Problem to initialize Systick in FRDM-MCXA153 using peripherals config tool
2,164 次查看
zorrotz
I have used peripherals config tool to configure the Systick to work with cpu_clk divided by 4.
After building the project there are 2 compilation errors, due to the lack of kCPU_CLK_to_SYSTICK and kCLOCK_DivSYSTICK definitions.
I have checked that these definitions are not included in fsl_clock.h file.
Note that I use MCUxpresso IDE 25.6 and SDK 25.09.
The fsl_clock.h file of the mcux-sdk 2.16 available in github includes these definitions, but i not confident in this file because i have found some bugs, for example:
- the are some comments that are incorrect
- CLOCK_FRO12MTrimConfig() function of fsl_clock.c file has this code:
                 SCG0->SIRCSTAT = SCG_SIRCSTAT_CCOTRIM(config.cltrim);
                 SCG0->SIRCSTAT = SCG_SIRCSTAT_CCOTRIM(config.ccotrim);
    and i think that it should be:
                 SCG0->SIRCSTAT = SCG_SIRCSTAT_CLTRIM(config.cltrim);
I have also search the documentation for SDK 25.12, but these definitions are not included.
I can manually modify fsl_clock.h file, but I prefer to have a correct SDK.
Is there a SDK version for FRDM-MCXA153 which includes these definitions?
标签 (2)
标记 (2)
2,102 次查看
Harry_Zhang
Hi @zorrotz
Yes, i have checked the code.
It is a bug.
I will report it to our SDK team.
If you want to use kCPU_CLK_to_SYSTICK and kCLOCK_DivSYSTICK.
You need to add some code in fsl_clock.h
Hope this will help you.
Harry
4 回复数
2,140 次查看
Harry_Zhang
Hi  @zorrotz
I have checked the frdm_mcxa153 v25.09 SDK.
In fsl_clock.c
status_t CLOCK_FRO12MTrimConfig(sirc_trim_config_t config)
    SCG0->SIRCTCFG = SCG_SIRCTCFG_TRIMDIV(config.trimDiv) | SCG_SIRCTCFG_TRIMSRC(config.trimSrc);
    if (kSCG_SircTrimNonUpdate == config.trimMode)
        SCG0->SIRCSTAT = (SCG0->SIRCSTAT & ~SCG_SIRCSTAT_CLTRIM_MASK) | SCG_SIRCSTAT_CLTRIM(config.cltrim);
        SCG0->SIRCSTAT = (SCG0->SIRCSTAT & ~SCG_SIRCSTAT_CCOTRIM_MASK) | SCG_SIRCSTAT_CCOTRIM(config.ccotrim);
    /* Set trim mode. */
    SCG0->SIRCCSR = (SCG0->SIRCCSR & ~(SCG_SIRCCSR_SIRCTREN_MASK | SCG_SIRCCSR_SIRCTRUP_MASK)) | (uint32_t)config.trimMode;
    if ((SCG0->SIRCCSR & SCG_SIRCCSR_SIRCVLD_MASK) == 0U)
        return (status_t)kStatus_Fail;
    if ((SCG0->SIRCCSR & SCG_SIRCCSR_SIRCERR_MASK) == SCG_SIRCCSR_SIRCERR_MASK)
    if ((SCG0->SIRCCSR & SCG_SIRCCSR_TRIM_LOCK_MASK) == 0U)
    return (status_t)kStatus_Success;
You can refer to it.
Harry
2,131 次查看
zorrotz
Hi Harry
Yes, CLOCK_FRO12MTrimConfig() function in SDK v25.09 is OK, but the problem is that this SDK version doesn't have kCPU_CLK_to_SYSTICK and kCLOCK_DivSYSTICK definitions.
2,103 次查看
Harry_Zhang
Hi @zorrotz
It is a bug.
Harry
2,087 次查看
zorrotz
Thank you Harry!
I will modify fsl_clock.h file.
