Writing QSPI Flash on MCXN947 board.
已解决
跳至解决方案
8,908 次查看
takagi_y
The other day I asked a question about writing flash to FRDM-MCXN947.
Thanks to your answer, I am now able to write to FRDM-MCXN947.
Thank you.
This time I would like to ask a question about writing flash to another board using MCXN947.
I tried to write to this board using the writing method for FRDM-MCXN947 as a reference, but an error occurred.
Below is the content of the console at that time.
NXP: MCXN947
DAP stride is 1024 bytes (256 words)
Inspected v.2 External Flash Device on SPI using SFDP JEDEC ID MCXN9xx_SFDP_FlexSPI.cfx
Image 'MCXN9xx_SFDP_FlexSPI Sep 19 2024 18:18:31'
Opening flash driver MCXN9xx_SFDP_FlexSPI.cfx
VECTRESET requested, but not supported on ARMv8-M CPUs. Using SOFTRESET instead.
Using SOFT reset to run the flash driver
Driver V.2 dynamic startup failed - driver Init provided no flash parameters
driver describes no sectors starting at 0x80000000
Flash Driver V.2 startup failed - rc Ef(58): Flash Driver describes no sectors at its base address
chip initialization failed - Ef(58): Flash Driver describes no sectors at its base address
failed to initialize flash driver MCXN9xx_SFDP_FlexSPI.cfx
Is there any setting or anything I need to do?
I would appreciate your reply.
标签 (1)
1 解答
7,838 次查看
Harry_Zhang
Hi @takagi_y
You can write from the SEC tool, this proves that the FCB produced by SEC is correct.
So i think you can flash the correct FCB to 0x80000400.
And then delete mcxn_flexspi_nor_config.c and mcxn_flexspi_nor_config.h in MCUXpresso.
Because they generate the NEW FCB and flash in 0x80000400.
And you can debug it.
I tested, i generate the FCB.bin through the SEC tool. and flash it into 0x80000400.
And i can debug it successfully.
To summarize, put the correct FCB into 0x80000400, and put the correct application into 0x80001000.
Harry
在原帖中查看解决方案
23 回复数
8,191 次查看
Harry_Zhang
HI @takagi_y
"I tried to write to this board using the writing method for FRDM-MCXN947 as a reference, but an error occurred."
You change to another board.
Did you try the same method but not succeed?
Harry
8,173 次查看
takagi_y
Thank you for your reply.
I modified the project with reference to the demo program of FRDM-MCXN947 and confirmed writing from IDE.
The procedure is as written yesterday under "As additional information...".
My board uses MX25L3233F for Flash, so I built an example of CMSIS-DAP Flash Drivers and checked it.
First, I used the one I built without any modifications and wrote it from the IDE. (CONFIG_OPTION0=0xC0000001)
As a result, the following was displayed on the console and writing was not performed.
MCUXpresso IDE RedlinkMulti Driver v24.9 (Sep 19 2024 19:34:05 - crt_emu_cm_redlink build 802)
Found chip XML file in C:/WorkSpace/MCUX/MCUXpressoIDE_24.9.25/NX-N947/frdmmcxn947_hello_world_qspi_xip/Debug\MCXN947.xml
( 5) Remote configuration complete
Reconnected to existing LinkServer process.
Probe Firmware: MCU-LINK (r0FF) CMSIS-DAP V3.153 (NXP Semiconductors)
Serial Number: VUDADS0NIE0ZM
VID:PID: 1FC9:0143
USB Path: 0001:0008:00
Using memory from core 0 after searching for a good core
processor is in secure mode
debug interface type = CoreSight DP (DAP DP ID 6BA02477) over SWD TAP 0
processor type = Cortex-M33 (CPU ID 00000D21) on DAP AP 0
number of h/w breakpoints = 8
number of flash patches = 0
number of h/w watchpoints = 4
Probe(0): Connected&Reset. DpID: 6BA02477. CpuID: 00000D21. Info: <None>
Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Content of CoreSight Debug ROM(s):
RBASE E00FE000: CID B105100D PID 0000095000 ROM (type 0x1)
ROM 1 E00FF000: CID B105100D PID 04000BB4C9 ROM (type 0x1)
ROM 2 E000E000: CID B105900D PID 04000BBD21 CSt ARM ARMv8-M type 0x0 Misc - Undefined
ROM 2 E0001000: CID B105900D PID 04000BBD21 CSt ARM DWTv2 type 0x0 Misc - Undefined
ROM 2 E0002000: CID B105900D PID 04000BBD21 CSt ARM FPBv2 type 0x0 Misc - Undefined
ROM 2 E0000000: CID B105900D PID 04000BBD21 CSt ARM ITMv2 type 0x43 Trace Source - Bus
ROM 2 E0041000: CID B105900D PID 04002BBD21 CSt ARM ETMv4.0 type 0x13 Trace Source - Core
ROM 2 E0042000: CID B105900D PID 04000BBD21 CSt ARM CTIv2 type 0x14 Debug Control - Trigger, e.g. ECT
ROM 1 E0040000: CID B105900D PID 04000BBD21 CSt type 0x11 Trace Sink - TPIU
ROM 1 E0044000: CID B105900D PID 04003BB908 CSt CSTF type 0x12 Trace Link - Trace funnel/router
ROM 1 E0045000: CID B105900D PID 04001BB961 CSt type 0x21 Trace Sink - ETB
NXP: MCXN947
Inspected v.2 External Flash Device on SPI using SFDP JEDEC ID MCXN9xx_SFDP_FlexSPI_.cfx
Image 'MCXN9xx_SFDP_FlexSPI Mar 6 2025 17:01:24'
Opening flash driver MCXN9xx_SFDP_FlexSPI_.cfx
Flash variant 'JEDEC_FlexSPI_Device' detected (0B = at 0x80000000)
failed to initialize flash driver MCXN9xx_SFDP_FlexSPI_.cfx
Flash variant 'JEDEC_FlexSPI_Device' detected (4MB = 64*64K at 0x80000000)
Closing flash driver MCXN9xx_SFDP_FlexSPI_.cfx
Next, I changed the setting value used in the SEC tool (CONFIG_OPTION0=0xC0000405) and checked, but writing was not performed here either.
(You can write with the SEC tool.)
The following is the console display at that time.
Found chip XML file in C:/WorkSpace/MCUX/MCUXpressoIDE_24.9.25/NX-N947/NX-N947_ledblinky/frdmmcxn947_led_blinky/Debug_NoRAM\MCXN947.xml
VID:PID: 1FC9:0143
( 30) Emulator Connected
NXP: MCXN947
Inspected v.2 External Flash Device on SPI using SFDP JEDEC ID MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx
Image 'MCXN9xx_SFDP_FlexSPI Mar 6 2025 18:26:01'
Opening flash driver MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx
failed to initialize flash driver MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx
Is it necessary to change anything other than CONFIG_OPTION0 for MX25L3233F?
8,155 次查看
Harry_Zhang
Hi @takagi_y
On FRDM-MCXN947, the Qflash is W25Q64JVSSIQ.
On your customer board, the qflash is MX25L3233F.
So you need to change the Flash burning algorithm.
Such as MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx
And in the mcxn_flexspi_nor_config.c
Change the LUT
Harry
8,093 次查看
takagi_y
I compared the data sheets for W25Q64JVSSIQ and MX25L3233F and confirmed that the LUT contents are the same.
Does the above mean that you need to change the code other than CONFIG_OPTION0 and CONFIG_OPTION1 in MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx?
Or does it mean that there are other files that need to be modified besides MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx?
If other files need to be modified, could you please let me know the files?
7,971 次查看
Harry_Zhang
Hi @takagi_y
Apart from MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx and mcxn_flexspi_nor_config.c, there are no other files that need to be modified.
"I compared the data sheets for W25Q64JVSSIQ and MX25L3233F and confirmed that the LUT contents are the same."
No, they are different.
You can refer to the flexspi_polling example, it includes the LUT of W25Q64JVSSIQ and MX25L3233F.
#if EXAMPLE_FLASH_TYPE == FLASH_W25Q64
/* W25Q64JVSSIQ */
const uint32_t customLUTOctalMode[CUSTOM_LUT_LENGTH] = {
    /* Read data */
    [4 * NOR_CMD_LUT_SEQ_IDX_READ] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0xEB, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_4PAD, 0x18),
    [4 * NOR_CMD_LUT_SEQ_IDX_READ + 1] = FLEXSPI_LUT_SEQ(
        kFLEXSPI_Command_MODE8_SDR, kFLEXSPI_4PAD, 0xF0, kFLEXSPI_Command_DUMMY_SDR, kFLEXSPI_4PAD, 0x04),
    [4 * NOR_CMD_LUT_SEQ_IDX_READ + 2] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_READ_SDR, kFLEXSPI_4PAD, 0x00, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /* Read status register */
    [4 * NOR_CMD_LUT_SEQ_IDX_READSTATUS] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x05, kFLEXSPI_Command_READ_SDR, kFLEXSPI_1PAD, 0x00),
    /* Write enable */
    [4 * NOR_CMD_LUT_SEQ_IDX_WRITEENABLE] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x06, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /* Write enable */
    [4 * NOR_CMD_LUT_SEQ_IDX_WRITEENABLE_OPI] =
    /* Read ID */
    [4 * NOR_CMD_LUT_SEQ_IDX_READID_OPI] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x9F, kFLEXSPI_Command_READ_SDR, kFLEXSPI_1PAD, 0x00),
    /* Sector erase */
    [4 * NOR_CMD_LUT_SEQ_IDX_ERASESECTOR] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x20, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_1PAD, 0x18),
    /* Chip erase */
    [4 * NOR_CMD_LUT_SEQ_IDX_CHIPERASE] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x60, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /* Page program */
    [4 * NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x32, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_1PAD, 0x18),
    [4 * NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM + 1] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_WRITE_SDR, kFLEXSPI_4PAD, 0x00, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /* Enter Quad mode */
    [4 * NOR_CMD_LUT_SEQ_IDX_ENTEROPI] =
    /*  Dummy write, do nothing when AHB write command is triggered. */
    [4 * NOR_CMD_LUT_SEQ_IDX_WRITE] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x0, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x0),
    /*  Read status register using Quad mode */
    [4 * NOR_CMD_LUT_SEQ_IDX_READSTATUS_OPI] =
#endif
#if EXAMPLE_FLASH_TYPE == FLASH_MT35XU512
/* MT35XU512ABA1G12 */
    /*  OPI DDR read */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0xCC, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0xCC),
        kFLEXSPI_Command_RADDR_DDR, kFLEXSPI_8PAD, 0x20, kFLEXSPI_Command_DUMMY_DDR, kFLEXSPI_8PAD, 0x0D),
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_READ_DDR, kFLEXSPI_8PAD, 0x00, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /* Write Enable */
    /* Read ID under octal mode */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x9F, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x9F),
    [4 * NOR_CMD_LUT_SEQ_IDX_READID_OPI + 1] = FLEXSPI_LUT_SEQ(
        kFLEXSPI_Command_DUMMY_DDR, kFLEXSPI_8PAD, 0x10, kFLEXSPI_Command_READ_DDR, kFLEXSPI_8PAD, 0x00),
    /*  Write Enable */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x06, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x06),
    /*  Erase Sector */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x20, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x20),
    [4 * NOR_CMD_LUT_SEQ_IDX_ERASESECTOR + 1] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_RADDR_DDR, kFLEXSPI_8PAD, 0x20, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /*  Erase Chip */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x60, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x60),
    /*  Program */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x8E, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x8E),
    [4 * NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM + 1] = FLEXSPI_LUT_SEQ(
        kFLEXSPI_Command_RADDR_DDR, kFLEXSPI_8PAD, 0x20, kFLEXSPI_Command_WRITE_DDR, kFLEXSPI_8PAD, 0x00),
    /* Enter OPI mode */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x81, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_1PAD, 0x18),
    [4 * NOR_CMD_LUT_SEQ_IDX_ENTEROPI + 1] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_WRITE_SDR, kFLEXSPI_1PAD, 0x00, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /*  Read status register using Octal DDR read */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x05, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x05),
    [4 * NOR_CMD_LUT_SEQ_IDX_READSTATUS_OPI + 1] = FLEXSPI_LUT_SEQ(
#endif
Harry
7,843 次查看
takagi_y
I have checked the example you provided.
The Flash I want to use is MX25L3233F.
The example you provided is for MT35XU512ABA, which is a different model number.
The following is an excerpt of the MX25L3233F command, which is the same as the MT35XU512ABA command.
It is MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx, but do I need to make any changes other than to FlashConfig.h?
7,784 次查看
Harry_Zhang
Hi @takagi_y
Apart from MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx and  FlashConfig.h, there are no other files that need to be modified.
Harry
7,683 次查看
takagi_y
I have only modified the two files you mentioned, but the error still occurs.
I will upload the files I am using and the error message.
I cannot identify the reason why the Flash Driver V2 fails to start, so please give me some advice.
In this file, the value of sflashA1Size has been changed from 8M to 4M.
* Copyright 2018-2022 NXP
* All rights reserved.
* SPDX-License-Identifier: BSD-3-Clause
#include "mcxn_flexspi_nor_config.h"
/* Component ID definition, used by tools. */
#ifndef FSL_COMPONENT_ID
#define FSL_COMPONENT_ID "platform.drivers.xip_board"
#endif
* Code
#if defined(__CC_ARM) || defined(__ARMCC_VERSION) || defined(__GNUC__)
__attribute__((section(".flexspi_fcb"), used))
#elif defined(__ICCARM__)
#pragma location = ".flexspi_fcb"
#endif
#ifndef FLEXSPI_USE_CUSTOM_FCB
#define FLEXSPI_USE_CUSTOM_FCB (0)
#endif
#if FLEXSPI_USE_CUSTOM_FCB
/* FCB for W25Q64 */
const uint8_t CUSTOM_FCB[] = {
0x46, 0x43, 0x46, 0x42, 0x00, 0x04, 0x01, 0x56, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x03, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x01, 0x04, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xeb, 0x04, 0x18, 0x0a, 0x06,
0x32, 0x04, 0x26, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x04, 0x04, 0x24, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20,
0x04, 0x18, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xd8, 0x04, 0x18, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x04, 0x18, 0x08, 0x04, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x60, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00,
0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
#else
const flexspi_nor_config_t qspiflash_config = {
.memConfig =
.tag = FLEXSPI_CFG_BLK_TAG,
.version = FLEXSPI_CFG_BLK_VERSION,
.readSampleClksrc=kFlexSPIReadSampleClk_LoopbackFromDqsPad,
.csHoldTime = 3u,
.csSetupTime = 3u,
// Enable DDR mode, Wordaddassable, Safe configuration, Differential clock
.controllerMiscOption = (1u << kFlexSpiMiscOffset_SafeConfigFreqEnable),
.deviceType = kFlexSpiDeviceType_SerialNOR,
.sflashPadType = kSerialFlash_4Pads,
.serialClkFreq = kFlexSpiSerialClk_75MHz,
.sflashA1Size = 4u * 1024u * 1024u,
.lookupTable =
// Read LUTs
[0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0xEB, RADDR_SDR, FLEXSPI_4PAD, 0x18),
[1] = FLEXSPI_LUT_SEQ(DUMMY_SDR, FLEXSPI_4PAD, 0x06, READ_SDR, FLEXSPI_4PAD, 0x04),
// Read Status LUTs
[4 * 1 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x05, READ_SDR, FLEXSPI_1PAD, 0x04),
// Write Enable LUTs
[4 * 3 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x06, STOP, FLEXSPI_1PAD, 0x0),
// Erase Sector LUTs
[4 * 5 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x20, RADDR_SDR, FLEXSPI_1PAD, 0x18),
// Erase Block LUTs
[4 * 8 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0xD8, RADDR_SDR, FLEXSPI_1PAD, 0x18),
// Pape Program LUTs
[4 * 9 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x02, RADDR_SDR, FLEXSPI_1PAD, 0x18),
[4 * 9 + 1] = FLEXSPI_LUT_SEQ(WRITE_SDR, FLEXSPI_1PAD, 0x04, STOP, FLEXSPI_1PAD, 0x0),
// Erase Chip LUTs
[4 * 11 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x60, STOP, FLEXSPI_1PAD, 0x0),
.pageSize = 256u,
.sectorSize = 4u * 1024u,
.ipcmdSerialClkFreq = 1u,
.blockSize = 64u * 1024u,
.isUniformBlockSize = false,
#endif
FlashConfig.h
I created four different versions of this file with different values ​​for CONFIG_OPTION0. (0xC0000001, 0xC0000405, 0xC0000401, 0xC0000101)
I have used each one to check.
