SmartDMA documentation for RT595
414 次查看
jacobvecht
With the RT595, I need to use DMA to rapidly copy data from FlexIO to a RAM buffer, and the documentation says I should use SmartDMA for this. The RT595 reference manual (Rev 2 of 12/2023) chapter 17 is only one page long and appears to stop abruptly. The majority of the documentation is not there. Where is the documentation for SmartDMA in the RT575? I see NXP has posted the SmartDMA cookbook, and a few very specific app notes. There is also a very minimal API document, clearly also unfinished. I do not see links to any secure document. How do I get a reference-manual level description of this peripheral?
标记 (1)
4 回复数
341 次查看
Sam_Gao
@jacobvecht
I couldn't find information about a reference manual containing a complete register map or bit-level programming model for the i.MX RT595 SmartDMA.
The reference-manual level documentation with detailed register maps for the i.MX RT595 SmartDMA is not publicly available, as the intended use is through a high-level API with pre-compiled firmware.
Here is a summary of the available information and the intended usage model based on the documentation:
  • SmartDMA API User Guide (IMXRT500SDMAAPIUG): This is the primarysoftware development. It details the API functions used to initialize, control, and interact with the SmartDMA. It includes function prototypes for initialization ( SMARTDMA_Init ), loading firmware ( SMARTDMA_InstallFirmware ), and starting operations ( SMARTDMA_Boot ),
  • Application Notes :AN14650, AN13942, AN14152
331 次查看
jacobvecht
This is not a satisfactory solution. I was aware of all these sources before getting your answer, and got almost exactly the same response from you as I previously received from an AI chat bot.  All one can do with these application notes is to make an exact copy of the project described. The API documentation is incomplete, and the chapter on SmartDMA stops mid -sentence after less than one page.  Meanwhile the documentation for the FlexIO says we must use SmartDMA. Nowhere is there any instruction for how to do this unless I want to reproduce the camera examples. We have no list of DMA triggers or request sources. This situation is totally unusable. Here I am midway through a project, the hardware is there and there is no support from the manufacturer ANYWHERE of how to use DMA for a non-standard FlexIO application. This is just too unreasonable. What on earth can I do now? restart the project with an ST microcontroller?  NXP must, MUST provide documentation for the SmartDMA, at the very least, provide a complete API document that lists all the functions and structures, but preferably gives a full list of registers. The present situation is unreasonable and unbearable, and your response is woefully unsatisfactory. At the very least, how does NXP account for the abrupt abandonment of its chapter on SmartDMA in the reference manual?
310 次查看
Sam_Gao
'Q1. 'At the very least, how does NXP account for the abrupt abandonment of its chapter on SmartDMA in the reference manual?'
-->This question is out of my scope, and I cannot give a definitive answer. I need to try to find the relevant team and product owner, but I'm not sure if I can, as re-org or unanswerable issues are common.
Q2. The API documentation is incomplete, and the chapter on SmartDMA stops mid -sentence after less than one page. Meanwhile the documentation for the FlexIO says we must use SmartDMA. Nowhere is there any instruction for how to do this unless I want to reproduce the camera examples. We have no list of DMA triggers or request sources. This situation is totally unusable. Here I am midway through a project, the hardware is there and there is no support from the manufacturer ANYWHERE of how to use DMA for a non-standard FlexIO application. This is just too unreasonable.
--> How did you arrive at this conclusion?
282 次查看
jacobvecht
Sam_Gao of NXP has asked how I reached the conclusion that "the documentation for the FlexIO says we must use SmartDMA"
My answer is that in the RT595 reference manual rev 2 page 2171 we see the following:
51.1.2 DMA Support
On this device, the standard DMA is not supported for use with the FLEXIO module. The SmartDMA should be used instead. Any reference to the standard DMA should be disregarded in the chapter.