%3CLINGO-SUB%20id%3D%22lingo-sub-2264733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%E5%A4%96%E8%AE%BE%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E5%9C%A8%20FRDM-MCXA153%20%E4%B8%AD%E5%88%9D%E5%A7%8B%E5%8C%96%20Systick%20%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E5%A4%96%E8%AE%BE%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E5%B0%86%20Systick%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%BD%BF%E7%94%A8%E9%99%A4%E4%BB%A5%204%20%E7%9A%84%20cpu_clk%E3%80%82%3C%2FP%3E%3CP%3E%E6%9E%84%E5%BB%BA%E9%A1%B9%E7%9B%AE%E5%90%8E%EF%BC%8C%E7%94%B1%E4%BA%8E%E7%BC%BA%E5%B0%91%3CSPAN%3EkCPU_CLK_to_SYSTICK%20%E5%92%8C%20kCLOCK_DivSYSTICK%20%E5%AE%9A%E4%B9%89%EF%BC%8C%3C%2FSPAN%3E%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%A4%E4%B8%AA%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86fsl_clock.h%E4%B8%AD%E6%98%AF%E5%90%A6%E5%8C%85%E5%90%AB%E8%BF%99%E4%BA%9B%E5%AE%9A%E4%B9%89%E9%94%89%E5%88%80%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20MCUxpresso%20IDE%2025.6%20%E5%92%8C%20SDK%2025.09%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Efsl_clock.hgithub%20%E4%B8%8A%E7%9A%84%20mcux-sdk%202.16%20%E6%96%87%E4%BB%B6%E5%8C%85%E5%90%AB%E8%BF%99%E4%BA%9B%E5%AE%9A%E4%B9%89%EF%BC%8C%E4%BD%86%E6%88%91%E5%AF%B9%E8%AF%A5%E6%96%87%E4%BB%B6%E6%B2%A1%E6%9C%89%E4%BF%A1%E5%BF%83%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E5%8F%91%E7%8E%B0%E4%BA%86%E4%B8%80%E4%BA%9B%20bug%EF%BC%8C%E4%BE%8B%E5%A6%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E-%20%E6%9C%89%E4%BA%9B%E8%AF%84%E8%AE%BA%E6%98%AF%E9%94%99%E8%AF%AF%E7%9A%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E-%20fsl_clock.c%20%E7%9A%84%20CLOCK_FRO12MTrimConfig()%20%E5%87%BD%E6%95%B0%E6%96%87%E4%BB%B6%E4%B8%AD%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20SCG0-%26gt%3BSIRCSTAT%20%3D%3CFONT%20color%3D%22%23FF0000%22%3ESCG_SIRCSTAT_CCOTRIM%3C%2FFONT%3E(config.cltrim)%3B%3CBR%20%2F%3E%20SCG0-%26gt%3BSIRCSTAT%20%3D%20SCG_SIRCSTAT_CCOTRIM%EF%BC%88config.ccotrim%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%20%20%20%E6%88%91%E8%AE%A4%E4%B8%BA%E5%BA%94%E8%AF%A5%E5%A6%82%E6%AD%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20SCG0-%26gt%3BSIRCSTAT%20%3D%3CFONT%20color%3D%22%23FF0000%22%3ESCG_SIRCSTAT_CLTRIM%3C%2FFONT%3E(config.cltrim)%3B%3CBR%20%2F%3E%20SCG0-%26gt%3BSIRCSTAT%20%3D%20SCG_SIRCSTAT_CCOTRIM%EF%BC%88config.ccotrim%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E8%BF%98%E6%90%9C%E7%B4%A2%E4%BA%86%20SDK%2025.12%20%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E5%8C%85%E6%8B%AC%E8%BF%99%E4%BA%9B%E5%AE%9A%E4%B9%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E6%89%8B%E5%8A%A8%E4%BF%AE%E6%94%B9%20fsl_clock.h%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E6%88%91%E6%9B%B4%E5%B8%8C%E6%9C%9B%E6%9C%89%E4%B8%80%E4%B8%AA%E6%AD%A3%E7%A1%AE%E7%9A%84%20SDK%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%8C%85%E5%90%AB%E8%BF%99%E4%BA%9B%E5%AE%9A%E4%B9%89%E7%9A%84%20FRDM-MCXA153%20SDK%20%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2264733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%97%B6%E9%92%9F%7C%E8%AE%A1%E6%97%B6%E5%99%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCXA%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20to%20initialize%20Systick%20in%20FRDM-MCXA153%20using%20peripherals%20config%20tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59428%22%20target%3D%22_blank%22%3E%40zorrotz%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%90%91%E6%88%91%E4%BB%AC%E7%9A%84%20SDK%20%E5%9B%A2%E9%98%9F%E6%8A%A5%E5%91%8A%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E8%A6%81%E4%BD%BF%E7%94%A8%20kCPU_CLK_to_SYSTICK%20%E5%92%8C%3CSPAN%3EkCLOCK_DivSYSTICK%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1766042327334.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1766042327334.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1766042327334.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370571iBB6BAEF02471336F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1766042327334.png%22%20alt%3D%22Harry_Zhang_0-1766042327334.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_2-1766042465654.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_2-1766042465654.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_2-1766042465654.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370573iB2765589F9902F1D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_2-1766042465654.png%22%20alt%3D%22Harry_Zhang_2-1766042465654.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_1-1766042338256.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1766042338256.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1766042338256.