MCX N947 IFR MAP
MCX N947 IFR MAP
stejen
Hello, in the reference manual of the MCX N947 is stated:
For all details related to CMPA and CFPA, including their fields and address settings, see the IFR map file MCXNx4x_PFR_Fusemap.xlsx, attached to this document.
However, I can not find that document anywhere. It is not inside the reference manual and  not downloadble anywhere either.
I would like to learn more and have a reference of all the CMPA/CFPA fields and their meanings. But I can not find a comprehensive list for my MCU.
Any help would be appreciated,
carlos_o
Hi @stejen,
Thanks for your post,
The MCXNx4x_IFR_Fusemap.xlsx is attached to the MCX Nx4x Security Reference Manual, apologies the confusion.
A recommendation is to use pdf reader like acrobat reader to see the attached files.
carlos_o
Hi @stejen,
marek-trmac
Hi @stejen
you can download Secure Provisioning Tool, that allows to edit the CMPA/CFPA fields. The tool provides simple description for each value. The tool also allows to create bin file from the configuration and/or apply the configuration to chip.
The tool can be downloaded from https://nxp.com/mcuxpresso/secure
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
%3CLINGO-SUB%20id%3D%22lingo-sub-2206784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCX%20N947%20IFR%20MAP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2206784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20in%20the%20reference%20manual%20of%20the%20MCX%20N947%20is%20stated%3A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22%22%3EFor%20all%20details%20related%20to%20CMPA%20and%20CFPA%2C%20including%20their%20fields%20and%20address%20settings%2C%20see%20the%20IFR%20map%20file%20MCXNx4x_PFR_Fusemap.xlsx%2C%20attached%20to%20this%20document.%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20class%3D%22%22%3EHowever%2C%20I%20can%20not%20find%20that%20document%20anywhere.%20It%20is%20not%20inside%20the%20reference%20manual%20and%26nbsp%3B%20not%20downloadble%20anywhere%20either.%3C%2FP%3E%3CP%20class%3D%22%22%3EI%20would%20like%20to%20learn%20more%20and%20have%20a%20reference%20of%20all%20the%20CMPA%2FCFPA%20fields%20and%20their%20meanings.%20But%20I%20can%20not%20find%20a%20comprehensive%20list%20for%20my%20MCU.%3C%2FP%3E%3CP%20class%3D%22%22%3EAny%20help%20would%20be%20appreciated%2C%3C%2FP%3E%3CP%20class%3D%22%22%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2206784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EMCXN%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2206993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCX%20N947%20IFR%20MAP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2206993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251666%22%20target%3D%22_blank%22%3E%40stejen%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post%2C%3C%2FP%3E%0A%3CP%3EThe%26nbsp%3BMCXNx4x_IFR_Fusemap.xlsx%20is%20attached%20to%20the%20%3CSTRONG%3EMCX%20Nx4x%20Security%20Reference%20Manual%3C%2FSTRONG%3E%2C%20apologies%20the%20confusion.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EA%20recommendation%20is%20to%20use%20pdf%20reader%20like%20acrobat%20reader%20to%20see%20the%20attached%20files.%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2206871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCX%20N947%20IFR%20MAP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2206871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251666%22%20target%3D%22_blank%22%3E%40stejen%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Eyou%20can%20download%20Secure%20Provisioning%20Tool%2C%20that%20allows%20to%20edit%20the%20CMPA%2FCFPA%20fields.%20The%20tool%20provides%20simple%20description%20for%20each%20value.%20The%20tool%20also%20allows%20to%20create%20bin%20file%20from%20the%20configuration%20and%2For%20apply%20the%20configuration%20to%20chip.%3C%2FP%3E%0A%3CP%3EThe%20tool%20can%20be%20downloaded%20from%20%3CA%20href%3D%22https%3A%2F%2Fnxp.com%2Fmcuxpresso%2Fsecure%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.com%2Fmcuxpresso%2Fsecure%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
