FreeRTOS crash in a Wi-Fi setup example
1,543 次查看
azarubkin
I'm getting FreeRTOS crash in the "wifi_setup" example imported from SDK.
Here's a tail of the debugging session output:
[New Thread 3]
[New Thread 9]
[New Thread 1610631818]
[New Thread 5]
[New Thread 6]
[New Thread 4]
[New Thread 8]
[New Thread 7]
[New Thread 10]
Thread
2 received signal SIGSTOP, Stopped (signal).
[Switching to Thread 3]
Reset_Handler () at C:/tmp/mcux_sdk_release_25_06_00/mcuxsdk/devices/RT/RT1060/MIMXRT1062/gcc\startup_MIMXRT1062.S:446
446	    b DefaultISR
The debugger shows the state of the threads. The top of the current thread call stack is:
"Tmr Svc": Stopped
Reset_Handler@0x60002524
<signal handler called>@0xfffffffd
If I look at pxReadyTasksLists array in the debugger, it shows that its 2nd element has uxNumberOfItems == 1 but pxIndex points to xListEnd. At the same time, xListEnd->pxNext and pxPrevious point to "tcp/ip" task. I've attached a screenshot.
My setup:
  • MIMXRT1060-EVKB board
  • MAYA-W161 M.2 Wi-Fi card
  • I have the resistors resoldered on the board to enable M.2 connector.
  • I'm using Visual Studio Code with MCUXpresso for VS Code extension
  • I've imported MCUXpresso SDK Repository version 25.03.00 (I've checked version 25.06.00 but it made no difference)
  • I've imported the following example from Repository: wifi_examples/wifi_setup, as a Freestanding application.
  • I've also made a wrapper for tcpip_input function to print something to the debug console.
As my Wi-Fi card isn't readily available in the choice of cards, I've made the following changes to the SDK sources:
(.venv) c:\tmp\mcux_sdk_release_25_06_00\mcuxsdk>west diff
=== diff for mcu-sdk-examples (mcuxsdk/examples):
diff --git mcuxsdk/examples/_boards/evkbmimxrt1060/wifi_examples/wifi_setup/prj.conf mcuxsdk/examples/_boards/evkbmimxrt1060/wifi_examples/wifi_setup/prj.conf
index 8892a39d6..8060d7118 100644
--- mcuxsdk/examples/_boards/evkbmimxrt1060/wifi_examples/wifi_setup/prj.conf
+++ mcuxsdk/examples/_boards/evkbmimxrt1060/wifi_examples/wifi_setup/prj.conf
@@ -7,4 +7,4 @@ CONFIG_MCUX_COMPONENT_middleware.sdmmc.host.usdhc.non_blocking=y
 CONFIG_MCUX_COMPONENT_utility.assert_lite=n
 CONFIG_MCUX_COMPONENT_utility.debug_console_lite=n
 CONFIG_MCUX_COMPONENT_component.wifi_bt_module.IW416=y
-CONFIG_MCUX_COMPONENT_component.wifi_bt_module.board_murata_1xk_usd=y
\ No newline at end of file
+CONFIG_MCUX_COMPONENT_component.wifi_bt_module.board_ubx_maya_w1_m2=y
=== diff for mcu-sdk-components (mcuxsdk/components):
diff --git mcuxsdk/components/wifi_bt_module/CMakeLists.txt mcuxsdk/components/wifi_bt_module/CMakeLists.txt
index d06643b..6e7c777 100644
--- mcuxsdk/components/wifi_bt_module/CMakeLists.txt
+++ mcuxsdk/components/wifi_bt_module/CMakeLists.txt
@@ -154,6 +154,12 @@ if (CONFIG_MCUX_COMPONENT_component.wifi_bt_module.board_ubx_maya_w1_usd)
 endif()
+if (CONFIG_MCUX_COMPONENT_component.wifi_bt_module.board_ubx_maya_w1_m2)
+     mcux_add_macro(
+        "-DWIFI_IW416_BOARD_UBX_MAYA_W1_M2"
+endif()
 if (CONFIG_MCUX_COMPONENT_component.wifi_bt_module.board_murata_2dl_m2)
      mcux_add_macro(
         "-DWIFI_IW611_BOARD_MURATA_2DL_M2"
diff --git mcuxsdk/components/wifi_bt_module/Kconfig mcuxsdk/components/wifi_bt_module/Kconfig
index ee38df8..0d37f8f 100644
--- mcuxsdk/components/wifi_bt_module/Kconfig
+++ mcuxsdk/components/wifi_bt_module/Kconfig
@@ -246,6 +246,20 @@ menu "wifi_bt_module"
                         Detailed information about Type MAYA W1 module you can find on
                         https://www.u-blox.com/en/product/maya-w1-series
+                config MCUX_COMPONENT_component.wifi_bt_module.board_ubx_maya_w1_m2
+                    bool "NXP UBX-MAYA-W1-M2"
+                    help
+                        The MAYA-W1 series are host-based Wi-Fi 4 and Bluetooth 5.2 multiradio
+                        modules designed for a wide range of industrial applications, such as
+                        industrial automation and smart manufacturing, EV charging infrastructures,
+                        professional appliances, tracking and telematics, point-of-sale and
+                        ticketing machines, building automation, and healthcare. The modules
+                        are designed and built to meet the high reliability and quality requirements
+                        of such applications.
