How to change the project to non-xip?
1,417件の閲覧回数
jarman_zhou
Hi,I used the sdk project evkmimxrt1020_freertos_hello and it works fine. However, when I select Link application to RAM, an error will be reported. If I want to achieve non-xip, do I only need to select this item? Is there anything else that needs to be modified?
err:File 'evkmimxrt1020_freertos_hello.axf' load failure: Ef(11). No flash configured.
