FRDM-MCXW71 NBU Firmware Setup
4,348件の閲覧回数
goran_petrushev
I have been playing around with the FRDM-MCXW71 board recently and I encountered some uncertainties while trying to set up the NBU firmware.
I followed through this guide for it and what I noticed is that it's quite old. My confusion is specifically regarding the .sb3 files that are in the SDK used for flashing the firmware. In the guide, said file is named differently, it is just mcxw71_nbu_ble_1_9_14_1.sb3
When I went digging in the SDK for this file, I found 3 different files going by:
  • mcxw71_nbu_ble_hadm_hosted.sb3
  • mcxw71_nbu_ble_hosted.sb3
  • mcxw71_nbu_ble_xp_hosted.sb3
There is also a .xip file with the same name for each one of these. I tried looking around to find any explanation about the difference between these but I couldn't find any. Furthermore, I tried running the bm beacon example with each firmware file and it only worked with mcxw71_nbu_ble_hadm_hosted.sb3
Thanks in advance for reading and answering
10 返答(返信)
4,336件の閲覧回数
marek-trmac
you might find additional info here:
Getting Started with FRDM-MCXW71 | NXP Semiconductors
Processor-specific workflows — MCUXpresso Secure Provisioning Tool 25.03 25.03 documentation
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
3,978件の閲覧回数
MrShen
Using the MCUXpresso Secure Provisioning Tool 25.09 manufacturing tool to perform NBU firmware updates. After selecting to run the application SB file and clicking start, it also fails. May I ask what the problem is? How can it be resolved? Thank you!Secure Provisioning Tool 失败.pngSecure Provisioning Tool 失败.pngSecure Provisioning Tool 3.pngSecure Provisioning Tool 3.pngSecure Provisioning Tool 2.pngSecure Provisioning Tool 2.png
3,937件の閲覧回数
PakostaP
It is impossible to tell from the provided information.
Did you use an SB file from the SDK that is signed with NXP keys? If so, it can only be used with the FRDM board, as those boards have pre-burned NXP keys.
If you are using a custom SB file, did you use the correct keys for signing it? Also, are the commands in the SB file correct?
Both scenarios how to update NBU FW are described in the documentation linked by Marek.
3,932件の閲覧回数
MrShen
I don't have a FRDM board. Could you provide the pre-burned NXP keys and the burning method? If not, where can I find the custom SB file, or the SB configuration files and binary files such as *.yaml files that need to be imported for the custom SB file? Thank you!
3,915件の閲覧回数
marek-trmac
Hi @MrShen
if you really want to use NXP "demo" keys used on EVK board, start Secure Provisioning Tool and go to main menu > File > New Workspace, select the processor with a board and in the profile select "Plain signed image running on onchip flash FRDM-MCXW71 keys".
If you want to generate new keys, select ""Plain signed image running on onchip flash"
As a source application, select any sample application from the drop down list.
Create new workspace and build the bootable image.
After that follow the flow described in Processor-specific workflows — Secure Provisioning Tool 25.09
Marek
3,786件の閲覧回数
MrShen
Hello, according to the steps, Create new workspace and build the bootable image. In the menu bar, select 'Tools' > 'Manufacturing Tools', after executing Write image, execute Apply SB image,''mcxw71_nbu_ble_1_9_14_0.sb3". After the NBU firmware update is successful. Now when debugging the program in MCUXpresso IDE, debugging cannot proceed, Error: Wire Ack Fault - target connected.Dbug失败.pngDbug失败.png
屏幕截图 2025-11-03 104257.png屏幕截图 2025-11-03 104257.png屏幕截图 2025-11-03 104244.png屏幕截图 2025-11-03 104244.png
屏幕截图 2025-11-03 095916.png屏幕截图 2025-11-03 095916.png屏幕截图 2025-11-03 100021.png屏幕截图 2025-11-03 100021.png屏幕截图 2025-11-03 100114.png屏幕截图 2025-11-03 100114.png
3,779件の閲覧回数
MrShen
Resolved! The jumper was not connected, thank you!
3,880件の閲覧回数
MrShen
Hello, according to the instructions you mentioned, after selecting to create a new workspace, I built the image file. Then I used the tool—the manufacturing tool—to write the application SB image, i.e., the file "mcxw71_nbu_ble_1_9_14_0.sb3". However, after clicking "Start", the firmware download still failed.
