iMX8ULP REV=A2 flash_singleboot_m33".  Then used "uuu -b emmc flash.bin" but after this ı get HID(W):LIBUSB_ERROR_TIMEOUT. In the serial port it prints:
"invalid container image
Download -65712, Total size 0
ROM download failure -65712
Wrong Container, no image foundSPL: failed to boot from all boot devices"
These are the files that I use the generate the .bin file: mx8ulpa2-ahab-container.img, upower_a1.bin (fimware-upower-1.3.0), bl31.bin , u-boot.bin, u-boot-spl.bin and the m33_image.bin. Used command "make imx8ulp_evk_defconfig " to generate the u boot files.
2,299件の閲覧回数
pengyong_zhang
Hi @MadKEm
you should run the uuu -b emmc < flash.bin>, or uuu -b emmc_all <.wic image>
please run the uuu -h see the uuu UG.
B.R
%3CLINGO-SUB%20id%3D%22lingo-sub-2149035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8ulp%20EVK-HID(W)%3A%20LIBUSB_ERROR_PIPE%20(-9)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CSPAN%3E%E3%80%82i.MX%208ULP%20EVK%E3%81%AE%E5%85%A5%E9%96%80%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E4%B8%AD%E3%81%A7%E3%81%99%E3%80%82uuu.exe%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABBSP%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E9%83%A8%E5%88%86%E3%81%A7%E3%80%81HID(W)%3A%20LIBUSB_ERROR_PIPE%20(-9)%20%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E3%80%81uuu%20-b%20emmc_all%20imx-boot-imx8ulpevk-sd.bin-flash_singleboot_m33%E3%81%A8uuu.exe%20LF_v6.12.20-2.0.0_images_IMX8ULPEVK.zip%E3%81%A7%E3%81%99%E3%80%82%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81Linux%E3%82%B3%E3%82%A2%E3%81%AE%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%E3%80%8C%5BERROR%5D%20DFI%20error.%20Please%20check%20DDR%20configuration.%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%8E%9F%E5%9B%A0%E3%81%A8%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2149035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%96%E3%83%BC%E3%83%88ROM%7C%E3%83%96%E3%83%BC%E3%83%88%7C%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EUSB%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8ulp%20EVK-HID(W)%3A%20LIBUSB_ERROR_PIPE%20(-9)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82meta-imx%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20-%20Linux%206.12.20-2.0.0%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8A%BD%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%99%E3%82%8B%E3%81%A8%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8CROM%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AE%E5%A4%B1%E6%95%97%E3%80%8D%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81u%20%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8ulp%20EVK-HID(W)%3A%20LIBUSB_ERROR_PIPE%20(-9)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3E%40pengyong_zhang%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82%E3%81%9D%E3%82%8C%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82SO%E3%80%81%E3%81%93%E3%81%AE%E5%BE%8C%20Linux%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20(flash.bin)%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A8%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82uboot-imx.git%E3%80%81imx-atf.git%E3%80%81firmware-sentinel-0.10.bin%20%E3%81%A8%20firmware-upower-1.3.0.bin%E3%80%82flash.bin%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E6%8A%BD%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82VSCode%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81evk9mimx8ulp_hello_world_cm33%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82hello_world.bin%20%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%92%20m33_image.bin%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81imx-mkimage%20%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81flash.bin%20%22make%20SOC%3DiMX8ULP%20REV%3DA2%20flash_singleboot_m33%22%20%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%8Cuuu%20-b%20emmc%20flash.bin%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E5%BE%8C%E3%80%81HID(W)%3ALIBUSB_ERROR_TIMEOUT%20%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%E3%80%8C%E7%84%A1%E5%8A%B9%E3%81%AA%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%3CP%3E%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%20-65712%E3%80%81%E5%90%88%E8%A8%88%E3%82%B5%E3%82%A4%E3%82%BA%200%3C%2FP%3E%3CP%3EROM%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E5%A4%B1%E6%95%97%20-65712%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93SPL%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF.bin%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20mx8ulpa2-ahab-container.img%E3%80%81upower_a1.bin%20(fimware-upower-1.3.0)%E3%80%81bl31.bin%E3%80%81u-boot.bin%E3%80%81u-boot-spl.bin%20%E3%81%A8%20m33_image.bin%E3%80%82%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%8Cmake%20imx8ulp_evk_defconfig%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81u%20%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8ulp%20EVK-HID(W)%3A%20LIBUSB_ERROR_PIPE%20(-9)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253610%22%20target%3D%22_blank%22%3E%40MadKEm%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Euuu%20-b%20emmc%20%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%20uuu%20-b%20emmc_all%20%26lt%3B.wic%E7%94%BB%E5%83%8F%26gt%3B%3C%2FP%3E%0A%3CP%3Euuu%20-h%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%20uuu%20UG%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%3C%2FLINGO-BODY%3E
