MC33772:zero drift
MC33772:zero drift
Wenjing
Dear friend
    Our 33772 has a zero drift of 18mv when collecting voltage with GPIO0。What causes it?I need help,Thanks.
     best wishes        Wenjing
        2024.8.15
TomasVaverka
Hello Jing,
How is your GPIO0 configured and have you tested other GPIOs?
To diagnose the exact cause, consider performing a detailed analysis of the circuit, including measuring the actual input signal, checking the stability of the reference voltage and reviewing the PCB layout for potential issues.
BRs, Tomas
Wenjing
Dear Tomas:
    My  GPIO0 configured" BCC_GPIOX_AN_IN_ABS_MEAS",ALL GPIOS have the same status,I can show the PCB layout for you. Thanks!!!!
best wishes
        WENJING
        2024.8.16