When using the custom SB file method, it was mentioned that the NBU firmware should be copied to the workspace as "source_images\nbu_firmware.xip". Where can this NBU firmware be found, and which specific file is it? Please provide it if possible.
After selecting the advanced command "update-nbu-firmware", a prompt appears indicating that the file "nbu_firmware.xip" cannot be found. This prevents the generation of the SB file, so please also provide this file if available.屏幕截图 2025-11-01 222516.png屏幕截图 2025-11-01 222516.png屏幕截图 2025-11-01 222526.png屏幕截图 2025-11-01 222526.png屏幕截图 2025-11-01 222600.png屏幕截图 2025-11-01 222600.png屏幕截图 2025-11-01 222615.png屏幕截图 2025-11-01 222615.png屏幕截图 2025-11-01 222629.png屏幕截图 2025-11-01 222629.png屏幕截图 2025-11-01 222653.png屏幕截图 2025-11-01 222653.png屏幕截图 2025-11-01 222711.png屏幕截图 2025-11-01 222711.png
タグ(1)
3,766件の閲覧回数
PakostaP
For every .sb file with NBU firmware, there is a corresponding .xip file. Therefore, the SDK should contain a file named mcxw71_nbu_ble_1_9_14_0.xip. If you copy this file into the source_image folder and rename it to nbu_firmware.xip, it will enable the update_nbu_firmware command, and you're good to go.
3,723件の閲覧回数
MrShen
OK,Thank you!
%3CLINGO-SUB%20id%3D%22lingo-sub-2130041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-MCXW71%20NBU%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2130041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%80%E8%BF%91%E3%80%81FRDM-MCXW71%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%81%84%E3%81%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81NBU%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E4%B8%8D%E7%A2%BA%E5%AE%9F%E3%81%AA%E7%82%B9%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FFRDM-Training-Hub%2FFRDM-MCXW71-Hands-On-1-NBU-and-User-Firmware-Update-Using-ISP%2Fta-p%2F1970154%3Fattachment-id%3D184523%22%20target%3D%22_self%22%3E%E3%81%93%E3%81%AE%3C%2FA%3E%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%8B%E3%81%AA%E3%82%8A%E5%8F%A4%E3%81%84%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AE%E6%B7%B7%E4%B9%B1%E3%81%AF%E7%89%B9%E3%81%AB.sb3%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%A7%E3%81%99%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%20SDKs%20%E5%86%85%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%E3%82%AC%E3%82%A4%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%80%81%20%3CSTRONG%3Emcxw71_nbu_ble_1_9_14_1.sb3%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%20SDKs%20%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%203%20%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3Emcxw71_nbu_ble_hadm_hosted.sb3%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Emcxw71_nbu_ble_hosted.sb3%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Emcxw71_nbu_ble_xp_hosted.sb3%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E.xip%3C%2FSTRONG%3E%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AB%E5%90%8C%E3%81%98%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E9%81%95%E3%81%84%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E8%AA%AC%E6%98%8E%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%88%E3%81%86%E3%81%A8%E8%AA%BF%E3%81%B9%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E5%90%84%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7bm%E3%83%93%E3%83%BC%E3%82%B3%E3%83%B3%E3%81%AE%E4%BE%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%20%3CSTRONG%3Emcxw71_nbu_ble_hadm_hosted.sb3%3C%2FSTRONG%3E%E3%81%A7%E3%81%AE%E3%81%BF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E8%AA%AD%E3%82%93%E3%81%A7%E5%9B%9E%E7%AD%94%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2130041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFRDM%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXW71%20NBU%20Firmware%20Setup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOK%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXW71%20NBU%20Firmware%20Setup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE.sbNBU%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B.xip%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81SDK%20%E3%81%AB%E3%81%AF%3CCODE%20translate%3D%22no%22%3Emcxw71_nbu_ble_1_9_14_0.xip%3C%2FCODE%3E%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%3CCODE%20translate%3D%22no%22%3Esource_image%3C%2FCODE%3E%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E5%90%8D%E5%89%8D%E3%82%92%3CCODE%20translate%3D%22no%22%3Enbu_firmware.xip%3C%2FCODE%3E%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%20%3CCODE%20translate%3D%22no%22%3Eupdate_nbu_firmware%3C%2FCODE%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXW71%20NBU%20Firmware%20Setup%20%20debugging%20cannot%20proceed%2C%20Error%3A%20Wire%20Ack%20Fault%20-%20target%20connect%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E3%81%AF%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXW71%20NBU%20Firmware%20Setup%20%20debugging%20cannot%20proceed%2C%20Error%3A%20Wire%20Ack%20Fault%20-%20target%20connect%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E8%B5%B7%E5%8B%95%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%20%E3%83%90%E3%83%BC%E3%81%A7%E3%80%81%5B%E3%83%84%E3%83%BC%E3%83%AB%5D%20%26gt%3B%20%5B%E8%A3%BD%E9%80%A0%E3%83%84%E3%83%BC%E3%83%AB%5D%20%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81SB%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E9%81%A9%E7%94%A8%20(%E3%80%8Cmcxw71_nbu_ble_1_9_14_0.sb3%E3%80%8D)%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82NBU%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81MCUXpresso%20IDE%20%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E7%B6%9A%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Wire%20Ack%20Fault%20-%20target%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Dbug%E5%A4%B1%E8%B4%A5.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Dbug%E5%A4%B1%E8%B4%A5.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363618iB896944D9787ADEF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Dbug%E5%A4%B1%E8%B4%A5.png%22%20alt%3D%22Dbug%E5%A4%B1%E8%B4%A5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDbug%E5%A4%B1%E8%B4%A5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20104257.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20104257.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363622i4C5AB7AFDA05CDAD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20104257.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20104257.