Problem to initialize Systick in FRDM-MCXA153 using peripherals config tool
2,072件の閲覧回数
zorrotz
I have used peripherals config tool to configure the Systick to work with cpu_clk divided by 4.
After building the project there are 2 compilation errors, due to the lack of kCPU_CLK_to_SYSTICK and kCLOCK_DivSYSTICK definitions.
I have checked that these definitions are not included in fsl_clock.h file.
Note that I use MCUxpresso IDE 25.6 and SDK 25.09.
The fsl_clock.h file of the mcux-sdk 2.16 available in github includes these definitions, but i not confident in this file because i have found some bugs, for example:
- the are some comments that are incorrect
- CLOCK_FRO12MTrimConfig() function of fsl_clock.c file has this code:
                 SCG0->SIRCSTAT = SCG_SIRCSTAT_CCOTRIM(config.cltrim);
                 SCG0->SIRCSTAT = SCG_SIRCSTAT_CCOTRIM(config.ccotrim);
    and i think that it should be:
                 SCG0->SIRCSTAT = SCG_SIRCSTAT_CLTRIM(config.cltrim);
I have also search the documentation for SDK 25.12, but these definitions are not included.
I can manually modify fsl_clock.h file, but I prefer to have a correct SDK.
Is there a SDK version for FRDM-MCXA153 which includes these definitions?
ラベル(2)
タグ(2)
2,010件の閲覧回数
Harry_Zhang
Hi @zorrotz
Yes, i have checked the code.
It is a bug.
I will report it to our SDK team.
If you want to use kCPU_CLK_to_SYSTICK and kCLOCK_DivSYSTICK.
You need to add some code in fsl_clock.h
Harry_Zhang_3-1766042710072.pngHarry_Zhang_3-1766042710072.pngHarry_Zhang_4-1766042747585.pngHarry_Zhang_4-1766042747585.png
Hope this will help you.
Harry
4 返答(返信)
2,048件の閲覧回数
Harry_Zhang
Hi  @zorrotz
I have checked the frdm_mcxa153 v25.09 SDK.
In fsl_clock.c
status_t CLOCK_FRO12MTrimConfig(sirc_trim_config_t config)
    SCG0->SIRCTCFG = SCG_SIRCTCFG_TRIMDIV(config.trimDiv) | SCG_SIRCTCFG_TRIMSRC(config.trimSrc);
    if (kSCG_SircTrimNonUpdate == config.trimMode)
        SCG0->SIRCSTAT = (SCG0->SIRCSTAT & ~SCG_SIRCSTAT_CLTRIM_MASK) | SCG_SIRCSTAT_CLTRIM(config.cltrim);
        SCG0->SIRCSTAT = (SCG0->SIRCSTAT & ~SCG_SIRCSTAT_CCOTRIM_MASK) | SCG_SIRCSTAT_CCOTRIM(config.ccotrim);
    /* Set trim mode. */
    SCG0->SIRCCSR = (SCG0->SIRCCSR & ~(SCG_SIRCCSR_SIRCTREN_MASK | SCG_SIRCCSR_SIRCTRUP_MASK)) | (uint32_t)config.trimMode;
    if ((SCG0->SIRCCSR & SCG_SIRCCSR_SIRCVLD_MASK) == 0U)
        return (status_t)kStatus_Fail;
    if ((SCG0->SIRCCSR & SCG_SIRCCSR_SIRCERR_MASK) == SCG_SIRCCSR_SIRCERR_MASK)
    if ((SCG0->SIRCCSR & SCG_SIRCCSR_TRIM_LOCK_MASK) == 0U)
    return (status_t)kStatus_Success;
You can refer to it.
Harry
2,039件の閲覧回数
zorrotz
Hi Harry
Yes, CLOCK_FRO12MTrimConfig() function in SDK v25.09 is OK, but the problem is that this SDK version doesn't have kCPU_CLK_to_SYSTICK and kCLOCK_DivSYSTICK definitions.
2,011件の閲覧回数
Harry_Zhang
Hi @zorrotz
It is a bug.
