Netx Duo UDP Sample program
DanielTC
In the SDK_2_15_100_MIMXRT1170-EVK\rtos\azure-rtos\netxduo\samples directory
how would you build the file demo_netx_duo_udp.c using IAR Embedded Workbench?
Gavin_Jia
Hi @DanielTC ,
Thanks for your interest in NXP MIMXRT series!
demo_netx_duo_udp.c is a simple example and very complete. So try importing a project already in the SDK like netx_do_iperf or netx_do_ping. Then go replace the original source file with the demo_netx_do_udp.c code and compile.
Gavin
Gavin_Jia
Hi @DanielTC ,
Gavin
DanielTC
Thanks Gavin, this solves my problem
%3CLINGO-SUB%20id%3D%22lingo-sub-1880044%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENetx%20Duo%20UDP%20Sample%20program%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1880044%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIn%20the%20SDK_2_15_100_MIMXRT1170-EVK%5Crtos%5Cazure-rtos%5Cnetxduo%5Csamples%20directory%3C%2FP%3E%3CP%3Ehow%20would%20you%20build%20the%20file%20demo_netx_duo_udp.c%20using%20IAR%20Embedded%20Workbench%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1885365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20Netx%20Duo%20UDP%20Sample%20program%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1885365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20Gavin%2C%20this%20solves%20my%20problem%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1881404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20Netx%20Duo%20UDP%20Sample%20program%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1881404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234480%22%20target%3D%22_blank%22%3E%40DanielTC%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20interest%20in%20NXP%20MIMXRT%20series!%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Edemo_netx_duo_udp.c%26nbsp%3B%3C%2FSPAN%3Eis%20a%20simple%20example%20and%20very%20complete.%20So%20try%20importing%20a%20project%20already%20in%20the%20SDK%20like%20netx_do_iperf%20or%20netx_do_ping.%20Then%20go%20replace%20the%20original%20source%20file%20with%20the%20demo_netx_do_udp.c%20code%20and%20compile.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EGavin%3C%2FP%3E%3C%2FLINGO-BODY%3E
