MCUXpressoIDE_11.9.0_2144 - JN-AN-1244 - Config Pins problem
1,168 次查看
Larz
Goodday,
I've imported the JN-AN-1244 into MCUXpress. I've set the MCU to JN5189 and the associated SDK is JN5189DK6 version 2.6.13.
When I go to the "Pins" configtool and select the JN-AN-1244 project I get the message:
Can I solve this?
1,151 次查看
Larz
@Ricardo_Zamora Thank you for your reply.
I will look at the SDK\docs\wireless\Common\Connectivity Framework Reference Manual.pdf
Where can I find the output (output pins LED) in the JN-AN-1244 files?
For example the ExtendedColorLight has more outputs...
1,154 次查看
Ricardo_Zamora
Hope you are doing well. When using Connectivity applications, it is recommended to use the Connectivity Framework. Such as the "Keyboard" and "GPIO Adapter" services. So, could you please try to taking as a base these services? (Please refer to SDK\docs\wireless\Common\Connectivity Framework Reference Manual.pdf)
Ricardo
