errors in code of SDK for RT1170
1,021件の閲覧回数
mastupristi
Senior Contributor I
I use SDK 25.12.00 for RT1170
When I use the `-Wextra` compilation parameter I get the following warning (I use -Werror so I get errors)
drivers/nxpDrivers/fsl_asrc.c:886:52: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_asrc_edma.c:56:48: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_asrc_edma.c:56:77: error: unused parameter 'done' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_asrc_edma.c:56:92: error: unused parameter 'tcds' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_asrc_edma.c:79:49: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_asrc_edma.c:79:78: error: unused parameter 'done' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_asrc_edma.c:79:93: error: unused parameter 'tcds' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_asrc_edma.c:376:42: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_asrc_edma.c:400:43: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_caam.c:18:2: error: #warning "DCACHE must be set to write-trough mode to safely invalidate cache!!" [-Werror=cpp]
drivers/nxpDrivers/fsl_caam.c:833:53: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_caam.c:1168:53: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_caam.c:1600:59: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_caam.c:1601:56: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_caam.c:1823:61: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_caam.c:1824:58: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_caam.c:1913:61: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_caam.c:1914:58: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_pmu.h:500:78: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_pmu.h:566:78: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_clock.c:1745:46: error: unused parameter 'src' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_clock.c:1745:60: error: unused parameter 'freq' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_clock.c:1758:56: error: unused parameter 'src' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_clock.c:1862:46: error: unused parameter 'src' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_clock.c:1862:60: error: unused parameter 'freq' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_clock.c:1866:56: error: unused parameter 'src' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_enet.h:1147:82: error: unused parameter 'rxEnabled' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_enet.c:480:38: error: unused parameter 'srcClock_Hz' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_enet.c:2956:73: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_enet.c:3161:56: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexcan.c:1889:43: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexcan.c:2319:56: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexcan.c:4342:56: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexcan_edma.c:267:60: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_i2c_master.c:1367:61: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_i2s.c:787:59: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_i2s.c:815:62: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_i2s_edma.c:65:54: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_i2s_edma.c:65:83: error: unused parameter 'done' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_i2s_edma.c:65:98: error: unused parameter 'tcds' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_i2s_edma.c:85:54: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_i2s_edma.c:85:83: error: unused parameter 'done' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_i2s_edma.c:85:98: error: unused parameter 'tcds' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_i2s_edma.c:427:63: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_i2s_edma.c:456:66: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_spi.c:1346:61: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_spi_edma.c:77:54: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_spi_edma.c:102:54: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_spi_edma.c:432:65: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_uart.c:739:61: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_uart.c:928:64: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_uart_edma.c:360:68: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexio_uart_edma.c:391:65: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexspi.c:1190:49: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_flexspi_edma.c:142:51: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_iee_apc.c:32:41: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_iee_apc.c:54:42: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_iee_apc.c:629:41: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_key_manager.c:213:36: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpi2c.c:2388:50: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpi2c_edma.c:515:55: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpi2c_edma.c:600:53: error: unused parameter 'dmaHandle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpi2c_edma.c:600:85: error: unused parameter 'isTransferDone' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpi2c_edma.c:600:110: error: unused parameter 'tcds' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpi2c_freertos.c:16:45: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpi2c_freertos.c:16:74: error: unused parameter 'drv_handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpspi.c:1101:93: error: unused parameter 'stateParams' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpspi.c:1160:104: error: unused parameter 'stateParams' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpspi.c:1690:51: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpspi.c:2158:50: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpspi_edma.c:694:47: error: unused parameter 'tcds' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpspi_edma.c:845:55: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpspi_edma.c:1252:46: error: unused parameter 'tcds' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpspi_edma.c:1338:54: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpspi_freertos.c:16:45: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpspi_freertos.c:16:74: error: unused parameter 'drv_handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpuart.c:242:58: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpuart.c:1932:54: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpuart.c:2283:49: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpuart.c:2283:61: error: unused parameter 'irqHandle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpuart_edma.c:388:58: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpuart_edma.c:419:55: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_lpuart_freertos.c:19:70: error: unused parameter 'state' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_mipi_dsi.c:823:60: error: unused parameter 'virtualChannel' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_mipi_dsi.c:1367:49: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_ocotp.c:144:44: error: unused parameter 'srcClock_Hz' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_pdm_edma.c:87:74: error: unused parameter 'done' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_pdm_edma.c:87:89: error: unused parameter 'tcds' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_pdm_edma.c:496:52: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_puf.c:80:55: error: unused parameter 'conf' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_pwm.c:1281:42: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_qtmr.c:724:44: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_rdc_sema42.c:91:42: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_rdc_sema42.c:107:44: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_sai.c:2098:45: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_sai.c:2126:48: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_sai_edma.c:95:76: error: unused parameter 'done' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_sai_edma.c:133:76: error: unused parameter 'done' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_sai_edma.c:1044:49: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_sai_edma.c:1073:52: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_sai_edma.c:1104:58: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_sema4.c:95:29: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_sema4.c:111:31: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_smartcard_emvsim.c:947:92: error: comparison of integer expressions of different signedness: 'int' and 'unsigned int' [-Werror=sign-compare]
drivers/nxpDrivers/fsl_smartcard_uart.h:84:30: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.h:92:28: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.h:107:50: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.h:121:39: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.h:138:45: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.h:151:33: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.h:165:32: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.h:175:35: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.h:183:38: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:20:8: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:20:41: error: 'UART_BASE_PTRS' undeclared here (not in a function); did you mean 'LPUART_BASE_PTRS'?