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370572i405EC295B6ABDCAD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_1-1766042338256.png%22%20alt%3D%22Harry_Zhang_1-1766042338256.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%82%A8%E9%9C%80%E8%A6%81%E5%9C%A8%20fsl_clock.h%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%B8%80%E4%BA%9B%E4%BB%A3%E7%A0%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_3-1766042710072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_3-1766042710072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_3-1766042710072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370574i22E81EFC9BD1CF58%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_3-1766042710072.png%22%20alt%3D%22Harry_Zhang_3-1766042710072.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_4-1766042747585.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_4-1766042747585.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_4-1766042747585.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370575i94E45AB45ABA1856%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_4-1766042747585.png%22%20alt%3D%22Harry_Zhang_4-1766042747585.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20to%20initialize%20Systick%20in%20FRDM-MCXA153%20using%20peripherals%20config%20tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%93%88%E9%87%8C%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8CSDK%20v25.09%20%E4%B8%AD%E7%9A%84%20CLOCK_FRO12MTrimConfig()%20%E5%87%BD%E6%95%B0%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E9%97%AE%E9%A2%98%E6%98%AF%E8%AF%A5%20SDK%20%E7%89%88%E6%9C%AC%E6%B2%A1%E6%9C%89%20kCPU_CLK_to_SYSTICK%20%E5%92%8C%20kCLOCK_DivSYSTICK%20%E5%AE%9A%E4%B9%89%E3%80%82%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20to%20initialize%20Systick%20in%20FRDM-MCXA153%20using%20peripherals%20config%20tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59428%22%20target%3D%22_blank%22%3E%40zorrotz%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%20frdm_mcxa153%20v25.09%20SDK%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%20fsl_clock.c%20%E4%B8%AD%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1765968291918.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1765968291918.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1765968291918.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370422i3B4D76CF66338690%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1765968291918.png%22%20alt%3D%22Harry_Zhang_0-1765968291918.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Estatus_t%20CLOCK_FRO12MTrimConfig(sirc_trim_config_t%20config)%0A%7B%0A%20%20%20%20SCG0-%26gt%3BSIRCTCFG%20%3D%20SCG_SIRCTCFG_TRIMDIV(config.trimDiv)%20%7C%20SCG_SIRCTCFG_TRIMSRC(config.trimSrc)%3B%0A%0A%20%20%20%20if%20(kSCG_SircTrimNonUpdate%20%3D%3D%20config.trimMode)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20SCG0-%26gt%3BSIRCSTAT%20%3D%20(SCG0-%26gt%3BSIRCSTAT%20%26amp%3B%20~SCG_SIRCSTAT_CLTRIM_MASK)%20%7C%20SCG_SIRCSTAT_CLTRIM(config.cltrim)%3B%0A%20%20%20%20%20%20%20%20SCG0-%26gt%3BSIRCSTAT%20%3D%20(SCG0-%26gt%3BSIRCSTAT%20%26amp%3B%20~SCG_SIRCSTAT_CCOTRIM_MASK)%20%7C%20SCG_SIRCSTAT_CCOTRIM(config.ccotrim)%3B%0A%20%20%20%20%7D%0A%0A%20%20%20%20%2F*%20Set%20trim%20mode.%20*%2F%0A%20%20%20%20SCG0-%26gt%3BSIRCCSR%20%3D%20(SCG0-%26gt%3BSIRCCSR%20%26amp%3B%20~(SCG_SIRCCSR_SIRCTREN_MASK%20%7C%20SCG_SIRCCSR_SIRCTRUP_MASK))%20%7C%20(uint32_t)config.trimMode%3B%0A%0A%20%20%20%20if%20((SCG0-%26gt%3BSIRCCSR%20%26amp%3B%20SCG_SIRCCSR_SIRCVLD_MASK)%20%3D%3D%200U)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20return%20(status_t)kStatus_Fail%3B%0A%20%20%20%20%7D%0A%0A%20%20%20%20if%20((SCG0-%26gt%3BSIRCCSR%20%26amp%3B%20SCG_SIRCCSR_SIRCERR_MASK)%20%3D%3D%20SCG_SIRCCSR_SIRCERR_MASK)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20return%20(status_t)kStatus_Fail%3B%0A%20%20%20%20%7D%0A%0A%20%20%20%20if%20((SCG0-%26gt%3BSIRCCSR%20%26amp%3B%20SCG_SIRCCSR_TRIM_LOCK_MASK)%20%3D%3D%200U)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20return%20(status_t)kStatus_Fail%3B%0A%20%20%20%20%7D%0A%0A%20%20%20%20return%20(status_t)kStatus_Success%3B%0A%7D%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266133%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20to%20initialize%20Systick%20in%20FRDM-MCXA153%20using%20peripherals%20config%20tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266133%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%E5%93%88%E9%87%8C%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E4%BF%AE%E6%94%B9%20fsl_clock.h%E9%94%89%E5%88%80%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3C%2FLINGO-BODY%3E
