Virtualbox
Virtualbox
Peter19
#Linkserver MCUXPRESSO-VSC
I get problems starting a debug session on win vbox vm.
Anyone tried this?
Labels (2)
Peter19
@Harry_Zhang
Hello, I’m attempting to debug the FRDM‑MCXN947 board using the MCUXpresso VS Code extension (v25.11.16) with LinkServer as the debug probe.
My environment is:
  • Host OS: Windows 11
  • Guest OS: Windows 11 (VirtualBox VM)
  • MCUXpresso VS Code extension: 25.11.16
  • Debug probe: LinkServer
  • Target board: FRDM‑MCXN947
Problem: When I start a debug session inside the VM, the session fails to launch. The extension is installed correctly, but the debugger does not connect to the target.
Question: Has anyone successfully run LinkServer debugging in this configuration (Windows 11 host + Windows 11 guest in VirtualBox)? Are there known limitations or required configuration steps for USB passthrough or driver setup in VirtualBox that affect LinkServer?
Thanks for any guidance.
Harry_Zhang
Hi @Peter19
LinkServer requires low-level USB/HID access, but VirtualBox USB passthrough is unstable for HID-class debug probes.
So i think LinkServer debugging rarely works reliably inside VirtualBox.
I think you can try to  Debug on the HOST, not the VB
you can use MCUXpresso IDE on Host or MCUXpresso VS Code extension on Host.
Harry
Harry_Zhang
Hi @Peter19
Can you describe your issue in detail?
Harry