// FlashConfig.h
// MCUXpresso IDE Flash driver
// Config file for MCXN9xx FlexSPI driver
// Copyright 2022-2024 NXP
// SPDX-License-Identifier: BSD-3-Clause
#ifndef FLASHCONFIG_H_
#define FLASHCONFIG_H_
#include "fsl_flexspi_nor_flash.h"
extern flexspi_nor_config_t flashConfig;
#if defined (DEBUG)
#define MCXN9xx_SFDP_FlexSPI
#endif
// MCX N1xNxxx Reference Manual - 15.4.2 FlexSPI NOR Configuration Option Block
#if defined (MCXN9xx_SFDP_FlexSPI) || defined (MCXN9xx_SFDP_FlexSPI_S)
* 0xC : tag
* 0 : option_size (0 = option1 not specified)
* 0 : device_type (0 = Read SFDP for SDR commands)
* 0 : query_pads (0 = 1 data pad during query)
* 0 : cmd_pads (0 = 1 data pad during flash access)
* 0 : quad_mode_setting (0 = not configured)
* 0 : misc_mode
* 1 : max_freq (0 = Don't change FlexSPI clock setting)
#define CONFIG_OPTION0 0xC0000001
//#define CONFIG_OPTION0 0xC0000405
//#define CONFIG_OPTION0 0xC0000401
//#define CONFIG_OPTION0 0xC0000101
* 0x0 : Single Flash connected to Port A
#define CONFIG_OPTION1 0x00000000
#endif
// Flash Base Address Information
#if defined (MCXN9xx_SFDP_FlexSPI_S)
#define USE_SECURE_FLASHADDR
#define FLASH_BASE_ADDR 0x90000000
#else
#define FLASH_BASE_ADDR 0x80000000
#endif
#endif /* FLASHCONFIG_H_ */
When 0xC0000001 is used for CONFIG_OPTION0, the following Console A is displayed on the Console, and when not, Console B is displayed.
Console A
VID:PID: 1FC9:0143
USB Path: 0001:0003:00
NXP: MCXN947
Inspected v.2 External Flash Device on SPI using SFDP JEDEC ID MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx
Image 'MCXN9xx_SFDP_FlexSPI Mar 21 2025 14:26:16'
Opening flash driver MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx
failed to initialize flash driver MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx
Closing flash driver MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx
Console B
VID:PID: 1FC9:0143
NXP: MCXN947
7,613 次查看
Harry_Zhang
Hi @takagi_y
Have we considered hardware connectivity issues?
Are you a custom board?
If you are a custom board, can you connect this flash to FRDM-MXN947?
And try again.
If the flash still cannot work when connected to FRDM-MXN947.
I will buy this flash and test it.
Harry
7,574 次查看
takagi_y
As you suggested, I replaced the Flash of FRDM-MXN947 with MX25L3233 and checked.
I was able to write when I used the same mcxn_flexspi_nor_config.c as the one I uploaded the other day and FlashConfig.h with CONFIG_OPTION0 set to 0xC0000101.
However, I cannot write on my board even when I use the same file.
On my board, I use port A in INDIVIDUAL mode, so SS0_b is connected to MX25L3233 and SS1_b is connected to PSRAM, but I wonder if PSRAM is affecting it.
I have attached a circuit diagram showing the connection of Flash and PSRAM.
If you have any comments, please give me some advice.
Also, I have set the Memory configuration editor as follows.
The flash size is set to 0xffff000, but since I'm using a 4MByte product, I think 0x3ff000 is correct.
Will this size setting affect flash writing?
标记 (1)
7,514 次查看
takagi_y
We have confirmed the following regarding this issue and would like to inform you of the issue.
We suspected that the PSRAM may be affecting the circuit, so we opened JP1 in the circuit diagram uploaded yesterday and checked with the PSRAM electrically disconnected, but we were unable to write to the Flash.
If you have any advice, including about yesterday's post, we would appreciate it.
7,434 次查看
Harry_Zhang
Hi @takagi_y
"As you suggested, I replaced the Flash of FRDM-MXN947 with MX25L3233 and checked.
I was able to write when I used the same mcxn_flexspi_nor_config.c as the one I uploaded the other day and FlashConfig.h with CONFIG_OPTION0 set to 0xC0000101."
This proves that your software configuration is fine.
So I think it's still a hardware issue.
Can you try connecting to Nor Flash only?
Disconnect the PSRAM related electrically(including DATA CLOCK CS).
Harry
7,424 次查看
takagi_y
Since the CEn of the PSRAM is fixed at the H level, I believe that the DATA and CLOCK of the PSRAM do not affect the QSPI Flash.
Are there any other possible causes?
7,364 次查看
takagi_y
I have an additional question.
The PSRAM is electrically isolated, and in this state, writing can be done from the SEC tool.
If writing is done from the IDE in the same state, it fails.
If the PSRAM is affecting it, I think writing cannot be done with the SEC tool either.
What do you think?
7,266 次查看
Harry_Zhang
Hi @takagi_y
Yes, your analysis is correct.
If writing can be done from the SEC tool.
This proves that there is no issue with the hardware.
Previously, you verified that your software had no issues with FRDM mcxn947, and now you have verified that your hardware has no issues with SEC tool,
so can you work now?
Harry
7,244 次查看
takagi_y
I can write from the SEC tool, but I cannot write from MCUXpresso IDE.
I think there is some reason why I cannot write from MCUXpresso IDE, but I don't know what it is.
Could you give me some advice?
标记 (1)
7,839 次查看
Harry_Zhang
Hi @takagi_y
Harry
6,699 次查看
takagi_y
In this thread, I have asked a question about not being able to write using write_image_win.bat, but this has not yet been resolved.
I would like to summarize the current situation.
- When writing to a brand new board using a bat file, the process that should say "Erase memory before writing image" is displayed as "failed."
- Boards that have already been written to using the SEC tool can be written to using the bat file.
The following are the questions I would like to ask.
1. Why can't I write to a brand new board using a bat file?
2. Is there anything I need to do to write to a brand new board using a bat file?
3. Is there a difference between a board that has already been written to using the SEC tool and a brand new board?
Please answer.
6,677 次查看
Harry_Zhang
Hi @takagi_y
We have already resolved the previous issue. For this question, I suggest you create a new one in the community.
We will do our best to support you. Thank you for your understanding.
Harry
6,597 次查看
takagi_y
Understood.
I have posted the question below, so please reply there.
https://community.nxp.com/t5/MCX-Microcontrollers/Writing-to-the-QSPI-Flash-of-MCXN947-using-write-i...
%3CLINGO-SUB%20id%3D%22lingo-sub-2055980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%89%8D%E5%87%A0%E5%A4%A9%E6%88%91%E9%97%AE%E4%BA%86%E4%B8%80%E4%B8%AA%E5%85%B3%E4%BA%8E%E5%B0%86%E9%97%AA%E5%AD%98%E5%86%99%E5%85%A5FRDM-MCXN947%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94%EF%BC%8C%E6%88%91%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E5%86%99%E5%85%A5%20FRDM-MCXN947%20%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E8%BF%99%E6%AC%A1%E6%88%91%E6%83%B3%E9%97%AE%E4%B8%80%E4%B8%AA%E5%85%B3%E4%BA%8E%E4%BD%BF%E7%94%A8MCXN947%E5%B0%86%E9%97%AA%E5%AD%98%E5%86%99%E5%85%A5%E5%8F%A6%E4%B8%80%E5%9D%97%E6%9D%BF%E5%AD%90%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%8F%82%E8%80%83FRDM-MCXN947%E7%9A%84%E5%86%99%E5%85%A5%E6%96%B9%E6%B3%95%E5%86%99%E5%85%A5%E8%AF%A5%E6%9D%BF%E5%AD%90%EF%BC%8C%E4%BD%86%E6%98%AF%E5%87%BA%E7%8E%B0%E4%BA%86%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E5%BD%93%E6%97%B6%E6%8E%A7%E5%88%B6%E5%8F%B0%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%E6%81%A9%E6%99%BA%E6%B5%A6%EF%BC%9AMCXN947%3CBR%20%2F%3E%20DAP%20%E6%AD%A5%E5%B9%85%E4%B8%BA%201024%20%E5%AD%97%E8%8A%82%EF%BC%88256%20%E4%B8%AA%E5%AD%97%EF%BC%89%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI.cfx%20%E6%A3%80%E6%9F%A5%20SPI%20%E4%B8%8A%E7%9A%84%20v.2%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E5%9B%BE%E7%89%87%E2%80%9CMCXN9xx_SFDP_FlexSPI%202024%E5%B9%B49%E6%9C%8819%E6%97%A5%2018%3A18%3A31%E2%80%9D%3CBR%20%2F%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI.cfx%3CBR%20%2F%3E%E5%B7%B2%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv8-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E6%94%B9%E7%94%A8%20SOFTRESET%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%8A%A8%E6%80%81%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E6%9C%AA%E6%8F%90%E4%BE%9B%E9%97%AA%E5%AD%98%E5%8F%82%E6%95%B0%3CBR%20%2F%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%8E%200x80000000%20%E5%BC%80%E5%A7%8B%E7%9A%84%E6%89%87%E5%8C%BA%3CBR%20%2F%3EFlash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20rc%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3CBR%20%2F%3E%E8%8A%AF%E7%89%87%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%20-%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9C%B0%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI.cfx%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI.cfx%20%E6%A3%80%E6%9F%A5%20SPI%20%E4%B8%8A%E7%9A%84%20v.2%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E5%9B%BE%E7%89%87%E2%80%9CMCXN9xx_SFDP_FlexSPI%202024%20%E5%B9%B4%209%20%E6%9C%88%2019%20%E6%97%A5%2018%3A18%3A31%E2%80%9D%3CBR%20%2F%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI.cfx%3CBR%20%2F%3E%E5%B7%B2%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv8-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E6%94%B9%E7%94%A8%20SOFTRESET%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%8A%A8%E6%80%81%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E6%9C%AA%E6%8F%90%E4%BE%9B%E9%97%AA%E5%AD%98%E5%8F%82%E6%95%B0%3CBR%20%2F%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%8E%200x80000000%20%E5%BC%80%E5%A7%8B%E7%9A%84%E6%89%87%E5%8C%BA%3CBR%20%2F%3EFlash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20rc%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3CBR%20%2F%3E%E8%8A%AF%E7%89%87%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%20-%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9C%B0%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI.cfx%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E8%AE%BE%E7%BD%AE%E6%88%96%E5%81%9A%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2055980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EMCXN%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2083516%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2083516%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%B7%B2%E5%B0%86%E9%97%AE%E9%A2%98%E5%8F%91%E5%B8%83%E5%9C%A8%E4%B8%8B%E9%9D%A2%EF%BC%8C%E8%AF%B7%E5%9C%A8%E9%82%A3%E9%87%8C%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCX-Microcontrollers%2FWriting-to-the-QSPI-Flash-of-MCXN947-using-write-image-win-bat%2Fm-p%2F2083513%23M2906%22%20target%3D%22_self%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCX-Microcontrollers%2FWriting-to-the-QSPI-Flash-of-MCXN947-using-write-image-win-bat%2Fmp%2F2083513%23M2906%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2083212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2083212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E4%BA%86%E4%B9%8B%E5%89%8D%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E5%AF%B9%E4%BA%8E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E5%9C%A8%E7%A4%BE%E5%8C%BA%E4%B8%AD%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%86%E5%B0%BD%E5%8A%9B%E6%94%AF%E6%8C%81%E6%82%A8%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%90%86%E8%A7%A3%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2083050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2083050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E8%BF%99%E4%B8%AA%E5%B8%96%E5%AD%90%E4%B8%AD%EF%BC%8C%E6%88%91%E9%97%AE%E4%BA%86%E4%B8%80%E4%B8%AA%E5%85%B3%E4%BA%8E%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20write_image_win.bat%20%E5%86%99%E5%85%A5%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%B0%9A%E6%9C%AA%E8%A7%A3%E5%86%B3%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E6%80%BB%E7%BB%93%E4%B8%80%E4%B8%8B%E7%9B%AE%E5%89%8D%E7%9A%84%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CP%3E-%20%E5%BD%93%E4%BD%BF%E7%94%A8%20bat%20%E6%96%87%E4%BB%B6%E5%86%99%E5%85%A5%E5%85%A8%E6%96%B0%E4%B8%BB%E6%9D%BF%E6%97%B6%EF%BC%8C%E5%BA%94%E8%AF%A5%E6%98%BE%E7%A4%BA%E2%80%9C%E5%86%99%E5%85%A5%E5%9B%BE%E5%83%8F%E5%89%8D%E6%93%A6%E9%99%A4%E5%86%85%E5%AD%98%E2%80%9D%E7%9A%84%E8%BF%87%E7%A8%8B%E6%98%BE%E7%A4%BA%E4%B8%BA%E2%80%9C%E5%A4%B1%E8%B4%A5%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E-%20%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%20SEC%20%E5%B7%A5%E5%85%B7%E5%86%99%E5%85%A5%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20bat%20%E6%96%87%E4%BB%B6%E8%BF%9B%E8%A1%8C%E5%86%99%E5%85%A5%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E6%83%B3%E9%97%AE%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E1.