Harry
1,995件の閲覧回数
zorrotz
Thank you Harry!
I will modify fsl_clock.h file.
%3CLINGO-SUB%20id%3D%22lingo-sub-2264733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E8%A8%AD%E5%AE%9A%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6FRDM-MCXA153%E3%81%A7Systick%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E8%A8%AD%E5%AE%9A%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81Systick%20%E3%81%8C%20cpu_clk%20%E3%82%92%204%20%E3%81%A7%E5%89%B2%E3%81%A3%E3%81%A6%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%20%3CSPAN%3EkCPU_CLK_to_SYSTICK%20%E3%81%A8%20kCLOCK_DivSYSTICK%20%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%81%8C%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%812%20%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%81%8Cfsl_clock.h%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%AA%E3%81%8A%E3%80%81MCUxpresso%20IDEs%2025.6%20%E3%81%A8%20SDKs%2025.09%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Efsl_clock.hgithub%20%E3%81%A7%E5%85%A5%E6%89%8B%E5%8F%AF%E8%83%BD%E3%81%AA%20mcux-sdk%202.16%20%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%83%90%E3%82%B0%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E8%87%AA%E4%BF%A1%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BE%8B%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E-%20%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E-%20fsl_clock.c%20%E3%81%AE%20CLOCK_FRO12MTrimConfig()%20%E9%96%A2%E6%95%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCG0-%26gt%3BSIRCSTAT%20%3D%20SCG_SIRCSTAT_%20%3CFONT%20color%3D%22%23FF0000%22%3ECCOTRIM%3C%2FFONT%3E%20(config.cltrim)%3B%3CBR%20%2F%3ESCG0-%26gt%3BSIRCSTAT%20%3D%20SCG_SIRCSTAT_CCOTRIM(config.ccotrim)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AF%E3%81%93%E3%81%86%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A0%E3%81%A8%E8%80%83%E3%81%88%E3%81%BE%E3%81%99%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCG0-%26gt%3BSIRCSTAT%20%3D%20SCG_SIRCSTAT_%20%3CFONT%20color%3D%22%23FF0000%22%3ECLTRIM%3C%2FFONT%3E%20(config.cltrim)%3B%3CBR%20%2F%3ESCG0-%26gt%3BSIRCSTAT%20%3D%20SCG_SIRCSTAT_CCOTRIM(config.ccotrim)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESDK%2025.12%20%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%82%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%81%AF%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Efsl_clock.h%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7CAN%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%20SDKs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%A5%BD%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%92%E5%90%AB%E3%82%80%20FRDM-MCXA153%20%E3%81%AE%20SDK%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2264733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%7C%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCXA%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20to%20initialize%20Systick%20in%20FRDM-MCXA153%20using%20peripherals%20config%20tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59428%22%20target%3D%22_blank%22%3E%40zorrotz%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E3%83%90%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ESDK%20%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EkCPU_CLK_to_SYSTICK%20%E3%81%A8%3CSPAN%3EkCLOCK_DivSYSTICK%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1766042327334.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1766042327334.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1766042327334.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370571iBB6BAEF02471336F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1766042327334.png%22%20alt%3D%22Harry_Zhang_0-1766042327334.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1766042327334.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_2-1766042465654.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_2-1766042465654.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_2-1766042465654.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370573iB2765589F9902F1D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_2-1766042465654.png%22%20alt%3D%22Harry_Zhang_2-1766042465654.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_2-1766042465654.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_1-1766042338256.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1766042338256.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1766042338256.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370572i405EC295B6ABDCAD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_1-1766042338256.png%22%20alt%3D%22Harry_Zhang_1-1766042338256.