Ctimer Peripherals setup mcxn947
chyde432
I have set up my CTimer using the peripherals tool on mcuxpresso
As you can see in the attached my CTimer match config is defined as constant by the peripherals tool - I can not edit this code- is there anyway to change the match value of without having to explicitly set up the CTimer without the peripherals tool. Thanks.
Any help would be appreciated. Thanks
Labels (2)
Hello @chyde432
Yes, you can use any Edit tool open this file to change match value.
Alice