+                        Detailed information about Type MAYA W1 module you can find on
+                        https://www.u-blox.com/en/product/maya-w1-series
             endchoice
         endif
diff --git mcuxsdk/components/wifi_bt_module/incl/wifi_bt_module_config.h mcuxsdk/components/wifi_bt_module/incl/wifi_bt_module_config.h
index b59457d..84316a5 100644
--- mcuxsdk/components/wifi_bt_module/incl/wifi_bt_module_config.h
+++ mcuxsdk/components/wifi_bt_module/incl/wifi_bt_module_config.h
@@ -286,6 +286,17 @@
         .ed_ctrl_2g = 0x1, .ed_offset_2g = 0x9, .ed_ctrl_5g = 0x1, .ed_offset_5g = 0xC \
+/* u-blox EVK-MAYA-W1-M2 */
+#elif defined(WIFI_IW416_BOARD_UBX_MAYA_W1_M2)
+#define WIFI_BT_TX_PWR_LIMITS "wlan_txpwrlimit_cfg_WW.h"
+#define SD8978
+#define SDMMCHOST_OPERATION_VOLTAGE_1V8
+#define WIFI_BT_USE_M2_INTERFACE
+#define WLAN_ED_MAC_CTRL                                                               \
+        .ed_ctrl_2g = 0x1, .ed_offset_2g = 0x9, .ed_ctrl_5g = 0x1, .ed_offset_5g = 0xC \
 /* Redfinch RW61X */
 #elif defined(WIFI_BOARD_RW610)
 #define WIFI_BT_TX_PWR_LIMITS "wlan_txpwrlimit_cfg_WW_rw610.h"
=== diff for wifi_nxp (mcuxsdk/middleware/wifi_nxp):
diff --git mcuxsdk/middleware/wifi_nxp/port/net/net.c mcuxsdk/middleware/wifi_nxp/port/net/net.c
index 5b830d24..6a4a48d2 100644
--- mcuxsdk/middleware/wifi_nxp/port/net/net.c
+++ mcuxsdk/middleware/wifi_nxp/port/net/net.c
@@ -318,8 +318,10 @@ int net_wlan_init(void)
         (void)wifi_register_wrapper_net_is_ip_or_ipv6_callback(&wrapper_net_is_ip_or_ipv6);
 #endif
         ip_2_ip4(&g_mlan.ipaddr)->addr = INADDR_ANY;
+// HACK: This is a hack to allow the wifi_tcpip_input_wrapper to be used as the input function for the wifi interface
+err_t wifi_tcpip_input_wrapper(struct pbuf *p, struct netif *netif);
         ret = netifapi_netif_add(&g_mlan.netif, ip_2_ip4(&g_mlan.ipaddr), ip_2_ip4(&g_mlan.ipaddr),
-                                 ip_2_ip4(&g_mlan.ipaddr), NULL, lwip_netif_init, tcpip_input);
+                                 ip_2_ip4(&g_mlan.ipaddr), NULL, lwip_netif_init, wifi_tcpip_input_wrapper);
         if (ret != WM_SUCCESS)
             net_e("MLAN interface add failed");
@@ -331,7 +333,7 @@ int net_wlan_init(void)
 #if UAP_SUPPORT
         ret = netifapi_netif_add(&g_uap.netif, ip_2_ip4(&g_uap.ipaddr), ip_2_ip4(&g_uap.ipaddr),
-                                 ip_2_ip4(&g_uap.ipaddr), NULL, lwip_netif_uap_init, tcpip_input);
+                                 ip_2_ip4(&g_uap.ipaddr), NULL, lwip_netif_uap_init, wifi_tcpip_input_wrapper);
             net_e("UAP interface add failed");
Empty diff in 91 projects.
My wrapper function looks as:
    PRINTF("In wrapper\r\n");
    const err_t result = tcpip_input(p, netif);
    return result;
So there's nothing criminal there, just calling the original function. The crash happens after "In wrapper" is printed to the console, when the software should switch to "tcp/ip" task.
There's a similar post on FreeRTOS forum: https://forums.freertos.org/t/incorrect-pxreadytaskslists-state-causes-fault/17791, only in my case pxCurrentTCB is correct, pointing to "Tmr Svc" task.
The solution to that topic was an incorrect interrupt priority. I tried setting all NVIC->IPRn registers to 0xF0 at the beginning of the program to set all priorities to the lowest possible level but that didn't help. I also checked the stacks -- they are fine. I can attach my project or upload it anywhere if that helps.
If I don't use wrapper function, so that the SDK code calls tcpip_input directly, the example works but sometimes I get delays in ping responses of like 1600 ms which is strange because I ping my local router. So I suspect the bug is still there but adding a PRINTF makes it more apparent.
8 回复数
1,509 次查看
azarubkin
xPSR register value is 0x81000004.
1,509 次查看
azarubkin
If I run the project in MCUXpresso IDE with SDK 25.6.0, the execution hits MemManage_Handler, if that helps. In MCUXpresso for VS Code, it's DefaultISR instead of MemManage_Handler.
1,528 次查看
DanielRuvalcaba
Let me check this.
Daniel.
1,500 次查看
DanielRuvalcaba
I tested wifi_setup on an RT1060-EVKB with a 1XK (IW416) M.2 module, and it is working on my side. I selected the correct module by using the Kconfig GUI.
1. Right click on the project > Configure > Open Kconfig GUI Configuration
2. Component configuration > wifi_bt_module > config > Select NXP IW416 module (NXP IW416-MURATA-1XK-M2)
There is no option for MAYA-W161. Nevertheless, both modules use the same SoC. Could you please try with the same option as me "NXP IW416-MURATA-1XK-M2"?
Daniel.
1,494 次查看
azarubkin
Have you tried building it in debug mode? I've found that the crash happens only in debug build. Also, setting
#define configTIMER_TASK_STACK_DEPTH (configMINIMAL_STACK_SIZE * 2)
fixes it in debug mode as well.
It appears stack overflow happens in timer task in debug mode. How do I calculate the amount of stack needed for the task?
1,469 次查看
DanielRuvalcaba
I'm not sure why it crashes on your side. Are you using the example as is with the recommendation I gave you?
I tested in on 25.03 in debug mode and it is working on my side.
Daniel.
1,364 次查看
azarubkin
For some reason, replacing tcpip_input with a simple wrapper leads to stack requirements growth in Tmr Svc thread.
1,465 次查看
azarubkin
Yes I am sure. I've imported the example from scratch, reverted most of my modifications to the SDK and selected MURATA-1XK-M2 board in the Kconfig GUI tool.
