Hello, my name is Fabian, I've been assigned to support your case.
Thank you for your interest in our products
I believe I'm not understanding your question but, I will try to explain a little the development environment for PN7462.
Regarding the question, if can be driven by USB signal, yes. We actually provide an NFC Reader Library that has a series of examples, one of them is intended to show the work using USB through PC/SC interface.
In order to use the evaluation board and, run the examples we highly recommend the use of our MCUXpresso IDE.
Fabian
