i.MX8MM SDK is bad
i.MX8MM SDK is bad
1,026 次查看
davidvescovi
Not only will it not load into Xpresso IDE the manifest is full of errors.
This could not have been tested or they would have seen the many errors.
880 次查看
CarlosCasillas
Hi David,
I’m afraid that MCUXpresso IDE is not supported by MCUXpresso SDK for i.MX8MM. Just IAR and GCC are supported.
Hope this will be useful for you.
Best regards!
/Carlos
880 次查看
davidvescovi
let me get this … you don't support your own toolchain?