%20%E4%B8%BA%E4%BB%80%E4%B9%88%E6%88%91%E4%B8%8D%E8%83%BD%E4%BD%BF%E7%94%A8%20bat%20%E6%96%87%E4%BB%B6%E5%86%99%E5%85%A5%E5%85%A8%E6%96%B0%E7%9A%84%E4%B8%BB%E6%9D%BF%EF%BC%9F%3C%2FP%3E%3CP%3E2.%20%E4%BD%BF%E7%94%A8%20bat%20%E6%96%87%E4%BB%B6%E5%86%99%E5%85%A5%E5%85%A8%E6%96%B0%E4%B8%BB%E6%9D%BF%E6%97%B6%E6%88%91%E9%9C%80%E8%A6%81%E5%81%9A%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E3.%20%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%20SEC%20%E5%B7%A5%E5%85%B7%E5%86%99%E5%85%A5%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%8E%E5%85%A8%E6%96%B0%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B9%8B%E9%97%B4%E6%9C%89%E4%BB%80%E4%B9%88%E5%8C%BA%E5%88%AB%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%9B%9E%E7%AD%94%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E6%82%A8%E6%95%99%E6%88%91%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%8C%E6%88%91%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E4%BB%8E%20IDE%20%E7%BC%96%E5%86%99%E3%80%82%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%94%B5%E8%B7%AF%E6%9D%BF%E5%88%B6%E9%80%A0%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%20write_image_win.bat%20%E5%86%99%E5%85%A5%E9%97%AA%E5%AD%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20SEC%20%E5%B7%A5%E5%85%B7%E7%9A%84%20write_image_win.bat%20%E5%86%99%E5%85%A5%E6%88%91%E8%83%BD%E5%A4%9F%E4%BB%8E%20IDE%20%E5%86%99%E5%85%A5%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E5%B0%BD%E7%AE%A1%E6%88%91%E8%83%BD%E5%A4%9F%E5%86%99%E5%85%A5%E6%88%91%E4%B8%80%E7%9B%B4%E7%94%A8%E4%BA%8E%E6%B5%8B%E8%AF%95%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%EF%BC%8C%E4%BD%86%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%86%99%E5%85%A5%E6%96%B0%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%97%B6%EF%BC%8C%E6%93%A6%E9%99%A4%E9%97%AA%E5%AD%98%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E6%83%B3%E4%BD%BF%E7%94%A8%20write_image_win.bat%20%E5%86%99%E5%85%A5%20i.MX%20RT1021%20%E5%92%8C%20i.MX%20RT1062%20%E5%AE%9A%E5%88%B6%E6%9D%BF%E4%B8%8A%E7%9A%84%E9%97%AA%E5%AD%98%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%96%B0%E6%9D%BF%E4%B8%8A%E6%93%A6%E9%99%A4%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%B0%B1%E5%83%8F%20MCXN947%20%E4%B8%80%E6%A0%B7%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E4%BB%80%E4%B9%88%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E6%AF%94%E5%A6%82%E5%9C%A8%E6%AF%8F%E4%B8%AA%E8%BF%87%E7%A8%8B%E4%B9%8B%E9%97%B4%E5%A2%9E%E5%8A%A0%E7%AD%89%E5%BE%85%E6%97%B6%E9%97%B4%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E9%99%84%E4%B8%8A%E5%86%99%E5%85%A5%20MCXN947%20%E6%97%B6%E7%9A%84%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%23%20%23%23%20Parse%20input%20arguments%20%23%23%20%23%3CBR%20%2F%3E%20%23%20%23%23%20Check%20connection%20%23%23%20%23%3CBR%20%2F%3E%20blhost%20-t%202000%20-u%200x1FC9%2C0x014F%20-j%20--%20%E8%8E%B7%E5%8F%96%E5%B1%9E%E6%80%A7%201%200%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%E2%80%9C%E5%91%BD%E4%BB%A4%E2%80%9D%EF%BC%9A%E2%80%9C%E8%8E%B7%E5%8F%96%E5%B1%9E%E6%80%A7%E2%80%9D%EF%BC%8C%3CBR%20%2F%3E%20%E2%80%9C%E5%9B%9E%E5%A4%8D%E2%80%9D%EF%BC%9A%20%5B%3CBR%20%2F%3E%201258488320%3CBR%20%2F%3E%20%5D%EF%BC%8C%3CBR%20%2F%3E%20%E2%80%9C%E5%9C%B0%E4%BD%8D%E2%80%9D%EF%BC%9A%20%7B%3CBR%20%2F%3E%20%22description%22%3A%20%220%20(0x0)%20%E6%88%90%E5%8A%9F%E3%80%82%22%2C%3CBR%20%2F%3E%E2%80%9C%E5%80%BC%E2%80%9D%EF%BC%9A0%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20blhost%20%E6%88%90%E5%8A%9F%3CBR%20%2F%3E%23%20%23%23%20Configure%20FlexSPI%20NOR%20using%20FCB%20on%20address%200x20020000%20%23%23%20%23%3CBR%20%2F%3E%20blhost%20-t%205000%20-u%200x1FC9%2C0x014F%20-j%20--%20%E5%86%99%E5%85%A5%E5%86%85%E5%AD%98%200x20020000%20%22C%3A%5CWorkSpace%5CMCUX%5CMCUXpressoSecureProvisioningv10%5CNX-N947_20250410%5Csource_images%5Cfrdmmcxn947_led_blinky.fcb.bin%22%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20%E2%80%9C%E5%91%BD%E4%BB%A4%E2%80%9D%EF%BC%9A%E2%80%9C%E5%86%99%E5%85%A5%E5%86%85%E5%AD%98%E2%80%9D%EF%BC%8C%3CBR%20%2F%3E%20%E2%80%9C%E5%9B%9E%E5%A4%8D%E2%80%9D%EF%BC%9A%20%5B%3CBR%20%2F%3E%20512%3CBR%20%2F%3E%20%5D%EF%BC%8C%3CBR%20%2F%3E%20%E2%80%9C%E5%9C%B0%E4%BD%8D%E2%80%9D%EF%BC%9A%20%7B%3CBR%20%2F%3E%20%22description%22%3A%20%220%20(0x0)%20%E6%88%90%E5%8A%9F%E3%80%82%22%2C%3CBR%20%2F%3E%E2%80%9C%E5%80%BC%E2%80%9D%EF%BC%9A0%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20blhost%20%E6%88%90%E5%8A%9F%3CBR%20%2F%3Eblhost%20-t%205000%20-u%200x1FC9%2C0x014F%20-j%20--%20%E9%85%8D%E7%BD%AE%E5%86%85%E5%AD%98%209%200x20020000%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%E2%80%9C%E5%91%BD%E4%BB%A4%E2%80%9D%EF%BC%9A%E2%80%9C%E9%85%8D%E7%BD%AE%E5%86%85%E5%AD%98%E2%80%9D%EF%BC%8C%3CBR%20%2F%3E%20%E2%80%9C%E5%9B%9E%E5%A4%8D%E2%80%9D%EF%BC%9A%20%5B%5D%EF%BC%8C%3CBR%20%2F%3E%20%E2%80%9C%E5%9C%B0%E4%BD%8D%E2%80%9D%EF%BC%9A%20%7B%3CBR%20%2F%3E%20%22description%22%3A%20%220%20(0x0)%20%E6%88%90%E5%8A%9F%E3%80%82%22%2C%3CBR%20%2F%3E%E2%80%9C%E5%80%BC%E2%80%9D%EF%BC%9A0%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20blhost%20%E6%88%90%E5%8A%9F%3CBR%20%2F%3E%23%20%23%23%20Erase%20flash%20%23%23%20%23%3CBR%20%2F%3E%20blhost%20-t%2050091%20-u%200x1FC9%2C0x014F%20-j%20--%20%E9%97%AA%E5%AD%98%E6%93%A6%E9%99%A4%E5%8C%BA%E5%9F%9F%200x80000000%209132%200%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%E2%80%9C%E5%91%BD%E4%BB%A4%E2%80%9D%EF%BC%9A%E2%80%9Cflash-erase-region%E2%80%9D%EF%BC%8C%3CBR%20%2F%3E%20%E2%80%9C%E5%9B%9E%E5%A4%8D%E2%80%9D%EF%BC%9A%20%5B%5D%EF%BC%8C%3CBR%20%2F%3E%20%E2%80%9C%E5%9C%B0%E4%BD%8D%E2%80%9D%EF%BC%9A%20%7B%3CBR%20%2F%3E%20%E2%80%9C%E6%8F%8F%E8%BF%B0%E2%80%9D%EF%BC%9A%E2%80%9C20106%EF%BC%880x4e8a%EF%BC%89FlexSPINOR%EF%BC%9A%E5%91%BD%E4%BB%A4%E5%A4%B1%E8%B4%A5%E3%80%82%E2%80%9D%EF%BC%8C%3CBR%20%2F%3E%E2%80%9C%E5%80%BC%E2%80%9D%EF%BC%9A20106%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20blhost%20%E5%A4%B1%E8%B4%A5%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2077049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2077049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BB%8ESEC%E5%B7%A5%E5%85%B7%E4%B8%AD%E5%86%99%E5%85%A5%EF%BC%8C%E8%BF%99%E8%AF%81%E6%98%8ESEC%E7%94%9F%E6%88%90%E7%9A%84FCB%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%89%80%E4%BB%A5%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%E6%AD%A3%E7%A1%AE%E7%9A%84%20FCB%20%E5%88%B7%E6%96%B0%E5%88%B0%200x80000400%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%E5%9C%A8MCUXpresso%E4%B8%AD%E5%88%A0%E9%99%A4mcxn_flexspi_nor_config.c%E5%92%8Cmcxn_flexspi_nor_config.h%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%BB%AC%E7%94%9F%E6%88%90%E4%BA%86%E6%96%B0%E7%9A%84%20FCB%20%E5%B9%B6%E9%97%AA%E5%AD%98%E5%9C%A8%200x80000400%20%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%B0%83%E8%AF%95%E5%AE%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%B5%8B%E8%AF%95%E4%BA%86%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%88%91%E9%80%9A%E8%BF%87SEC%E5%B7%A5%E5%85%B7%E7%94%9F%E6%88%90%E4%BA%86FCB.bin%E3%80%82%E5%B9%B6%E5%B0%86%E5%85%B6%E5%88%B7%E6%96%B0%E5%88%B0%200x80000400%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E8%B0%83%E8%AF%95%E5%AE%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1744193877363.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1744193877363.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F332272iC5E03CEE11937E36%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1744193877363.png%22%20alt%3D%22Harry_Zhang_0-1744193877363.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%80%BB%E7%BB%93%E4%B8%80%E4%B8%8B%EF%BC%8C%E5%B0%86%E6%AD%A3%E7%A1%AE%E7%9A%84FCB%E6%94%BE%E5%85%A50x80000400%EF%BC%8C%E5%B0%86%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%94%BE%E5%85%A50x80001000%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2075539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2075539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BB%8E%20SEC%20%E5%B7%A5%E5%85%B7%E5%86%99%E5%85%A5%EF%BC%8C%E4%BD%86%E4%B8%8D%E8%83%BD%E4%BB%8E%20MCUXpresso%20IDE%20%E5%86%99%E5%85%A5%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%88%91%E6%97%A0%E6%B3%95%E4%BB%8E%20MCUXpresso%20IDE%20%E5%86%99%E5%85%A5%E6%98%AF%E6%9C%89%E5%8E%9F%E5%9B%A0%E7%9A%84%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E6%98%AF%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E3%80%82%3CBR%20%2F%3E%E4%BD%A0%E8%83%BD%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2075076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2075076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E7%9A%84%E5%88%86%E6%9E%90%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20SEC%20%E5%B7%A5%E5%85%B7%E8%BF%9B%E8%A1%8C%E5%86%99%E5%85%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E8%AF%81%E6%98%8E%E7%A1%AC%E4%BB%B6%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%82%A8%E5%B7%B2%E9%AA%8C%E8%AF%81%E6%82%A8%E7%9A%84%E8%BD%AF%E4%BB%B6%E4%B8%8E%20FRDM%20mcxn947%20%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%82%A8%E5%B7%B2%E9%AA%8C%E8%AF%81%E6%82%A8%E7%9A%84%E7%A1%AC%E4%BB%B6%E4%B8%8E%20SEC%20%E5%B7%A5%E5%85%B7%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E9%82%A3%E4%B9%88%E4%BD%A0%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2073529%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2073529%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3EPSRAM%20%E6%98%AF%E7%94%B5%E6%B0%94%E9%9A%94%E7%A6%BB%E7%9A%84%EF%BC%8C%E5%9C%A8%E8%BF%99%E7%A7%8D%E7%8A%B6%E6%80%81%E4%B8%8B%EF%BC%8C%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20SEC%20%E5%B7%A5%E5%85%B7%E8%BF%9B%E8%A1%8C%E5%86%99%E5%85%A5%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E5%9C%A8%E7%9B%B8%E5%90%8C%E7%8A%B6%E6%80%81%E4%B8%8B%E4%BB%8E%20IDE%20%E8%BF%9B%E8%A1%8C%E5%86%99%E5%85%A5%EF%BC%8C%E5%88%99%E4%BC%9A%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%20PSRAM%20%E5%BD%B1%E5%93%8D%E4%BA%86%E5%AE%83%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E4%B9%9F%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20SEC%20%E5%B7%A5%E5%85%B7%E8%BF%9B%E8%A1%8C%E5%86%99%E5%85%A5%E3%80%82%3CBR%20%2F%3E%E4%BD%A0%E6%80%8E%E4%B9%88%E8%AE%A4%E4%B8%BA%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2070798%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2070798%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8EPSRAM%E7%9A%84CEn%E5%9B%BA%E5%AE%9A%E4%B8%BAH%E7%94%B5%E5%B9%B3%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E7%9B%B8%E4%BF%A1PSRAM%E7%9A%84DATA%E5%92%8CCLOCK%E4%B8%8D%E4%BC%9A%E5%BD%B1%E5%93%8DQSPI%20Flash%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E5%8F%AF%E8%83%BD%E7%9A%84%E5%8E%9F%E5%9B%A0%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2070746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2070746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E2%80%9C%3CSPAN%3E%E6%8C%89%E7%85%A7%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E5%B0%86FRDM-MXN947%E7%9A%84Flash%E6%9B%BF%E6%8D%A2%E4%B8%BAMX25L3233%E5%B9%B6%E6%A3%80%E6%9F%A5%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E4%B8%8E%E5%89%8D%E5%87%A0%E5%A4%A9%E4%B8%8A%E4%BC%A0%E7%9A%84%E7%9B%B8%E5%90%8C%E7%9A%84%20mcxn_flexspi_nor_config.c%20%E5%92%8C%E5%B0%86%20CONFIG_OPTION0%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%200xC0000101%20%E7%9A%84%20FlashConfig.h%20%E6%97%B6%EF%BC%8C%E6%88%91%E8%83%BD%E5%A4%9F%E5%86%99%E5%85%A5%E3%80%82%3C%2FSPAN%3E%20%E2%80%9D%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E8%AF%81%E6%98%8E%E4%BD%A0%E7%9A%84%E8%BD%AF%E4%BB%B6%E9%85%8D%E7%BD%AE%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%89%80%E4%BB%A5%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%BB%8D%E7%84%B6%E6%98%AF%E4%B8%80%E4%B8%AA%E7%A1%AC%E4%BB%B6%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%BB%85%E8%BF%9E%E6%8E%A5%E5%88%B0%20Nor%20Flash%20%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%96%AD%E5%BC%80%3CSPAN%3EPSRAM%3C%2FSPAN%3E%E7%9B%B8%E5%85%B3%3CSPAN%3E%E7%94%B5%E8%BF%9E%E6%8E%A5%EF%BC%88%E5%8C%85%E6%8B%ACDATA%20CLOCK%20CS%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%93%88%E5%88%A9%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2068142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2068142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