Get error while importing FRDM - K64F SDK into MCUXpresso
2,074件の閲覧回数
devang15tank
I am using FRDM - K64F board in MCUXpresso IDE v10.3.1 [Build 2233] [2019-02-20] when i import SDK for the board "SDK_2.7.0_FRDM-K64F.zip" using drag and drop technique. I got to many errors like below. Can any one help me??
!ENTRY com.crt.log 4 -1 2020-03-29 23:50:09.772
!MESSAGE Unable to find part support for NXP MK64FN1M0xxx12 in project Project Resetting to generic part for core cm4.
!STACK 0
java.lang.Exception: java.lang.Exception: Unable to find part support for NXP MK64FN1M0xxx12 in project Project Resetting to generic part for core cm4.
at com.crt.utils.general.Reporter.log(Reporter.java:654)
at com.nxp.mcuxpresso.addons.docsupport.ui.DebugInfoContentProvider.getChildren(DebugInfoContentProvider.java:123)
at org.eclipse.ui.internal.navigator.extensions.SafeDelegateTreeContentProvider.getChildren(SafeDelegateTreeContentProvider.java:95)
at org.eclipse.ui.internal.navigator.extensions.SafeDelegateTreeContentProvider.getChildren(SafeDelegateTreeContentProvider.java:241)
at org.eclipse.ui.internal.navigator.extensions.SafeDelegateTreeContentProvider.getChildren(SafeDelegateTreeContentProvider.java:93)
at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider$1.run(NavigatorContentServiceContentProvider.java:157)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider.internalGetChildren(NavigatorContentServiceContentProvider.java:143)
at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider.getChildren(NavigatorContentServiceContentProvider.java:129)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1356)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:341)
at org.eclipse.jface.viewers.StructuredViewer.getFilteredChildren(StructuredViewer.java:901)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:618)
at org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren(AbstractTreeViewer.java:2604)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalRefreshStruct(AbstractTreeViewer.java:1894)
at org.eclipse.jface.viewers.TreeViewer.internalRefreshStruct(TreeViewer.java:668)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh(AbstractTreeViewer.java:1870)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh(AbstractTreeViewer.java:1827)
at org.eclipse.ui.navigator.CommonViewer.internalRefresh(CommonViewer.java:529)
at org.eclipse.jface.viewers.StructuredViewer.lambda$3(StructuredViewer.java:1531)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1447)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:354)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1408)
at org.eclipse.jface.viewers.StructuredViewer.refresh(StructuredViewer.java:1531)
at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer.java:535)
at org.eclipse.ui.navigator.CommonViewer.refresh(CommonViewer.java:346)
at org.eclipse.ui.navigator.CommonViewer.refresh(CommonViewer.java:492)
at org.eclipse.ui.internal.navigator.resources.workbench.ResourceExtensionContentProvider$4.run(ResourceExtensionContentProvider.java:312)
at org.eclipse.ui.internal.navigator.resources.workbench.ResourceExtensionContentProvider.runUpdates(ResourceExtensionContentProvider.java:323)
at org.eclipse.ui.internal.navigator.resources.workbench.ResourceExtensionContentProvider.processDelta(ResourceExtensionContentProvider.java:130)
at org.eclipse.ui.model.WorkbenchContentProvider.resourceChanged(WorkbenchContentProvider.java:100)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:299)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:289)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:152)
at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:374)
at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1469)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2253)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:128)
at org.eclipse.ui.internal.editors.text.WorkspaceOperationRunner.run(WorkspaceOperationRunner.java:73)
at org.eclipse.ui.internal.editors.text.WorkspaceOperationRunner.run(WorkspaceOperationRunner.java:63)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.executeOperation(TextFileDocumentProvider.java:458)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.saveDocument(TextFileDocumentProvider.java:761)
at org.eclipse.ui.texteditor.AbstractTextEditor.performSave(AbstractTextEditor.java:5025)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSave(AbstractTextEditor.java:4820)
at org.eclipse.ui.texteditor.AbstractTextEditor$TextEditorSavable.doSave(AbstractTextEditor.java:7117)
at org.eclipse.ui.Saveable.doSave(Saveable.java:220)
at org.eclipse.ui.internal.SaveableHelper.doSaveModel(SaveableHelper.java:340)
at org.eclipse.ui.internal.SaveableHelper.lambda$1(SaveableHelper.java:193)
at org.eclipse.ui.internal.SaveableHelper.lambda$3(SaveableHelper.java:271)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
at org.eclipse.ui.internal.WorkbenchWindow$14.run(WorkbenchWindow.java:2195)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2191)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.java:278)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.java:259)
at org.eclipse.ui.internal.SaveableHelper.saveModels(SaveableHelper.java:204)
at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelper.java:148)
at org.eclipse.ui.internal.WorkbenchPage.saveSaveable(WorkbenchPage.java:3917)
at org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPage.java:3931)
at org.eclipse.ui.internal.handlers.SaveHandler.execute(SaveHandler.java:54)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:291)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:92)
at sun.reflect.GeneratedMethodAccessor156.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:305)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:239)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:287)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:527)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:577)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:385)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:331)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:88)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1271)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1078)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1103)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1088)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1130)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1126)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1547)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4962)
at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:364)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4843)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:359)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5178)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2560)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3815)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
Caused by: java.lang.Exception: Unable to find part support for NXP MK64FN1M0xxx12 in project Project Resetting to generic part for core cm4.
at com.crt.config.database.TargetConfig.initFromString(TargetConfig.java:1434)
at com.crt.config.database.TargetConfig.init(TargetConfig.java:1296)
at com.crt.config.database.TargetConfig.<init>(TargetConfig.java:701)
at com.crt.config.database.TargetConfig.loadTargetConfig(TargetConfig.java:380)
at com.nxp.mcuxpresso.addons.docsupport.ui.DebugInfoContentProvider.getChildren(DebugInfoContentProvider.java:107)
... 117 more
frdm-k64f development board.‌ freescale k64‌ mcuxpresso_v10.3.1‌ sdk 2.7.0‌
5 返答(返信)
1,988件の閲覧回数
danielchen
Hi DEVANG:
SDK_2.7 should work with MCUXpresso IDE 11.x
Please download latest IDE from below link
MCUXpresso IDE|Eclipse-based Integrated Development Environment (IDE) | NXP
1,988件の閲覧回数
devang15tank
@Daniel Chen i have one project on related to LPC54638 with all required SDK If i upgrade MCUXpresso will new MCUXpresso support my older one project and it's all configuration(SDK and MCU settings)??
1,988件の閲覧回数
danielchen
It should compatible with your old projects. To be safe, please backup your old project.
1,988件の閲覧回数
devang15tank
Thank you danielchen66‌ :smileyhappy:. New MCUXpresso version work with FRDM-M64K SDK as well as with my older one project. I am satisfied with your response and support.
1,988件の閲覧回数
danielchen
Thank you, Have a nice day. :smileyhappy:
