Netx Duo UDP Sample program
DanielTC
In the SDK_2_15_100_MIMXRT1170-EVK\rtos\azure-rtos\netxduo\samples directory
how would you build the file demo_netx_duo_udp.c using IAR Embedded Workbench?
Gavin_Jia
Hi @DanielTC ,
Thanks for your interest in NXP MIMXRT series!
demo_netx_duo_udp.c is a simple example and very complete. So try importing a project already in the SDK like netx_do_iperf or netx_do_ping. Then go replace the original source file with the demo_netx_do_udp.c code and compile.
Gavin
Gavin_Jia
Hi @DanielTC ,
Gavin
DanielTC
Thanks Gavin, this solves my problem
