Questions about how to use the PNEV7462C development board
577 次查看
FSubvert
How to use the PNEV7462C development board to drive an NFC board with a PN7462 chip? Can it be driven by USB signal?
551 次查看
Fabian_R
Hello, my name is Fabian, I've been assigned to support your case.
Thank you for your interest in our products
I believe I'm not understanding your question but, I will try to explain a little the development environment for PN7462.
Regarding the question, if can be driven by USB signal, yes. We actually provide an NFC Reader Library that has a series of examples, one of them is intended to show the work using USB through PC/SC interface.
In order to use the evaluation board and, run the examples we highly recommend the use of our MCUXpresso IDE.
Fabian
