MCX-N947 How to output 8080 8-bit data for LCD(RGB565)
1,039 次查看
billie
I'm going to use new LCD which has 8080 8-bit interface with MCXN947.
So, I'd like to check 8080 8-bit data output of MCXN947 with LCD-PAR-S035.
As you know, LCD-PAR-S035 can be changed 8080 8-bit mode from 16-bit mode.
So, I changed that fsl_flexio_mculcd.h and pin_mux.c.
- fsl_flexio_mculcd.h : #define FLEXIO_MCULCD_DATA_BUS_WIDTH 8UL
- pin_mux.c : Flexio_D16 ~ FlexIO_D23.
However, I can't see correct output on the LCD(LCD-PAR-S035) like attached images.
Please let me what to fix in order to get correct output.
Billy(Seongjin)
960 次查看
billie
Hi Celeste,
8080 8-bit bus data output of N947 is confirmed.
Thanks for your support.
Billy(Seongjin)
7 回复数
1,008 次查看
Celeste_Liu
Hello @billie ,
Thanks for your post. Could you let me know which demo you are using and the version of the SDK? I will help you check it out.
BRs,
Celeste
1,000 次查看
billie
Hi Celeste,
Here are the version of SDK and demo example.
In my testing, latest version SDK doesn't work with LCD-PAR-S035.
  • SDK : SDK_2_x_MCX-N9XX-EVK - 2.16.000
  • Demo example :  mcxn9xxevk_lvgl_demo_benchmark_bm
Billy(Seongjin)
973 次查看
Celeste_Liu
Hello @billie ,
Thanks for your information. I'm still working on this. Please allow me more time and I'll let you know as soon as I have any progress.
BRs,
Celeste
961 次查看
billie
Hi Celeste,
Billy(Seongjin)
136 次查看
xiaobai_226
I also encountered this problem. Could you please tell me how to modify the code in the sdk? Could you teach me how to do it? Thank you
标记 (1)
113 次查看
xiaobai_226
After reading your article, I solved the pin problem. Thank you for sharing. Thank you
953 次查看
Celeste_Liu
Hello @billie ,
Thank you for your sharing. As you said, I will close this thread. If there are any new issues, please feel free to create a new post.
BRs,
Celeste
%3CLINGO-SUB%20id%3D%22lingo-sub-2144139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCX-N947%20%E5%A6%82%E4%BD%95%E4%B8%BA%20LCD%EF%BC%88RGB565%EF%BC%89%E8%BE%93%E5%87%BA%208080%208%20%E4%BD%8D%E6%95%B0%E6%8D%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20MCXN947%20%E7%9A%84%208080%208%20%E4%BD%8D%E6%8E%A5%E5%8F%A3%E7%9A%84%E6%96%B0%E5%9E%8B%20LCD%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%83%B3%E7%94%A8%20LCD-PAR-S035%20%E6%A3%80%E6%9F%A5%20MCXN947%20%E7%9A%84%208080%208%20%E4%BD%8D%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E3%80%82%3C%2FP%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E9%83%BD%E7%9F%A5%E9%81%93%EF%BC%8CLCD-PAR-S035%20%E5%8F%AF%E4%BB%A5%E4%BB%8E%2016%20%E4%BD%8D%E6%A8%A1%E5%BC%8F%E6%9B%B4%E6%94%B9%E4%B8%BA%208080%208%20%E4%BD%8D%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BF%AE%E6%94%B9%E4%BA%86%20fsl_flexio_mculcd.h%20%E5%92%8C%20pin_mux.c%E3%80%82%3C%2FP%3E%3CP%3E-%20fsl_flexio_mculcd.h%20%EF%BC%9A%23define%3CSPAN%3EFLEXIO_MCULCD_DATA_BUS_WIDTH%208UL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E-%20pin_mux.c%20%3A%20Flexio_D16%20~%20FlexIO_D23%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E5%9C%A8%20LCD%EF%BC%88LCD-PAR-S035%EF%BC%89%E4%B8%8A%E7%9C%8B%E4%B8%8D%E5%88%B0%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%BE%93%E5%87%BA%EF%BC%8C%E5%B0%B1%E5%83%8F%E9%99%84%E5%9B%BE%E4%B8%80%E6%A0%B7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E4%BF%AE%E6%AD%A3%E6%89%8D%E8%83%BD%E8%8E%B7%E5%BE%97%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%BE%93%E5%87%BA%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%AF%94%E5%88%A9%EF%BC%88%E6%88%90%E8%BF%9B%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2144139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EMCX%20N%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCX-N947%20How%20to%20output%208080%208-bit%20data%20for%20LCD(RGB565)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195598%22%20target%3D%22_blank%22%3E%40billie%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%88%86%E4%BA%AB%E3%80%82%E5%A6%82%E6%82%A8%E6%89%80%E8%AF%B4%EF%BC%8C%E6%88%91%E5%B