FS26 MSPI_CRC_I bit set in M_COM_FLG register
3,174 次查看
ben1111
Hi, I trying to read out the M_DEVICEID register on the FS26 PMIC/SBC deivce from a S32K3 MCU with SPI, and I get the correct values for device ID, but a lot of Flags are set in the "General device status" bits response.
E.g. I see that bit COM_G is set, so I read out M_COM_FLAG and see that bit MSPI_CRC_I is set (CRC not valid).
I've tried different CRC calculations provided by AI assistance and all of them give the same result but get the CRC fault anyway.
This is what my SPI communication looks like.
Reading of M_DEVICEID register:
Reading of M_COM_FLG register:
As can be seen, both responses from FS26 gives 254 for General Device Status bits.
And in the last message (M_COM_FLG) the data is 0x04, which is MSPI_CRC_I.
In the above SPI messages I calculate CRC for reading M_DEVICEID register as 166 (0xA6) but the FS26 respond with 150 (0x96).
And for reading M_COM_FLG register I calculate and send CRC = 234 (0xEA) but FS26 respond with CRC 251 (0xFB).
These are the C function to calculate 8bit CRC:
uint8_t FS26_CalculateCRC(
    uint8_t byte0,
    uint8_t byte1,
    uint8_t byte2,
    uint8_t byte3)
    uint8_t crc = 0xFF;      // Seed
    uint8_t poly = 0x1D;
    // Data bytes used in CRC calculation:
    // byte0 = bit31..24
    // byte1 = bit23..16
    // byte2 = bit15..8
    // byte3 = CRC byte, assumed to be 0x00 during calculation
    uint8_t data[4];
    data[0] = byte0;
    data[1] = byte1;
    data[2] = byte2;
    data[3] = byte3;   // CRC byte cleared during calculation
    for (int byte = 0; byte < 4; byte++)
        crc ^= data[byte];
        for (int bit = 0; bit < 8; bit++)
            if (crc & 0x80)
                crc = (crc << 1) ^ poly;
            else
                crc <<= 1;
    return crc;
and the function above is called like this (where CRC is set intially to 0):
uint8_t crc = FS26_CalculateCRC(
            masterTxData[0],
            masterTxData[1],
            masterTxData[2],
            0);
masterTxData[3] = crc;
标记 (1)
3,108 次查看
Robin_Shen
First, let me clarify that I am an S32K technical support engineer, so I am not familiar with FS26.
I installed SW32K3_RTD_R23-11_7.0.0_P01_D2602_DesignStudio_updatesite.zip and S32K3_SBC_FS26_R23-11_6.0.0_D2511_DesignStudio_updatesite.zip in S32DS v3.6.4.
At the end of the main function of Sbc_fs26_example_IP_S32K344, M_DEVICEID and M_COM_FLG are read using Sbc_fs26_ReadRegister().
I did not calculate the CRC by myself. The Sbc_fs26_ReadRegister()function appears to call Sbc_fs26_CalcCrc() to calculate the CRC value.
Sbc_fs26_CalcCrc Sbc_fs26_TransferData Sbc_fs26_ReadRegister Sbc_fs26_example_IP_S32K344.png
/* This function calculates CRC value of passed data array. */
static uint8 Sbc_fs26_CalcCrc(const uint8* pu8Data)
uint8 u8Crc = SBC_FS26_COM_CRC_INIT_U8; /* Result. */
uint8 u8TableIdx = 0U; /* Index to the CRC table. */
uint8 u8DataIdx = 0U; /* Index to the data array (memory). */
/* Calculate CRC. */
for (u8DataIdx = 0U; u8DataIdx < (SBC_FS26_COMM_FRAME_SIZE_U8 - 1U); u8DataIdx++)
u8TableIdx = u8Crc ^ pu8Data[u8DataIdx];
u8Crc = au8CrcTable[u8TableIdx];
return u8Crc;
Please also check the SPI configuration:
Robin
- If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
2,852 次查看
ben1111
Hi, thanks for the reply.
The thing is, we're actually using the MCXE31B chip (which is the same as S32K3xx) with MCUXpresso sdk, so I haven't got Design studio. But I downloaded it and tried to install the real-time drivers and SBC/FS26 code but wasn't able to do it.
Could you please provide me with the complete function, the macro (SBC_FS26_COMM_FRAME_SIZE_U8) and the crc table au8CrcTable[].
Also give me the function Sbc_fs26_ReadRegister() calls the function Sbc_fs26_CalcCrc() so I can see how it is used.
