MCX-N947: 1 MHz clock (sirc_1mhz, clk_1M)
805 次查看
ygrayne
According to the block diagram on page 1221 of the reference manual for the MCX-N947, the clock 'sirc_1mhz' is always on. SysTick and CTIMER allow to select this clock, assuming 'clk-1M' is this SIRC-derived 1 MHz clock (is it?). However, neither SysTick nor CTIMER work with this clock selected. Both work with other clock selections.
Do I miss something to enable the 1 MHz clock, despite the aforementioned block diagram?
FWIW, a similar block diagram can be found in the ref manual for the MCX-A346, and on this MCU the 1 MHz clock is always on (called 'CLK_1M' there, in the diagram 'sirc_1mhz').
Thanks.
778 次查看
Harry_Zhang
Hi @ygrayne
"According to the block diagram on page 1221 of the reference manual for the MCX-N947, the clock 'sirc_1mhz' is always on. "
No, you need to enable this clock.
SYSCON->CLOCK_CTRL |=  SYSCON_CLOCK_CTRL_FRO1MHZ_CLK_ENA_MASK;                 /*!< Enable FRO_1M is on */
"SysTick and CTIMER allow to select this clock, assuming 'clk-1M' is this SIRC-derived 1 MHz clock (is it?)."
Yes, you are right.
I think you can refer to this code.
CLOCK_AttachClk(kCLK_1M_to_SYSTICK0);                 /*!< Switch SYSTICK0 to CLK_1M */
CLOCK_AttachClk(kCLK_1M_to_CTIMER0);                 /*!< Switch CTIMER0 to CLK_1M */
Hope this will help you.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2204757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCX-N947%EF%BC%9A1%20MHz%20%E6%97%B6%E9%92%9F%EF%BC%88sirc_1mhz%E3%80%81clk_1M%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%A0%B9%E6%8D%AE%20MCX-N947%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E7%AC%AC%201221%20%E9%A1%B5%E7%9A%84%E6%96%B9%E6%A1%86%E5%9B%BE%EF%BC%8C%E6%97%B6%E9%92%9F%20%E2%80%9Csirc_1mhz%E2%80%9D%20%E5%A7%8B%E7%BB%88%E5%A4%84%E4%BA%8E%E5%BC%80%E5%90%AF%E7%8A%B6%E6%80%81%E3%80%82SysTick%20%E5%92%8C%20CTIMER%20%E5%85%81%E8%AE%B8%E9%80%89%E6%8B%A9%E8%AF%A5%E6%97%B6%E9%92%9F%EF%BC%8C%E5%81%87%E8%AE%BE%20%22clk-1M%20%22%E6%98%AF%E6%BA%90%E8%87%AA%20SIRC%20%E7%9A%84%201%20MHz%20%E6%97%B6%E9%92%9F%EF%BC%88%E6%98%AF%E5%90%97%EF%BC%9F%EF%BC%89%E4%BD%86%E6%98%AF%EF%BC%8C%E9%80%89%E6%8B%A9%E6%AD%A4%E6%97%B6%E9%92%9F%E5%90%8E%EF%BC%8CSyStick%20%E6%88%96%E9%9D%9E%20CTIMER%20%E9%83%BD%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E4%B8%A4%E8%80%85%E5%9D%87%E5%8F%AF%E4%B8%8E%E5%85%B6%E4%BB%96%E6%97%B6%E9%92%9F%E9%80%89%E6%8B%A9%E9%85%8D%E5%90%88%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%BD%E7%AE%A1%E6%9C%89%E4%B8%8A%E8%BF%B0%E6%A1%86%E5%9B%BE%EF%BC%8C%E4%BD%86%E6%88%91%E6%98%AF%E5%90%A6%E6%BC%8F%E6%8E%89%E4%BA%86%E5%90%AF%E7%94%A8%201%20MHz%20%E6%97%B6%E9%92%9F%E7%9A%84%E6%9F%90%E4%BA%9B%E4%BF%A1%E6%81%AF%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E6%8F%90%E4%B8%80%E4%B8%8B%EF%BC%8CMCX-A346%20%E7%9A%84%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E4%B9%9F%E6%9C%89%E7%B1%BB%E4%BC%BC%E7%9A%84%E6%A1%86%E5%9B%BE%EF%BC%8C%E5%9C%A8%E8%AF%A5%20MCU%20%E4%B8%8A%EF%BC%8C1%20MHz%20%E6%97%B6%E9%92%9F%E5%A7%8B%E7%BB%88%3CSTRONG%3E%E5%A4%84%E4%BA%8E%3C%2FSTRONG%3E%E5%BC%80%E5%90%AF%E7%8A%B6%E6%80%81%EF%BC%88%E6%AD%A4%E5%A4%84%E7%A7%B0%E4%B8%BA%20%22CLK_1M%22%EF%BC%8C%E5%9B%BE%E4%B8%AD%E7%A7%B0%E4%B8%BA%20%22sirc_1mhz%22%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2204757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EMCX%20N%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCX-N947%3A%201%20MHz%20clock%20(sirc_1mhz%2C%20clk_1M)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255348%22%20target%3D%22_blank%22%3E%40ygrayne%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%22%20%E6%A0%B9%E6%8D%AE%20MCX-N947%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E7%AC%AC%201221%20%E9%A1%B5%E7%9A%84%E6%96%B9%E6%A1%86%E5%9B%BE%EF%BC%8C%3CSPAN%3E%E6%97%B6%E9%92%9F%20%E2%80%9Csirc_1mhz%E2%80%9D%20%E5%A7%8B%E7%BB%88%E5%A4%84%E4%BA%8E%3C%2FSPAN%3E%E5%BC%80%E5%90%AF%E7%8A%B6%E6%80%81%E3%80%82%22%3C%2FP%3E%0A%3CP%3E%E4%B8%8D%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E5%90%AF%E7%94%A8%E6%AD%A4%E6%97%B6%E9%92%9F%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ESYSCON-%26gt%3BCLOCK_CTRL%20%7C%3D%20%20SYSCON_CLOCK_CTRL_FRO1MHZ_CLK_ENA_MASK%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*!%26lt%3B%20Enable%20FRO_1M%20is%20on%20*%2F%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%22%3CSPAN%3ESysTick%20%E5%92%8C%20CTIMER%20%E5%85%81%E8%AE%B8%E9%80%89%E6%8B%A9%E8%AF%A5%E6%97%B6%E9%92%9F%EF%BC%8C%E5%81%87%E8%AE%BE%20%22clk-1M%20%22%E6%98%AF%E6%BA%90%E8%87%AA%20SIRC%20%E7%9A%84%201%20MHz%20%E6%97%B6%E9%92%9F%EF%BC%88%E6%98%AF%E5%90%97%EF%BC%9F%EF%BC%89%3C%2FSPAN%3E%22%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E8%AF%B4%E5%BE%97%E5%AF%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%83%B3%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E8%BF%99%E6%AE%B5%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ESYSCON-%26gt%3BCLOCK_CTRL%20%7C%3D%20%20SYSCON_CLOCK_CTRL_FRO1MHZ_CLK_ENA_MASK%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*!%26lt%3B%20Enable%20FRO_1M%20is%20on%20*%2F%0ACLOCK_AttachClk(kCLK_1M_to_SYSTICK0)%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*!%26lt%3B%20Switch%20SYSTICK0%20to%20CLK_1M%20*%2F%0ACLOCK_AttachClk(kCLK_1M_to_CTIMER0)%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*!%26lt%3B%20Switch%20CTIMER0%20to%20CLK_1M%20*%2F%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E