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20104257.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20104244.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20104244.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363621i82C3977BBA926B4B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20104244.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20104244.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20104244.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20095916.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20095916.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363623i94D068CD32845BB3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20095916.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20095916.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20095916.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20100021.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20100021.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363624iC9F552C46408A704%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20100021.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20100021.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20100021.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20100114.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20100114.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363625iC783C3DB43F98E82%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20100114.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20100114.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20100114.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20105431.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20105431.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363626iB74DC471B2F20972%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20105431.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20105431.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20105431.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20105441.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20105441.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363627i55F1B854A5C708A1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20105441.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20105441.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-03%20105441.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXW71%20NBU%20Firmware%20Setup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E3%81%94%E6%8C%87%E7%A4%BA%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AE%E4%BD%9C%E6%88%90%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%84%E3%83%BC%E3%83%AB%20(%E8%A3%BD%E9%80%A0%E3%83%84%E3%83%BC%E3%83%AB)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20SB%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20(%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cmcxw71_nbu_ble_1_9_14_0.sb3%E3%80%8D)%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%80%8C%E9%96%8B%E5%A7%8B%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20SB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81NBU%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%80%8Csource_images%5Cnbu_firmware.xip%E3%80%8D%E3%81%A8%E3%81%97%E3%81%A6%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%20NBU%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%81%A9%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%20%E3%81%BE%E3%81%9F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%81%8B%3F%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%AB%98%E5%BA%A6%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%8Cupdate-nbu-firmware%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%80%8Cnbu_firmware.xip%E3%80%8D%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%20SB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8BSO%E3%80%81%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222516.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222516.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363581i72E6EC25E5DB2887%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222516.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222516.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222516.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222526.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222526.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363583iFE9C7F324B283551%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222526.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222526.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222526.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222600.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222600.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363580iFBA6DA087CF96EEB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222600.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222600.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222600.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222615.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222615.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363582iFEE702B282D0D35D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222615.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222615.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222615.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222629.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222629.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363584iA8A226BB07F0CFBB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222629.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222629.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222629.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222653.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222653.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363585i8C4DE0F935E6968E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222653.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222653.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222653.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222711.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222711.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363586iF9B0FE0FE3E1B447%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222711.