MCXA153VLH ADC trigger
1,206 次查看
_Ferrari_
I am developing a project based on the MCXA153VLH microprocessor and I need to sample an analog signal at regular time intervals.
I thought about using a timer to act as a trigger to start the conversion. At the end of the conversion, the analog-to-digital converter should generate an interrupt to signal the end of the conversion and the availability of the data to be converted.
I have already used a similar technique with the LPC5526 microprocessor with excellent results. In that project, I used timer 4, associating the start of the conversion with trigger 9.
Unfortunately, I cannot find which trigger number is associated with a timer that starts the AD conversion on the MCXA153VLH microprocessor.
Could you provide me with detailed information?
Thank you and have a good day.
标记 (3)
867 次查看
5 回复数
1,151 次查看
Hello @_Ferrari_
There is also a timer-triggered ADC on the MCXA153; please refer to it.
MCXA153 RM ->
 13.5.1.11 ADC Trigger input connections (ADC0_TRIG0 - ADC0_TRIG3)
Alice
1,139 次查看
_Ferrari_
Thank you very much for your answer.
Just another question: what is the correct number to put in the ADC trigger configuration
to have CTimer0_MAT0 as ADC input trigger ?
Thank you for your help and cooperation,
regards
标记 (3)
1,098 次查看
Hello @_Ferrari_
The MCXA153 features four ADC trigger input registers, namely ADC0_TRIG0 to ADC0_TRIG3. You can utilize any one of these registers, meaning you can input values 0, 1, 2, or 3.
Thank you.
Alice
1,079 次查看
_Ferrari_
Thank you for your answer!
I need to write a number from zero to 3, which identifies one of the registers:
0 for ADC0_TRIG0
 1 for ADC0_TRIG1
2 for ADC0_TRIG2
3 for ADC0_TRIG3
If I've understood correctly, into one of these registers, for example ADC0_TRIG0, I need to write the TRIGIN data, which should be 00_1001b (CTimer0_MAT0 input is selected).
I can't figure out how to write the 00_1001b data into the ADC0_TRIG0 register using the Peripherals tool in MCUXpresso IDE.
Could you please explain how to do it?
Thanks, and have a good day.
标记 (3)
868 次查看
%3CLINGO-SUB%20id%3D%22lingo-sub-2155041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCXA153VLH%20ADC%20%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%8F%91%E4%B8%80%E4%B8%AA%E5%9F%BA%E4%BA%8E%20MCXA153VLH%20%E5%BE%AE%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E5%AE%9A%E6%9C%9F%E5%AF%B9%E6%A8%A1%E6%8B%9F%E4%BF%A1%E5%8F%B7%E8%BF%9B%E8%A1%8C%E9%87%87%E6%A0%B7%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9B%BE%E8%80%83%E8%99%91%E8%BF%87%E4%BD%BF%E7%94%A8%E8%AE%A1%E6%97%B6%E5%99%A8%E4%BD%9C%E4%B8%BA%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E6%9D%A5%E5%BC%80%E5%A7%8B%E8%BD%AC%E6%8D%A2%E3%80%82%E5%9C%A8%E8%BD%AC%E6%8D%A2%E7%BB%93%E6%9D%9F%E6%97%B6%EF%BC%8C%E6%A8%A1%E6%8B%9F-%E6%95%B0%E5%AD%97%E5%8F%98%E6%B5%81%E5%99%A8%E5%BA%94%E4%BA%A7%E7%94%9F%E4%B8%AD%E6%96%AD%EF%BC%8C%E4%BB%A5%E8%A1%A8%E6%98%8E%E8%BD%AC%E6%8D%A2%E7%BB%93%E6%9D%9F%E4%BB%A5%E5%8F%8A%E5%BE%85%E8%BD%AC%E6%8D%A2%E6%95%B0%E6%8D%AE%E7%9A%84%E5%8F%AF%E7%94%A8%E6%80%A7%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%20LPC5526%20%E5%BE%AE%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%8A%E4%BD%BF%E7%94%A8%E8%BF%87%E7%B1%BB%E4%BC%BC%E7%9A%84%E6%8A%80%E6%9C%AF%EF%BC%8C%E6%95%88%E6%9E%9C%E9%9D%9E%E5%B8%B8%E5%A5%BD%E3%80%82%E5%9C%A8%E9%82%A3%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E8%AE%A1%E6%97%B6%E5%99%A8%204%EF%BC%8C%E5%B0%86%E8%BD%AC%E6%8D%A2%E7%9A%84%E5%BC%80%E5%A7%8B%E4%B8%8E%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%209%20%E7%9B%B8%E5%85%B3%E8%81%94%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E5%93%AA%E4%B8%AA%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E4%B8%8E%E5%9C%A8%20MCXA153VLH%20%E5%BE%AE%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%8A%E5%90%AF%E5%8A%A8%20AD%20%E8%BD%AC%E6%8D%A2%E7%9A%84%E8%AE%A1%E6%97%B6%E5%99%A8%E7%9B%B8%E5%85%B3%E8%81%94%E3%80%82%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%EF%BC%8C%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2155041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EMCXA%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159087%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXA153VLH%20%20ADC0%20TRIGGER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159087%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202847%22%20target%3D%22_blank%22%3E%40_Ferrari_%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%A6%E7%BB%86%E6%AD%A5%E9%AA%A4%E8%AF%B7%E5%8F%82%E9%98%85%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-Config-Tools%2FLPC553x-configure-ADC-hardware-trigger-sources%2Fm-p%2F1731393%23M1731%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-Config-Tools%2FLPC553x-configure-ADC-hardware-trigger-sources%2Fm-p%2F1731393%23M1731%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1756289139928.