Thank you!
2,796 次查看
Robin_Shen
Please install SW32K3_RTD_R23-11_7.0.0_P01_D2602_DesignStudio_updatesite.zip and S32K3_SBC_FS26_R23-11_6.0.0_D2511_DesignStudio_updatesite.zip in S32DS v3.6.6 by refer to How To Download, Install and Configure the RTD 5.0.0 with S32 Design Studio 3.6.0
SW32K3_RTD_R23-11_7.0.0_P01_D2602_DesignStudio_updatesite.zip can be download by click S32K3 Standard Software -> Automotive SW - S32K3/S32M27x - Real-Time Drivers for Cortex-M -> S32K3 Real-Time Drivers AUTOSAR R23-11 Version 7.0.0 P01
S32K3_SBC_FS26_R23-11_6.0.0_D2511_DesignStudio_updatesite.zip can be download by click S32K3 Standard Software -> Automotive SW - SBC/PMIC - Real Time Drivers -> SBC FS26 R23-11 6.0.0
Then you will be able to find the Sbc_fs26_example_IP_S32K344
%3CLINGO-SUB%20id%3D%22lingo-sub-2344059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS26%20M_COM_FLG%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E8%AE%BE%E7%BD%AE%E7%9A%84%20MSPI_CRC_I%20%E4%BD%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2344059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%83%B3%E4%BB%8E%E5%B8%A6%E6%9C%89%20SPI%20%E7%9A%84%20S32K3%20MCU%20%E8%AF%BB%E5%87%BA%20FS26%20PMIC%2FSBC%20%E8%AE%BE%E5%A4%87%E4%B8%8A%E7%9A%84%20M_DEVICEID%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%AE%BE%E5%A4%87%20ID%20%E5%80%BC%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BE%88%E5%A4%9A%E6%A0%87%E5%BF%97%E9%83%BD%E6%98%AF%E5%9C%A8%20%22%20%E9%80%9A%E7%94%A8%E8%AE%BE%E5%A4%87%E7%8A%B6%E6%80%81%20%22%20%E4%BD%8D%E5%93%8D%E5%BA%94%E4%B8%AD%E8%AE%BE%E7%BD%AE%E7%9A%84%E3%80%82%3CBR%20%2F%3E%E4%BE%8B%E5%A6%82%E6%88%91%E7%9C%8B%E5%88%B0%20COM_G%20%E4%BD%8D%E8%A2%AB%E8%AE%BE%E7%BD%AE%EF%BC%8C%E4%BA%8E%E6%98%AF%E8%AF%BB%E5%87%BA%20M_COM_FLAG%EF%BC%8C%E5%8F%91%E7%8E%B0%20MSPI_CRC_I%20%E4%BD%8D%E8%A2%AB%E8%AE%BE%E7%BD%AE%EF%BC%88CRC%20%E6%97%A0%E6%95%88%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E4%BA%BA%E5%B7%A5%E6%99%BA%E8%83%BD%E5%8D%8F%E5%8A%A9%E6%8F%90%E4%BE%9B%E7%9A%84%E4%B8%8D%E5%90%8C%20CRC%20%E8%AE%A1%E7%AE%97%E6%96%B9%E6%B3%95%EF%BC%8C%E7%BB%93%E6%9E%9C%E9%83%BD%E4%B8%80%E6%A0%B7%EF%BC%8C%E4%BD%86%E8%BF%98%E6%98%AF%E5%87%BA%E7%8E%B0%E4%BA%86%20CRC%20%E6%95%85%E9%9A%9C%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E7%9A%84%20SPI%20%E9%80%9A%E4%BF%A1%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%20M_DEVICEID%EF%BC%9A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22spi_read_m_deviceid.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22spi_read_m_deviceid.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22spi_read_m_deviceid.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22spi_read_m_deviceid.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381150i6614E4FE8F80A31D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22spi_read_m_deviceid.png%22%20alt%3D%22spi_read_m_deviceid.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%20M_COM_FLG%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22spi_read_m_com_flag.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22spi_read_m_com_flag.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22spi_read_m_com_flag.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22spi_read_m_com_flag.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381151i0015B76EEEFAB815%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22spi_read_m_com_flag.png%22%20alt%3D%22spi_read_m_com_flag.