The only modification to the SDK is to call my wrapper function instead of tcpip_input:
 #endif
 #if UAP_SUPPORT
And the wrapper function itself is:
    return result;
%3CLINGO-SUB%20id%3D%22lingo-sub-2135058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFreeRTOS%20%E5%9C%A8%20Wi-Fi%20%E8%AE%BE%E7%BD%AE%E7%A4%BA%E4%BE%8B%E4%B8%AD%E5%B4%A9%E6%BA%83%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E4%BB%8E%20SDK%20%E5%AF%BC%E5%85%A5%E7%9A%84%22wifi_setup%22%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%20FreeRTOS%20%E5%B4%A9%E6%BA%83%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E8%BE%93%E5%87%BA%E7%9A%84%E5%B0%BE%E9%83%A8%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5BNew%20Thread%203%5D%0A%5BNew%20Thread%209%5D%0A%5BNew%20Thread%201610631818%5D%0A%5BNew%20Thread%205%5D%0A%5BNew%20Thread%206%5D%0A%5BNew%20Thread%204%5D%0A%5BNew%20Thread%208%5D%0A%5BNew%20Thread%207%5D%0A%5BNew%20Thread%2010%5D%0A%0AThread%20%0A2%20received%20signal%20SIGSTOP%2C%20Stopped%20(signal).%0A%5BSwitching%20to%20Thread%203%5D%0AReset_Handler%20()%20at%20C%3A%2Ftmp%2Fmcux_sdk_release_25_06_00%2Fmcuxsdk%2Fdevices%2FRT%2FRT1060%2FMIMXRT1062%2Fgcc%5Cstartup_MIMXRT1062.S%3A446%0A446%09%20%20%20%20b%20DefaultISR%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E8%B0%83%E8%AF%95%E5%99%A8%E4%BC%9A%E6%98%BE%E7%A4%BA%E7%BA%BF%E7%A8%8B%E7%9A%84%E7%8A%B6%E6%80%81%E3%80%82%E5%BD%93%E5%89%8D%E7%BA%BF%E7%A8%8B%E8%B0%83%E7%94%A8%E6%A0%88%E7%9A%84%E9%A1%B6%E5%B1%82%E6%98%AF%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%22Tmr%20Svc%22%3A%20Stopped%0AReset_Handler%400x60002524%0A%3CSIGNAL%20handler%3D%22%22%20called%3D%22%22%3E%400xfffffffd%3C%2FSIGNAL%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%AD%E6%9F%A5%E7%9C%8B%3CSTRONG%3EpxReadyTasksLists%3C%2FSTRONG%3E%E6%95%B0%E7%BB%84%EF%BC%8C%E4%BC%9A%E5%8F%91%E7%8E%B0%E5%AE%83%E7%9A%84%E7%AC%AC%202%20%E4%B8%AA%E5%85%83%E7%B4%A0%E6%9C%89%3CSTRONG%3EuxNumberOfItems%3C%2FSTRONG%3E%3D%3D%201%EF%BC%8C%E4%BD%86%3CSTRONG%3EpxIndex%3C%2FSTRONG%3E%E6%8C%87%E5%90%91%3CSTRONG%3ExListEnd%3C%2FSTRONG%3E%E3%80%82%E5%90%8C%E6%97%B6%EF%BC%8C%3CSTRONG%3E%20xListEnd-%3C%2FSTRONG%3E%20%26gt%3B%3CSTRONG%3E%20pxNext%3C%2FSTRONG%3E%20%E5%92%8C%3CSTRONG%3E%20pxPrevious%3C%2FSTRONG%3E%20%E6%8C%87%E5%90%91%22tcp%2Fip%22%20%E4%BB%BB%E5%8A%A1%E3%80%82%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E6%88%AA%E5%9B%BE%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22azarubkin_0-1752673050909.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22azarubkin_0-1752673050909.png%22%20style%3D%22width%3A%20359px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F347874iD8F6A5F3BE9FE529%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22azarubkin_0-1752673050909.png%22%20alt%3D%22azarubkin_0-1752673050909.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%3C%2FP%3E%3CUL%3E%3CLI%3EMIMXRT1060-EVKB%E6%9D%BF%3C%2FLI%3E%3CLI%3EMAYA-W161%20M.2%20Wi-Fi%20%E7%BD%91%E5%8D%A1%3C%2FLI%3E%3CLI%3E%E6%88%91%E5%9C%A8%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%8A%E8%A7%A3%E6%9E%90%E4%BA%86%E7%94%B5%E9%98%BB%E5%99%A8%E4%BB%A5%E5%90%AF%E7%94%A8%20M.2%20%E8%BF%9E%E6%8E%A5%E5%99%A8%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%B8%A6%E6%9C%89%20MCUXpresso%20for%20VS%20Code%20%E6%89%A9%E5%B1%95%E5%8A%9F%E8%83%BD%E7%9A%84%20Visual%20Studio%20Code%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%88%91%E5%B7%B2%E5%AF%BC%E5%85%A5%20MCUXpresso%20SDK%20Repository%20%E7%89%88%E6%9C%AC%2025.03.00%EF%BC%88%E6%88%91%E5%B7%B2%E6%A3%80%E6%9F%A5%E8%BF%87%E7%89%88%E6%9C%AC%2025.06.00%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E4%B8%8D%E5%90%8C%EF%BC%89%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%88%91%E4%BB%8E%20repository%3A%20wifi_examples%2Fwifi_setup%20%E4%B8%AD%E5%AF%BC%E5%85%A5%E4%BA%86%E4%BB%A5%E4%B8%8B%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%BD%9C%E4%B8%BA%E7%8B%AC%E7%AB%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%88%91%E8%BF%98%E4%B8%BA%3CSTRONG%3Etcpip_input%3C%2FSTRONG%3E%E5%87%BD%E6%95%B0%E5%81%9A%E4%BA%86%E4%B8%80%E4%B8%AA%E5%B0%81%E8%A3%85%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%90%91%