标记 (4)
%3CLINGO-SUB%20id%3D%22lingo-sub-2249832%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT595%20%E7%9A%84%20SmartDMA%20%E6%96%87%E6%A1%A3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249832%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AF%B9%E4%BA%8E%20RT595%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20DMA%20%E5%B0%86%E6%95%B0%E6%8D%AE%E4%BB%8E%20FlexIO%20%E5%BF%AB%E9%80%9F%E5%A4%8D%E5%88%B6%E5%88%B0%20RAM%20%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C%E8%80%8C%E6%96%87%E6%A1%A3%E4%B8%AD%E8%AF%B4%E6%88%91%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20SmartDMA%20%E6%9D%A5%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%80%E7%9B%AE%E7%9A%84%E3%80%82RT595%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%882023%20%E5%B9%B4%2012%20%E6%9C%88%E7%AC%AC%202%20%E4%BF%AE%E8%AE%A2%E7%89%88%EF%BC%89%E7%AC%AC%2017%20%E7%AB%A0%E5%8F%AA%E6%9C%89%E4%B8%80%E9%A1%B5%E9%95%BF%EF%BC%8C%E8%80%8C%E4%B8%94%E4%BC%BC%E4%B9%8E%E7%AA%81%E7%84%B6%E5%81%9C%E6%AD%A2%E4%BA%86%E3%80%82%E5%A4%A7%E9%83%A8%E5%88%86%E6%96%87%E4%BB%B6%E9%83%BD%E4%B8%8D%E5%AD%98%E5%9C%A8%E3%80%82RT575%20%E4%B8%AD%20SmartDMA%20%E7%9A%84%E6%96%87%E6%A1%A3%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%E6%88%91%E7%9C%8B%E5%88%B0%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8F%91%E5%B8%83%E4%BA%86%20SmartDMA%20%E7%83%B9%E9%A5%AA%E6%89%8B%E5%86%8C%E5%92%8C%E4%B8%80%E4%BA%9B%E9%9D%9E%E5%B8%B8%E5%85%B7%E4%BD%93%E7%9A%84%E5%BA%94%E7%94%A8%E8%AF%B4%E6%98%8E%E3%80%82%E8%BF%98%E6%9C%89%E4%B8%80%E4%BB%BD%E9%9D%9E%E5%B8%B8%E7%AE%80%E7%9F%AD%E7%9A%84%20API%20%E6%96%87%E6%A1%A3%EF%BC%8C%E6%98%BE%E7%84%B6%E4%B9%9F%E6%98%AF%E6%9C%AA%E5%AE%8C%E6%88%90%E7%9A%84%E3%80%82%E6%88%91%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E4%BB%BB%E4%BD%95%E5%AE%89%E5%85%A8%E6%96%87%E4%BB%B6%E7%9A%84%E9%93%BE%E6%8E%A5%E3%80%82%E5%A6%82%E4%BD%95%E8%8E%B7%E5%BE%97%E8%AF%A5%E5%A4%96%E8%AE%BE%E7%9A%84%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E7%BA%A7%E5%88%AB%E6%8F%8F%E8%BF%B0%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2249832%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E9%80%9A%E4%BF%A1%26amp%3B%20%E6%8E%A7%E5%88%B6%EF%BC%88I3C%20%7C%20I2C%20%7C%20SPI%20%7C%20FlexCAN%20%7C%20%E4%BB%A5%E5%A4%AA%E7%BD%91%20%7C%20FlexIO%EF%BC%89%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2251637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SmartDMA%20documentation%20for%20RT595%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2251637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E'Q1%E3%80%82%E2%80%9C%E8%87%B3%E5%B0%91%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E5%A6%82%E4%BD%95%E8%A7%A3%E9%87