drivers/nxpDrivers/fsl_smartcard_uart.c:23:46: error: 'UART_CLOCKS' undeclared here (not in a function); did you mean 'LPUART_CLOCKS'?
drivers/nxpDrivers/fsl_smartcard_uart.c:29:45: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:30:42: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:31:48: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:32:45: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:33:44: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:36:44: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:37:50: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:48:44: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:72:45: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:101:48: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:137:42: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:171:45: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:215:44: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:439:23: error: 'kCLOCK_Pit0' undeclared (first use in this function); did you mean 'kCLOCK_Pit2'?
drivers/nxpDrivers/fsl_smartcard_uart.c:442:5: error: 'PIT' undeclared (first use in this function); did you mean 'PIT1'?
drivers/nxpDrivers/fsl_smartcard_uart.c:448:20: error: 'PIT0_IRQn' undeclared (first use in this function); did you mean 'PIT2_IRQn'?
drivers/nxpDrivers/fsl_smartcard_uart.c:435:46: error: parameter 'channel' set but not used [-Werror=unused-but-set-parameter]
drivers/nxpDrivers/fsl_smartcard_uart.c:458:24: error: 'kCLOCK_Pit0' undeclared (first use in this function); did you mean 'kCLOCK_Pit2'?
drivers/nxpDrivers/fsl_smartcard_uart.c:461:21: error: 'PIT0_IRQn' undeclared (first use in this function); did you mean 'PIT2_IRQn'?
drivers/nxpDrivers/fsl_smartcard_uart.c:473:5: error: 'PIT' undeclared (first use in this function); did you mean 'PIT1'?
drivers/nxpDrivers/fsl_smartcard_uart.c:470:40: error: parameter 'channel' set but not used [-Werror=unused-but-set-parameter]
drivers/nxpDrivers/fsl_smartcard_uart.c:486:5: error: 'PIT' undeclared (first use in this function); did you mean 'PIT1'?
drivers/nxpDrivers/fsl_smartcard_uart.c:483:46: error: parameter 'channel' set but not used [-Werror=unused-but-set-parameter]
drivers/nxpDrivers/fsl_smartcard_uart.c:527:30: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:621:28: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:680:50: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:712:39: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:758:45: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:820:35: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:986:32: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:1087:50: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:1288:33: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:1491:38: error: unknown type name 'UART_Type'; did you mean 'LPUART_Type'?
drivers/nxpDrivers/fsl_smartcard_uart.c:483:13: error: 'smartcard_uart_TimerStop' defined but not used [-Werror=unused-function]
drivers/nxpDrivers/fsl_smartcard_uart.c:454:13: error: 'smartcard_uart_TimerDeinit' defined but not used [-Werror=unused-function]
drivers/nxpDrivers/fsl_smartcard_uart.c:435:13: error: 'smartcard_uart_TimerInit' defined but not used [-Werror=unused-function]
drivers/nxpDrivers/fsl_smartcard_uart.c:23:30: error: 's_uartClock' defined but not used [-Werror=unused-const-variable=]
drivers/nxpDrivers/fsl_smartcard_uart.c:20:25: error: 's_uartBases' defined but not used [-Werror=unused-const-variable=]
drivers/nxpDrivers/fsl_snvs_hp.c:246:30: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_snvs_hp.c:260:32: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_snvs_lp.c:267:32: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_soc_mipi_csi2rx.c:30:50: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_soc_mipi_csi2rx.c:42:50: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_soc_mipi_csi2rx.c:65:52: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_spdif.c:547:49: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_spdif.c:575:52: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_spdif_edma.c:89:49: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_spdif_edma.c:89:78: error: unused parameter 'done' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_spdif_edma.c:89:93: error: unused parameter 'tcds' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_spdif_edma.c:109:49: error: unused parameter 'handle' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_spdif_edma.c:109:78: error: unused parameter 'done' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_spdif_edma.c:109:93: error: unused parameter 'tcds' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_spdif_edma.c:663:53: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_spdif_edma.c:692:56: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_ssarc.c:69:21: error: array subscript 16 is above array bounds of 'struct <anonymous>[16]' [-Werror=array-bounds=]
drivers/nxpDrivers/fsl_ssarc.c:65:21: error: array subscript 16 is above array bounds of 'struct <anonymous>[16]' [-Werror=array-bounds=]
drivers/nxpDrivers/fsl_tempsensor.c:32:1: error: 'static' is not at beginning of declaration [-Werror=old-style-declaration]
drivers/nxpDrivers/fsl_tempsensor.c:33:1: error: 'static' is not at beginning of declaration [-Werror=old-style-declaration]
drivers/nxpDrivers/fsl_tempsensor.c:34:1: error: 'static' is not at beginning of declaration [-Werror=old-style-declaration]
drivers/nxpDrivers/fsl_tempsensor.c:35:1: error: 'static' is not at beginning of declaration [-Werror=old-style-declaration]
drivers/nxpDrivers/fsl_xrdc2.c:80:29: error: unused parameter 'base' [-Werror=unused-parameter]
drivers/nxpDrivers/fsl_xrdc2.c:91:31: error: unused parameter 'base' [-Werror=unused-parameter]
Could you please fix them?