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_1-1766042338256.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Efsl_clock.h%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_3-1766042710072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_3-1766042710072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_3-1766042710072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370574i22E81EFC9BD1CF58%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_3-1766042710072.png%22%20alt%3D%22Harry_Zhang_3-1766042710072.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_3-1766042710072.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_4-1766042747585.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_4-1766042747585.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_4-1766042747585.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370575i94E45AB45ABA1856%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_4-1766042747585.png%22%20alt%3D%22Harry_Zhang_4-1766042747585.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_4-1766042747585.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20to%20initialize%20Systick%20in%20FRDM-MCXA153%20using%20peripherals%20config%20tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81SDK%20v25.09%20%E3%81%AE%20CLOCK_FRO12MTrimConfig()%20%E9%96%A2%E6%95%B0%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%20SDK%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF%20kCPU_CLK_to_SYSTICK%20%E3%81%A8%20kCLOCK_DivSYSTICK%20%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%81%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20to%20initialize%20Systick%20in%20FRDM-MCXA153%20using%20peripherals%20config%20tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59428%22%20target%3D%22_blank%22%3E%40zorrotz%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Efrdm_mcxa153%20v25.09%20SDK%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3Efsl_clock.c%E5%86%85%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1765968291918.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1765968291918.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1765968291918.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370422i3B4D76CF66338690%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1765968291918.png%22%20alt%3D%22Harry_Zhang_0-1765968291918.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1765968291918.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Estatus_t%20CLOCK_FRO12MTrimConfig(sirc_trim_config_t%20config)%0A%7B%0A%20%20%20%20SCG0-%26gt%3BSIRCTCFG%20%3D%20SCG_SIRCTCFG_TRIMDIV(config.trimDiv)%20%7C%20SCG_SIRCTCFG_TRIMSRC(config.trimSrc)%3B%0A%0A%20%20%20%20if%20(kSCG_SircTrimNonUpdate%20%3D%3D%20config.trimMode)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20SCG0-%26gt%3BSIRCSTAT%20%3D%20(SCG0-%26gt%3BSIRCSTAT%20%26amp%3B%20~SCG_SIRCSTAT_CLTRIM_MASK)%20%7C%20SCG_SIRCSTAT_CLTRIM(config.cltrim)%3B%0A%20%20%20%20%20%20%20%20SCG0-%26gt%3BSIRCSTAT%20%3D%20(SCG0-%26gt%3BSIRCSTAT%20%26amp%3B%20~SCG_SIRCSTAT_CCOTRIM_MASK)%20%7C%20SCG_SIRCSTAT_CCOTRIM(config.ccotrim)%3B%0A%20%20%20%20%7D%0A%0A%20%20%20%20%2F*%20Set%20trim%20mode.%20*%2F%0A%20%20%20%20SCG0-%26gt%3BSIRCCSR%20%3D%20(SCG0-%26gt%3BSIRCCSR%20%26amp%3B%20~(SCG_SIRCCSR_SIRCTREN_MASK%20%7C%20SCG_SIRCCSR_SIRCTRUP_MASK))%20%7C%20(uint32_t)config.trimMode%3B%0A%0A%20%20%20%20if%20((SCG0-%26gt%3BSIRCCSR%20%26amp%3B%20SCG_SIRCCSR_SIRCVLD_MASK)%20%3D%3D%200U)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20return%20(status_t)kStatus_Fail%3B%0A%20%20%20%20%7D%0A%0A%20%20%20%20if%20((SCG0-%26gt%3BSIRCCSR%20%26amp%3B%20SCG_SIRCCSR_SIRCERR_MASK)%20%3D%3D%20SCG_SIRCCSR_SIRCERR_MASK)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20return%20(status_t)kStatus_Fail%3B%0A%20%20%20%20%7D%0A%0A%20%20%20%20if%20((SCG0-%26gt%3BSIRCCSR%20%26amp%3B%20SCG_SIRCCSR_TRIM_LOCK_MASK)%20%3D%3D%200U)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20return%20(status_t)kStatus_Fail%3B%0A%20%20%20%20%7D%0A%0A%20%20%20%20return%20(status_t)kStatus_Success%3B%0A%7D%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E9%A0%82%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266133%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20to%20initialize%20Systick%20in%20FRDM-MCXA153%20using%20peripherals%20config%20tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266133%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%83%8F%E3%83%AA%E3%83%BC%EF%BC%81%3C%2FP%3E%3CP%3Efsl_clock.h%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3C%2FLINGO-BODY%3E
