FreeRTOS with MPU
FreeRTOS with MPU
1,686 次查看
yevgengyl
Hello !
Could it be possible to have example for FRDM-K82F board and FreeRTOS, where tasks are created with MPU protection ?
I have investigated latest SDK v2.4 and haven't found nothing about it.
Eugene
1,421 次查看
danielchen
Hi Eugene:
The MPU API interface is defined in
devices/[MCU]/drivers/fsl_sysmpu.c
devices/[MCU]/drivers/fsl_sysmpu.h
There is a SYSMPU example defines protected/unprotected memory region for the core access
boards\frdmk82f\driver_examples\sysmpu
These APIs can also used in a FreeRTOS projects.
1,421 次查看
yevgengyl
Hi Daniel !
Yes, I'm looking these examples and APIs. But it take time and some testing effort for create RTOS_MPU port.
I expect NXP have done this implementation already and it can be part of SDK.
Could you confirm if MPU enabled RTOS is not exists on your side yet ?
Eugene