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%E5%8F%B0%E6%89%93%E5%8D%B0%E4%B8%80%E4%BA%9B%E5%86%85%E5%AE%B9%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%94%B1%E4%BA%8E%E6%88%91%E7%9A%84%20Wi-Fi%20%E7%BD%91%E5%8D%A1%E5%9C%A8%E7%BD%91%E5%8D%A1%E9%80%89%E6%8B%A9%E4%B8%AD%E6%B2%A1%E6%9C%89%E7%8E%B0%E6%88%90%E7%9A%84%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%AF%B9%20SDK%20%E6%BA%90%E5%81%9A%E4%BA%86%E4%BB%A5%E4%B8%8B%E6%94%B9%E5%8A%A8%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E(.venv)%20c%3A%5Ctmp%5Cmcux_sdk_release_25_06_00%5Cmcuxsdk%26gt%3Bwest%20diff%0A%3D%3D%3D%20diff%20for%20mcu-sdk-examples%20(mcuxsdk%2Fexamples)%3A%0Adiff%20--git%20mcuxsdk%2Fexamples%2F_boards%2Fevkbmimxrt1060%2Fwifi_examples%2Fwifi_setup%2Fprj.conf%20mcuxsdk%2Fexamples%2F_boards%2Fevkbmimxrt1060%2Fwifi_examples%2Fwifi_setup%2Fprj.conf%0Aindex%208892a39d6..8060d7118%20100644%0A---%20mcuxsdk%2Fexamples%2F_boards%2Fevkbmimxrt1060%2Fwifi_examples%2Fwifi_setup%2Fprj.conf%0A%2B%2B%2B%20mcuxsdk%2Fexamples%2F_boards%2Fevkbmimxrt1060%2Fwifi_examples%2Fwifi_setup%2Fprj.conf%0A%40%40%20-7%2C4%20%2B7%2C4%20%40%40%20CONFIG_MCUX_COMPONENT_middleware.sdmmc.host.usdhc.non_blocking%3Dy%0A%20CONFIG_MCUX_COMPONENT_utility.assert_lite%3Dn%0A%20CONFIG_MCUX_COMPONENT_utility.debug_console_lite%3Dn%0A%20CONFIG_MCUX_COMPONENT_component.wifi_bt_module.IW416%3Dy%0A-CONFIG_MCUX_COMPONENT_component.wifi_bt_module.board_murata_1xk_usd%3Dy%0A%5C%20No%20newline%20at%20end%20of%20file%0A%2BCONFIG_MCUX_COMPONENT_component.wifi_bt_module.board_ubx_maya_w1_m2%3Dy%0A%0A%0A%3D%3D%3D%20diff%20for%20mcu-sdk-components%20(mcuxsdk%2Fcomponents)%3A%0Adiff%20--git%20mcuxsdk%2Fcomponents%2Fwifi_bt_module%2FCMakeLists.txt%20mcuxsdk%2Fcomponents%2Fwifi_bt_module%2FCMakeLists.txt%0Aindex%20d06643b..6e7c777%20100644%0A---%20mcuxsdk%2Fcomponents%2Fwifi_bt_module%2FCMakeLists.txt%0A%2B%2B%2B%20mcuxsdk%2Fcomponents%2Fwifi_bt_module%2FCMakeLists.txt%0A%40%40%20-154%2C6%20%2B154%2C12%20%40%40%20if%20(CONFIG_MCUX_COMPONENT_component.wifi_bt_module.board_ubx_maya_w1_usd)%0A%20%20%20%20%20)%0A%20endif()%0A%0A%2Bif%20(CONFIG_MCUX_COMPONENT_component.wifi_bt_module.board_ubx_maya_w1_m2)%0A%2B%20%20%20%20%20mcux_add_macro(%0A%2B%20%20%20%20%20%20%20%20%22-DWIFI_IW416_BOARD_UBX_MAYA_W1_M2%22%0A%2B%20%20%20%20)%0A%2Bendif()%0A%2B%0A%20if%20(CONFIG_MCUX_COMPONENT_component.wifi_bt_module.board_murata_2dl_m2)%0A%20%20%20%20%20%20mcux_add_macro(%0A%20%20%20%20%20%20%20%20%20%22-DWIFI_IW611_BOARD_MURATA_2DL_M2%22%0Adiff%20--git%20mcuxsdk%2Fcomponents%2Fwifi_bt_module%2FKconfig%20mcuxsdk%2Fcomponents%2Fwifi_bt_module%2FKconfig%0Aindex%20ee38df8..0d37f8f%20100644%0A---%20mcuxsdk%2Fcomponents%2Fwifi_bt_module%2FKconfig%0A%2B%2B%2B%20mcuxsdk%2Fcomponents%2Fwifi_bt_module%2FKconfig%0A%40%40%20-246%2C6%20%2B246%2C20%20%40%40%20menu%20%22wifi_bt_module%22%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Detailed%20information%20about%20Type%20MAYA%20W1%20module%20you%20can%20find%20on%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20https%3A%2F%2Fwww.u-blox.com%2Fen%2Fproduct%2Fmaya-w1-series%0A%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20config%20MCUX_COMPONENT_component.wifi_bt_module.board_ubx_maya_w1_m2%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20bool%20%22NXP%20UBX-MAYA-W1-M2%22%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20help%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20The%20MAYA-W1%20series%20are%20host-based%20Wi-Fi%204%20and%20Bluetooth%205.2%20multiradio%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20modules%20designed%20for%20a%20wide%20range%20of%20industrial%20applications%2C%20such%20as%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20industrial%20automation%20and%20smart%20manufacturing%2C%20EV%20charging%20infrastructures%2C%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20professional%20appliances%2C%20tracking%20and%20telematics%2C%20point-of-sale%20and%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20ticketing%20machines%2C%20building%20automation%2C%20and%20healthcare.