802.1AS PTP example code on the RT1180
2,873 次查看
ViorelDv
Hello everybody,
I just received the RT1180 and I want to check the PTP on this board.
On the RT1170 there is the example code evkbmimxrt1170_enet_qos_txrx_ptp1588_transfer_cm7.
Do we have something similar for the RT1180 ?
I saw that fsl_enet_qos.h looks tot to be available in the SDK for RT1180.
Thank you for your support,
Viorel
标记 (2)
5 回复数
2,852 次查看
diego_charles
Hi @ViorelDv
Do you need PTP implementation using an stack?  Does our GenAVB stack works for you? https://github.com/NXP/GenAVB_TSN
Diego
2,824 次查看
ViorelDv
Hello @diego_charles ,
Thank you for the feedback.
I suppose that the GenAVB might also work.
Are the interfaces ENET_Ptp1588SetTimer/ENET_Ptp1588getTimer no longer supported for RT1180?
Viorel
2,785 次查看
diego_charles
Hi @ViorelDv
Thank you for your reply as well!
I checked and , at this moment this functions/interfaces are not implemented in the RT1180SDK. But I do not know if they will be added to upcoming SDK versions.
Are you in a hurry to evaluate PTP?  Do you need more help?
Diego
2,766 次查看
ViorelDv
Hi @diego_charles ,
We were using in one of our projects an implementation with RT1170 using ENET_Ptp1588SetTimer/ENET_Ptp1588getTimer.
I was hopping that I will be able to port the code, more or less, directly on RT1180.
In this case I think we will have to try to adapt to GenAVB.
Viorel
2,742 次查看
diego_charles
Hi @ViorelDv
Ok, I understand you!
Feel free to reach out us again in the future, if you get any issues with that stack and we can help out.
Diego