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%87%BA%EF%BC%8CFS26%20%E7%9A%84%E4%B8%A4%E4%B8%AA%E5%93%8D%E5%BA%94%E9%83%BD%E7%BB%99%E5%87%BA%E4%BA%86%20254%20%E7%9A%84%E9%80%9A%E7%94%A8%E8%AE%BE%E5%A4%87%E7%8A%B6%E6%80%81%E4%BD%8D%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%9D%A1%E6%8A%A5%E6%96%87%EF%BC%88M_COM_FLG%EF%BC%89%E4%B8%AD%EF%BC%8C%E6%95%B0%E6%8D%AE%E4%B8%BA%200x04%EF%BC%8C%E5%8D%B3%20MSPI_CRC_I%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E4%B8%8A%E8%BF%B0%20SPI%20%E4%BF%A1%E6%81%AF%E4%B8%AD%EF%BC%8C%E6%88%91%E8%AE%A1%E7%AE%97%E8%AF%BB%E5%8F%96%20M_DEVICEID%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%20CRC%20%E4%B8%BA%20166%20(0xA6)%EF%BC%8C%E4%BD%86%20FS26%20%E7%9A%84%E5%93%8D%E5%BA%94%E4%B8%BA%20150%20(0x96)%E3%80%82%3CBR%20%2F%3E%E4%B8%BA%E4%BA%86%E8%AF%BB%E5%8F%96%20M_COM_FLG%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%88%91%E8%AE%A1%E7%AE%97%E5%B9%B6%E5%8F%91%E9%80%81%E4%BA%86%20CRC%20%3D%20234%20(0xEA)%EF%BC%8C%E4%BD%86%20FS26%20%E5%9B%9E%E5%BA%94%E8%AF%B4%20CRC%20251%20(0xFB)%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BA%9B%E6%98%AF%E8%AE%A1%E7%AE%97%208%20%E4%BD%8D%20CRC%20%E7%9A%84%20C%20%E8%AF%AD%E8%A8%80%E5%87%BD%E6%95%B0%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3EFS26_CalculateCRC%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3E%E5%AD%97%E8%8A%820%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3E%E5%AD%97%E8%8A%821%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3E%E5%AD%97%E8%8A%822%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3E%E5%AD%97%E8%8A%823%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3Ecrc%3C%2FSPAN%3E%3CSPAN%3E%3D%20%3C%2FSPAN%3E%3CSPAN%3E0xFF%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%20%20%20%20%20%20%2F%2F%20%E7%A7%8D%E5%AD%90%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3E%E5%A4%9A%E8%BE%B9%E5%BD%A2%3C%2FSPAN%3E%3CSPAN%3E%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x1D%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%2F%2FCRC%20%E8%AE%A1%E7%AE%97%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E6%95%B0%E6%8D%AE%E5%AD%97%E8%8A%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E5%AD%97%E8%8A%82%200%20%3D%20%E4%BD%8D%2031...24%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20byte1%20%3D%20bit23..16%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20byte2%20%3D%20bit15..8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%2F%2Fbyte3%20%3D%20CRC%20%E5%AD%97%E8%8A%82%EF%BC%8C%E8%AE%A1%E7%AE%97%E6%97%B6%E5%81%87%E5%AE%9A%E4%B8%BA%200x00%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3E%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E4%3C%2FSPAN%3E%3CSPAN%3E%5D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E%E5%AD%97%E8%8A%82%200%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E%E5%AD%97%E8%8A%82%201%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E%E5%AD%97%E8%8A%82%202%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3Ed%20%3CSPAN%3Eata%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Ebyte3%3C%2FSPAN%3E%3CSPAN%3E%3B%2F%2F%E8%AE%A1%E7%AE%97%E6%9C%9F%E9%97%B4%3C%2FSPAN%3E%3CSPAN%3E%E6%B8%85%E9%99%A4%20CRC%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3Efor%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3Eint%3C%2FSPAN%3E%20%3CSPAN%3E%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%20%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3Ecrc%3C%2FSPAN%3E%20%3CSPAN%3E%5E%3D%3C%2FSPAN%3E%20%3CSPAN%3E%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%3E%5D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%BA%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Eint%3C%2FSPAN%3E%20%3CSPAN%3E%E4%BD%8D%3C%2FSPAN%3E%3CSPAN%3E%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E4%BD%8D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E8%3C%2FSPAN%3E%3CSPAN%3E%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E4%BD%8D%3C%2FSPAN%3E%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ecrc%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3E0x80%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Ecrc%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ecrc%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%5E%3C%2FSPAN%3E%20%3CSPAN%3E%E8%81%9A