%8A%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E7%AA%81%E7%84%B6%E6%94%BE%E5%BC%83%E6%9C%89%E5%85%B3SmartDMA%E7%9A%84%E7%AB%A0%E8%8A%82%EF%BC%9F%E2%80%9D%3C%2FP%3E%0A%3CP%3E--%26gt%3B%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E8%B6%85%E5%87%BA%E4%BA%86%E6%88%91%E7%9A%84%E8%8C%83%E5%9B%B4%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E7%BB%99%E5%87%BA%E6%98%8E%E7%A1%AE%E7%9A%84%E7%AD%94%E6%A1%88%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E8%AE%BE%E6%B3%95%E6%89%BE%E5%88%B0%E7%9B%B8%E5%85%B3%E5%9B%A2%E9%98%9F%E5%92%8C%E4%BA%A7%E5%93%81%E8%B4%9F%E8%B4%A3%E4%BA%BA%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E8%83%BD%E5%90%A6%E6%89%BE%E5%88%B0%EF%BC%8C%E5%9B%A0%E4%B8%BA%E9%87%8D%E7%BB%84%E6%88%96%E6%97%A0%E6%B3%95%E5%9B%9E%E7%AD%94%E7%9A%84%E9%97%AE%E9%A2%98%E5%BE%88%E5%B8%B8%E8%A7%81%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EQ2.%20API%20%E6%96%87%E6%A1%A3%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E5%85%B3%E4%BA%8E%20SmartDMA%20%E7%9A%84%E7%AB%A0%E8%8A%82%E4%B8%8D%E5%88%B0%E4%B8%80%E9%A1%B5%E5%B0%B1%E4%B8%AD%E9%80%94%E5%81%9C%E6%AD%A2%E3%80%82%3CFONT%20color%3D%22%23FF0000%22%3E%3CEM%3E%E5%90%8C%E6%97%B6%EF%BC%8CFlexIO%20%E7%9A%84%E6%96%87%E6%A1%A3%E8%AF%B4%E6%88%91%E4%BB%AC%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20SmartDMA%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%E9%99%A4%E9%9D%9E%E6%88%91%E6%83%B3%E5%A4%8D%E5%88%B6%E7%85%A7%E7%9B%B8%E6%9C%BA%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%90%A6%E5%88%99%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%9C%B0%E6%96%B9%E5%8F%AF%E4%BB%A5%E6%8C%87%E5%AF%BC%E6%88%91%E5%A6%82%E4%BD%95%E6%93%8D%E4%BD%9C%E3%80%82%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%20DMA%20%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E6%88%96%E8%AF%B7%E6%B1%82%E6%9D%A5%E6%BA%90%E7%9A%84%E6%B8%85%E5%8D%95%E3%80%82%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%AE%8C%E5%85%A8%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%E3%80%82%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E8%BF%9B%E8%A1%8C%E5%88%B0%E4%B8%80%E5%8D%8A%EF%BC%8C%E7%A1%AC%E4%BB%B6%E5%B7%B2%E7%BB%8F%E5%88%B0%E4%BD%8D%EF%BC%8C%E4%BD%86%E5%88%B6%E9%80%A0%E5%95%86%E6%B2%A1%E6%9C%89%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E6%94%AF%E6%8C%81%EF%BC%8C%E8%AF%B4%E6%98%8E%E5%A6%82%E4%BD%95%E5%9C%A8%E9%9D%9E%E6%A0%87%E5%87%86%20FlexIO%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E4%BD%BF%E7%94%A8%20DMA%E3%80%82%E8%BF%99%E5%A4%AA%E4%B8%8D%E5%90%88%E7%90%86%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E--%26gt%3B%20%E4%BD%A0%E6%98%AF%E5%A6%82%E4%BD%95%E5%BE%97%E5%87%BA%E8%BF%99%E4%B8%80%E7%BB%93%E8%