%85%B3%E4%BA%8E%E6%AD%A4%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B7%B2%E7%A1%AE%E8%AE%A4%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%8C%E5%B9%B6%E5%B8%8C%E6%9C%9B%E5%91%8A%E7%9F%A5%E6%82%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%80%80%E7%96%91PSRAM%E5%8F%AF%E8%83%BD%E5%AF%B9%E7%94%B5%E8%B7%AF%E6%9C%89%E5%BD%B1%E5%93%8D%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E4%BB%AC%E6%89%93%E5%BC%80%E4%BA%86%E6%98%A8%E5%A4%A9%E4%B8%8A%E4%BC%A0%E7%9A%84%E7%94%B5%E8%B7%AF%E5%9B%BE%E4%B8%AD%E7%9A%84JP1%EF%BC%8C%E5%B9%B6%E5%9C%A8PSRAM%E7%94%B5%E6%B0%94%E6%96%AD%E5%BC%80%E7%9A%84%E7%8A%B6%E6%80%81%E4%B8%8B%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%A3%80%E6%9F%A5%EF%BC%8C%E4%BD%86%E6%98%AF%E6%88%91%E4%BB%AC%E6%97%A0%E6%B3%95%E5%86%99%E5%85%A5Flash%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9C%89%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%EF%BC%8C%E5%8C%85%E6%8B%AC%E5%85%B3%E4%BA%8E%E6%98%A8%E5%A4%A9%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%8C%89%E7%85%A7%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E5%B0%86FRDM-MXN947%E7%9A%84Flash%E6%9B%BF%E6%8D%A2%E4%B8%BAMX25L3233%E5%B9%B6%E8%BF%9B%E8%A1%8C%E6%A3%80%E6%9F%A5%E3%80%82%3CBR%20%2F%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E4%B8%8E%E5%89%8D%E5%87%A0%E5%A4%A9%E4%B8%8A%E4%BC%A0%E7%9A%84%E7%9B%B8%E5%90%8C%E7%9A%84%20mcxn_flexspi_nor_config.c%20%E5%92%8C%20FlashConfig.h%20%E6%97%B6%EF%BC%8C%E6%88%91%E8%83%BD%E5%A4%9F%E5%86%99%E5%85%A5%E5%B0%86%20CONFIG_OPTION0%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%200xC0000101%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E5%8D%B3%E4%BD%BF%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%8C%E6%88%91%E4%B9%9F%E6%97%A0%E6%B3%95%E5%9C%A8%E6%88%91%E7%9A%84%E6%9D%BF%E4%B8%8A%E4%B9%A6%E5%86%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9A%84%E4%B8%BB%E6%9D%BF%E4%B8%8A%EF%BC%8C%E6%88%91%E5%9C%A8%20INDIVIDUAL%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E4%BD%BF%E7%94%A8%E7%AB%AF%E5%8F%A3%20A%EF%BC%8C%E5%9B%A0%E6%AD%A4%20SS0_b%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20MX25L3233%EF%BC%8CSS1_b%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20PSRAM%EF%BC%8C%E4%BD%86%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%20PSRAM%20%E6%98%AF%E5%90%A6%E4%BC%9A%E5%BD%B1%E5%93%8D%E5%AE%83%E3%80%82%3CBR%20%2F%3E%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E6%98%BE%E7%A4%BA%20Flash%20%E5%92%8C%20PSRAM%20%E8%BF%9E%E6%8E%A5%E7%9A%84%E7%94%B5%E8%B7%AF%E5%9B%BE%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9C%89%E4%BB%BB%E4%BD%95%E6%84%8F%E8%A7%81%EF%BC%8C%E8%AF%B7%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22N947-FlexSPI.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22N947-FlexSPI.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F329590i0027E8D352A7CF05%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22N947-FlexSPI.png%22%20alt%3D%22N947-FlexSPI.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%88%91%E8%BF%98%E5%B0%86%E5%86%85%E5%AD%98%E9%85%8D%E7%BD%AE%E7%BC%96%E8%BE%91%E5%99%A8%E8%AE%BE%E7%BD%AE%E5%A6%82%E4%B8%8B%E3%80%82%3CBR%20%2F%3E%E9%97%AA%E5%AD%98%E5%A4%A7%E5%B0%8F%E8%AE%BE%E7%BD%AE%E4%B8%BA%200xffff000%EF%BC%8C%E4%BD%86%E7%94%B1%E4%BA%8E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%204MByte%20%E4%BA%A7%E5%93%81%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E8%AE%A4%E4%B8%BA%200x3ff000%20%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E4%B8%AA%E5%B0%BA%E5%AF%B8%E8%AE%BE%E7%BD%AE%E4%BC%9A%E5%BD%B1%E5%93%8Dflash%E5%86%99%E5%85%A5%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22memory_config.bmp%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22memory_config.bmp%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F329591i1A0F66904D29EE85%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22memory_config.bmp%22%20alt%3D%22memory_config.bmp%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BC%9A%E8%80%83%E8%99%91%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E5%9C%A8%E6%88%91%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%8A%EF%BC%8CFLEXSPI0_A_SS0_b%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20MX25L3233%EF%BC%8C%E4%BD%86%20FLEXSPI0_A_SS1_b%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20PSRAM%E3%80%82%3CBR%20%2F%3E%E4%B8%A4%E6%AC%BE%E8%8A%AF%E7%89%87%E7%9A%84FLEXSPI0_A_SCLK%E5%92%8CFLEXSPI0_A_DATA0-3%E4%BD%BF%E7%94%A8%E5%90%8C%E4%B8%80%E4%B8%AA%E7%AB%AF%E5%AD%90%E3%80%82%3CBR%20%2F%3E%E4%BD%A0%E8%A7%89%E5%BE%97%E8%BF%99%E4%B8%AA%E7%8A%B6%E6%80%81%E4%BC%9A%E5%BD%B1%E5%93%8Dflash%E7%9A%84%E5%86%99%E5%85%A5%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E8%80%83%E8%99%91%E8%BF%87%E7%A1%AC%E4%BB%B6%E8%BF%9E%E6%8E%A5%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E6%98%AF%E5%AE%9A%E5%88%B6%E6%9D%BF%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%98%AF%E5%AE%9A%E5%88%B6%E6%9D%BF%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%E6%AD%A4%E9%97%AA%E5%AD%98%E8%BF%9E%E6%8E%A5%E5%88%B0FRDM-MXN947%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E8%BF%9E%E6%8E%A5%E5%88%B0%20FRDM-MXN947%20%E6%97%B6%E9%97%AA%E5%AD%98%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E8%B4%AD%E4%B9%B0%E8%BF%99%E4%B8%AA%E9%97%AA%E5%85%89%E7%81%AF%E5%B9%B6%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2066272%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2066272%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AA%E4%BF%AE%E6%94%B9%E4%BA%86%E4%BD%A0%E8%AF%B4%E7%9A%84%E4%B8%A4%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E9%94%99%E8%AF%AF%E4%BB%8D%E7%84%B6%E5%87%BA%E7%8E%B0%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E4%B8%8A%E4%BC%A0%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%96%87%E4%BB%B6%E5%92%8C%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E7%A1%AE%E5%AE%9A%20Flash%20Driver%20V2%20%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%8C%E8%AF%B7%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CP%3Emcxn_flexspi_nor_config.c%3CBR%20%2F%3E%E5%9C%A8%E8%BF%99%E4%B8%AA%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8CsflashA1Size%E7%9A%84%E5%80%BC%E4%BB%8E8M%E4%BF%AE%E6%94%B9%E4%B8%BA4M%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%3CP%3E%2F*%3CBR%20%2F%3E%20*%20%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%202018-2022%20%E6%81%A9%E6%99%BA%E6%B5%A6%3CBR%20%2F%3E*%20%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20SPDX%E8%AE%B8%E5%8F%AF%E8%AF%81%E6%A0%87%E8%AF%86%E7%AC%A6%EF%BC%9ABSD-3%E6%9D%A1%E6%AC%BE%3CBR%20%2F%3E*%2F%3C%2FP%3E%3CP%3E%23%E5%8C%85%E6%8B%AC%E2%80%9Cmcxn_flexspi_nor_config.h%E2%80%9D%3C%2FP%3E%3CP%3E%2F*%20%E7%BB%84%E4%BB%B6%20ID%20%E5%AE%9A%E4%B9%89%EF%BC%8C%E7%94%B1%E5%B7%A5%E5%85%B7%E4%BD%BF%E7%94%A8%E3%80%82*%2F%3CBR%20%2F%3E%20%23%E5%A6%82%E6%9E%9C%E5%AE%9A%E4%B9%89FSL_COMPONENT_ID%3CBR%20%2F%3E%20%23%E5%AE%9A%E4%B9%89FSL_COMPONENT_ID%E2%80%9C%E5%B9%B3%E5%8F%B0.%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F.xip_%E6%9D%BF%E2%80%9D%3CBR%20%2F%3E%23%E7%BB%93%E6%9D%9F%3C%2FP%3E%3CP%3E%2F*******************************************************************************%3CBR%20%2F%3E*%20Code%3CBR%20%2F%3E******************************************************************************%2F%3C%2FP%3E%3CP%3E%23%E5%A6%82%E6%9E%9C%E5%AE%9A%E4%B9%89%EF%BC%88__CC_ARM%EF%BC%89%7C%7C%E5%AE%9A%E4%B9%89%EF%BC%88__ARMCC_VERSION%EF%BC%89%7C%7C%E5%AE%9A%E4%B9%89%EF%BC%88%20__GNUC__%20%EF%BC%89%3CBR%20%2F%3E%20__attribute__%20((section(%22.flexspi_fcb%22)%EF%BC%8C%E5%B7%B2%E4%BD%BF%E7%94%A8))%3CBR%20%2F%3E%20%23elif%20%E5%AE%9A%E4%B9%89%EF%BC%88%20__ICCARM__%20%EF%BC%89%3CBR%20%2F%3E%20%23pragma%20%E4%BD%8D%E7%BD%AE%20%3D%20%E2%80%9C.flexspi_fcb%E2%80%9D%3CBR%20%2F%3E%23%E7%BB%93%E6%9D%9F%3C%2FP%3E%3CP%3E%23ifndef%20FLEXSPI_USE_CUSTOM_FCB%3CBR%20%2F%3E%23define%20FLEXSPI_USE_CUSTOM_FCB%20(0)%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3E%23if%20FLEXSPI_USE_CUSTOM_FCB%3CBR%20%2F%3E%2F*%20FCB%20for%20W25Q64%20*%2F%3CBR%20%2F%3Econst%20uint8_t%20CUSTOM_FCB%5B%5D%20%3D%20%7B%3CBR%20%2F%3E0x46%2C%200x43%2C%200x46%2C%200x42%2C%200x00%2C%200x04%2C%200x01%2C%200x56%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x01%2C%200x03%2C%200x03%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x10%2C%200x00%2C%200x00%2C%200x00%2C%200x01%2C%200x04%2C%200x01%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x80%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200xeb%2C%200x04%2C%200x18%2C%200x0a%2C%200x06%2C%3CBR%20%2F%3E0x32%2C%200x04%2C%200x26%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x05%2C%200x04%2C%200x04%2C%200x24%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x06%2C%200x04%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x20%2C%3CBR%20%2F%3E0x04%2C%200x18%2C%200x08%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200xd8%2C%200x04%2C%200x18%2C%200x08%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x02%2C%200x04%2C%200x18%2C%200x08%2C%200x04%2C%200x20%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x60%2C%200x04%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x01%2C%200x00%2C%200x00%2C%200x00%2C%200x10%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x01%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x01%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%7D%3B%3CBR%20%2F%3E%23else%3C%2FP%3E%3CP%3E%2F*%20W25Q64%20%E7%9A%84%20FCB%20*%2F%3CBR%20%2F%3E%20const%20flexspi_nor_config_t%20qspiflash_config%20%3D%20%7B%3CBR%20%2F%3E%20.memConfig%3D%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%E3%80%82%E6%A0%87%E7%AD%BE%3DFLEXSPI_CFG_BLK_%E6%A0%87%E7%AD%BE%EF%BC%8C%3CBR%20%2F%3E%20%E3%80%82%E7%89%88%E6%9C%AC%3DFLEXSPI_CFG_BLK_%E7%89%88%E6%9C%AC%EF%BC%8C%3CBR%20%2F%3E%20.readSampleClksrc%3DkFlexSPIReadSampleClk_LoopbackFromDqsPad%EF%BC%8C%3CBR%20%2F%3E.csHoldTime%3D%203u%EF%BC%8C%3CBR%20%2F%3E%20.csSetupTime%3D%203u%EF%BC%8C%3CBR%20%2F%3E%20%2F%2F%20%E5%90%AF%E7%94%A8%20DDR%20%E6%A8%A1%E5%BC%8F%E3%80%81%E5%8F%AF%E5%AD%97%E6%B7%BB%E5%8A%A0%E3%80%81%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%E3%80%81%E5%B7%AE%E5%88%86%E6%97%B6%E9%92%9F%3CBR%20%2F%3E.controllerMiscOption%3D%EF%BC%881u%26lt%3B%3CKFLEXSPIMISCOFFSET_SAFECONFIGFREQENABLE%3E%3C%2FKFLEXSPIMISCOFFSET_SAFECONFIGFREQENABLE%3E%20.%E8%AE%BE%E5%A4%87%E7%B1%BB%E5%9E%8B%3D%20kFlexSpiDeviceType_SerialNOR%EF%BC%8C%3CBR%20%2F%3E%20.sflashPad%E7%B1%BB%E5%9E%8B%3DkSerialFlash_4Pads%EF%BC%8C%3CBR%20%2F%3E%20.serialClkFreq%3DkFlexSpiSerialClk_75MHz%EF%BC%8C%3CBR%20%2F%3E%20.sflashA1%E5%A4%A7%E5%B0%8F%3D%204u%20*%201024u%20*%201024u%EF%BC%8C%3CBR%20%2F%3E%20.lookupTable%3D%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%2F%2F%20%E8%AF%BB%E5%8F%96%E6%9F%A5%E6%89%BE%E8%A1%A8%3CBR%20%2F%3E%5B0%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200xEB%2C%20RADDR_SDR%2C%20FLEXSPI_4PAD%2C%200x18)%2C%3CBR%20%2F%3E%20%5B1%5D%20%3D%20FLEXSPI_LUT_SEQ(DUMMY_SDR%2C%20FLEXSPI_4PAD%2C%200x06%2C%20READ_SDR%2C%20FLEXSPI_4PAD%2C%200x04)%2C%3C%2FP%3E%3CP%3E%2F%2F%20%E8%AF%BB%E5%8F%96%E7%8A%B6%E6%80%81%E6%9F%A5%E6%89%BE%E8%A1%A8%3CBR%20%2F%3E%5B4%20*%201%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%EF%BC%8CFLEXSPI_1PAD%EF%BC%8C0x05%EF%BC%8CREAD_SDR%EF%BC%8CFLEXSPI_1PAD%EF%BC%8C0x04)%EF%BC%8C%3C%2FP%3E%3CP%3E%2F%2F%20%E5%86%99%E5%85%A5%E5%90%AF%E7%94%A8%E6%9F%A5%E6%89%BE%E8%A1%A8%3CBR%20%2F%3E%5B4%20*%203%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%EF%BC%8CFLEXSPI_1PAD%EF%BC%8C0x06%EF%BC%8C%E5%81%9C%E6%AD%A2%EF%BC%8CFLEXSPI_1PAD%EF%BC%8C0x0)%EF%BC%8C%3C%2FP%3E%3CP%3E%2F%2F%20%E6%93%A6%E9%99%A4%E6%89%87%E5%8C%BA%E6%9F%A5%E6%89%BE%E8%A1%A8%3CBR%20%2F%3E%5B4%20*%205%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%EF%BC%8CFLEXSPI_1PAD%EF%BC%8C0x20%EF%BC%8CRADDR_SDR%EF%BC%8CFLEXSPI_1PAD%EF%BC%8C0x18)%EF%BC%8C%3C%2FP%3E%3CP%3E%2F%2F%20%E6%93%A6%E9%99%A4%E5%9D%97%E6%9F%A5%E6%89%BE%E8%A1%A8%3CBR%20%2F%3E%5B4%20*%208%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200xD8%2C%20RADDR_SDR%2C%20FLEXSPI_1PAD%2C%200x18)%2C%3C%2FP%3E%3CP%3E%2F%2F%20Pape%20%E7%A8%8B%E5%BA%8F%E6%9F%A5%E6%89%BE%E8%A1%A8%3CBR%20%2F%3E%5B4%20*%209%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%EF%BC%8CFLEXSPI_1PAD%EF%BC%8C0x02%EF%BC%8CRADDR_SDR%EF%BC%8CFLEXSPI_1PAD%EF%BC%8C0x18)%EF%BC%8C%3CBR%20%2F%3E%20%5B4%20*%209%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(WRITE_SDR%EF%BC%8CFLEXSPI_1PAD%EF%BC%8C0x04%EF%BC%8C%E5%81%9C%E6%AD%A2%EF%BC%8CFLEXSPI_1PAD%EF%BC%8C0x0)%EF%BC%8C%3C%2FP%3E%3CP%3E%2F%2F%20%E6%93%A6%E9%99%A4%E8%8A%AF%E7%89%87%E6%9F%A5%E6%89%BE%E8%A1%A8%3CBR%20%2F%3E%5B4%20*%2011%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%EF%BC%8CFLEXSPI_1PAD%EF%BC%8C0x60%EF%BC%8C%E5%81%9C%E6%AD%A2%EF%BC%8CFLEXSPI_1PAD%EF%BC%8C0x0)%EF%BC%8C%3CBR%20%2F%3E%20%7D%2C%3CBR%20%2F%3E%20%7D%2C%3CBR%20%2F%3E%20.