best regards
Max
タグ(1)
5 返答(返信)
984件の閲覧回数
EdwinHz
Hi @mastupristi,
Are you using a specific example code from the SDK? I tried on a few SDK examples, but I didn't see the same issues.
974件の閲覧回数
mastupristi
Hi @EdwinHz
I get SDK_25_12_00_MIMXRT1170-EVKB, and
I just compiled each .c file in SDK_25_12_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/ one by one to highlight errors.
The compiler parameters are:
	--std=gnu23 \
	-c \
	-mcpu=cortex-m7 \
	-mthumb \
	-mfloat-abi=hard \
	-mfpu=fpv5-d16 \
	-specs=nano.specs \
	-mfp16-format=ieee \
	-fno-common \
	-O3 \
	-g3 \
	-Wall \
	-Wextra \
	-ffunction-sections \
	-fdata-sections \
	-fno-math-errno -fno-trapping-math -fno-signaling-nans \
	-falign-functions  -falign-jumps -falign-labels -falign-loops \
	-fstrict-aliasing \
	-fno-ivopts \
	-MMD \
	-MP \
	-Werror \
	-fdebug-prefix-map=$(ROOT_DIR)=.
best regards
Max
955件の閲覧回数
EdwinHz
Hi @mastupristi,
Thank you for reporting this. The -Wextra compiler flag does help to increase robustness and even prevent potential nuance errors on code by providing much stricter warning messages. However:
1. They don't show actual errors with the code; they are only potential warnings escalated to errors by the -Werror flag.
2. For the evaluation purposes that the SDK drivers are mainly used for, they will hardly represent a real issue.
3. Can even represent false positives at times.
In this case, since they don't represent real issues with the drivers' functionality and usage, it is up to the client to decide if they want to handle these un-consequential warning messages.
BR,
Edwin.
898件の閲覧回数
mastupristi
Hi @EdwinHz ,
Thank you for the clarification. However, I must admit I find this position somewhat surprising.
In many professional environments, strict compilation settings such as -Werror, -Wextra, and even static analysis tools are standard practice for production firmware, not just for robustness but also for compliance, safety, and long-term maintainability. Under these conditions, the SDK drivers in their current form do not build cleanly, which makes their direct use problematic.
While I understand that some warnings may not indicate functional defects in evaluation scenarios, they can still represent real risks in production contexts, especially when code is integrated into larger systems with stricter quality requirements. Treating them as “unconsequential” shifts the burden entirely onto the user, who must then audit, patch, or fork vendor code to meet basic build policies.
Could you please clarify NXP’s intended positioning of these drivers?
  • Are they meant only as reference implementations for evaluation?
  • Is there any plan to provide production-quality builds that are warning-clean under common strict flags?
  • What is the recommended approach for customers who need to use the SDK in safety-critical or high-reliability products?
Rewriting or maintaining private patches for core drivers significantly increases engineering cost and undermines the value of an official SDK. Clear guidance on best practices for production use would be very helpful.
Max
826件の閲覧回数
EdwinHz
Hi @mastupristi,
Firstly, I would like to clarify that what I meant by "inconsequential", was not that the warnings should be ignored. Rather, that the importance of these warning messages will depend on the client's specific applications.
The main purpose of the drivers we provide in the SDKs is to allow the proper evaluation of the MCU's capabilities, as well as the capacity for the client to work with their full functionality. However, the compliance of these drivers with specific standardizations or "best practices" are reserved for the client's side, since this will depend on a case-by-case manner.
That said, I do understand your concerns, so I will forward them to the SDK team.
BR,
Edwin.