%20The%20modules%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20are%20designed%20and%20built%20to%20meet%20the%20high%20reliability%20and%20quality%20requirements%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20of%20such%20applications.%0A%2B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Detailed%20information%20about%20Type%20MAYA%20W1%20module%20you%20can%20find%20on%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20https%3A%2F%2Fwww.u-blox.com%2Fen%2Fproduct%2Fmaya-w1-series%0A%2B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20endchoice%0A%20%20%20%20%20%20%20%20%20endif%0A%0Adiff%20--git%20mcuxsdk%2Fcomponents%2Fwifi_bt_module%2Fincl%2Fwifi_bt_module_config.h%20mcuxsdk%2Fcomponents%2Fwifi_bt_module%2Fincl%2Fwifi_bt_module_config.h%0Aindex%20b59457d..84316a5%20100644%0A---%20mcuxsdk%2Fcomponents%2Fwifi_bt_module%2Fincl%2Fwifi_bt_module_config.h%0A%2B%2B%2B%20mcuxsdk%2Fcomponents%2Fwifi_bt_module%2Fincl%2Fwifi_bt_module_config.h%0A%40%40%20-286%2C6%20%2B286%2C17%20%40%40%0A%20%20%20%20%20%20%20%20%20.ed_ctrl_2g%20%3D%200x1%2C%20.ed_offset_2g%20%3D%200x9%2C%20.ed_ctrl_5g%20%3D%200x1%2C%20.ed_offset_5g%20%3D%200xC%20%5C%0A%20%20%20%20%20%7D%0A%0A%2B%2F*%20u-blox%20EVK-MAYA-W1-M2%20*%2F%0A%2B%23elif%20defined(WIFI_IW416_BOARD_UBX_MAYA_W1_M2)%0A%2B%23define%20WIFI_BT_TX_PWR_LIMITS%20%22wlan_txpwrlimit_cfg_WW.h%22%0A%2B%23define%20SD8978%0A%2B%23define%20SDMMCHOST_OPERATION_VOLTAGE_1V8%0A%2B%23define%20WIFI_BT_USE_M2_INTERFACE%0A%2B%23define%20WLAN_ED_MAC_CTRL%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5C%0A%2B%20%20%20%20%7B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5C%0A%2B%20%20%20%20%20%20%20%20.ed_ctrl_2g%20%3D%200x1%2C%20.ed_offset_2g%20%3D%200x9%2C%20.ed_ctrl_5g%20%3D%200x1%2C%20.ed_offset_5g%20%3D%200xC%20%5C%0A%2B%20%20%20%20%7D%0A%2B%0A%20%2F*%20Redfinch%20RW61X%20*%2F%0A%20%23elif%20defined(WIFI_BOARD_RW610)%0A%20%23define%20WIFI_BT_TX_PWR_LIMITS%20%22wlan_txpwrlimit_cfg_WW_rw610.h%22%0A%0A%0A%3D%3D%3D%20diff%20for%20wifi_nxp%20(mcuxsdk%2Fmiddleware%2Fwifi_nxp)%3A%0Adiff%20--git%20mcuxsdk%2Fmiddleware%2Fwifi_nxp%2Fport%2Fnet%2Fnet.c%20mcuxsdk%2Fmiddleware%2Fwifi_nxp%2Fport%2Fnet%2Fnet.c%0Aindex%205b830d24..6a4a48d2%20100644%0A---%20mcuxsdk%2Fmiddleware%2Fwifi_nxp%2Fport%2Fnet%2Fnet.c%0A%2B%2B%2B%20mcuxsdk%2Fmiddleware%2Fwifi_nxp%2Fport%2Fnet%2Fnet.c%0A%40%40%20-318%2C8%20%2B318%2C10%20%40%40%20int%20net_wlan_init(void)%0A%20%20%20%20%20%20%20%20%20(void)wifi_register_wrapper_net_is_ip_or_ipv6_callback(%26amp%3Bwrapper_net_is_ip_or_ipv6)%3B%0A%20%23endif%0A%20%20%20%20%20%20%20%20%20ip_2_ip4(%26amp%3Bg_mlan.ipaddr)-%26gt%3Baddr%20%3D%20INADDR_ANY%3B%0A%2B%2F%2F%20HACK%3A%20This%20is%20a%20hack%20to%20allow%20the%20wifi_tcpip_input_wrapper%20to%20be%20used%20as%20the%20input%20function%20for%20the%20wifi%20interface%0A%2Berr_t%20wifi_tcpip_input_wrapper(struct%20pbuf%20*p%2C%20struct%20netif%20*netif)%3B%0A%20%20%20%20%20%20%20%20%20ret%20%3D%20netifapi_netif_add(%26amp%3Bg_mlan.netif%2C%20ip_2_ip4(%26amp%3Bg_mlan.ipaddr)%2C%20ip_2_ip4(%26amp%3Bg_mlan.ipaddr)%2C%0A-%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20ip_2_ip4(%26amp%3Bg_mlan.ipaddr)%2C%20NULL%2C%20lwip_netif_init%2C%20tcpip_input)%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20ip_2_ip4(%26amp%3Bg_mlan.ipaddr)%2C%20NULL%2C%20lwip_netif_init%2C%20wifi_tcpip_input_wrapper)%3B%0A%20%20%20%20%20%20%20%20%20if%20(ret%20!%3D%20WM_SUCCESS)%0A%20%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20net_e(%22MLAN%20interface%20add%20failed%22)%3B%0A%40%40%20-331%2C7%20%2B333%2C7%20%40%40%20int%20net_wlan_init(void)%0A%0A%20%23if%20UAP_SUPPORT%0A%20%20%20%20%20%20%20%20%20ret%20%3D%20netifapi_netif_add(%26amp%3Bg_uap.netif%2C%20ip_2_ip4(%26amp%3Bg_uap.ipaddr)%2C%20ip_2_ip4(%26amp%3Bg_uap.ipaddr)%2C%0A-%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20ip_2_ip4(%26amp%3Bg_uap.ipaddr)%2C%20NULL%2C%20lwip_netif_uap_init%2C%20tcpip_input)%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20ip_2_ip4(%26amp%3Bg_uap.ipaddr)%2C%20NULL%2C%20lwip_netif_uap_init%2C%20wifi_tcpip_input_wrapper)%3B%0A%20%20%20%20%20%20%20%20%20if%20(ret%20!%3D%20WM_SUCCESS)%0A%20%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20net_e(%22UAP%20interface%20add%20failed%22)%3B%0A%0A%0AEmpty%20diff%20in%2091%20projects.