%E9%A1%B5%E9%9D%A2%E5%A4%A7%E5%B0%8F%3D%20256u%EF%BC%8C%3CBR%20%2F%3E%20.%E6%89%87%E5%8C%BA%E5%A4%A7%E5%B0%8F%3D%204u%20*%201024u%EF%BC%8C%3CBR%20%2F%3E%20.ipcmd%E4%B8%B2%E8%A1%8C%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%3D%201u%EF%BC%8C%3CBR%20%2F%3E%20.blockSize%3D%2064u%20*%201024u%EF%BC%8C%3CBR%20%2F%3E%20.isUniformBlockSize%3D%20%E5%81%87%EF%BC%8C%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%23%E7%BB%93%E6%9D%9F%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3EFlashConfig.h%3CBR%20%2F%3E%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%E8%AF%A5%E6%96%87%E4%BB%B6%E7%9A%84%E5%9B%9B%E4%B8%AA%E4%B8%8D%E5%90%8C%E7%89%88%E6%9C%AC%EF%BC%8C%E5%85%B6%E4%B8%AD%20CONFIG_OPTION0%20%E5%85%B7%E6%9C%89%E4%B8%8D%E5%90%8C%E7%9A%84%E5%80%BC%E3%80%82%EF%BC%880xC0000001%E3%80%810xC0000405%E3%80%810xC0000401%E3%80%810xC0000101%EF%BC%89%3CBR%20%2F%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E7%94%A8%E6%AF%8F%E4%B8%80%E4%B8%AA%E6%9D%A5%E6%A3%80%E6%9F%A5%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%3CP%3E%2F%2F********************************************************************************************%3CBR%20%2F%3E%20%2F%2FFlashConfig.h%3CBR%20%2F%3E%2F%2F%20MCUXpresso%20IDE%20%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%2F%2F%20MCXN9xx%20FlexSPI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%3CBR%20%2F%3E%2F%2F********************************************************************************************%3CBR%20%2F%3E%20%2F%2F%3CBR%20%2F%3E%20%2F%2F%20%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%202022-2024%20%E6%81%A9%E6%99%BA%E6%B5%A6%3CBR%20%2F%3E%2F%2F%3CBR%20%2F%3E%20%2F%2F%20SPDX%20%E8%AE%B8%E5%8F%AF%E8%AF%81%E6%A0%87%E8%AF%86%E7%AC%A6%EF%BC%9ABSD-3%20%E6%9D%A1%E6%AC%BE%3CBR%20%2F%3E%2F%2F********************************************************************************************%3C%2FP%3E%3CP%3E%23ifndef%20FLASHCONFIG_H_%3CBR%20%2F%3E%23define%20FLASHCONFIG_H_%3C%2FP%3E%3CP%3E%23%E5%8C%85%E6%8B%AC%E2%80%9Cfsl_flexspi_nor_flash.h%E2%80%9D%3C%2FP%3E%3CP%3E%E5%A4%96%E9%83%A8%20flexspi_nor_config_t%20flashConfig%EF%BC%9B%3C%2FP%3E%3CP%3E%23if%20defined%20(DEBUG)%3CBR%20%2F%3E%23define%20MCXN9xx_SFDP_FlexSPI%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%2F%2F%20MCX%20N1xNxxx%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%20-%2015.4.2FlexSPI%20NOR%E9%85%8D%E7%BD%AE%E9%80%89%E9%A1%B9%E5%9D%97%3C%2FP%3E%3CP%3E%23%E5%A6%82%E6%9E%9C%E5%AE%9A%E4%B9%89%EF%BC%88MCXN9xx_SFDP_FlexSPI%EF%BC%89%7C%7C%E5%AE%9A%E4%B9%89%EF%BC%88MCXN9xx_SFDP_FlexSPI_S%EF%BC%89%3CBR%20%2F%3E%20%2F*%3CBR%20%2F%3E%20*%200xC%20%3A%20%E6%A0%87%E7%AD%BE%3CBR%20%2F%3E*%200%EF%BC%9Aoption_size%EF%BC%880%20%3D%20%E6%9C%AA%E6%8C%87%E5%AE%9A%20option1%EF%BC%89%3CBR%20%2F%3E%20*%200%EF%BC%9Adevice_type%EF%BC%880%20%3D%20%E8%AF%BB%E5%8F%96%20SDR%20%E5%91%BD%E4%BB%A4%E7%9A%84%20SFDP%EF%BC%89%3CBR%20%2F%3E%20*%200%20%3A%20query_pads%EF%BC%880%20%3D%20%E6%9F%A5%E8%AF%A2%E6%9C%9F%E9%97%B4%E7%9A%84%201%20%E6%95%B0%E6%8D%AE%E5%A1%AB%E5%85%85%EF%BC%89%3CBR%20%2F%3E%20*%200%EF%BC%9Acmd_pads%EF%BC%880%3D%E9%97%AA%E5%AD%98%E8%AE%BF%E9%97%AE%E6%9C%9F%E9%97%B4%E4%B8%BA%201%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%9E%AB%EF%BC%89%3CBR%20%2F%3E%20*%200%EF%BC%9Aquad_mode_setting%EF%BC%880%3D%E6%9C%AA%E9%85%8D%E7%BD%AE%EF%BC%89%3CBR%20%2F%3E%20*%200%EF%BC%9Amisc_mode%3CBR%20%2F%3E%20*%201%EF%BC%9Amax_freq%EF%BC%880%3D%E4%B8%8D%E6%9B%B4%E6%94%B9%20FlexSPI%20%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%EF%BC%89%3CBR%20%2F%3E%20*%2F%3CBR%20%2F%3E%20%23%E5%AE%9A%E4%B9%89%20CONFIG_OPTION0%200xC0000001%3CBR%20%2F%3E%20%2F%2F%23%E5%AE%9A%E4%B9%89%20CONFIG_OPTION0%200xC0000405%3CBR%20%2F%3E%20%2F%2F%23%E5%AE%9A%E4%B9%89%20CONFIG_OPTION0%200xC0000401%3CBR%20%2F%3E%20%2F%2F%23%E5%AE%9A%E4%B9%89%20CONFIG_OPTION0%200xC0000101%3C%2FP%3E%3CP%3E%2F*%3CBR%20%2F%3E%20*%200x0%EF%BC%9A%E5%8D%95%E4%B8%AA%E9%97%AA%E5%AD%98%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%AB%AF%E5%8F%A3A%3CBR%20%2F%3E%20*%2F%3CBR%20%2F%3E%20%23%E5%AE%9A%E4%B9%89%20CONFIG_OPTION1%200x00000000%3C%2FP%3E%3CP%3E%23endif%3C%2FP%3E%3CP%3E%2F%2F%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20%2F%2F%20Flash%20%E5%9F%BA%E5%9C%B0%E5%9D%80%E4%BF%A1%E6%81%AF%3CBR%20%2F%3E%2F%2F%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20%23%E5%A6%82%E6%9E%9C%E5%AE%9A%E4%B9%89%EF%BC%88MCXN9xx_SFDP_FlexSPI_S%EF%BC%89%3CBR%20%2F%3E%20%23%E5%AE%9A%E4%B9%89USE_SECURE_FLASHADDR%3CBR%20%2F%3E%20%23%E5%AE%9A%E4%B9%89FLASH_BASE_ADDR%200x90000000%3CBR%20%2F%3E%20%EF%BC%83%E5%88%AB%E7%9A%84%3CBR%20%2F%3E%23%E5%AE%9A%E4%B9%89FLASH_BASE_ADDR%200x80000000%3CBR%20%2F%3E%20%23%E7%BB%93%E6%9D%9F%3C%2FP%3E%3CP%3E%23endif%20%2F*%20FLASHCONFIG_H_%20*%2F%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93CONFIG_OPTION0%E4%BD%BF%E7%94%A80xC0000001%E6%97%B6%EF%BC%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%8A%E4%BC%9A%E6%98%BE%E7%A4%BA%E5%A6%82%E4%B8%8B%E6%8E%A7%E5%88%B6%E5%8F%B0A%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%98%AF%EF%BC%8C%E5%88%99%E4%BC%9A%E6%98%BE%E7%A4%BA%E6%8E%A7%E5%88%B6%E5%8F%B0B%E3%80%82%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0A%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3EMCUXpresso%20IDE%20RedlinkMulti%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20v24.9%EF%BC%882024%20%E5%B9%B4%209%20%E6%9C%88%2019%20%E6%97%A5%2019%3A34%3A05%20-%20crt_emu_cm_redlink%20%E7%89%88%E6%9C%AC%20802%EF%BC%89%3CBR%20%2F%3E%E5%9C%A8%20C%3A%2FWorkSpace%2FMCUX%2FMCUXpressoIDE_24.9.25%2FNX-N947%2FNX-N947_ledblinky%2Ffrdmmcxn947_led_blinky%2FDebug_NoRAM%5CMCXN947.xml%20%E4%B8%AD%E6%89%BE%E5%88%B0%E8%8A%AF%E7%89%87%20XML%20%E6%96%87%E4%BB%B6%3CBR%20%2F%3E%EF%BC%885%EF%BC%89%E8%BF%9C%E7%A8%8B%E9%85%8D%E7%BD%AE%E5%AE%8C%E6%88%90%3CBR%20%2F%3E%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%8E%B0%E6%9C%89%E7%9A%84%20LinkServer%20%E8%BF%9B%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%E6%8E%A2%E9%92%88%E5%9B%BA%E4%BB%B6%EF%BC%9AMCU-LINK%EF%BC%88r0FF%EF%BC%89CMSIS-DAP%20V3.153%EF%BC%88%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%EF%BC%89%3CBR%20%2F%3E%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9AVUDADS0NIE0ZM%3CBR%20%2F%3E%E8%A7%86%E9%A2%91ID%EF%BC%9APID%EF%BC%9A1FC9%EF%BC%9A0143%3CBR%20%2F%3E%20USB%20%E8%B7%AF%E5%BE%84%EF%BC%9A0001%3A0003%3A00%3CBR%20%2F%3E%E6%90%9C%E7%B4%A2%E5%88%B0%E5%90%88%E9%80%82%E7%9A%84%E6%A0%B8%E5%BF%83%E5%90%8E%E4%BD%BF%E7%94%A8%E6%A0%B8%E5%BF%83%200%20%E7%9A%84%E5%86%85%E5%AD%98%3CBR%20%2F%3E%E5%A4%84%E7%90%86%E5%99%A8%E5%A4%84%E4%BA%8E%E5%AE%89%E5%85%A8%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%20%3D%20CoreSight%20DP%EF%BC%88DAP%20DP%20ID%206BA02477%EF%BC%89%E9%80%9A%E8%BF%87%20SWD%20TAP%200%3CBR%20%2F%3E%E5%A4%84%E7%90%86%E5%99%A8%E7%B1%BB%E5%9E%8B%20%3D%20Cortex-M33%EF%BC%88CPU%20ID%2000000D21%EF%BC%89%E5%9C%A8%20DAP%20AP%200%20%E4%B8%8A%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%208%3CBR%20%2F%3E%E9%97%AA%E5%AD%98%E8%A1%A5%E4%B8%81%E6%95%B0%E9%87%8F%20%3D%200%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E7%9B%91%E6%B5%8B%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%204%3CBR%20%2F%3E%E6%8E%A2%E9%92%88(0)%EF%BC%9A%E5%B7%B2%E8%BF%9E%E6%8E%A5%E5%B9%B6%E9%87%8D%E7%BD%AE%E3%80%82DpID%EF%BC%9A6BA02477%E3%80%82CPUID%EF%BC%9A00000D21%E3%80%82%E4%BF%A1%E6%81%AF%EF%BC%9A%3CNONE%3E%3CBR%20%2F%3E%20%E8%B0%83%E8%AF%95%E5%8D%8F%E8%AE%AE%EF%BC%9ASWD%E3%80%82RTCK%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%E7%9F%A2%E9%87%8F%E6%8D%95%E8%8E%B7%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3CBR%20%2F%3ECoreSight%20%E8%B0%83%E8%AF%95%20ROM%20%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%9A%3CBR%20%2F%3E%20RBASE%20E00FE000%EF%BC%9ACID%20B105100D%20PID%200000095000%20ROM%EF%BC%88%E7%B1%BB%E5%9E%8B%200x1%EF%BC%89%3CBR%20%2F%3E%20ROM%201%20E00FF000%EF%BC%9ACID%20B105100D%20PID%2004000BB4C9%20ROM%EF%BC%88%E7%B1%BB%E5%9E%8B%200x1%EF%BC%89%3CBR%20%2F%3E%20ROM%202%20E000E000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ARMv8-M%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3CBR%20%2F%3EROM%202%20E0001000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20DWTv2%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3CBR%20%2F%3EROM%202%20E0002000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20FPBv2%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3CBR%20%2F%3EROM%202%20E0000000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ITMv2%20%E7%B1%BB%E5%9E%8B%200x43%20%E8%B7%9F%E8%B8%AA%E6%BA%90%20-%20%E6%80%BB%E7%BA%BF%3CBR%20%2F%3EROM%202%20E0041000%3A%20CID%20B105900D%20PID%2004002BBD21%20CSt%20ARM%20ETMv4.0%20%E7%B1%BB%E5%9E%8B%200x13%20%E8%B7%9F%E8%B8%AA%E6%BA%90%20-%20%E6%A0%B8%E5%BF%83%3CBR%20%2F%3EROM%202%20E0042000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20CTIv2%20%E7%B1%BB%E5%9E%8B%200x14%20%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%20-%20%E8%A7%A6%E5%8F%91%E5%99%A8%EF%BC%8C%E4%BE%8B%E5%A6%82%E7%94%B5%E4%BC%91%E5%85%8B%E6%B2%BB%E7%96%97%3CBR%20%2F%3EROM%201%20E0040000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20%E7%B1%BB%E5%9E%8B%200x11%20%E8%B7%9F%E8%B8%AA%E6%8E%A5%E6%94%B6%E5%99%A8%20-%20TPIU%3CBR%20%2F%3E%20ROM%201%20E0044000%EF%BC%9ACID%20B105900D%20PID%2004003BB908%20CSt%20CSTF%20%E7%B1%BB%E5%9E%8B%200x12%20%E8%B7%9F%E8%B8%AA%E9%93%BE%E6%8E%A5%20-%20%E8%B7%9F%E8%B8%AA%E6%BC%8F%E6%96%97%2F%E8%B7%AF%E7%94%B1%E5%99%A8%3CBR%20%2F%3EROM%201%20E0045000%EF%BC%9ACID%20B105900D%20PID%2004001BB961%20CSt%20%E7%B1%BB%E5%9E%8B%200x21%20%E8%B7%9F%E8%B8%AA%E6%8E%A5%E6%94%B6%E5%99%A8%20-%20ETB%3CBR%20%2F%3E%E6%81%A9%E6%99%BA%E6%B5%A6%EF%BC%9AMCXN947%3CBR%20%2F%3E%20DAP%20%E6%AD%A5%E5%B9%85%E4%B8%BA%201024%20%E5%AD%97%E8%8A%82%EF%BC%88256%20%E4%B8%AA%E5%AD%97%EF%BC%89%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx%20%E6%A3%80%E6%9F%A5%20SPI%20%E4%B8%8A%E7%9A%84%20v.2%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E5%9B%BE%E7%89%87%E2%80%9CMCXN9xx_SFDP_FlexSPI%202025%E5%B9%B43%E6%9C%8821%E6%97%A5%2014%3A26%3A16%E2%80%9D%3CBR%20%2F%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx%3CBR%20%2F%3E%E5%B7%B2%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv8-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E6%94%B9%E7%94%A8%20SOFTRESET%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%E6%A3%80%E6%B5%8B%E5%88%B0%20Flash%20%E5%8F%98%E4%BD%93%E2%80%98JEDEC_FlexSPI_Device%E2%80%99%EF%BC%880B%20%3D%20%E4%BD%8D%E4%BA%8E%200x80000000%EF%BC%89%3CBR%20%2F%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%8E%200x80000000%20%E5%BC%80%E5%A7%8B%E7%9A%84%E6%89%87%E5%8C%BA%3CBR%20%2F%3EFlash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20rc%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3CBR%20%2F%3E%E8%8A%AF%E7%89%87%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%20-%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9C%B0%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx%20%E6%A3%80%E6%9F%A5%20SPI%20%E4%B8%8A%E7%9A%84%20v.2%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E5%9B%BE%E7%89%87%E2%80%9CMCXN9xx_SFDP_FlexSPI%202025%E5%B9%B43%E6%9C%8821%E6%97%A5%2014%3A26%3A16%E2%80%9D%3CBR%20%2F%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx%3CBR%20%2F%3E%E5%B7%B2%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv8-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E6%94%B9%E7%94%A8%20SOFTRESET%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%E6%A3%80%E6%B5%8B%E5%88%B0%20Flash%20%E5%8F%98%E4%BD%93%E2%80%98JEDEC_FlexSPI_Device%E2%80%99%EF%BC%884MB%20%3D%2064*64K%EF%BC%8C%E4%BD%8D%E4%BA%8E%200x80000000%EF%BC%89%3CBR%20%2F%3E%E5%85%B3%E9%97%AD%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx%3C%2FNONE%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0B%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3EMCUXpresso%20IDE%20RedlinkMulti%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20v24.9%EF%BC%882024%20%E5%B9%B4%209%20%E6%9C%88%2019%20%E6%97%A5%2019%3A34%3A05%20-%20crt_emu_cm_redlink%20%E7%89%88%E6%9C%AC%20802%EF%BC%89%3CBR%20%2F%3E%E5%9C