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222711.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-01%20222711.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXW71%20NBU%20Firmware%20Setup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239904%22%20target%3D%22_blank%22%3E%40MrShen%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EEVK%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%20NXP%E3%80%8C%E3%83%87%E3%83%A2%E3%80%8D%E3%82%AD%E3%83%BC%E3%82%92%E5%AE%9F%E9%9A%9B%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E3%83%A1%E3%82%A4%E3%83%B3%20%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%20%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%26gt%3B%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AE%E9%A0%86%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%80%81%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%80%8C%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20FRDM-MCXW71%20%E3%82%AD%E3%83%BC%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E7%BD%B2%E5%90%8D%E6%B8%88%E3%81%BF%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AD%E3%83%BC%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E7%BD%B2%E5%90%8D%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%83%80%E3%82%A6%E3%83%B3%20%E3%83%AA%E3%82%B9%E3%83%88%E3%81%8B%E3%82%89%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E8%B5%B7%E5%8B%95%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fdocs.mcuxpresso.nxp.com%2Fsecure%2Flatest%2F06_processor_specific_workflow.html%23update-nbu-firmware%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E5%9B%BA%E6%9C%89%E3%81%AE%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%95%E3%83%AD%E3%83%BC%20-%20Secure%20Provisioning%20Tool%2025.09%3C%2FA%3E%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXW71%20NBU%20Firmware%20Setup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BA%8B%E5%89%8D%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%20NXP%20%E3%82%AD%E3%83%BC%E3%81%A8%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%96%B9%E6%B3%95%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20SB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20SB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%20SB%20%E6%A7%8B%E6%88%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20(*.yaml%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AA%E3%81%A9)%20%E3%81%AF%E3%81%A9%E3%81%93%E3%81%ABCAN%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXW71%20NBU%20Firmware%20Setup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E6%83%85%E5%A0%B1%E3%81%8B%E3%82%89%E5%88%A4%E6%96%AD%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%0A%3CP%3ENXP%20%E3%82%AD%E3%83%BC%E3%81%A7%E7%BD%B2%E5%90%8D%E3%81%95%E3%82%8C%E3%81%9F%20SDK%20%E3%81%AE%20SB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%82%82%E3%81%97SO%E3%81%AA%E3%82%89%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%20NXP%20%E3%82%AD%E3%83%BC%E3%81%8C%E4%BA%8B%E5%89%8D%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81FRDM%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%81%BF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20SB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E7%BD%B2%E5%90%8D%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%81%BE%E3%81%9F%E3%80%81SB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3ENBU%20FW%20%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E4%B8%A1%E6%96%B9%E3%81%AE%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%81%AF%E3%80%81Marek%20%E3%81%8C%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%81%9F%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXW71%20NBU%20Firmware%20Setup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EMCUXpresso%20Secure%20Provisioning%20Tool%2025.09%E8%A3%BD%E9%80%A0%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6NBU%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AESB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%80%8C%E9%96%8B%E5%A7%8B%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%82%82%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Secure%20Provisioning%20Tool%20%E5%A4%B1%E8%B4%A5.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Secure%20Provisioning%20Tool%20%E5%A4%B1%E8%B4%A5.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363198i9D57EEC62A44A6D7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Secure%20Provisioning%20Tool%20%E5%A4%B1%E8%B4%A5.png%22%20alt%3D%22Secure%20Provisioning%20Tool%20%E5%A4%B1%E8%B4%A5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESecure%20Provisioning%20Tool%20%E5%A4%B1%E8%B4%A5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Secure%20Provisioning%20Tool%203.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Secure%20Provisioning%20Tool%203.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363199i3C1D5B7FDCE4F59F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Secure%20Provisioning%20Tool%203.png%22%20alt%3D%22Secure%20Provisioning%20Tool%203.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESecure%20Provisioning%20Tool%203.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Secure%20Provisioning%20Tool%202.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Secure%20Provisioning%20Tool%202.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363200i590FC360F0B8B678%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Secure%20Provisioning%20Tool%202.png%22%20alt%3D%22Secure%20Provisioning%20Tool%202.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESecure%20Provisioning%20Tool%202.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2130088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXW71%20NBU%20Firmware%20Setup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2130088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%BF%BD%E5%8A%A0%E6%83%85%E5%A0%B1%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-frdm-mcxw71%3AGS-FRDM-MCXW71%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFRDM-MCXW71%20%E5%85%A5%E9%96%80%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.mcuxpresso.nxp.com%2Fsecure%2Flatest%2F06_processor_specific_workflow.html%23update-nbu-firmware%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E5%9B%BA%E6%9C%89%E3%81%AE%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%95%E3%83%AD%E3%83%BC%20%E2%80%94%20MCUXpresso%20Secure%20Provisioning%20Tool%2025.03%2025.03%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