%3CLINGO-SUB%20id%3D%22lingo-sub-2321911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1170%20%E7%94%A8%20SDK%20%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E5%86%85%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3ERT1170%E3%81%AB%E3%81%AFSDK%2025.12.00%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%60-Wextra%60%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E8%AD%A6%E5%91%8A%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20(-Werror%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99)%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Edrivers%2FnxpDrivers%2Ffsl_asrc.c%3A886%3A52%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_asrc_edma.c%3A56%3A48%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_asrc_edma.c%3A56%3A77%3A%20error%3A%20unused%20parameter%20'done'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_asrc_edma.c%3A56%3A92%3A%20error%3A%20unused%20parameter%20'tcds'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_asrc_edma.c%3A79%3A49%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_asrc_edma.c%3A79%3A78%3A%20error%3A%20unused%20parameter%20'done'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_asrc_edma.c%3A79%3A93%3A%20error%3A%20unused%20parameter%20'tcds'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_asrc_edma.c%3A376%3A42%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_asrc_edma.c%3A400%3A43%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_caam.c%3A18%3A2%3A%20error%3A%20%23warning%20%22DCACHE%20must%20be%20set%20to%20write-trough%20mode%20to%20safely%20invalidate%20cache!!%22%20%5B-Werror%3Dcpp%5D%0Adrivers%2FnxpDrivers%2Ffsl_caam.c%3A833%3A53%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_caam.c%3A1168%3A53%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_caam.c%3A1600%3A59%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_caam.c%3A1601%3A56%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_caam.c%3A1823%3A61%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_caam.c%3A1824%3A58%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_caam.c%3A1913%3A61%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_caam.c%3A1914%3A58%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_pmu.h%3A500%3A78%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_pmu.h%3A566%3A78%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_clock.c%3A1745%3A46%3A%20error%3A%20unused%20parameter%20'src'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_clock.c%3A1745%3A60%3A%20error%3A%20unused%20parameter%20'freq'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_clock.c%3A1758%3A56%3A%20error%3A%20unused%20parameter%20'src'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_clock.c%3A1862%3A46%3A%20error%3A%20unused%20parameter%20'src'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_clock.c%3A1862%3A60%3A%20error%3A%20unused%20parameter%20'freq'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_clock.c%3A1866%3A56%3A%20error%3A%20unused%20parameter%20'src'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_enet.h%3A1147%3A82%3A%20error%3A%20unused%20parameter%20'rxEnabled'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_enet.c%3A480%3A38%3A%20error%3A%20unused%20parameter%20'srcClock_Hz'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_enet.c%3A2956%3A73%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_enet.c%3A3161%3A56%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexcan.c%3A1889%3A43%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexcan.c%3A2319%3A56%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexcan.c%3A4342%3A56%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexcan_edma.c%3A267%3A60%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_i2c_master.c%3A1367%3A61%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_i2s.c%3A787%3A59%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_i2s.c%3A815%3A62%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_i2s_edma.c%3A65%3A54%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_i2s_edma.c%3A65%3A83%3A%20error%3A%20unused%20parameter%20'done'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_i2s_edma.c%3A65%3A98%3A%20error%3A%20unused%20parameter%20'tcds'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_i2s_edma.c%3A85%3A54%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_i2s_edma.c%3A85%3A83%3A%20error%3A%20unused%20parameter%20'done'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_i2s_edma.c%3A85%3A98%3A%20error%3A%20unused%20parameter%20'tcds'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_i2s_edma.c%3A427%3A63%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_i2s_edma.c%3A456%3A66%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_spi.c%3A1346%3A61%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_spi_edma.c%3A77%3A54%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_spi_edma.c%3A102%3A54%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_spi_edma.c%3A432%3A65%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_uart.c%3A739%3A61%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_uart.c%3A928%3A64%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_uart_edma.c%3A360%3A68%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexio_uart_edma.c%3A391%3A65%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexspi.c%3A1190%3A49%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_flexspi_edma.c%3A142%3A51%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_iee_apc.c%3A32%3A41%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_iee_apc.c%3A54%3A42%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_iee_apc.c%3A629%3A41%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_key_manager.c%3A213%3A36%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpi2c.c%3A2388