AE%BA%E7%9A%84%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2251290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SmartDMA%20documentation%20for%20RT595%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2251290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E4%B8%8D%E6%98%AF%E4%B8%80%E4%B8%AA%E4%BB%A4%E4%BA%BA%E6%BB%A1%E6%84%8F%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E5%9C%A8%E5%BE%97%E5%88%B0%E4%BD%A0%E7%9A%84%E5%9B%9E%E7%AD%94%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E7%9F%A5%E9%81%93%E4%BA%86%E6%89%80%E6%9C%89%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E6%9D%A5%E6%BA%90%EF%BC%8C%E8%80%8C%E4%B8%94%E4%BB%8E%E4%BD%A0%E9%82%A3%E9%87%8C%E5%BE%97%E5%88%B0%E7%9A%84%E7%AD%94%E5%A4%8D%E4%B8%8E%E6%88%91%E4%B9%8B%E5%89%8D%E4%BB%8E%E4%BA%BA%E5%B7%A5%E6%99%BA%E8%83%BD%E8%81%8A%E5%A4%A9%E6%9C%BA%E5%99%A8%E4%BA%BA%E9%82%A3%E9%87%8C%E5%BE%97%E5%88%B0%E7%9A%84%E7%AD%94%E5%A4%8D%E5%87%A0%E4%B9%8E%E4%B8%80%E6%A8%A1%E4%B8%80%E6%A0%B7%E3%80%82%20%E4%BD%BF%E7%94%A8%E8%BF%99%E4%BA%9B%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%E6%89%80%E8%83%BD%E5%81%9A%E7%9A%84%E5%B0%B1%E6%98%AF%E5%88%B6%E4%BD%9C%E6%89%80%E6%8F%8F%E8%BF%B0%E9%A1%B9%E7%9B%AE%E7%9A%84%E7%B2%BE%E7%A1%AE%E5%89%AF%E6%9C%AC%E3%80%82API%20%E6%96%87%E6%A1%A3%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E6%9C%89%E5%85%B3%20SmartDMA%20%E7%9A%84%E7%AB%A0%E8%8A%82%E4%B8%8D%E5%88%B0%E4%B8%80%E9%A1%B5%E5%B0%B1%E4%B8%AD%E9%80%94%E5%81%9C%E6%AD%A2%E3%80%82%20%E5%90%8C%E6%97%B6%EF%BC%8CFlexIO%20%E7%9A%84%E6%96%87%E6%A1%A3%E8%AF%B4%E6%88%91%E4%BB%AC%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20SmartDMA%E3%80%82%E9%99%A4%E9%9D%9E%E6%88%91%E6%83%B3%E5%A4%8D%E5%88%B6%E7%85%A7%E7%9B%B8%E6%9C%BA%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%90%A6%E5%88%99%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%9C%B0%E6%96%B9%E5%8F%AF%E4%BB%A5%E6%8C%87%E5%AF%BC%E6%88%91%E5%A6%82%E4%BD%95%E6%93%8D%E4%BD%9C%E3%80%82%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%20DMA%20%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E6%88%96%E8%AF%B7%E6%B1%82%E6%9D%A5%E6%BA%90%E7%9A%84%E6%B8%85%E5%8D%95%E3%80%82%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%AE%8C%E5%85%A8%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%E3%80%82%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E8%BF%9B%E8%A1%8C%E5%88%B0%E4%B8%80%E5%8D%8A%EF%BC%8C%E7%A1%AC%E4%BB%B6%E5%B7%B2%E7%BB%8F%E5%88%B0%E4%BD%8D%EF%BC%8C%E4%BD%86%E5%88%B6%E9%80%A0%E5%95%86%E6%B2%A1%E6%9C%89%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E6%94%AF%E6%8C%81%EF%BC%8C%E8%AF%B4%E6%98%8E%E5%A6%82%E4%BD%95%E5%9C%A8%E9%9D%9E%E6%A0%87%E5%87%86%20FlexIO%