%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E6%88%91%E7%9A%84%E5%B0%81%E8%A3%85%E5%87%BD%E6%95%B0%E5%A6%82%E4%B8%8B%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eerr_t%20wifi_tcpip_input_wrapper(struct%20pbuf%20*p%2C%20struct%20netif%20*netif)%0A%7B%0A%20%20%20%20PRINTF(%22In%20wrapper%5Cr%5Cn%22)%3B%0A%20%20%20%20const%20err_t%20result%20%3D%20tcpip_input(p%2C%20netif)%3B%0A%20%20%20%20return%20result%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%BF%99%E5%B9%B6%E4%B8%8D%E6%9E%84%E6%88%90%E7%8A%AF%E7%BD%AA%EF%BC%8C%E5%8F%AA%E6%98%AF%E8%B0%83%E7%94%A8%E4%BA%86%E5%8E%9F%E6%9D%A5%E7%9A%84%E5%87%BD%E6%95%B0%E3%80%82%22%E5%9C%A8%E5%8C%85%E8%A3%85%E5%99%A8%22%20%E6%89%93%E5%8D%B0%E5%88%B0%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%90%8E%E5%8F%91%E7%94%9F%E5%B4%A9%E6%BA%83%EF%BC%8C%E6%AD%A4%E6%97%B6%E8%BD%AF%E4%BB%B6%E5%BA%94%E5%88%87%E6%8D%A2%E5%88%B0%22tcp%2Fip%22%20%E4%BB%BB%E5%8A%A1%E3%80%82%3C%2FP%3E%3CP%3EFreeRTOS%20%E8%AE%BA%E5%9D%9B%E4%B8%8A%E6%9C%89%E4%B8%80%E4%B8%AA%E7%B1%BB%E4%BC%BC%E7%9A%84%E5%B8%96%E5%AD%90%3CA%20href%3D%22https%3A%2F%2Fforums.freertos.org%2Ft%2Fincorrect-pxreadytaskslists-state-causes-fault%2F17791%2C%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fforums.freertos.org%2Ft%2Fincorrect-pxreadytaskslists-state-causes-fault%2F17791%E3%80%81%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fforums.freertos.org%2Ft%2Fincorrect-pxreadytaskslists-state-causes-fault%2F17791%E3%80%81%3C%2FA%3E%20%E5%8F%AA%E6%9C%89%E6%88%91%E7%9A%84%3CSTRONG%3EpxCurrentTCB%3C%2FSTRONG%3E%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E5%AE%83%E6%8C%87%E5%90%91%22Tmr%20Svc%22%20%E4%BB%BB%E5%8A%A1%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%A5%E9%97%AE%E9%A2%98%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%98%AF%E4%B8%AD%E6%96%AD%E4%BC%98%E5%85%88%E7%BA%A7%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%E6%88%91%E8%AF%95%E8%BF%87%E5%9C%A8%E7%A8%8B%E5%BA%8F%E5%BC%80%E5%A7%8B%E6%97%B6%E5%B0%86%E6%89%80%E6%9C%89%20NVIC-%26gt%3BIPRn%20%E5%AF%84%E5%AD%98%E5%99%A8%E8%AE%BE%E7%BD%AE%E4%B8%BA%200xF0%EF%BC%8C%E5%B0%86%E6%89%80%E6%9C%89%E4%BC%98%E5%85%88%E7%BA%A7%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%B0%BD%E5%8F%AF%E8%83%BD%E4%BD%8E%E7%9A%84%E7%BA%A7%E5%88%AB%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E7%94%A8%E3%80%82%E6%88%91%E8%BF%98%E6%A3%80%E6%9F%A5%E4%BA%86%E5%A0%86%E6%A0%88--%E5%AE%83%E4%BB%AC%E9%83%BD%E5%BE%88%E5%A5%BD%E3%80%82%E5%A6%82%E6%9E%9C%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%8A%8A%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E9%99%84%E5%90%8E%E6%88%96%E4%B8%8A%E4%BC%A0%E5%88%B0%E4%BB%BB%E4%BD%95%E5%9C%B0%E6%96%B9%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%B8%8D%E4%BD%BF%E7%94%A8%E5%B0%81%E8%A3%85%E5%87%BD%E6%95%B0%EF%BC%8C%E8%AE%A9%20SDK%20%E4%BB%A3%E7%A0%81%E7%9B%B4%E6%8E%A5%E8%B0%83%E7%94%A8%3CSTRONG%3Etcpip_input%3C%2FSTRONG%3E%EF%BC%8C%E7%A4%BA%E4%BE%8B%E5%B0%B1%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BD%86%E6%9C%89%E6%97%B6%20ping%20%E5%93%8D%E5%BA%94%E4%BC%9A%E5%87%BA%E7%8E%B0%201600%20%E6%AF%AB%E7%A7%92%E7%9A%84%E5%BB%B6%E8%BF%9F%EF%BC%8C%E8%BF%99%E5%BE%88%E5%A5%87%E6%80%AA%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%20ping%20%E7%9A%84%E6%98%AF%E6%9C%AC%E5%9C%B0%E8%B7%AF%E7%94%B1%E5%99%A8%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%80%80%E7%96%91%E9%94%99%E8%AF%AF%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%EF%BC%8C%E5%8F%AA%E6%98%AF%E5%A2%9E%E5%8A%A0%E4%BA%86%20PRINTF%20%E4%BD%BF%E5%85%B6%E6%9B%B4%E5%8A%A0%E6%98%8E%E6%98%BE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FreeRTOS%20crash%20in%20a%20Wi-Fi%20setup%20example%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%94%B1%E4%BA%8E%E6%9F%90%E4%BA%9B%E5%8E%9F%E5%9B%A0%EF%BC%8C%E7%94%A8%E7%AE%80%E5%8D%95%E5%B0%81%E8%A3%85%E5%99%A8%E6%9B%BF%E6%8D%A2%20tcpip_input%20%E4%BC%9A%E5%AF%BC%E8%87%B4%20Tmr%20Svc%20%E7%BA%BF%E7%A8%8B%E7%9A%84%E5%A0%86%E6%A0%88%E9%9C%80%E6%B1%82%E5%A2%9E%E9%95%BF%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FreeRTOS%20crash%20in%20a%20Wi-Fi%20setup%20example