I am working with an imx93evk sdk_2_16 (I am not sure how I generated it, will provide the generation steps in next post).
I observed that, the "PRINTF()" function is not able to print float values (it will only print textual content and remains blank in the place of float values)
I read in this query that, I need to enable some macros during project generation, but since my project is already generated, I couldn't regenerate it (there are many untracked changes which will be lost if I rebuild again)
So, is there a way where I can modify in the source code, so that I can achieve this. (I tried enabling the PRINT_FLOAT_ENABLE macro but yet it is not working)
This is the configuration, I currently have :
PRINT_FLOAT_ENABLE = 1
SDK_DEBUG_CONSOLE = 1
Thanks!
已解决! 转到解答。
How did you modify your source code?
Please try to define these flags before fsl_debug_console.
// main.c
#define PRINTF_FLOAT_ENABLE 1
#define SDK_DEBUGCONSOLE 1
#include "fsl_debug_console.h"
If not work, then try to modify LDFLAGS
-Wl,-u,_printf_float
Zhiming
// main.c
Zhiming
