rw612
rw612
gtecaskari
This is the worst SDK I have ever used, and the new versions are getting worse. The overall quality is unacceptable. Some CMake configurations in the SDK need to be changed, the new project generation process is poor, the configuration tools are very bad, and the documentation is inadequate. Overall, the entire toolchain should be redesigned from scratch.
Christine_Li
Hi, @gtecaskari
Sorry for the bad experience.
Can you please let me know your detailed SDK version and what IDE are you using?
Are you using MCUXpersso for VS Code based on SDK 25.12.00?
And would you mind to let me know what's the detailed issue did you meet?
Hope I can help you somehow and I believe we can improve better with your suggestions and recommendations.
Thanks for your valuable feedback!
Christine.
Christine_Li
Hi, @gtecaskari
Anything I can do for you on this case?
If you can provide us valuable recommendations, would be appreciated very much!
Christine.
Christine_Li
Hi, @gtecaskari
I sincerely apologize for the bad experience on our SDK.
Anything I can do for you?
Christine.
%3CLINGO-SUB%20id%3D%22lingo-sub-2305383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Erw612%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20is%20the%20worst%20SDK%20I%20have%20ever%20used%2C%20and%20the%20new%20versions%20are%20getting%20worse.%20The%20overall%20quality%20is%20unacceptable.%20Some%20CMake%20configurations%20in%20the%20SDK%20need%20to%20be%20changed%2C%20the%20new%20project%20generation%20process%20is%20poor%2C%20the%20configuration%20tools%20are%20very%20bad%2C%20and%20the%20documentation%20is%20inadequate.%20Overall%2C%20the%20entire%20toolchain%20should%20be%20redesigned%20from%20scratch.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20rw612%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%EF%BC%8C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244149%22%20target%3D%22_blank%22%3E%40gtecaskari%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ESorry%20for%20the%20bad%20experience.%3C%2FP%3E%0A%3CP%3ECan%20you%20please%20let%20me%20know%20your%20detailed%20SDK%20version%20and%20what%20IDE%20are%20you%20using%3F%3C%2FP%3E%0A%3CP%3EAre%20you%20using%20MCUXpersso%20for%20VS%20Code%20based%20on%20SDK%2025.12.00%3F%3C%2FP%3E%0A%3CP%3EAnd%20would%20you%20mind%20to%20let%20me%20know%20what's%20the%20detailed%20issue%20did%20you%20meet%3F%3C%2FP%3E%0A%3CP%3EHope%20I%20can%20help%20you%20somehow%20and%20I%20believe%20we%20can%20improve%20better%20with%20your%20suggestions%20and%20recommendations.%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20valuable%20feedback!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2327566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20rw612%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244149%22%20target%3D%22_blank%22%3E%40gtecaskari%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAnything%20I%20can%20do%20for%20you%20on%20this%20case%3F%3C%2FP%3E%0A%3CP%3EIf%20you%20can%20provide%20us%20valuable%20recommendations%2C%20would%20be%20appreciated%20very%20much!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2330152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20rw612%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2330152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244149%22%20target%3D%22_blank%22%3E%40gtecaskari%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20sincerely%20apologize%20for%20the%20bad%20experience%20on%20our%20SDK.%3C%2FP%3E%0A%3CP%3EAnything%20I%20can%20do%20for%20you%3F%3C%2FP%3E%0A%3CP%3EIf%20you%20can%20provide%20us%20valuable%20recommendations%2C%20would%20be%20appreciated%20very%20much!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E
