VS code build error - ninja: error: loading 'build.ninja':
6,667件の閲覧回数
dan_ash
I was happily using VS Code building RT700 code using mcuxsdk repo 25.12.00.
All the sudden my projects would not build and I saw message:
Workspace is /c:/projects/mcuxsdk/mcuxsdk/examples/demo_apps/hello_world
build task started....
"C:\Program Files\CMake\bin\cmake.EXE" --build C:/projects/mcuxsdk/mcuxsdk/examples/demo_apps/hello_world/debug --target all --
ninja: error: loading 'build.ninja': The system cannot find the file specified.
I am sure I did something.
I removed the repo and re-cloned. Reimported core0 hello world.
Any ideas? Thank you.
Still same.
I saw community post: https://community.nxp.com/t5/i-MX-Processors/I-have-a-problem-to-run-a-project-and-gave-me-an-Error-...
The post states the files need the following variables set properly
1) mcux_include.json - ARMGCC_DIR
My file: "ARMGCC_DIR"
: "C:/NXP/MCUXpressoIDE_25.6.136/ide/tools"
2) .vscode\mcuxpresso-tools.json - toolchainPath
My file: "toolchainPath": "C:/NXP/MCUXpressoIDE_25.6.136/ide/tools"
6,622件の閲覧回数
dan_ash
After chatting with Jason, I realized I had not seen the first error which was missing yaml.
What happened was I had some other issue and installed Python (3.13) from VS Code (extensions), but I already had a working 3.14 I installed in Windows, which had yaml. I had also copied west.exe to that Python folder. And my path had the 3.14 folder.
Once I uninstalled (Windows settings apps uninstall) the 3.13 I installed from VS code everything worked again.
Long story, 3.13 did not have yaml, but I decided to simply remove it and rely on the original 3.14 I had.
Sorry I went back more in the build and found
-- Ninja version: 1.13.1
CMake Error at C:/projects/mcuxsdk/mcuxsdk/cmake/extension/mcux_module.cmake:74 (message):
Traceback (most recent call last):
File "C:\projects\mcuxsdk\mcuxsdk\scripts\misc\mcux_module.py", line 28, in <module>
import yaml
ModuleNotFoundError: No module named 'yaml'
Call Stack (most recent call first):
c:/projects/mcuxsdk/mcuxsdk/cmake/extension/mcux.cmake:279 (include)
CMakeLists.txt:5 (project)
-- Configuring incomplete, errors occurred!
Configure finished with return code 1
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
* Executing task: CMake: build
build finished with error(s).
3 返答(返信)
6,637件の閲覧回数
fsl_jason_yu
Hi @dan_ash ,
I didn't see this issue before. Could you please confirm:
1. The new cloned repo is clean.
2. The imported project folder is clean.
3. When you see the error, does the file "ninja.build" exist?
6,633件の閲覧回数
dan_ash
@fsl_jason_yu ,
This is all I see.
No ninja.build, but it was there before when things works.
6,623件の閲覧回数
dan_ash
import yaml
%3CLINGO-SUB%20id%3D%22lingo-sub-2201285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EVS%20%E3%82%B3%E3%83%BC%E3%83%89%20%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%A8%E3%83%A9%E3%83%BC%20-%20ninja%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'build.ninja'%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%3A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%20mcuxsdk%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%2025.12.00%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20RT700%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%20VS%20Code%20%E3%82%92%E5%BF%AB%E9%81%A9%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%AA%81%E7%84%B6%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8C%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%0A%3CP%3E%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AF%20%2Fc%3A%2Fprojects%2Fmcuxsdk%2Fmcuxsdk%2Fexamples%2Fdemo_apps%2Fhello_world%20%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%22C%3A%5CProgram%20Files%5CCMake%5Cbin%5Ccmake.EXE%22%20--C%3A%2Fprojects%2Fmcuxsdk%2Fmcuxsdk%2Fexamples%2Fdemo_apps%2Fhello_world%2Fdebug%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%20--%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20--%3CBR%20%2F%3E%20ninja%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'build.ninja'%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E4%B8%AD%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%8D%E3%81%A3%E3%81%A8%E4%BD%95%E3%81%8B%E3%82%92%E3%81%97%E3%81%9F%E3%82%93%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E5%86%8D%E5%BA%A6%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82core0%20hello%20world%E3%82%92%E5%86%8D%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%95%E3%81%8B%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%20%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%A0%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FI-have-a-problem-to-run-a-project-and-gave-me-an-Error-to-build%2Fm-p%2F2068732%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FI-have-a-problem-to-run-a-project-and-gave-me-an-Error-to-build%2Fmp%2F2068732%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%81%A7%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E6%AC%A1%E3%81%AE%E5%A4%89%E6%95%B0%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E8%BF%B0%E3%81%B9%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%201)%20mcux_include.json%20-%20%3CSPAN%3EARMGCC_DIR%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20%22ARMGCC_DIR%22%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%22C%3A%2FNXP%2FMCUXpressoIDE_25.6.136%2Fide%2Ftools%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2)%20.vscode%5Cmcuxpresso-tools.json%20-%3CSPAN%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%A7%81%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20%22toolchainPath%22%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%22C%3A%2FNXP%2FMCUXpressoIDE_25.6.136%2Fide%2Ftools%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20VS%20code%20build%20error%20-%20ninja%3A%20error%3A%20loading%20'build.ninja'%3A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EJason%20%E3%81%A8%E3%83%81%E3%83%A3%E3%83%83%E3%83%88%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E7%A7%81%E3%81%AF%20yaml%20%E3%81%8C%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%84%E3%81%A6%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%9F%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%A8%E3%80%81%E5%88%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81VS%20Code%20(%E6%8B%A1%E5%BC%B5%E6%A9%9F%E8%83%BD)%20%E3%81%8B%E3%82%89%20Python%20(3.13)%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81Windows%20%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%9F%203.14%20%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%A6%E3%80%81yaml%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82west.exe%20%E3%82%82%E3%81%9D%E3%81%AE%20Python%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AE%E3%83%91%E3%82%B9%E3%81%AB%E3%81%AF%203.14%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3EVS%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%9F%203.13%20%E3%82%92%E3%82%A2%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%20(Windows%20%E8%A8%AD%E5%AE%9A%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E3%82%A2%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB)%20%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E5%86%8D%E3%81%B3%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%95%B7%E3%81%84%E8%A9%B1%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%813.13%20%E3%81%AB%E3%81%AF%20yaml%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E5%8D%98%E7%B4%94%E3%81%AB%E5%89%8A%E9%99%A4%E3%81%97%E3%80%81%E5%85%83%E3%81%AE%203.14%20%E3%81%AB%E9%A0%BC%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E3%82%82%E3%81%A3%E3%81%A8%E9%81%A1%E3%81%A3%E3%81%A6%3CBR%20%2F%3E%3CBR%20%2F%3E--%20Ninja%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.13.1%3C%2FP%3E%0A%3CP%3EC%3A%2Fprojects%2Fmcuxsdk%2Fmcuxsdk%2Fcmake%2Fextension%2Fmcux_module.cmake%3A74%20%E3%81%A7%E3%81%AE%20CMake%20%E3%82%A8%E3%83%A9%E3%83%BC%20(%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8)%3A%3C%2FP%3E%0A%3CP%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%EF%BC%88%E6%9C%80%E6%96%B0%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C%EF%BC%89%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22C%3A%5Cprojects%5Cmcuxsdk%5Cmcuxsdk%5Cscripts%5Cmisc%5Cmcux_module.py%22%E3%80%81%3CMODULE%3E%20%E3%81%AE%2028%20%E8%A1%8C%E7%9B%AE%3C%2FMODULE%3E%3C%2FP%3E%0A%3CP%3Eyaml%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3CBR%20%2F%3EModuleNotFoundError%3A%20'yaml'%20%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%20(%E6%9C%80%E6%96%B0%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E5%85%88%E9%A0%AD)%3A%3C%2FP%3E%0A%3CP%3Ec%3A%2Fprojects%2Fmcuxsdk%2Fmcuxsdk%2Fcmake%2Fextension%2Fmcux.cmake%3A279%20(%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89)%3C%2FP%3E%0A%3CP%3ECMakeLists.txt%3A5%20(%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88)%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20--%20%E8%A8%AD%E5%AE%9A%E3%81%8C%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%A7%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%A7%8B%E6%88%90%E3%81%AF%E6%88%BB%E3%82%8A%E3%82%B3%E3%83%BC%E3%83%891%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E*%20%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%201%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E*%20%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%AF%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%86%8D%E5%88%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E9%96%89%E3%81%98%E3%82%8B%E3%81%AB%E3%81%AF%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E*%20%E5%AE%9F%E8%A1%8C%E3%82%BF%E3%82%B9%E3%82%AF%3A%20CMake%3A%20%E3%83%93%E3%83%AB%E3%83%89%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AF%20%2Fc%3A%2Fprojects%2Fmcuxsdk%2Fmcuxsdk%2Fexamples%2Fdemo_apps%2Fhello_world%20%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%22C%3A%5CProgram%20Files%5CCMake%5Cbin%5Ccmake.EXE%22%20--C%3A%2Fprojects%2Fmcuxsdk%2Fmcuxsdk%2Fexamples%2Fdemo_apps%2Fhello_world%2Fdebug%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%20--%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20--%3C%2FP%3E%0A%3CP%3Eninja%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'build.ninja'%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E4%B8%AD%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20VS%20code%20build%20error%20-%20ninja%3A%20error%3A%20loading%20'build.ninja'%3A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57117%22%20target%3D%22_blank%22%3E%40fsl_jason_yu%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%8C%E8%A6%8B%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22dan_ash_0-1762742293975.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dan_ash_0-1762742293975.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364551i74405B9B58F69154%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22dan_ash_0-1762742293975.png%22%20alt%3D%22dan_ash_0-1762742293975.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edan_ash_0-1762742293975.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Eninja.build%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%89%A9%E4%BA%8B%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AF%E4%BB%A5%E5%89%8D%E3%81%8B%E3%82%89%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20VS%20code%20build%20error%20-%20ninja%3A%20error%3A%20loading%20'build.ninja'%3A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204615%22%20target%3D%22_blank%22%3E%40dan_ash%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E5%89%8D%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3A%3C%2FP%3E%0A%3CP%3E1.%E6%96%B0%E3%81%97%E3%81%8F%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AF%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%AF%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E3.%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%82%89%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cninja.build%E3%80%8D%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22fsl_jason_yu_0-1762741557665.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fsl_jason_yu_0-1762741557665.png%22%20style%3D%22width%3A%20347px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364544i7C363F9C79CC7B37%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22fsl_jason_yu_0-1762741557665.png%22%20alt%3D%22fsl_jason_yu_0-1762741557665.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Efsl_jason_yu_0-1762741557665.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
