Any MCU from NXP can support separated address and data pins for external bus?
1,556 次查看
Norihiro
Senior Contributor II
I selected MCX Micro as a location for my question.
But this question is not for specific MCU family from NXP.
My question is, is there any MCUs from NXP that can support separated
In my understanding, NXP's MCU that support the external bus interface
have multiplexed address/data pins.
Norihiro Michigami
AVNET
1,500 次查看
ZhangJennie
Hi norihiromichiga ,
Thanks. I was considering MCX because this is MCX space.
 Considering other MCUs,  LPC17xx/18xx, LPC40xx integrates EMC module which has saperated data and address external bus. But these LPCs are legacy product which is not recommended for new design.
RT1060 RT1170 also support EMC. I would suggest you consider as well.
Hope this helps,
Jun Zhang
4 回复数
1,518 次查看
Norihiro
Hello Jun,
Thank you for your answer.
But as I posted in my first post, my quesiton is not limited to MCX series.
Does NXP have any series of MCU that can suppor seperated address and data bus of external bus interface?
Norihiro Michigami
AVNET
1,501 次查看
ZhangJennie
Hope this helps,
Jun Zhang
1,480 次查看
Norihiro
Hello Jun,
Thank you for your comment. I understood your point.
BTW, customer may have questions that are not classified to specific MCU like this question.
If there is a forum for general questions, it may be good for customers.
Norihiro Michigami
AVNET
1,539 次查看
ZhangJennie
Hi norihiromichiga,
MCX N only supports external memory over FlexSPI interface or SPI
Hope this will help you,
Jun Zhang