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E4%BD%BF%E7%94%A8%20DMA%E3%80%82%E8%BF%99%E5%A4%AA%E4%B8%8D%E5%90%88%E7%90%86%E4%BA%86%E3%80%82%E6%88%91%E7%8E%B0%E5%9C%A8%E5%88%B0%E5%BA%95%E8%AF%A5%E6%80%8E%E4%B9%88%E5%8A%9E%EF%BC%9F%E7%94%A8%20ST%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E9%A1%B9%E7%9B%AE%EF%BC%9F%20%E6%81%A9%E6%99%BA%E6%B5%A6%E5%BF%85%E9%A1%BB%E6%8F%90%E4%BE%9B%20SmartDMA%20%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%8C%E8%87%B3%E5%B0%91%E8%A6%81%E6%8F%90%E4%BE%9B%E4%B8%80%E4%BB%BD%E5%AE%8C%E6%95%B4%E7%9A%84%20API%20%E6%96%87%E6%A1%A3%EF%BC%8C%E5%88%97%E5%87%BA%E6%89%80%E6%9C%89%E5%8A%9F%E8%83%BD%E5%92%8C%E7%BB%93%E6%9E%84%EF%BC%8C%E6%9C%80%E5%A5%BD%E8%BF%98%E8%83%BD%E6%8F%90%E4%BE%9B%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%AE%8C%E6%95%B4%E5%88%97%E8%A1%A8%E3%80%82%E7%9B%AE%E5%89%8D%E7%9A%84%E6%83%85%E5%86%B5%E6%98%AF%E4%B8%8D%E5%90%88%E7%90%86%E7%9A%84%EF%BC%8C%E4%B9%9F%E6%98%AF%E6%97%A0%E6%B3%95%E5%BF%8D%E5%8F%97%E7%9A%84%EF%BC%8C%E8%80%8C%E4%BD%A0%E4%BB%AC%E7%9A%84%E5%9B%9E%E5%BA%94%E5%8D%B4%E4%BB%A4%E4%BA%BA%E5%A4%A7%E5%A4%B1%E6%89%80%E6%9C%9B%E3%80%82%E8%87%B3%E5%B0%91%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E5%A6%82%E4%BD%95%E8%A7%A3%E9%87%8A%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E6%9C%89%E5%85%B3SmartDMA%E7%9A%84%E7%AB%A0%E8%8A%82%E7%AA%81%E7%84%B6%E6%94%BE%E5%BC%83%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SmartDMA%20documentation%20for%20RT595%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%20Sam_Gao%20%E9%97%AE%E6%88%91%E6%98%AF%E5%A6%82%E4%BD%95%E5%BE%97%E5%87%BA%22%3CEM%3EFlexIO%20%E7%9A%84%E6%96%87%E6%A1%A3%E8%AF%B4%E6%88%91%E4%BB%AC%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20SmartDMA%20%E8%BF%99%E4%B8%80%3C%2FEM%3E%E7%BB%93%E8%AE%BA%E7%9A%84%E3%80%82%22%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E5%9B%9E%E7%AD%94%E6%98%AF%EF%BC%8C%E5%9C%A8%20RT595%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%BF%AE%E8%AE%A2%E7%89%88%202%20%E7%AC%AC%202171%20%E9%A1%B5%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9C%8B%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3E51.1.2%20DMA%20%E6%94%AF%E6%8C%81%3C%2FSTRONG%3E%E5%9C%A8%E6%9C%AC%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E4%B8%8A%EF%BC%8C%E4%B8%8D%E6%94%AF%E6%8C%81%E6%A0%87%E5%87%86%20DMA%20%E4%B8%8E%20FLEXIO%20%E6%A8%A1%E5%9D%97%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%E5%BA%94%E6%94%B9%E7%94%A8%20SmartDMA%E3%80%82%E6%9C%AC%E7%AB%A0%E4%B8%AD%E5%AF%B9%E6%A0%87%E5%87%86%20DMA%20%E7%9A%84%E4%BB%BB%E4%BD%95%E5%8F%82%E8%80%83%E5%9D%87%E5%BA%94%E4%B8%8D%E4%BA%88%E8%80%83%E8%99%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