%3A50%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpi2c_edma.c%3A515%3A55%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpi2c_edma.c%3A600%3A53%3A%20error%3A%20unused%20parameter%20'dmaHandle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpi2c_edma.c%3A600%3A85%3A%20error%3A%20unused%20parameter%20'isTransferDone'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpi2c_edma.c%3A600%3A110%3A%20error%3A%20unused%20parameter%20'tcds'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpi2c_freertos.c%3A16%3A45%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpi2c_freertos.c%3A16%3A74%3A%20error%3A%20unused%20parameter%20'drv_handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpspi.c%3A1101%3A93%3A%20error%3A%20unused%20parameter%20'stateParams'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpspi.c%3A1160%3A104%3A%20error%3A%20unused%20parameter%20'stateParams'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpspi.c%3A1690%3A51%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpspi.c%3A2158%3A50%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpspi_edma.c%3A694%3A47%3A%20error%3A%20unused%20parameter%20'tcds'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpspi_edma.c%3A845%3A55%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpspi_edma.c%3A1252%3A46%3A%20error%3A%20unused%20parameter%20'tcds'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpspi_edma.c%3A1338%3A54%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpspi_freertos.c%3A16%3A45%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpspi_freertos.c%3A16%3A74%3A%20error%3A%20unused%20parameter%20'drv_handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpuart.c%3A242%3A58%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpuart.c%3A1932%3A54%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpuart.c%3A2283%3A49%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpuart.c%3A2283%3A61%3A%20error%3A%20unused%20parameter%20'irqHandle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpuart_edma.c%3A388%3A58%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpuart_edma.c%3A419%3A55%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_lpuart_freertos.c%3A19%3A70%3A%20error%3A%20unused%20parameter%20'state'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_mipi_dsi.c%3A823%3A60%3A%20error%3A%20unused%20parameter%20'virtualChannel'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_mipi_dsi.c%3A1367%3A49%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_ocotp.c%3A144%3A44%3A%20error%3A%20unused%20parameter%20'srcClock_Hz'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_pdm_edma.c%3A87%3A74%3A%20error%3A%20unused%20parameter%20'done'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_pdm_edma.c%3A87%3A89%3A%20error%3A%20unused%20parameter%20'tcds'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_pdm_edma.c%3A496%3A52%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_pmu.h%3A500%3A78%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_pmu.h%3A566%3A78%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_puf.c%3A80%3A55%3A%20error%3A%20unused%20parameter%20'conf'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_pwm.c%3A1281%3A42%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_qtmr.c%3A724%3A44%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_rdc_sema42.c%3A91%3A42%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_rdc_sema42.c%3A107%3A44%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_sai.c%3A2098%3A45%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_sai.c%3A2126%3A48%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_sai_edma.c%3A95%3A76%3A%20error%3A%20unused%20parameter%20'done'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_sai_edma.c%3A133%3A76%3A%20error%3A%20unused%20parameter%20'done'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_sai_edma.c%3A1044%3A49%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_sai_edma.c%3A1073%3A52%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_sai_edma.c%3A1104%3A58%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_sema4.c%3A95%3A29%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_sema4.c%3A111%3A31%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_emvsim.c%3A947%3A92%3A%20error%3A%20comparison%20of%20integer%20expressions%20of%20different%20signedness%3A%20'int'%20and%20'unsigned%20int'%20%5B-Werror%3Dsign-compare%5D%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.h%3A84%3A30%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.h%3A92%3A28%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.h%3A107%3A50%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.h%3A121%3A39%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.h%3A138%3A45%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.h%3A151%3A33%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.h%3A165%3A32%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.h%3A175%3A35%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.h%3A183%3A38%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A20%3A8%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A20%3A41%3A%20error%3A%20'UART_BASE_PTRS'%20undeclared%20here%20(not%20in%20a%20function)%3B%20did%20you%20mean%20'LPUART_BASE_PTRS'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A23%3A46%3A%20error%3A%20'UART_CLOCKS'%20undeclared%20here%20(not%20in%20a%20function)%3B%20did%20you%20mean%20'LPUART_CLOCKS'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A29%3A45%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A30%3A42%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A31%3A48%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A32%3A45%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A33%3A44%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