%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E7%A1%AE%E4%BF%A1%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BB%8E%E5%A4%B4%E5%BC%80%E5%A7%8B%E5%AF%BC%E5%85%A5%E4%BA%86%E7%A4%BA%E4%BE%8B%EF%BC%8C%E6%81%A2%E5%A4%8D%E4%BA%86%E5%AF%B9%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%E5%8C%85%E7%9A%84%E5%A4%A7%E9%83%A8%E5%88%86%E4%BF%AE%E6%94%B9%EF%BC%8C%E5%B9%B6%E5%9C%A8%20Kconfig%20GUI%20%E5%B7%A5%E5%85%B7%E4%B8%AD%E9%80%89%E6%8B%A9%E4%BA%86%20MURATA-1XK-M2%20%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%3E%E5%AF%B9%20SDK%20%E7%9A%84%E5%94%AF%E4%B8%80%E4%BF%AE%E6%94%B9%E6%98%AF%E8%B0%83%E7%94%A8%E6%88%91%E7%9A%84%E5%B0%81%E8%A3%85%E5%87%BD%E6%95%B0%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20tcpip_input%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%3D%3D%3D%20diff%20for%20wifi_nxp%20(mcuxsdk%2Fmiddleware%2Fwifi_nxp)%3A%0Adiff%20--git%20mcuxsdk%2Fmiddleware%2Fwifi_nxp%2Fport%2Fnet%2Fnet.c%20mcuxsdk%2Fmiddleware%2Fwifi_nxp%2Fport%2Fnet%2Fnet.c%0Aindex%205b830d24..6a4a48d2%20100644%0A---%20mcuxsdk%2Fmiddleware%2Fwifi_nxp%2Fport%2Fnet%2Fnet.c%0A%2B%2B%2B%20mcuxsdk%2Fmiddleware%2Fwifi_nxp%2Fport%2Fnet%2Fnet.c%0A%40%40%20-318%2C8%20%2B318%2C10%20%40%40%20int%20net_wlan_init(void)%0A%20%20%20%20%20%20%20%20%20(void)wifi_register_wrapper_net_is_ip_or_ipv6_callback(%26amp%3Bwrapper_net_is_ip_or_ipv6)%3B%0A%20%23endif%0A%20%20%20%20%20%20%20%20%20ip_2_ip4(%26amp%3Bg_mlan.ipaddr)-%26gt%3Baddr%20%3D%20INADDR_ANY%3B%0A%2B%2F%2F%20HACK%3A%20This%20is%20a%20hack%20to%20allow%20the%20wifi_tcpip_input_wrapper%20to%20be%20used%20as%20the%20input%20function%20for%20the%20wifi%20interface%0A%2Berr_t%20wifi_tcpip_input_wrapper(struct%20pbuf%20*p%2C%20struct%20netif%20*netif)%3B%0A%20%20%20%20%20%20%20%20%20ret%20%3D%20netifapi_netif_add(%26amp%3Bg_mlan.netif%2C%20ip_2_ip4(%26amp%3Bg_mlan.ipaddr)%2C%20ip_2_ip4(%26amp%3Bg_mlan.ipaddr)%2C%0A-%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20ip_2_ip4(%26amp%3Bg_mlan.ipaddr)%2C%20NULL%2C%20lwip_netif_init%2C%20tcpip_input)%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20ip_2_ip4(%26amp%3Bg_mlan.ipaddr)%2C%20NULL%2C%20lwip_netif_init%2C%20wifi_tcpip_input_wrapper)%3B%0A%20%20%20%20%20%20%20%20%20if%20(ret%20!%3D%20WM_SUCCESS)%0A%20%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20net_e(%22MLAN%20interface%20add%20failed%22)%3B%0A%40%40%20-331%2C7%20%2B333%2C7%20%40%40%20int%20net_wlan_init(void)%0A%0A%20%23if%20UAP_SUPPORT%0A%20%20%20%20%20%20%20%20%20ret%20%3D%20netifapi_netif_add(%26amp%3Bg_uap.netif%2C%20ip_2_ip4(%26amp%3Bg_uap.ipaddr)%2C%20ip_2_ip4(%26amp%3Bg_uap.ipaddr)%2C%0A-%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20ip_2_ip4(%26amp%3Bg_uap.ipaddr)%2C%20NULL%2C%20lwip_netif_uap_init%2C%20tcpip_input)%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20ip_2_ip4(%26amp%3Bg_uap.ipaddr)%2C%20NULL%2C%20lwip_netif_uap_init%2C%20wifi_tcpip_input_wrapper)%3B%0A%20%20%20%20%20%20%20%20%20if%20(ret%20!%3D%20WM_SUCCESS)%0A%20%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20net_e(%22UAP%20interface%20add%20failed%22)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E8%80%8C%E5%B0%81%E8%A3%85%E5%87%BD%E6%95%B0%E6%9C%AC%E8%BA%AB%E5%B0%B1%E6%98%AF%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eerr_t%20wifi_tcpip_input_wrapper(struct%20pbuf%20*p%2C%20struct%20netif%20*netif)%0A%7B%0A%20%20%20%20PRINTF(%22In%20wrapper%5Cr%5Cn%22)%3B%0A%20%20%20%20const%20err_t%20result%20%3D%20tcpip_input(p%2C%20netif)%3B%0A%20%20%20%20return%20result%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136658%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FreeRTOS%20crash%20in%20a%20Wi-Fi%20setup%20example%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136658%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%BD%A0%E9%82%A3%E8%BE%B9%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E5%B4%A9%E6%BA%83%E3%80%82%E4%BD%A0%E6%98%AF%E6%8C%89%E7%85%A7%E6%88%91%E7%BB%99%E4%BD%A0%E7%9A%84%E5%BB%BA%E8%AE%AE%E5%8E%9F%E5%B0%81%E4%B8%8D%E5%8A%A8%E5%9C%B0%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%E4%BE%8B%E5%AD%90%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%2025