%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%8D%E7%84%B6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Ecrc%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%20%3CSPAN%3Ecrc%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E5%B9%B6%E5%83%8F%E8%BF%99%E6%A0%B7%E8%B0%83%E7%94%A8%E4%B8%8A%E9%9D%A2%E7%9A%84%E5%87%BD%E6%95%B0%EF%BC%88%E5%85%B6%E4%B8%AD%20CRC%20%E5%88%9D%E5%A7%8B%E8%AE%BE%E7%BD%AE%E4%B8%BA%200%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3Ecrc%3C%2FSPAN%3E%3CSPAN%3E%3D%20%3C%2FSPAN%3E%3CSPAN%3EFS26_CalculateCRC%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%BB%20TxData%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%5D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%BB%20TxData%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%5D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%BB%20TxData%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%5D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%E4%B8%BB%20TxData%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Ecrc%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2344059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E9%80%9A%E4%BF%A1%26amp%3B%20%E6%8E%A7%E5%88%B6%EF%BC%88I3C%20%7C%20I2C%20%7C%20SPI%20%7C%20FlexCAN%20%7C%20%E4%BB%A5%E5%A4%AA%E7%BD%91%20%7C%20FlexIO%EF%BC%89%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E7%94%B5%E6%BA%90%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2344912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20MSPI_CRC_I%20bit%20set%20in%20M_COM_FLG%20register%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2344912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%0A%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E8%AF%B7%E5%85%81%E8%AE%B8%E6%88%91%E6%BE%84%E6%B8%85%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%88%91%E6%98%AF%E4%B8%80%E5%90%8D%20S32K%20%E6%8A%80%E6%9C%AF%E6%94%AF%E6%8C%81%E5%B7%A5%E7%A8%8B%E5%B8%88%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%AF%B9%20FS26%20%E5%B9%B6%E4%B8%8D%E7%86%9F%E6%82%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fautomotive-software-and-tools%2Fs32-design-studio-ide%2Fs32-design-studio-for-s32-platform%3AS32DS-S32PLATFORM%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20S32DS%20v3.6.4%3C%2FA%3E%20%E4%B8%AD%E5%AE%89%E8%A3%85%E4%BA%86%3CSTRONG%3E%20SW32K3_RTD_R23-11_7.0.0_P01_D2602_DesignStudio_updatesite.zip%3C%2FSTRONG%3E%20%E5%92%8C%3CSTRONG%3E%20S32K3_SBC_FS26_R23%20-11%20_6.0.0_D2511_DesignStudio_updatesite.%20zip%3C%2FSTRONG%3E%20%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%3CSTRONG%3ESbc_fs26_example_IP_S32K344%3C%2FSTRONG%3E%20%E7%9A%84%E4%B8%BB%E5%87%BD%E6%95%B0%E7%BB%93%E6%9D%9F%E6%97%B6%EF%BC%8C%E4%BD%BF%E7%94%A8%3CSTRONG%3ESbc_fs26_ReadRegister()%3C%2FSTRONG%3E%20%E8%AF%BB%E5%8F%96%3CSTRONG%3EM_DEVICEID%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3EM_COM_FLG%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%B2%A1%E6%9C%89%E8%87%AA%E5%B7%B1%E8%AE%A1%E7%AE%97%20CRC%E3%80%82%3CSTRONG%3ESbc_fs26_ReadRegister()%3C%2FSTRONG%3E%E5%87%BD%E6%95%B0%E4%BC%BC%E4%B9%8E%E8%B0%83%E7%94%A8%3CSTRONG%3ESbc_fs26_CalcCrc()%3C%2FSTRONG%3E%E6%9D%A5%E8%AE%A1%E7%AE%97%20CRC%20%E5%80%BC%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sbc_fs26_CalcCrc%20Sbc_fs26_TransferData%20Sbc_fs26_ReadRegister%20Sbc_fs26_example_IP_S32K344.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sbc_fs26_CalcCrc%20Sbc_fs26_TransferData%20Sbc_fs26_ReadRegister%20Sbc_fs26_example_IP_S32K344.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sbc_fs26_CalcCrc%20Sbc_fs26_TransferData%20Sbc_fs26_ReadRegister%20Sbc_fs26_example_IP_S32K344.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sbc_fs26_CalcCrc%20Sbc_fs26_TransferData%20Sbc_fs26_ReadRegister%20Sbc_fs26_example_IP_S32K344.