Need clarification on USB g_compositeDeviceConfigList.count
1,648件の閲覧回数
michaelhuslig
The MCUXpresso SDK USB Stack Composite Device User's Guide, section 4.2, says the config list count should be the number of classes in the composite device.  It shows as example MSD+CDC is 2 classes.
Shouldn't CDC+CDC be 1 class?  The SDK example twrk22f120m_dev_composite_cdc_vcom_cdc_vcom_freertos shows it as 2.
1,522件の閲覧回数
danielchen
Hi MICHAEl:
CDC+CDC is two classes, usb stack will need allocate more memory. You can consider it as the count of classes rather than the type of  classes.