%A8%20C%3A%2FWorkSpace%2FMCUX%2FMCUXpressoIDE_24.9.25%2FNX-N947%2FNX-N947_ledblinky%2Ffrdmmcxn947_led_blinky%2FDebug_NoRAM%5CMCXN947.xml%20%E4%B8%AD%E6%89%BE%E5%88%B0%E8%8A%AF%E7%89%87%20XML%20%E6%96%87%E4%BB%B6%3CBR%20%2F%3E%EF%BC%885%EF%BC%89%E8%BF%9C%E7%A8%8B%E9%85%8D%E7%BD%AE%E5%AE%8C%E6%88%90%3CBR%20%2F%3E%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%8E%B0%E6%9C%89%E7%9A%84%20LinkServer%20%E8%BF%9B%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%E6%8E%A2%E9%92%88%E5%9B%BA%E4%BB%B6%EF%BC%9AMCU-LINK%EF%BC%88r0FF%EF%BC%89CMSIS-DAP%20V3.153%EF%BC%88%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%EF%BC%89%3CBR%20%2F%3E%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9AVUDADS0NIE0ZM%3CBR%20%2F%3E%E8%A7%86%E9%A2%91ID%EF%BC%9APID%EF%BC%9A1FC9%EF%BC%9A0143%3CBR%20%2F%3E%20USB%20%E8%B7%AF%E5%BE%84%EF%BC%9A0001%3A0003%3A00%3CBR%20%2F%3E%E6%90%9C%E7%B4%A2%E5%88%B0%E5%90%88%E9%80%82%E7%9A%84%E6%A0%B8%E5%BF%83%E5%90%8E%E4%BD%BF%E7%94%A8%E6%A0%B8%E5%BF%83%200%20%E7%9A%84%E5%86%85%E5%AD%98%3CBR%20%2F%3E%E5%A4%84%E7%90%86%E5%99%A8%E5%A4%84%E4%BA%8E%E5%AE%89%E5%85%A8%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%20%3D%20CoreSight%20DP%EF%BC%88DAP%20DP%20ID%206BA02477%EF%BC%89%E9%80%9A%E8%BF%87%20SWD%20TAP%200%3CBR%20%2F%3E%E5%A4%84%E7%90%86%E5%99%A8%E7%B1%BB%E5%9E%8B%20%3D%20Cortex-M33%EF%BC%88CPU%20ID%2000000D21%EF%BC%89%E5%9C%A8%20DAP%20AP%200%20%E4%B8%8A%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%208%3CBR%20%2F%3E%E9%97%AA%E5%AD%98%E8%A1%A5%E4%B8%81%E6%95%B0%E9%87%8F%20%3D%200%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E7%9B%91%E6%B5%8B%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%204%3CBR%20%2F%3E%E6%8E%A2%E9%92%88(0)%EF%BC%9A%E5%B7%B2%E8%BF%9E%E6%8E%A5%E5%B9%B6%E9%87%8D%E7%BD%AE%E3%80%82DpID%EF%BC%9A6BA02477%E3%80%82CPUID%EF%BC%9A00000D21%E3%80%82%E4%BF%A1%E6%81%AF%EF%BC%9A%3CNONE%3E%3CBR%20%2F%3E%20%E8%B0%83%E8%AF%95%E5%8D%8F%E8%AE%AE%EF%BC%9ASWD%E3%80%82RTCK%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%E7%9F%A2%E9%87%8F%E6%8D%95%E8%8E%B7%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3CBR%20%2F%3ECoreSight%20%E8%B0%83%E8%AF%95%20ROM%20%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%9A%3CBR%20%2F%3E%20RBASE%20E00FE000%EF%BC%9ACID%20B105100D%20PID%200000095000%20ROM%EF%BC%88%E7%B1%BB%E5%9E%8B%200x1%EF%BC%89%3CBR%20%2F%3E%20ROM%201%20E00FF000%EF%BC%9ACID%20B105100D%20PID%2004000BB4C9%20ROM%EF%BC%88%E7%B1%BB%E5%9E%8B%200x1%EF%BC%89%3CBR%20%2F%3E%20ROM%202%20E000E000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ARMv8-M%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3CBR%20%2F%3EROM%202%20E0001000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20DWTv2%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3CBR%20%2F%3EROM%202%20E0002000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20FPBv2%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3CBR%20%2F%3EROM%202%20E0000000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ITMv2%20%E7%B1%BB%E5%9E%8B%200x43%20%E8%B7%9F%E8%B8%AA%E6%BA%90%20-%20%E6%80%BB%E7%BA%BF%3CBR%20%2F%3EROM%202%20E0041000%3A%20CID%20B105900D%20PID%2004002BBD21%20CSt%20ARM%20ETMv4.0%20%E7%B1%BB%E5%9E%8B%200x13%20%E8%B7%9F%E8%B8%AA%E6%BA%90%20-%20%E6%A0%B8%E5%BF%83%3CBR%20%2F%3EROM%202%20E0042000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20CTIv2%20%E7%B1%BB%E5%9E%8B%200x14%20%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%20-%20%E8%A7%A6%E5%8F%91%E5%99%A8%EF%BC%8C%E4%BE%8B%E5%A6%82%E7%94%B5%E4%BC%91%E5%85%8B%E6%B2%BB%E7%96%97%3CBR%20%2F%3EROM%201%20E0040000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20%E7%B1%BB%E5%9E%8B%200x11%20%E8%B7%9F%E8%B8%AA%E6%8E%A5%E6%94%B6%E5%99%A8%20-%20TPIU%3CBR%20%2F%3E%20ROM%201%20E0044000%EF%BC%9ACID%20B105900D%20PID%2004003BB908%20CSt%20CSTF%20%E7%B1%BB%E5%9E%8B%200x12%20%E8%B7%9F%E8%B8%AA%E9%93%BE%E6%8E%A5%20-%20%E8%B7%9F%E8%B8%AA%E6%BC%8F%E6%96%97%2F%E8%B7%AF%E7%94%B1%E5%99%A8%3CBR%20%2F%3EROM%201%20E0045000%EF%BC%9ACID%20B105900D%20PID%2004001BB961%20CSt%20%E7%B1%BB%E5%9E%8B%200x21%20%E8%B7%9F%E8%B8%AA%E6%8E%A5%E6%94%B6%E5%99%A8%20-%20ETB%3CBR%20%2F%3E%E6%81%A9%E6%99%BA%E6%B5%A6%EF%BC%9AMCXN947%3CBR%20%2F%3E%20DAP%20%E6%AD%A5%E5%B9%85%E4%B8%BA%201024%20%E5%AD%97%E8%8A%82%EF%BC%88256%20%E4%B8%AA%E5%AD%97%EF%BC%89%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E6%A3%80%E6%9F%A5%20SPI%20%E4%B8%8A%E7%9A%84%20v.2%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E5%9B%BE%E7%89%87%E2%80%9CMCXN9xx_SFDP_FlexSPI%202025%E5%B9%B43%E6%9C%886%E6%97%A5%2018%3A26%3A01%E2%80%9D%3CBR%20%2F%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3CBR%20%2F%3E%E5%B7%B2%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv8-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E6%94%B9%E7%94%A8%20SOFTRESET%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%8A%A8%E6%80%81%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E6%9C%AA%E6%8F%90%E4%BE%9B%E9%97%AA%E5%AD%98%E5%8F%82%E6%95%B0%3CBR%20%2F%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%8E%200x80000000%20%E5%BC%80%E5%A7%8B%E7%9A%84%E6%89%87%E5%8C%BA%3CBR%20%2F%3EFlash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20rc%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3CBR%20%2F%3E%E8%8A%AF%E7%89%87%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%20-%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9C%B0%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E6%A3%80%E6%9F%A5%20SPI%20%E4%B8%8A%E7%9A%84%20v.2%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E5%9B%BE%E7%89%87%E2%80%9CMCXN9xx_SFDP_FlexSPI%202025%E5%B9%B43%E6%9C%886%E6%97%A5%2018%3A26%3A01%E2%80%9D%3CBR%20%2F%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3CBR%20%2F%3E%E5%B7%B2%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv8-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E6%94%B9%E7%94%A8%20SOFTRESET%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%8A%A8%E6%80%81%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E6%9C%AA%E6%8F%90%E4%BE%9B%E9%97%AA%E5%AD%98%E5%8F%82%E6%95%B0%3CBR%20%2F%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%8E%200x80000000%20%E5%BC%80%E5%A7%8B%E7%9A%84%E6%89%87%E5%8C%BA%3CBR%20%2F%3EFlash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20rc%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3CBR%20%2F%3E%E8%8A%AF%E7%89%87%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%20-%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9C%B0%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3C%2FNONE%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2063601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2063601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E9%99%A4%E4%BA%86%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E5%92%8C%3CSPAN%3EFlashConfig.h%3C%2FSPAN%3E%E4%B9%8B%E5%A4%96%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%85%B6%E4%BB%96%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2062597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2062597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%A3%80%E6%9F%A5%E8%BF%87%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E7%A4%BA%E4%BE%8B%E3%80%82%3CBR%20%2F%3E%E6%88%91%E6%83%B3%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84Flash%E6%98%AFMX25L3233F%E3%80%82%3CBR%20%2F%3E%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E7%A4%BA%E4%BE%8B%E6%98%AF%20MT35XU512ABA%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E4%B8%8D%E5%90%8C%E7%9A%84%E5%9E%8B%E5%8F%B7%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AFMX25L3233F%E5%91%BD%E4%BB%A4%E7%9A%84%E6%91%98%E5%BD%95%EF%BC%8C%E4%B8%8EMT35XU512ABA%E5%91%BD%E4%BB%A4%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F328327i94C86C7AF2FA589B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F328328i698FE86060F7501C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F328329iD674305B2D9D8BB1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%AE%83%E6%98%AF%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%EF%BC%8C%E4%BD%86%E6%98%AF%E9%99%A4%E4%BA%86%20FlashConfig.h%20%E4%B9%8B%E5%A4%96%E6%88%91%E8%BF%98%E9%9C%80%E8%A6%81%E5%81%9A%E5%85%B6%E4%BB%96%E6%9B%B4%E6%94%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2062145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2062145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E9%99%A4%E4%BA%86%3CSPAN%3EMCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3C%2FSPAN%3E%E5%92%8C%3CSPAN%3Emcxn_flexspi_nor_config.c%3C%2FSPAN%3E%E4%B9%8B%E5%A4%96%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%85%B6%E4%BB%96%E6%96%87%E4%BB%B6%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E2%80%9C%3CSPAN%3E%E6%88%91%E6%AF%94%E8%BE%83%E4%BA%86%20W25Q64JVSSIQ%20%E5%92%8C%20MX25L3233F%20%E7%9A%84%E6%95%B0%E6%8D%AE%E8%A1%A8%EF%BC%8C%E5%B9%B6%E7%A1%AE%E8%AE%A4%20LUT%20%E5%86%85%E5%AE%B9%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FSPAN%3E%20%E2%80%9D%3C%2FP%3E%0A%3CP%3E%E4%B8%8D%EF%BC%8C%E5%AE%83%E4%BB%AC%E6%98%AF%E4%B8%8D%E5%90%8C%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%20flexspi_polling%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%AE%83%E5%8C%85%E5%90%AB%3CSPAN%3EW25Q64JVSSIQ%20%E5%92%8C%20MX25L3233F%20%E7%9A%84%20LUT%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23if%20EXAMPLE_FLASH_TYPE%20%3D%3D%20FLASH_W25Q64%0A%2F*%20W25Q64JVSSIQ%20*%2F%0Aconst%20uint32_t%20customLUTOctalMode%5BCUSTOM_LUT_LENGTH%5D%20%3D%20%7B%0A%20%20%20%20%2F*%20Read%20data%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READ%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200xEB%2C%20kFLEXSPI_Command_RADDR_SDR%2C%20kFLEXSPI_4PAD%2C%200x18)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READ%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(%0A%20%20%20%20%20%20%20%20kFLEXSPI_Command_MODE8_SDR%2C%20kFLEXSPI_4PAD%2C%200xF0%2C%20kFLEXSPI_Command_DUMMY_SDR%2C%20kFLEXSPI_4PAD%2C%200x04)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READ%20%2B%202%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_READ_SDR%2C%20kFLEXSPI_4PAD%2C%200x00%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Read%20status%20register%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READSTATUS%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x05%2C%20kFLEXSPI_Command_READ_SDR%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Write%20enable%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_WRITEENABLE%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x06%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Write%20enable%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_WRITEENABLE_OPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x06%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Read%20ID%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READID_OPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x9F%2C%20kFLEXSPI_Command_READ_SDR%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Sector%20erase%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_ERASESECTOR%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x20%2C%20kFLEXSPI_Command_RADDR_SDR%2C%20kFLEXSPI_1PAD%2C%200x18)%2C%0A%0A%20%20%20%20%2F*%20Chip%20erase%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_CHIPERASE%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x60%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Page%20program%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x32%2C%20kFLEXSPI_Command_RADDR_SDR%2C%20kFLEXSPI_1PAD%2C%200x18)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM%20%2B%201%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_WRITE_SDR%2C%20kFLEXSPI_4PAD%2C%200x00%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Enter%20Quad%20mode%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_ENTEROPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x05%2C%20kFLEXSPI_Command_READ_SDR%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20%20Dummy%20write%2C%20do%20nothing%20when%20AHB%20write%20command%20is%20triggered.