0%86%E5%85%B3%E9%97%AD%E6%AD%A4%E4%B8%BB%E9%A2%98%E3%80%82%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BB%BB%E4%BD%95%E6%96%B0%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E9%9A%8F%E6%97%B6%E5%88%9B%E5%BB%BA%E6%96%B0%E5%B8%96%E3%80%82%3C%2FP%3E%0A%3CP%3EBRs%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E8%8E%B1%E6%96%AF%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCX-N947%20How%20to%20output%208080%208-bit%20data%20for%20LCD(RGB565)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CSPAN%3E%EF%BC%8C%E5%A1%9E%E8%8E%B1%E6%96%AF%E7%89%B9%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E8080%20%E5%B7%B2%E7%A1%AE%E8%AE%A4%20N947%20%E7%9A%84%208%20%E4%BD%8D%E6%80%BB%E7%BA%BF%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%AF%94%E5%88%A9%EF%BC%88%E6%88%90%E8%BF%9B%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCX-N947%20How%20to%20output%208080%208-bit%20data%20for%20LCD(RGB565)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195598%22%20target%3D%22_blank%22%3E%40billie%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%20%E6%88%91%E8%BF%98%E5%9C%A8%E5%8A%AA%E5%8A%9B%E3%80%82%E8%AF%B7%E7%BB%99%E6%88%91%E6%9B%B4%E5%A4%9A%E7%9A%84%E6%97%B6%E9%97%B4%EF%BC%8C%E4%B8%80%E6%9C%89%E8%BF%9B%E5%B1%95%E6%88%91%E5%B0%B1%E4%BC%9A%E9%80%9A%E7%9F%A5%E4%BD%A0%E4%BB%AC%E3%80%82%20%3C%2FP%3E%0A%3CP%3EBRs%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E8%8E%B1%E6%96%AF%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCX-N947%20How%20to%20output%208080%208-bit%20data%20for%20LCD(RGB565)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%A1%9E%E8%8E%B1%E6%96%AF%E7%89%B9%E3%80%81%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%20SDK%20%E7%89%88%E6%9C%AC%E5%92%8C%E6%BC%94%E7%A4%BA%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9A%84%E6%B5%8B%E8%AF%95%E4%B8%AD%EF%BC%8C%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20SDK%20%E6%97%A0%E6%B3%95%E4%B8%8E%20LCD-PAR-S035%20%E9%85%8D%E5%90%88%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3ESDK%20%3A%20SDK_2_x_MCX-N9XX-EVK%20-%202.16.000%3C%2FLI%3E%3CLI%3E%E6%BC%94%E7%A4%BA%E7%A4%BA%E4%BE%8B%EF%BC%9Amcxn9xxevk_lvgl_demo_benchmark_bm%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%AF%94%E5%88%A9%EF%BC%88%E6%88%90%E8%BF%9B%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146101%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCX-N947%20How%20to%20output%208080%208-bit%20data%20for%20LCD(RGB565)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146101%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195598%22%20target%3D%22_blank%22%3E%40billie%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%20%3CSPAN%3E%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E6%BC%94%E7%A4%BA%E7%89%88%E4%BB%A5%E5%8F%8A%20SDK%20%E7%9A%84%E7%89%88%E6%9C%AC%E5%90%97%EF%BC%9F%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B8%AE%E4%BD%A0%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBRs%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E8%A5%BF%E8%8E%B1%E6%96%AF%E7%89%B9%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2253594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCX-N947%20How%20to%20output%208080%208-bit%20data%20for%20LCD(RGB565)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E8%83%BD%E5%90%A6%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E4%BF%AE%E6%94%B9%20sdk%20%E4%B8%AD%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9F%E4%BD%A0%E8%83%BD%E6%95%99%E6%88%91%E6%80%8E%E4%B9%88%E5%81%9A%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2253605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCX-N947%20How%20to%20output%208080%208-bit%20data%20for%20LCD(RGB565)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%AF%BB%E4%BA%86%E6%82%A8%E7%9A%84%E6%96%87%E7%AB%A0%E5%90%8E%EF%BC%8C%E6%88%91%E8%A7%A3%E5%86%B3%E4%BA%86%E9%92%88%E8%84%9A%E9%97%AE%E9%A2%98%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%88%86%E4%BA%AB%E3%80%82%E8%B0%A2%E8%B0%A2%3C%2FLINGO-BODY%3E
