Ctimer Peripherals setup mcxn947
727 次查看
chyde432
I have set up my CTimer using the peripherals tool on mcuxpresso
As you can see in the attached my CTimer match config is defined as constant by the peripherals tool - I can not edit this code- is there anyway to change the match value of without having to explicitly set up the CTimer without the peripherals tool. Thanks.
Any help would be appreciated. Thanks
标签 (2)
691 次查看
Hello @chyde432
Yes, you can use any Edit tool open this file to change match value.
Alice