%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_WRITE%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x0%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x0)%2C%0A%0A%20%20%20%20%2F*%20%20Read%20status%20register%20using%20Quad%20mode%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READSTATUS_OPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x05%2C%20kFLEXSPI_Command_READ_SDR%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%7D%3B%0A%23endif%0A%0A%23if%20EXAMPLE_FLASH_TYPE%20%3D%3D%20FLASH_MT35XU512%0A%2F*%20MT35XU512ABA1G12%20*%2F%0Aconst%20uint32_t%20customLUTOctalMode%5BCUSTOM_LUT_LENGTH%5D%20%3D%20%7B%0A%0A%20%20%20%20%2F*%20%20OPI%20DDR%20read%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READ%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200xCC%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200xCC)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READ%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(%0A%20%20%20%20%20%20%20%20kFLEXSPI_Command_RADDR_DDR%2C%20kFLEXSPI_8PAD%2C%200x20%2C%20kFLEXSPI_Command_DUMMY_DDR%2C%20kFLEXSPI_8PAD%2C%200x0D)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READ%20%2B%202%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_READ_DDR%2C%20kFLEXSPI_8PAD%2C%200x00%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Read%20status%20register%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READSTATUS%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x05%2C%20kFLEXSPI_Command_READ_SDR%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Write%20Enable%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_WRITEENABLE%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x06%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Read%20ID%20under%20octal%20mode%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READID_OPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x9F%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x9F)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READID_OPI%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(%0A%20%20%20%20%20%20%20%20kFLEXSPI_Command_DUMMY_DDR%2C%20kFLEXSPI_8PAD%2C%200x10%2C%20kFLEXSPI_Command_READ_DDR%2C%20kFLEXSPI_8PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20%20Write%20Enable%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_WRITEENABLE_OPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x06%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x06)%2C%0A%0A%20%20%20%20%2F*%20%20Erase%20Sector%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_ERASESECTOR%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x20%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x20)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_ERASESECTOR%20%2B%201%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_RADDR_DDR%2C%20kFLEXSPI_8PAD%2C%200x20%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20%20Erase%20Chip%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_CHIPERASE%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x60%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x60)%2C%0A%0A%20%20%20%20%2F*%20%20Program%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x8E%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x8E)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(%0A%20%20%20%20%20%20%20%20kFLEXSPI_Command_RADDR_DDR%2C%20kFLEXSPI_8PAD%2C%200x20%2C%20kFLEXSPI_Command_WRITE_DDR%2C%20kFLEXSPI_8PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Enter%20OPI%20mode%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_ENTEROPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x81%2C%20kFLEXSPI_Command_RADDR_SDR%2C%20kFLEXSPI_1PAD%2C%200x18)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_ENTEROPI%20%2B%201%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_WRITE_SDR%2C%20kFLEXSPI_1PAD%2C%200x00%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20%20Dummy%20write%2C%20do%20nothing%20when%20AHB%20write%20command%20is%20triggered.%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_WRITE%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x0%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x0)%2C%0A%0A%20%20%20%20%2F*%20%20Read%20status%20register%20using%20Octal%20DDR%20read%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READSTATUS_OPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x05%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x05)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READSTATUS_OPI%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(%0A%20%20%20%20%20%20%20%20kFLEXSPI_Command_DUMMY_DDR%2C%20kFLEXSPI_8PAD%2C%200x10%2C%20kFLEXSPI_Command_READ_DDR%2C%20kFLEXSPI_8PAD%2C%200x00)%2C%0A%7D%3B%0A%23endif%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2058562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2058562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AF%94%E8%BE%83%E4%BA%86%20W25Q64JVSSIQ%20%E5%92%8C%20MX25L3233F%20%E7%9A%84%E6%95%B0%E6%8D%AE%E8%A1%A8%EF%BC%8C%E5%B9%B6%E7%A1%AE%E8%AE%A4%20LUT%20%E5%86%85%E5%AE%B9%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%26gt%3B%20%E6%89%80%E4%BB%A5%E4%BD%A0%E9%9C%80%E8%A6%81%E6%94%B9%E5%8F%98Flash%E5%88%BB%E5%BD%95%E7%AE%97%E6%B3%95%E3%80%82%3CBR%20%2F%3E%26gt%3B%20%E4%BE%8B%E5%A6%82%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%BF%B0%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80%E6%82%A8%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%E4%B8%AD%E9%99%A4CONFIG_OPTION0%E5%92%8CCONFIG_OPTION1%E4%B9%8B%E5%A4%96%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%E8%AF%B4%E9%99%A4%E4%BA%86MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%E4%B9%8B%E5%A4%96%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E6%96%87%E4%BB%B6%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E5%85%B6%E4%BB%96%E6%96%87%E4%BB%B6%EF%BC%8C%E8%83%BD%E5%90%A6%E8%AF%B7%E5%91%8A%E7%9F%A5%E6%88%91%E4%BF%AE%E6%94%B9%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2057744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2057744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%9C%A8FRDM-MCXN947%E4%B8%8A%EF%BC%8CQflash%E6%98%AFW25Q64JVSSIQ%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E6%82%A8%E7%9A%84%E5%AE%A2%E6%88%B7%E6%9D%BF%E4%B8%8A%EF%BC%8Cqflash%20%E6%98%AF%20MX25L3233F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%89%80%E4%BB%A5%E9%9C%80%E8%A6%81%E6%94%B9%E5%8F%98Flash%E7%83%A7%E5%BD%95%E7%AE%97%E6%B3%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E4%BE%8B%E5%A6%82MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%9C%A8%20mcxn_flexspi_nor_config.c%20%E4%B8%AD%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%9B%B4%E6%94%B9%20LUT%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2025-03-07_18-01-29.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2025-03-07_18-01-29.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F327151i410610CB2C63825B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Snipaste_2025-03-07_18-01-29.png%22%20alt%3D%22Snipaste_2025-03-07_18-01-29.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%82%E8%80%83FRDM-MCXN947%E7%9A%84demo%E7%A8%8B%E5%BA%8F%E4%BF%AE%E6%94%B9%E4%BA%86%E5%B7%A5%E7%A8%8B%EF%BC%8C%E5%B9%B6%E7%A1%AE%E8%AE%A4%E5%8F%AF%E4%BB%A5%E4%BB%8EIDE%E5%86%99%E5%85%A5%E3%80%82%3CBR%20%2F%3E%E8%AF%A5%E7%A8%8B%E5%BA%8F%E4%B8%8E%E6%98%A8%E5%A4%A9%E5%9C%A8%E2%80%9C%E4%BD%9C%E4%B8%BA%E8%A1%A5%E5%85%85%E4%BF%A1%E6%81%AF...%E2%80%9D%E4%B8%8B%E6%89%80%E5%86%99%E7%9A%84%E4%B8%80%E6%A0%B7%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E4%B8%BB%E6%9D%BF%E4%BD%BF%E7%94%A8%20MX25L3233F%20%E4%BD%9C%E4%B8%BA%20Flash%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E6%9E%84%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%20CMSIS-DAP%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%A4%BA%E4%BE%8B%E5%B9%B6%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%A3%80%E6%9F%A5%E3%80%82%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E8%87%AA%E5%B7%B1%E6%9E%84%E5%BB%BA%E7%9A%84%E9%82%A3%E4%B8%AA%EF%BC%8C%E6%B2%A1%E6%9C%89%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E4%BF%AE%E6%94%B9%EF%BC%8C%E5%B9%B6%E4%BB%8E%20IDE%20%E7%BC%96%E5%86%99%E5%AE%83%E3%80%82%EF%BC%88CONFIG_OPTION0%3D0xC0000001%EF%BC%89%3CBR%20%2F%3E%E7%BB%93%E6%9E%9C%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%8A%E6%98%BE%E7%A4%BA%E5%A6%82%E4%B8%8B%EF%BC%8C%E5%B9%B6%E6%B2%A1%E6%9C%89%E8%BF%9B%E8%A1%8C%E5%86%99%E5%85%A5%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%3CP%3EMCUXpresso%20IDE%20RedlinkMulti%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20v24.9%EF%BC%882024%20%E5%B9%B4%209%20%E6%9C%88%2019%20%E6%97%A5%2019%3A34%3A05%20-%20crt_emu_cm_redlink%20%E7%89%88%E6%9C%AC%20802%EF%BC%89%3C%2FP%3E%3CP%3E%E5%9C%A8%20C%3A%2FWorkSpace%2FMCUX%2FMCUXpressoIDE_24.9.25%2FNX-N947%2Ffrdmmcxn947_hello_world_qspi_xip%2FDebug%5CMCXN947.xml%20%E4%B8%AD%E6%89%BE%E5%88%B0%E8%8A%AF%E7%89%87%20XML%20%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%EF%BC%885%EF%BC%89%E8%BF%9C%E7%A8%8B%E9%85%8D%E7%BD%AE%E5%AE%8C%E6%88%90%3C%2FP%3E%3CP%3E%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%8E%B0%E6%9C%89%E7%9A%84%20LinkServer%20%E8%BF%9B%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%8E%A2%E9%92%88%E5%9B%BA%E4%BB%B6%EF%BC%9AMCU-LINK%EF%BC%88r0FF%EF%BC%89CMSIS-DAP%20V3.153%EF%BC%88%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%EF%BC%89%3C%2FP%3E%3CP%3ESerial%20Number%3A%20VUDADS0NIE0ZM%3C%2FP%3E%3CP%3EVID%3APID%3A%201FC9%3A0143%3C%2FP%3E%3CP%3EUSB%20%E8%B7%AF%E5%BE%84%EF%BC%9A0001%3A0008%3A00%3C%2FP%3E%3CP%3E%E6%90%9C%E7%B4%A2%E5%88%B0%E5%90%88%E9%80%82%E7%9A%84%E6%A0%B8%E5%BF%83%E5%90%8E%E4%BD%BF%E7%94%A8%E6%A0%B8%E5%BF%83%200%20%E7%9A%84%E5%86%85%E5%AD%98%3C%2FP%3E%3CP%3E%E5%A4%84%E7%90%86%E5%99%A8%E5%A4%84%E4%BA%8E%E5%AE%89%E5%85%A8%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%20%3D%20CoreSight%20DP%EF%BC%88DAP%20DP%20ID%206BA02477%EF%BC%89%E9%80%9A%E8%BF%87%20SWD%20TAP%200%3C%2FP%3E%3CP%3E%E5%A4%84%E7%90%86%E5%99%A8%E7%B1%BB%E5%9E%8B%20%3D%20Cortex-M33%EF%BC%88CPU%20ID%2000000D21%EF%BC%89%E5%9C%A8%20DAP%20AP%200%20%E4%B8%8A%3C%2FP%3E%3CP%3E%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%208%3C%2FP%3E%3CP%3E%E9%97%AA%E5%AD%98%E8%A1%A5%E4%B8%81%E6%95%B0%E9%87%8F%20%3D%200%3C%2FP%3E%3CP%3E%E7%A1%AC%E4%BB%B6%E7%9B%91%E6%B5%8B%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%204%3C%2FP%3E%3CP%3E%E6%8E%A2%E6%B5%8B%E5%99%A8(0)%EF%BC%9A%E5%B7%B2%E8%BF%9E%E6%8E%A5%E5%B9%B6%E9%87%8D%E7%BD%AE%E3%80%82DpID%EF%BC%9A6BA02477%E3%80%82CPUID%EF%BC%9A00000D21%E3%80%82%E4%BF%A1%E6%81%AF%EF%BC%9A%3CNONE%3E%3C%2FNONE%3E%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%E5%8D%8F%E8%AE%AE%EF%BC%9ASWD%E3%80%82RTCK%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%E7%9F%A2%E9%87%8F%E6%8D%95%E8%8E%B7%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3ECoreSight%20%E8%B0%83%E8%AF%95%20ROM%20%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CP%3ERBASE%20E00FE000%EF%BC%9ACID%20B105100D%20PID%200000095000%20ROM%EF%BC%88%E7%B1%BB%E5%9E%8B%200x1%EF%BC%89%3C%2FP%3E%3CP%3EROM%201%20E00FF000%EF%BC%9ACID%20B105100D%20PID%2004000BB4C9%20ROM%EF%BC%88%E7%B1%BB%E5%9E%8B%200x1%EF%BC%89%3C%2FP%3E%3CP%3EROM%202%20E000E000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ARMv8-M%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3C%2FP%3E%3CP%3EROM%202%20E0001000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20DWTv2%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3C%2FP%3E%3CP%3EROM%202%20E0002000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20FPBv2%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3C%2FP%3E%3CP%3EROM%202%20E0000000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ITMv2%20%E7%B1%BB%E5%9E%8B%200x43%20%E8%B7%9F%E8%B8%AA%E6%BA%90%20-%20%E6%80%BB%E7%BA%BF%3C%2FP%3E%3CP%3EROM%202%20E0041000%3A%20CID%20B105900D%20PID%2004002BBD21%20CSt%20ARM%20ETMv4.0%20%E7%B1%BB%E5%9E%8B%200x13%20%E8%B7%9F%E8%B8%AA%E6%BA%90%20-%20%E6%A0%B8%E5%BF%83%3C%2FP%3E%3CP%3EROM%202%20E0042000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20CTIv2%20%E7%B1%BB%E5%9E%8B%200x14%20%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%20-%20%E8%A7%A6%E5%8F%91%E5%99%A8%EF%BC%8C%E4%BE%8B%E5%A6%82%E7%94%B5%E4%BC%91%E5%85%8B%E6%B2%BB%E7%96%97%3C%2FP%3E%3CP%3EROM%201%20E0040000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20%E7%B1%BB%E5%9E%8B%200x11%20%E8%B7%9F%E8%B8%AA%E6%8E%A5%E6%94%B6%E5%99%A8%20-%20TPIU%3C%2FP%3E%3CP%3EROM%201%20E0044000%EF%BC%9ACID%20B105900D%20PID%2004003BB908%20CSt%20CSTF%20%E7%B1%BB%E5%9E%8B%200x12%20%E8%B7%9F%E8%B8%AA%E9%93%BE%E6%8E%A5%20-%20%E8%B7%9F%E8%B8%AA%E6%BC%8F%E6%96%97%2F%E8%B7%AF%E7%94%B1%E5%99%A8%3C%2FP%3E%3CP%3EROM%201%20E0045000%EF%BC%9ACID%20B105900D%20PID%2004001BB961%20CSt%20%E7%B1%BB%E5%9E%8B%200x21%20