A36%3A44%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A37%3A50%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A48%3A44%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A72%3A45%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A101%3A48%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A137%3A42%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A171%3A45%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A215%3A44%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A439%3A23%3A%20error%3A%20'kCLOCK_Pit0'%20undeclared%20(first%20use%20in%20this%20function)%3B%20did%20you%20mean%20'kCLOCK_Pit2'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A442%3A5%3A%20error%3A%20'PIT'%20undeclared%20(first%20use%20in%20this%20function)%3B%20did%20you%20mean%20'PIT1'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A448%3A20%3A%20error%3A%20'PIT0_IRQn'%20undeclared%20(first%20use%20in%20this%20function)%3B%20did%20you%20mean%20'PIT2_IRQn'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A435%3A46%3A%20error%3A%20parameter%20'channel'%20set%20but%20not%20used%20%5B-Werror%3Dunused-but-set-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A458%3A24%3A%20error%3A%20'kCLOCK_Pit0'%20undeclared%20(first%20use%20in%20this%20function)%3B%20did%20you%20mean%20'kCLOCK_Pit2'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A461%3A21%3A%20error%3A%20'PIT0_IRQn'%20undeclared%20(first%20use%20in%20this%20function)%3B%20did%20you%20mean%20'PIT2_IRQn'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A473%3A5%3A%20error%3A%20'PIT'%20undeclared%20(first%20use%20in%20this%20function)%3B%20did%20you%20mean%20'PIT1'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A470%3A40%3A%20error%3A%20parameter%20'channel'%20set%20but%20not%20used%20%5B-Werror%3Dunused-but-set-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A486%3A5%3A%20error%3A%20'PIT'%20undeclared%20(first%20use%20in%20this%20function)%3B%20did%20you%20mean%20'PIT1'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A483%3A46%3A%20error%3A%20parameter%20'channel'%20set%20but%20not%20used%20%5B-Werror%3Dunused-but-set-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A527%3A30%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A621%3A28%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A680%3A50%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A712%3A39%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A758%3A45%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A820%3A35%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A986%3A32%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A1087%3A50%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A1288%3A33%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A1491%3A38%3A%20error%3A%20unknown%20type%20name%20'UART_Type'%3B%20did%20you%20mean%20'LPUART_Type'%3F%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A483%3A13%3A%20error%3A%20'smartcard_uart_TimerStop'%20defined%20but%20not%20used%20%5B-Werror%3Dunused-function%5D%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A454%3A13%3A%20error%3A%20'smartcard_uart_TimerDeinit'%20defined%20but%20not%20used%20%5B-Werror%3Dunused-function%5D%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A435%3A13%3A%20error%3A%20'smartcard_uart_TimerInit'%20defined%20but%20not%20used%20%5B-Werror%3Dunused-function%5D%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A23%3A30%3A%20error%3A%20's_uartClock'%20defined%20but%20not%20used%20%5B-Werror%3Dunused-const-variable%3D%5D%0Adrivers%2FnxpDrivers%2Ffsl_smartcard_uart.c%3A20%3A25%3A%20error%3A%20's_uartBases'%20defined%20but%20not%20used%20%5B-Werror%3Dunused-const-variable%3D%5D%0Adrivers%2FnxpDrivers%2Ffsl_snvs_hp.c%3A246%3A30%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_snvs_hp.c%3A260%3A32%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_snvs_lp.c%3A267%3A32%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_soc_mipi_csi2rx.c%3A30%3A50%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_soc_mipi_csi2rx.c%3A42%3A50%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_soc_mipi_csi2rx.c%3A65%3A52%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_spdif.c%3A547%3A49%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_spdif.c%3A575%3A52%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_spdif_edma.c%3A89%3A49%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_spdif_edma.c%3A89%3A78%3A%20error%3A%20unused%20parameter%20'done'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_spdif_edma.c%3A89%3A93%3A%20error%3A%20unused%20parameter%20'tcds'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_spdif_edma.c%3A109%3A49%3A%20error%3A%20unused%20parameter%20'handle'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_spdif_edma.c%3A109%3A78%3A%20error%3A%20unused%20parameter%20'done'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_spdif_edma.c%3A109%3A93%3A%20error%3A%20unused%20parameter%20'tcds'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_spdif_edma.c%3A663%3A53%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_spdif_edma.c%3A692%3A56%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_ssarc.c%3A69%3A21%3A%20error%3A%20array%20subscript%2016%20is%20above%20array%20bounds%20of%20'struct%20%3CANONYMOUS%3E%5B16%5D'%20%5B-Werror%3Darray-bounds%3D%5D%0Adrivers%2FnxpDrivers%2Ffsl_ssarc.c%3A69%3A21%3A%20error%3A%20array%20subscript%2016%20is%20above%20array%20bounds%20of%20'struct%20%3CANONYMOUS%3E%5B16%5D'%20%5B-Werror%3Darray-bounds%3D%5D%0Adrivers%2FnxpDrivers%2Ffsl_ssarc.c%3A65%3A21%3A%20error%3A%20array%20subscript%2016%20is%20above%20array%20bounds%20of%20'struct%20%3CANONYMOUS%3E%5B16%5D'%20%5B-Werror%3Darray-bounds%3D%5D%0Adrivers%2FnxpDrivers%2Ffsl_ssarc.c%3A65%3A21%3A%20error%3A%20array%20subscript%2016%20is%20above%20array