USB1 Dropping byte
USB1 Dropping byte
848 次查看
SteveR406
Using K66 with MCUXpresso SDK to create a HID Generic device on USB1 interface.  Data is processed in 8 byte blocks and on the second block it drops the first byte. The byte is missing by the time I get a callback to process the data.  Any thoughts on why the byte is dropped?
831 次查看
SteveR406
Solved:  Needed to change my Report Size in g_UsbDeviceInterface0HidGenericReportDescriptor[] to be 64.  Also changed USB_INTERFACE_0_HID_GENERIC_INPUT_REPORT_LENGTH to match.