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381265i3940DE0C137E7748%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Sbc_fs26_CalcCrc%20Sbc_fs26_TransferData%20Sbc_fs26_ReadRegister%20Sbc_fs26_example_IP_S32K344.png%22%20alt%3D%22Sbc_fs26_CalcCrc%20Sbc_fs26_TransferData%20Sbc_fs26_ReadRegister%20Sbc_fs26_example_IP_S32K344.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20style%3D%22background-color%3A%20%23ffffff%3B%20padding%3A%200px%200px%200px%202px%3B%22%3E%0A%3CDIV%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-family%3A%20'Courier%20New'%3B%20font-size%3A%2010pt%3B%20white-space%3A%20pre%3B%22%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20%E8%AF%A5%E5%87%BD%E6%95%B0%E8%AE%A1%E7%AE%97%E6%89%80%E4%BC%A0%E6%95%B0%E6%8D%AE%E6%95%B0%E7%BB%84%E7%9A%84%20CRC%20%E5%80%BC%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%E9%9D%99%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3Euint8%3C%2FSPAN%3E%20%3CSPAN%3ESbc_fs26_CalcCrc%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%B8%B8%E6%95%B0%3C%2FSPAN%3E%20%3CSPAN%3Euint8%3C%2FSPAN%3E%3CSPAN%3E*%20pu8Data)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Euint8%3C%2FSPAN%3E%3CSPAN%3Eu8Crc%20%3D%20SBC_FS26_COM_CRC_INIT_U8%EF%BC%9B%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%20%E7%BB%93%E6%9E%9C%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Euint8%3C%2FSPAN%3E%3CSPAN%3Eu8TableIdx%20%3D%200U%EF%BC%9B%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%20CRC%20%E8%A1%A8%E7%9A%84%E7%B4%A2%E5%BC%95%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Euint8%3C%2FSPAN%3E%3CSPAN%3Eu8DataIdx%20%3D%200U%EF%BC%9B%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%20%E6%95%B0%E6%8D%AE%E6%95%B0%E7%BB%84%EF%BC%88%E5%86%85%E5%AD%98%EF%BC%89%E7%9A%84%E7%B4%A2%E5%BC%95%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20%E8%AE%A1%E7%AE%97%20CRC%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%E4%B8%BA%3C%2FSPAN%3E%3CSPAN%3E(u8DataIdx%20%3D%200U%3B%20u8DataIdx%26lt%3B%20(SBC_FS26_COMM_FRAME_SIZE_U8%20-%201U)%3B%20u8DataIdx%2B%2B)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20u8TableIdx%20%3D%20u8Crc%20%5E%20pu8Data%5Bu8DataIdx%5D%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20u8Crc%20%3D%20au8CrcTable%5Bu8TableIdx%5D%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%3CSPAN%3Eu8Crc%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%3E%E8%BF%98%E8%AF%B7%E6%A3%80%E6%9F%A5%20SPI%20%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sbc_fs26_example_IP_S32K344%20SBC%20FS26%20R23-11%206.0.0%20Lpspi%20configuration.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sbc_fs26_example_IP_S32K344%20SBC%20FS26%20R23-11%206.0.0%20Lpspi%20configuration.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sbc_fs26_example_IP_S32K344%20SBC%20FS26%20R23-11%206.0.0%20Lpspi%20configuration.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sbc_fs26_example_IP_S32K344%20SBC%20FS26%20R23-11%206.0.0%20Lpspi%20configuration.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381260i7177F7759021F4E2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Sbc_fs26_example_IP_S32K344%20SBC%20FS26%20R23-11%206.0.0%20Lpspi%20configuration.png%22%20alt%3D%22Sbc_fs26_example_IP_S32K344%20SBC%20FS26%20R23-11%206.0.0%20Lpspi%20configuration.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%E7%A5%9D%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3ERobin%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22ACCEPT%20AS%20SOLUTION%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CP%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20MSPI_CRC_I%20bit%20set%20in%20M_COM_FLG%20register%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E5%AE%9E%E9%99%85%E4%B8%8A%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20MCUXpresso%20sdk%20%E7%9A%84%20MCXE31B%20%E8%8A%AF%E7%89%87%EF%BC%88%E4%B8%8E%20S32