%E8%B7%9F%E8%B8%AA%E6%8E%A5%E6%94%B6%E5%99%A8%20-%20ETB%3C%2FP%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%EF%BC%9AMCXN947%3C%2FP%3E%3CP%3EDAP%20%E6%AD%A5%E5%B9%85%E4%B8%BA%201024%20%E5%AD%97%E8%8A%82%EF%BC%88256%20%E4%B8%AA%E5%AD%97%EF%BC%89%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_.cfx%20%E6%A3%80%E6%9F%A5%20SPI%20%E4%B8%8A%E7%9A%84%20v.2%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%E5%9B%BE%E7%89%87%E2%80%9CMCXN9xx_SFDP_FlexSPI%202025%E5%B9%B43%E6%9C%886%E6%97%A5%2017%3A01%3A24%E2%80%9D%3C%2FP%3E%3CP%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_.cfx%3C%2FP%3E%3CP%3E%E5%B7%B2%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv8-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E6%94%B9%E7%94%A8%20SOFTRESET%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%E6%A3%80%E6%B5%8B%E5%88%B0%20Flash%20%E5%8F%98%E4%BD%93%E2%80%98JEDEC_FlexSPI_Device%E2%80%99%EF%BC%880B%20%3D%20%E4%BD%8D%E4%BA%8E%200x80000000%EF%BC%89%3C%2FP%3E%3CP%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%8E%200x80000000%20%E5%BC%80%E5%A7%8B%E7%9A%84%E6%89%87%E5%8C%BA%3C%2FP%3E%3CP%3EFlash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20rc%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3C%2FP%3E%3CP%3E%E8%8A%AF%E7%89%87%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%20-%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9C%B0%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_.cfx%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_.cfx%20%E6%A3%80%E6%9F%A5%20SPI%20%E4%B8%8A%E7%9A%84%20v.2%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%E5%9B%BE%E7%89%87%E2%80%9CMCXN9xx_SFDP_FlexSPI%202025%E5%B9%B43%E6%9C%886%E6%97%A5%2017%3A01%3A24%E2%80%9D%3C%2FP%3E%3CP%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_.cfx%3C%2FP%3E%3CP%3E%E5%B7%B2%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv8-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E6%94%B9%E7%94%A8%20SOFTRESET%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%E6%A3%80%E6%B5%8B%E5%88%B0%20Flash%20%E5%8F%98%E4%BD%93%E2%80%98JEDEC_FlexSPI_Device%E2%80%99%EF%BC%884MB%20%3D%2064*64K%EF%BC%8C%E4%BD%8D%E4%BA%8E%200x80000000%EF%BC%89%3C%2FP%3E%3CP%3E%E5%85%B3%E9%97%AD%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_.cfx%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CBR%20%2F%3E%E6%8E%A5%E4%B8%8B%E6%9D%A5%EF%BC%8C%E6%88%91%E6%9B%B4%E6%94%B9%E4%BA%86SEC%E5%B7%A5%E5%85%B7%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E8%AE%BE%E7%BD%AE%E5%80%BC%EF%BC%88CONFIG_OPTION0%3D0xC0000405%EF%BC%89%E5%B9%B6%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%A3%80%E6%9F%A5%EF%BC%8C%E4%BD%86%E8%BF%99%E9%87%8C%E4%B9%9F%E6%B2%A1%E6%9C%89%E8%BF%9B%E8%A1%8C%E5%86%99%E5%85%A5%E3%80%82%3CBR%20%2F%3E%EF%BC%88%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20SEC%20%E5%B7%A5%E5%85%B7%E8%BF%9B%E8%A1%8C%E7%BC%96%E5%86%99%E3%80%82%EF%BC%89%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E5%BD%93%E6%97%B6%E6%8E%A7%E5%88%B6%E5%8F%B0%E7%9A%84%E6%98%BE%E7%A4%BA%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%3CP%3EMCUXpresso%20IDE%20RedlinkMulti%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20v24.9%EF%BC%882024%20%E5%B9%B4%209%20%E6%9C%88%2019%20%E6%97%A5%2019%3A34%3A05%20-%20crt_emu_cm_redlink%20%E7%89%88%E6%9C%AC%20802%EF%BC%89%3C%2FP%3E%3CP%3E%E5%9C%A8%20C%3A%2FWorkSpace%2FMCUX%2FMCUXpressoIDE_24.9.25%2FNX-N947%2FNX-N947_ledblinky%2Ffrdmmcxn947_led_blinky%2FDebug_NoRAM%5CMCXN947.xml%20%E4%B8%AD%E6%89%BE%E5%88%B0%E8%8A%AF%E7%89%87%20XML%20%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%EF%BC%885%EF%BC%89%E8%BF%9C%E7%A8%8B%E9%85%8D%E7%BD%AE%E5%AE%8C%E6%88%90%3C%2FP%3E%3CP%3E%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%8E%B0%E6%9C%89%E7%9A%84%20LinkServer%20%E8%BF%9B%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%8E%A2%E9%92%88%E5%9B%BA%E4%BB%B6%EF%BC%9AMCU-LINK%EF%BC%88r0FF%EF%BC%89CMSIS-DAP%20V3.153%EF%BC%88%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%EF%BC%89%3C%2FP%3E%3CP%3ESerial%20Number%3A%20VUDADS0NIE0ZM%3C%2FP%3E%3CP%3EVID%3APID%3A%201FC9%3A0143%3C%2FP%3E%3CP%3EUSB%20%E8%B7%AF%E5%BE%84%EF%BC%9A0001%3A0008%3A00%3C%2FP%3E%3CP%3E%E6%90%9C%E7%B4%A2%E5%88%B0%E5%90%88%E9%80%82%E7%9A%84%E6%A0%B8%E5%BF%83%E5%90%8E%E4%BD%BF%E7%94%A8%E6%A0%B8%E5%BF%83%200%20%E7%9A%84%E5%86%85%E5%AD%98%3C%2FP%3E%3CP%3E%EF%BC%8830%EF%BC%89%E6%A8%A1%E6%8B%9F%E5%99%A8%E5%B7%B2%E8%BF%9E%E6%8E%A5%3C%2FP%3E%3CP%3E%E5%A4%84%E7%90%86%E5%99%A8%E5%A4%84%E4%BA%8E%E5%AE%89%E5%85%A8%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%20%3D%20CoreSight%20DP%EF%BC%88DAP%20DP%20ID%206BA02477%EF%BC%89%E9%80%9A%E8%BF%87%20SWD%20TAP%200%3C%2FP%3E%3CP%3E%E5%A4%84%E7%90%86%E5%99%A8%E7%B1%BB%E5%9E%8B%20%3D%20Cortex-M33%EF%BC%88CPU%20ID%2000000D21%EF%BC%89%E5%9C%A8%20DAP%20AP%200%20%E4%B8%8A%3C%2FP%3E%3CP%3E%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%208%3C%2FP%3E%3CP%3E%E9%97%AA%E5%AD%98%E8%A1%A5%E4%B8%81%E6%95%B0%E9%87%8F%20%3D%200%3C%2FP%3E%3CP%3E%E7%A1%AC%E4%BB%B6%E7%9B%91%E6%B5%8B%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%204%3C%2FP%3E%3CP%3E%E6%8E%A2%E6%B5%8B%E5%99%A8(0)%EF%BC%9A%E5%B7%B2%E8%BF%9E%E6%8E%A5%E5%B9%B6%E9%87%8D%E7%BD%AE%E3%80%82DpID%EF%BC%9A6BA02477%E3%80%82CPUID%EF%BC%9A00000D21%E3%80%82%E4%BF%A1%E6%81%AF%EF%BC%9A%3CNONE%3E%3C%2FNONE%3E%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%E5%8D%8F%E8%AE%AE%EF%BC%9ASWD%E3%80%82RTCK%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%E7%9F%A2%E9%87%8F%E6%8D%95%E8%8E%B7%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3ECoreSight%20%E8%B0%83%E8%AF%95%20ROM%20%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CP%3ERBASE%20E00FE000%EF%BC%9ACID%20B105100D%20PID%200000095000%20ROM%EF%BC%88%E7%B1%BB%E5%9E%8B%200x1%EF%BC%89%3C%2FP%3E%3CP%3EROM%201%20E00FF000%EF%BC%9ACID%20B105100D%20PID%2004000BB4C9%20ROM%EF%BC%88%E7%B1%BB%E5%9E%8B%200x1%EF%BC%89%3C%2FP%3E%3CP%3EROM%202%20E000E000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ARMv8-M%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3C%2FP%3E%3CP%3EROM%202%20E0001000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20DWTv2%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3C%2FP%3E%3CP%3EROM%202%20E0002000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20FPBv2%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3C%2FP%3E%3CP%3EROM%202%20E0000000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ITMv2%20%E7%B1%BB%E5%9E%8B%200x43%20%E8%B7%9F%E8%B8%AA%E6%BA%90%20-%20%E6%80%BB%E7%BA%BF%3C%2FP%3E%3CP%3EROM%202%20E0041000%3A%20CID%20B105900D%20PID%2004002BBD21%20CSt%20ARM%20ETMv4.0%20%E7%B1%BB%E5%9E%8B%200x13%20%E8%B7%9F%E8%B8%AA%E6%BA%90%20-%20%E6%A0%B8%E5%BF%83%3C%2FP%3E%3CP%3EROM%202%20E0042000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20CTIv2%20%E7%B1%BB%E5%9E%8B%200x14%20%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%20-%20%E8%A7%A6%E5%8F%91%E5%99%A8%EF%BC%8C%E4%BE%8B%E5%A6%82%E7%94%B5%E4%BC%91%E5%85%8B%E6%B2%BB%E7%96%97%3C%2FP%3E%3CP%3EROM%201%20E0040000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20%E7%B1%BB%E5%9E%8B%200x11%20%E8%B7%9F%E8%B8%AA%E6%8E%A5%E6%94%B6%E5%99%A8%20-%20TPIU%3C%2FP%3E%3CP%3EROM%201%20E0044000%EF%BC%9ACID%20B105900D%20PID%2004003BB908%20CSt%20CSTF%20%E7%B1%BB%E5%9E%8B%200x12%20%E8%B7%9F%E8%B8%AA%E9%93%BE%E6%8E%A5%20-%20%E8%B7%9F%E8%B8%AA%E6%BC%8F%E6%96%97%2F%E8%B7%AF%E7%94%B1%E5%99%A8%3C%2FP%3E%3CP%3EROM%201%20E0045000%EF%BC%9ACID%20B105900D%20PID%2004001BB961%20CSt%20%E7%B1%BB%E5%9E%8B%200x21%20%E8%B7%9F%E8%B8%AA%E6%8E%A5%E6%94%B6%E5%99%A8%20-%20ETB%3C%2FP%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%EF%BC%9AMCXN947%3C%2FP%3E%3CP%3EDAP%20%E6%AD%A5%E5%B9%85%E4%B8%BA%201024%20%E5%AD%97%E8%8A%82%EF%BC%88256%20%E4%B8%AA%E5%AD%97%EF%BC%89%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E6%A3%80%E6%9F%A5%20SPI%20%E4%B8%8A%E7%9A%84%20v.2%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%E5%9B%BE%E7%89%87%E2%80%9CMCXN9xx_SFDP_FlexSPI%202025%E5%B9%B43%E6%9C%886%E6%97%A5%2018%3A26%3A01%E2%80%9D%3C%2FP%3E%3CP%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3C%2FP%3E%3CP%3E%E5%B7%B2%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv8-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E6%94%B9%E7%94%A8%20SOFTRESET%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%8A%A8%E6%80%81%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E6%9C%AA%E6%8F%90%E4%BE%9B%E9%97%AA%E5%AD%98%E5%8F%82%E6%95%B0%3C%2FP%3E%3CP%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%8E%200x80000000%20%E5%BC%80%E5%A7%8B%E7%9A%84%E6%89%87%E5%8C%BA%3C%2FP%3E%3CP%3EFlash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20rc%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3C%2FP%3E%3CP%3E%E8%8A%AF%E7%89%87%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%20-%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9C%B0%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E6%A3%80%E6%9F%A5%20SPI%20%E4%B8%8A%E7%9A%84%20v.2%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%E5%9B%BE%E7%89%87%E2%80%9CMCXN9xx_SFDP_FlexSPI%202025%E5%B9%B43%E6%9C%886%E6%97%A5%2018%3A26%3A01%E2%80%9D%3C%2FP%3E%3CP%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3C%2FP%3E%3CP%3E%E5%B7%B2%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv8-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E6%94%B9%E7%94%A8%20SOFTRESET%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%8A%A8%E6%80%81%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E6%9C%AA%E6%8F%90%E4%BE%9B%E9%97%AA%E5%AD%98%E5%8F%82%E6%95%B0%3C%2FP%3E%3CP%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%8E%200x80000000%20%E5%BC%80%E5%A7%8B%E7%9A%84%E6%89%87%E5%8C%BA%3C%2FP%3E%3CP%3EFlash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20V.2%20%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20rc%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3C%2FP%3E%3CP%3E%E8%8A%AF%E7%89%87%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%20-%20Ef(58)%3A%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%85%B6%E5%9F%BA%E5%9C%B0%E5%9D%80%E5%A4%84%E6%9C%AA%E6%8F%8F%E8%BF%B0%E4%BB%BB%E4%BD%95%E6%89%87%E5%8C%BA%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CBR%20%2F%3E%E9%99%A4%E4%BA%86%20MX25L3233F%20%E7%9A%84%20CONFIG_OPTION0%20%E4%B9%8B%E5%A4%96%EF%BC%8C%E6%98%AF%E5%90%A6%E8%BF%98%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9%E5%85%B6%E4%BB%96%E5%86%85%E5%AE%B9%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E2%80%9C%3CSPAN%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20FRDM-MCXN947%20%E7%9A%84%E5%86%99%E5%85%A5%E6%96%B9%E6%B3%95%E4%BD%9C%E4%B8%BA%E5%8F%82%E8%80%83%E6%9D%A5%E5%86%99%E5%85%A5%E8%AF%A5%E6%9D%BF%EF%BC%8C%E4%BD%86%E5%8F%91%E7%94%9F%E4%BA%86%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%20%E2%80%9D%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E6%8D%A2%E5%88%B0%E5%8F%A6%E4%B8%80%E5%9D%97%E6%9D%BF%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%9D%E8%AF%95%E8%BF%87%E5%90%8C%E6%A0%B7%E7%9A%84%E6%96%B9%E6%B3%95%E4%BD%86%E6%98%AF%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%EF%BC%9F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20MCXN947%20%E6%9D%BF%E4%B8%8A%E5%86%99%E5%85%A5%20QSPI%20Flash%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%9C%E4%B8%BA%E8%A1%A5%E5%85%85%E4%BF%A1%E6%81%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E6%83%B3%E5%91%8A%E7%9F%A5%E6%82%A8%EF%BC%8C%E4%BB%8E%E6%82%A8%E8%81%94%E7%B3%BB%E6%88%91%E4%BB%AC%E7%9A%84%E6%BC%94%E7%A4%BA%E9%A1%B9%E7%9B%AE%E5%88%B0%E8%AF%A5%E6%9D%BF%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%88%91%E4%BB%AC%E4%B8%BA%E5%AE%9E%E7%8E%B0%20XIP%20%E5%A4%84%E7%90%86%E6%89%80%E5%81%9A%E7%9A%84%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E-%20%E5%A4%8D%E5%88%B6%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E6%BA%90%5Cmcxn_flexspi_nor_config.c%3CBR%20%2F%3E%E6%BA%90%5Cmcxn_flexspi_nor_config.h%3CBR%20%2F%3E%E9%93%BE%E6%8E%A5%E8%84%9A%E6%9C%AC%5Crodata.ldt%3CBR%20%2F%3E%E9%93%BE%E6%8E%A5%E8%84%9A%E6%9C%AC%5C%E6%96%87%E6%9C%AC.ldt%3C%2FP%3E%3CP%3E-%20%E4%BD%BF%E7%94%A8%20blhost%20%E9%87%8D%E5%86%99%E4%B8%BA%E2%80%9Cbootfromflexspi.bin%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E-%20%E6%9B%B4%E6%94%B9%E5%86%85%E5%AD%98%E9%85%8D%E7%BD%AE%E7%BC%96%E8%BE%91%E5%99%A8%E7%9A%84%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F326825iB59CC573151030E9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
