flexio camera
flexio camera
1,712 次查看
seobi
Hi, We are planning to use a parallel camera with FlexIO on the EVKBRT1170.
Referring to the RT1010 sample, we have two questions during the implementation:
1. The PCLK on the RT1010 is said to support up to 20MHz. How much is supported in the case of the RT1170? I couldn't find this information in the datasheet.
2. The sample for the RT1010 is for 8-bit data, but in our case, we need to use 16-bit data. Is it possible to obtain a sample for this? If not, could you guide us on what needs to be modified?
1,640 次查看
EdwinHz
Hi @seobi,
1. The PCLK frequency can be as high as the Clock Source frequency that the FlexIO admits. For the case of the RT1170, this would equate to a maximum of 120MHz.
2. I'm afraid that only 8-bit data is supported for the parallel camera emulated with FlexIO. I apologize for the inconvenience this may cause.
BR,
Edwin.
1,641 次查看
EdwinHz
Hi @seobi,
BR,
Edwin.
%3CLINGO-SUB%20id%3D%22lingo-sub-1945760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B1%88%E5%85%89%E7%9B%B8%E6%9C%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1945760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%88%91%E4%BB%AC%E8%AE%A1%E5%88%92%E5%9C%A8%20EVKBRT1170%20%E4%B8%8A%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20FlexIO%20%E7%9A%84%E5%B9%B6%E8%A1%8C%E6%91%84%E5%83%8F%E5%A4%B4%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83RT1010%E7%A4%BA%E4%BE%8B%EF%BC%8C%E6%88%91%E4%BB%AC%E5%9C%A8%E5%AE%9E%E7%8E%B0%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%9C%89%E4%B8%A4%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E1.%E6%8D%AE%E7%A7%B0%20RT1010%20%E4%B8%8A%E7%9A%84%20PCLK%20%E6%9C%80%E9%AB%98%E6%94%AF%E6%8C%81%2020MHz%E3%80%82%3CSPAN%3ERT1170%20%E7%9A%84%E6%83%85%E5%86%B5%E6%94%AF%E6%8C%81%E5%A4%9A%E5%B0%91%EF%BC%9F%E6%88%91%E5%9C%A8%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E8%BF%99%E6%96%B9%E9%9D%A2%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E2.%20RT1010%20%E7%9A%84%E6%A0%B7%E6%9C%AC%E6%98%AF%208%20%E4%BD%8D%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E4%BE%8B%E5%AD%90%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%2016%20%E4%BD%8D%E6%95%B0%E6%8D%AE%E3%80%82%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%BE%97%E6%AD%A4%E6%A0%B7%E6%9C%AC%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%EF%BC%8C%E6%82%A8%E8%83%BD%E6%8C%87%E5%AF%BC%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