K3xx%20%E7%9B%B8%E5%90%8C%EF%BC%89%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%20Design%20studio%E3%80%82%E4%BD%86%E6%88%91%E4%B8%8B%E8%BD%BD%E4%BA%86%E5%AE%83%E5%B9%B6%E5%B0%9D%E8%AF%95%E5%AE%89%E8%A3%85%E5%AE%9E%E6%97%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%20SBC%2FFS26%20%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%E6%B2%A1%E8%83%BD%E5%81%9A%E5%88%B0%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%8F%90%E4%BE%9B%E5%AE%8C%E6%95%B4%E7%9A%84%E5%87%BD%E6%95%B0%E3%80%81%E5%AE%8F%3CSTRONG%3E(SBC_FS26_COMM_FRAME_SIZE_U8%3C%2FSTRONG%3E)%20%E5%92%8C%20crc%20%E8%A1%A8%3CSTRONG%3Eau8CrcTable%3C%2FSTRONG%3E%5B%5D%E3%80%82%3CBR%20%2F%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E8%AF%B7%E7%BB%99%E6%88%91%E5%87%BD%E6%95%B0%3CSTRONG%3ESbc_fs26_ReadRegister()%20%3C%2FSTRONG%3E%E8%B0%83%E7%94%A8%E5%87%BD%E6%95%B0%3CSTRONG%3ESbc_fs26_CalcCrc%3C%2FSTRONG%3E()%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E4%BA%86%E8%A7%A3%E5%AE%83%E6%98%AF%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20MSPI_CRC_I%20bit%20set%20in%20M_COM_FLG%20register%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DS32DS-3-6%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E8%AF%B7%E5%9C%A8%20S32DS%20v3.6.6%20%E4%B8%AD%E5%AE%89%E8%A3%85%3C%2FA%3E%3CSTRONG%3E%20SW32K3_RTD_R23-11_7.0.%3C%2FSTRONG%3E%200_P01_D2602_DesignStudio_updatesite.zip%3CSPAN%3E%20%E5%92%8C%3C%2FSPAN%3E%3CSTRONG%3E%20S32K3_SBC_FS26_R23-11_6.0.0_D2511_DesignStudio_updatesite.zip%3C%2FSTRONG%3E%20%EF%BC%8C%E5%85%B7%E4%BD%93%E6%96%B9%E6%B3%95%E8%AF%B7%E5%8F%82%E9%98%85%E3%80%8A%20%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FHow-To-Download-Install-and-Configure-the-RTD-5-0-0-with-S32%2Fta-p%2F2015104%22%20target%3D%22_self%22%3E%20S32%20Design%20Studio%203.6.0%20%E4%B8%8B%E8%BD%BD%E3%80%81%E5%AE%89%E8%A3%85%E5%92%8C%E9%85%8D%E7%BD%AE%20RTD%205.0.0%E3%80%8B%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3Esw32k3_rtd_r23-11_7.0.0_p01_d2602_designstudio_Updatesite.zip%20%E5%8F%AF%E4%BB%A5%E7%82%B9%E5%87%BB%E4%B8%8B%E8%BD%BD%20S32K3%20%E6%A0%87%E5%87%86%E8%BD%AF%E4%BB%B6-%26gt%3B%20%E6%B1%BD%E8%BD%A6%E8%BD%AF%E4%BB%B6-S32K3%2FS32M27X-Cortex-M%20%E7%9A%84%E5%AE%9E%E6%97%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F-%26gt%3B%20S32K3%20%E5%AE%9E%E6%97%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20AUTOSA%3C%2FSTRONG%3E%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K3-STDSW-D%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ER%20R23-11%20%E7%89%88%E6%9C%AC%207.0.0%3C%2FA%3EP01%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3Es32k3_sbc_fs26_r23-11_6.0.0_d2511_designstudio_Updatesite.zip%20%E5%8F%AF%E4%BB%A5%E7%82%B9%E5%87%BB%E4%B8%8B%E8%BD%BD%20S32K3%20%E6%A0%87%E5%87%86%E8%BD%AF%E4%BB%B6-%26gt%3B%20%E6%B1%BD%E8%BD%A6%E8%BD%AF%E4%BB%B6-SBC%2FPMIC-%E5%AE%9E%E6%97%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F-%26gt%3B%20SBC%20FS26%20R23-11%206.0.%3C%2FSTRONG%3E%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K3-STDSW-D%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E0%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%82%A8%E5%B0%B1%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%3CSTRONG%3ESbc_fs26_example_IP_S32K344%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sbc_fs26_example_IP_S32K344%20File%20New%20S32DS%20Project%20From%20Example.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sbc_fs26_example_IP_S32K344%20File%20New%20S32DS%20Project%20From%20Example.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381489i3E2F26687A16A0D4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Sbc_fs26_example_IP_S32K344%20File%20New%20S32DS%20Project%20From%20Example.png%22%20alt%3D%22Sbc_fs26_example_IP_S32K344%20File%20New%20S32DS%20Project%20From%20Example.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