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1756289139928.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F354365i33F54ADA622C7AAA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1756289139928.png%22%20alt%3D%22Alice_Yang_0-1756289139928.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3EMCXA153VLH%20%20ADC0%20TRIGGER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E5%86%99%E5%85%A5%E4%B8%80%E4%B8%AA%E4%BB%8E%200%20%E5%88%B0%203%20%E7%9A%84%E6%95%B0%E5%AD%97%EF%BC%8C%E7%94%A8%E6%9D%A5%E6%A0%87%E8%AF%86%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A%3CBR%20%2F%3E0%20%E4%BB%A3%E8%A1%A8%20ADC0_TRIG0%3CBR%20%2F%3E%201%20%E4%BB%A3%E8%A1%A8%20ADC0_TRIG1%3CBR%20%2F%3E2%20%E4%BB%A3%E8%A1%A8%20ADC0_TRIG2%3CBR%20%2F%3E3%20%E4%BB%A3%E8%A1%A8%20ADC0_TRIG3%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E6%B2%A1%E6%9C%89%E7%90%86%E8%A7%A3%E9%94%99%E7%9A%84%E8%AF%9D%EF%BC%8C%E5%9C%A8%E8%BF%99%E4%BA%9B%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%EF%BC%8C%E4%BE%8B%E5%A6%82%20ADC0_TRIG0%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E5%86%99%E5%85%A5%20TRIGIN%20%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%AE%83%E5%BA%94%E8%AF%A5%E6%98%AF%2000_1001b%EF%BC%88%E9%80%89%E6%8B%A9%20CTimer0_MAT0%20%E8%BE%93%E5%85%A5%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20MCUXpresso%20IDE%20%E4%B8%AD%E7%9A%84%E5%A4%96%E8%AE%BE%E5%B7%A5%E5%85%B7%E5%B0%86%2000_1001b%20%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%20ADC0_TRIG0%20%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E5%A6%82%E4%BD%95%E6%93%8D%E4%BD%9C%EF%BC%9F%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXA153VLH%20%20ADC%20trigger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202847%22%20target%3D%22_blank%22%3E%40_Ferrari_%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMCXA153%20%E5%85%B7%E6%9C%89%E5%9B%9B%E4%B8%AA%20ADC%20%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E8%BE%93%E5%85%A5%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E5%8D%B3%20ADC0_TRIG0%20%E8%87%B3%20ADC0_TRIG3%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%BF%99%E4%BA%9B%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E7%9A%84%E4%BB%BB%E6%84%8F%E4%B8%80%E4%B8%AA%EF%BC%8C%E4%B9%9F%E5%B0%B1%E6%98%AF%E8%AF%B4%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%BE%93%E5%85%A5%E5%80%BC%200%E3%80%811%E3%80%812%20%E6%88%96%203%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3EMCXA153VLH%20%20ADC%20trigger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%E5%9C%A8%20ADC%20%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E9%85%8D%E7%BD%AE%E4%B8%AD%E8%BE%93%E5%85%A5%E7%9A%84%E6%AD%A3%E7%A1%AE%E6%95%B0%E5%AD%97%E6%98%AF%E5%A4%9A%E5%B0%91%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22_Ferrari__1-1755778454494.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22_Ferrari__1-1755778454494.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F353519i4C9E5146EDC9B2E0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22_Ferrari__1-1755778454494.png%22%20alt%3D%22_Ferrari__1-1755778454494.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%AE%A9%20ctimer0_mat0%20%E4%BD%9C%E4%B8%BA%20ADC%20%E8%BE%93%E5%85%A5%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E4%B8%8E%E5%90%88%E4%BD%9C%E3%80%81%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXA153VLH%20%20ADC%20trigger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202847%22%20target%3D%22_blank%22%3E%40_Ferrari_%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMCXA153%20%E4%B8%8A%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E5%AE%9A%E6%97%B6%E5%99%A8%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E7%9A%84%20ADC%EF%BC%9B%E8%AF%B7%E5%8F%82%E8%80%83%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EMCXA153%20RM%20-%26gt%3B%3C%2FP%3E%0A%3CP%3E13.5.1.11ADC%20%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E8%BE%93%E5%85%A5%E8%BF%9E%E6%8E%A5%20(ADC0_TRIG0-ADC0_TRIG3)%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1755771953163.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1755771953163.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F353506i5EB1D676DB4A03DE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1755771953163.png%22%20alt%3D%22Alice_Yang_0-1755771953163.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