%20bounds%20of%20'struct%20%3CANONYMOUS%3E%5B16%5D'%20%5B-Werror%3Darray-bounds%3D%5D%0Adrivers%2FnxpDrivers%2Ffsl_tempsensor.c%3A32%3A1%3A%20error%3A%20'static'%20is%20not%20at%20beginning%20of%20declaration%20%5B-Werror%3Dold-style-declaration%5D%0Adrivers%2FnxpDrivers%2Ffsl_tempsensor.c%3A33%3A1%3A%20error%3A%20'static'%20is%20not%20at%20beginning%20of%20declaration%20%5B-Werror%3Dold-style-declaration%5D%0Adrivers%2FnxpDrivers%2Ffsl_tempsensor.c%3A34%3A1%3A%20error%3A%20'static'%20is%20not%20at%20beginning%20of%20declaration%20%5B-Werror%3Dold-style-declaration%5D%0Adrivers%2FnxpDrivers%2Ffsl_tempsensor.c%3A35%3A1%3A%20error%3A%20'static'%20is%20not%20at%20beginning%20of%20declaration%20%5B-Werror%3Dold-style-declaration%5D%0Adrivers%2FnxpDrivers%2Ffsl_xrdc2.c%3A80%3A29%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%0Adrivers%2FnxpDrivers%2Ffsl_xrdc2.c%3A91%3A31%3A%20error%3A%20unused%20parameter%20'base'%20%5B-Werror%3Dunused-parameter%5D%3C%2FANONYMOUS%3E%3C%2FANONYMOUS%3E%3C%2FANONYMOUS%3E%3C%2FANONYMOUS%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A4%A7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20errors%20in%20code%20of%20SDK%20for%20RT1170%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186731%22%20target%3D%22_blank%22%3E%40EdwinHz%3C%2FA%3E%3C%2FP%3E%3CP%3ESDK_25_12_00_MIMXRT1170-EVKB%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%80%81%3C%2FP%3E%3CP%3E%E5%90%84.c%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9FSDK_25_12_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2F%20%E5%86%85%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%201%20%E3%81%A4%E3%81%9A%E3%81%A4%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%BC%B7%E8%AA%BF%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%09--std%3Dgnu23%20%5C%0A%09-c%20%5C%0A%09-mcpu%3Dcortex-m7%20%5C%0A%09-mthumb%20%5C%0A%09-mfloat-abi%3Dhard%20%5C%0A%09-mfpu%3Dfpv5-d16%20%5C%0A%09-specs%3Dnano.specs%20%5C%0A%09-mfp16-format%3Dieee%20%5C%0A%09-fno-common%20%5C%0A%09-O3%20%5C%0A%09-g3%20%5C%0A%09-Wall%20%5C%0A%09-Wextra%20%5C%0A%09-ffunction-sections%20%5C%0A%09-fdata-sections%20%5C%0A%09-fno-math-errno%20-fno-trapping-math%20-fno-signaling-nans%20%5C%0A%09-falign-functions%20%20-falign-jumps%20-falign-labels%20-falign-loops%20%5C%0A%09-fstrict-aliasing%20%5C%0A%09-fno-ivopts%20%5C%0A%09-MMD%20%5C%0A%09-MP%20%5C%0A%09-Werror%20%5C%0A%09-fdebug-prefix-map%3D%24(ROOT_DIR)%3D.%20%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A4%A7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20errors%20in%20code%20of%20SDK%20for%20RT1170%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F124967%22%20target%3D%22_blank%22%3E%40mastupristi%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3ESDK%20%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%20SDK%20%E3%81%AE%E4%BE%8B%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20errors%20in%20code%20of%20SDK%20for%20RT1170%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F124967%22%20target%3D%22_blank%22%3E%40mastupristi%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%94%E5%A0%B1%E5%91%8A%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82-Wextra%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%20%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AF%E3%80%81%E3%82%88%E3%82%8A%E5%8E%B3%E5%AF%86%E3%81%AA%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E5%A0%85%E7%89%A2%E6%80%A7%E3%82%92%E9%AB%98%E3%82%81%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%BD%9C%E5%9C%A8%E7%9A%84%E3%81%AA%E5%BE%AE%E5%A6%99%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E9%98%B2%E3%81%90%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%EF%BC%9A%3C%2FP%3E%0A%3CP%3E1.%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E7%A4%BA%E3%81%99%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81-Werror%20%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E3%82%A8%E3%82%B9%E3%82%AB%E3%83%AC%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E6%BD%9C%E5%9C%A8%E7%9A%84%E3%81%AA%E8%AD%A6%E5%91%8A%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20SDK%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E4%B8%BB%E3%81%AB%E8%A9%95%E4%BE%A1%E7%9B%AE%E7%9A%84%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E3.%20%E6%99%82%E3%81%AB%E3%81%AF%E8%AA%A4%E6%A4%9C%E5%87%BA%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%84%E4%BD%BF%E7%94%A8%E6%B3%95%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%AE%9F%E9%9A%9B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A1%A8%E3%81%99%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%AA%E3%81%84%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E6%B1%BA%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%E3%80%81%3CBR%20%2F%3E%E3%82%A8%E3%83%89%E3%82%A6%E3%82%A3%E3%83%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20errors%20in%20code%20of%20SDK%20for%20RT1170%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186731%22%20target%3D%22_blank%22%3E%40EdwinHz%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E7%AB%8B%E5%A0%B4%E3%81%AB%E5%B0%91%E3%80%85%E9%A9%9A%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%AA%8D%E3%82%81%E3%81%96%E3%82%8B%E3%82%92%E5%BE%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%97%E3%83%AD%E3%83%95%E3%82%A7%E3%83%83%E3%82%B7%E3%83%A7%E3%83%8A%E3%83%AB%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AF%E3%80%81%E5%A0%85%E7%89%A2%E6%80%A7%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AA%E3%81%8F%E3%80%81%E3%82%B3%E3%83%B3%E3%83%97%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%82%B9%E3%80%81%E3%82%BB%E3%83%BC%E3%83%95%E3%83%86%E3%82%A3%E6%80%A7%E3%80%81%E9%95%B7%E6%9C%9F%E7%9A%84%E3%81%AA%E4%BF%9D%E5%AE%88%E6%80%A7%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E-Werror%3C%2FFONT%3E%20%E3%80%81%