Missing core_cm0plus.h include file in SDK hello_world example
已解决
跳至解决方案
3,866 次查看
MarkPotts
I am trying to build the hello_world example from SDK_2.x_FRDM_KL02Z on a fresh Windows install of MCUXpresso IDE v11.6.0 but the compiler gives an error:
...CMSIS/MKL02Z4.h:180:10: fatal error: core_cm0plus.h: No such file or directory
180 | #include "core_cm0plus.h" /* Core Peripheral Access Layer */
Any help would be appreciated.
1 解答
3,787 次查看
Robin_Shen
This issue has been solved in MCUXpresso IDE version 11.6.1. This version has just been released and you should be able to download it now.
在原帖中查看解决方案
4 回复数
3,851 次查看
Robin_Shen
Hi MarkPotts,
Sorry for the inconvenience we bring you!
Thanks for the report, I have notified the MCUXpresso IDE team.
For now, try adding Include_core_cm0plus using the Manage SDK component.
Robin
3,844 次查看
MarkPotts
Hi Robin,
Thanks a lot for your quick response. I reverted back to an older MCUXpresso version (v11.4.1) to solve the problem for now. This generated a lot more header files in the project's CMIS folder and no compilation errors. I will try your suggestion when I get a chance.
Mark
3,788 次查看
Robin_Shen
3,754 次查看
MarkPotts
Thanks Robin,
I will upgrade vas soon as I get the chance.
Mark
