How can I generate a previous version of the SDK?
Nic1
I would like to get v2.12.2 of SDK for RW610 or RW612 but the version I can get on MCUXpresso SDK Builder is only v2.13.3.
How can I get them?
cdoumenc
2.12.2 is now part of inactive SDK releases since a more recent one is available and recommended (more stable).
Could you tell me why you want to use 2.12.2 instead of 2.13.3 ?
Nic1
Thank you for your replay.
The reason I would like to get one is that a software in RW612 couldn't work after upgrading the SDK.
cdoumenc
Could you explain the issue you are facing with SDK 2.13.3, please ?