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E-Wextra%3C%2FFONT%3E%E3%81%AA%E3%81%A9%E3%81%AE%E5%8E%B3%E5%AF%86%E3%81%AA%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E8%A8%AD%E5%AE%9A%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E3%81%AF%E9%9D%99%E7%9A%84%E5%88%86%E6%9E%90%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8C%E3%80%81%E8%A3%BD%E5%93%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%A8%99%E6%BA%96%E7%9A%84%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%8A%B6%E6%B3%81%E3%81%A7%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E5%BD%A2%E5%BC%8F%E3%81%AE%20SDK%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E5%95%8F%E9%A1%8C%E3%81%8C%E7%94%9F%E3%81%98%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%80%E9%83%A8%E3%81%AE%E8%AD%A6%E5%91%8A%E3%81%AF%E8%A9%95%E4%BE%A1%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%81%A7%E3%81%AF%E6%A9%9F%E8%83%BD%E4%B8%8A%E3%81%AE%E6%AC%A0%E9%99%A5%E3%82%92%E7%A4%BA%E3%81%95%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%89%B9%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%82%88%E3%82%8A%E5%8E%B3%E3%81%97%E3%81%84%E5%93%81%E8%B3%AA%E8%A6%81%E4%BB%B6%E3%82%92%E6%8C%81%E3%81%A4%E5%A4%A7%E8%A6%8F%E6%A8%A1%E3%81%AA%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E9%81%8B%E7%94%A8%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%AA%E3%82%B9%E3%82%AF%E3%82%92%E8%A1%A8%E3%81%99%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%82%92%E3%80%8C%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%AA%E3%81%84%E3%80%8D%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%A6%E6%89%B1%E3%81%86%E3%81%A8%E3%80%81%E8%B2%A0%E6%8B%85%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AB%E7%A7%BB%E3%82%8A%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E3%81%9F%E3%82%81%E3%81%AB%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%9B%A3%E6%9F%BB%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%95%E3%82%A9%E3%83%BC%E3%82%AF%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E7%94%9F%E3%81%98%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ENXP%20%E3%81%8C%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%9D%E3%82%B8%E3%82%B7%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E8%A9%95%E4%BE%A1%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E5%AE%9F%E8%A3%85%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AE%E3%81%BF%E6%84%8F%E5%9B%B3%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E5%8E%B3%E5%AF%86%E3%81%AA%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AE%E4%B8%8B%E3%81%A7%E8%AD%A6%E5%91%8A%E3%81%AE%E3%81%AA%E3%81%84%E6%9C%AC%E7%95%AA%E5%93%81%E8%B3%AA%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%82%BB%E3%83%BC%E3%83%95%E3%83%86%E3%82%A3%E3%81%8C%E9%87%8D%E8%A6%81%E8%A6%96%E3%81%95%E3%82%8C%E3%82%8B%E8%A3%BD%E5%93%81%E3%82%84%E9%AB%98%E4%BF%A1%E9%A0%BC%E6%80%A7%E8%A3%BD%E5%93%81%E3%81%A7%20SDK%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%82%B3%E3%82%A2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%9B%B8%E3%81%8D%E7%9B%B4%E3%81%97%E3%81%9F%E3%82%8A%E7%B6%AD%E6%8C%81%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%20%E3%82%B3%E3%82%B9%E3%83%88%E3%81%8C%E5%A4%A7%E5%B9%85%E3%81%AB%E5%A2%97%E5%8A%A0%E3%81%97%E3%80%81%E5%85%AC%E5%BC%8F%20SDK%20%E3%81%AE%E4%BE%A1%E5%80%A4%E3%81%8C%E6%90%8D%E3%81%AA%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9F%E7%A8%BC%E5%83%8D%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%99%E3%82%B9%E3%83%88%E3%83%97%E3%83%A9%E3%82%AF%E3%83%86%E3%82%A3%E3%82%B9%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%98%8E%E7%A2%BA%E3%81%AA%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%81%8C%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A4%A7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328115%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20errors%20in%20code%20of%20SDK%20for%20RT1170%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328115%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F124967%22%20target%3D%22_blank%22%3E%40mastupristi%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%80%8C%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%AA%E3%81%84%E3%80%8D%E3%81%A8%E3%81%AF%E3%80%81%3CSPAN%3E%E8%AD%A6%E5%91%8A%E3%82%92%E7%84%A1%E8%A6%96%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A8%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8A%E3%81%8D%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%80%E3%81%97%E3%82%8D%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E9%87%8D%E8%A6%81%E6%80%A7%E3%81%AF%E3%80%81%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESDK%20%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E4%B8%BB%E3%81%AA%E7%9B%AE%E7%9A%84%E3%81%AF%E3%80%81MCU%20%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E8%A9%95%E4%BE%A1%E3%81%97%E3%80%81%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AA%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E8%83%BD%E5%8A%9B%E3%82%92%E7%A2%BA%E4%BF%9D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%89%B9%E5%AE%9A%E3%81%AE%E6%A8%99%E6%BA%96%E5%8C%96%E3%82%84%E3%80%8C%E3%83%99%E3%82%B9%E3%83%88%20%E3%83%97%E3%83%A9%E3%82%AF%E3%83%86%E3%82%A3%E3%82%B9%E3%80%8D%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%80%81%E3%82%B1%E3%83%BC%E3%82%B9%E3%83%90%E3%82%A4%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7%E6%B1%BA%E3%81%BE%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E5%81%B4%E3%81%A7%E7%AE%A1%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%A8%E3%81%AF%E3%81%84%E3%81%88%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%87%B8%E5%BF%B5%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81SDK%20%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%E3%80%81%3CBR%20%2F%3E%E3%82%A8%E3%83%89%E3%82%A6%E3%82%A3%E3%83%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