.03%20%E7%89%88%E6%9C%AC%E7%9A%84%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E7%BB%93%E6%9E%9C%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EDaniel%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FreeRTOS%20crash%20in%20a%20Wi-Fi%20setup%20example%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%B0%9D%E8%AF%95%E8%BF%87%E5%9C%A8%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E4%B8%8B%E6%9E%84%E5%BB%BA%E5%90%97%EF%BC%9F%E6%88%91%E5%8F%91%E7%8E%B0%E5%B4%A9%E6%BA%83%E5%8F%AA%E5%8F%91%E7%94%9F%E5%9C%A8%E8%B0%83%E8%AF%95%E7%89%88%E6%9C%AC%E4%B8%AD%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E8%AE%BE%E7%BD%AE%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3EconfigTIMER_TASK_STACK_DEPTH%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EconfigMINIMAL_STACK_SIZE%20*%202%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E5%9C%A8%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E4%B8%8B%E4%B9%9F%E8%83%BD%E4%BF%AE%E5%A4%8D%E3%80%82%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E5%9C%A8%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E4%B8%8B%EF%BC%8C%E5%A0%86%E6%A0%88%E6%BA%A2%E5%87%BA%E4%BC%BC%E4%B9%8E%E5%8F%91%E7%94%9F%E5%9C%A8%E5%AE%9A%E6%97%B6%E5%99%A8%E4%BB%BB%E5%8A%A1%E4%B8%AD%E3%80%82%E5%A6%82%E4%BD%95%E8%AE%A1%E7%AE%97%E4%BB%BB%E5%8A%A1%E6%89%80%E9%9C%80%E7%9A%84%E5%A0%86%E6%A0%88%E6%95%B0%E9%87%8F%EF%BC%9F%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2135992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FreeRTOS%20crash%20in%20a%20Wi-Fi%20setup%20example%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%E8%A3%85%E6%9C%89%201XK%20(IW416)%20M.2%20%E6%A8%A1%E5%9D%97%E7%9A%84%20RT1060-EVKB%20%E4%B8%8A%E6%B5%8B%E8%AF%95%E4%BA%86%20wifi_setup%EF%BC%8C%E5%AE%83%E5%9C%A8%E6%88%91%E8%BF%99%E8%BE%B9%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%20Kconfig%20%E5%9B%BE%E5%BD%A2%E7%94%A8%E6%88%B7%E7%95%8C%E9%9D%A2%E9%80%89%E6%8B%A9%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%E9%A1%B9%E7%9B%AE%26gt%3B%20%E9%85%8D%E7%BD%AE%26gt%3B%20%E6%89%93%E5%BC%80%20Kconfig%20GUI%20%E9%85%8D%E7%BD%AE%3C%2FP%3E%0A%3CP%3E2%E3%80%82%E5%85%83%E5%99%A8%E4%BB%B6%E9%85%8D%E7%BD%AE%20%26gt%3B%20wifi_bt_module%20%26gt%3B%20config%20%26gt%3B%20%E9%80%89%E6%8B%A9%E6%81%A9%E6%99%BA%E6%B5%A6%20IW416%20%E6%A8%A1%E5%9D%97%20(NXP%20IW416-MURATA-1XK-M2)%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EMAYA-W161%3C%2FSPAN%3E%E6%B2%A1%E6%9C%89%E8%AF%A5%E9%80%89%E9%A1%B9%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E8%BF%99%E4%B8%A4%E4%B8%AA%E6%A8%A1%E5%9D%97%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%20SoC%E3%80%82%E6%82%A8%E8%83%BD%E5%90%A6%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%B8%8E%E6%88%91%E7%9B%B8%E5%90%8C%E7%9A%84%E9%80%89%E9%A1%B9%22NXP%20IW416-MURATA-1XK-M2%22%20%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2135872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FreeRTOS%20crash%20in%20a%20Wi-Fi%20setup%20example%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ExPSR%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%80%BC%E4%B8%BA%200x81000004%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2135861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FreeRTOS%20crash%20in%20a%20Wi-Fi%20setup%20example%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%E4%BD%BF%E7%94%A8%20SDK%2025.6.0%20%E7%9A%84%20MCUXpresso%20IDE%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E8%AF%A5%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%89%A7%E8%A1%8C%E6%97%B6%E4%BC%9A%E7%A2%B0%E5%88%B0%20MemManage_Handler%EF%BC%88%E5%A6%82%E6%9E%9C%E8%BF%99%E5%AF%B9%E4%BD%A0%E6%9C%89%E5%B8%AE%E5%8A%A9%E7%9A%84%E8%AF%9D%EF%BC%89%E3%80%82%E5%9C%A8%20MCUXpresso%20for%20VS%20Code%20%E4%B8%AD%EF%BC%8C%E5%AE%83%E6%98%AF%20DefaultISR%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20MemManage_Handler%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2135265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FreeRTOS%20crash%20in%20a%20Wi-Fi%20setup%20example%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AE%A9%E6%88%91%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E
