Create and Connect SDK application for Temperature Sensor with Internet Cloud
1,659 次查看
derbon43
Fresh Out Contributor
I am Interfacing temperature sensor with FRDM-K64F but need to connect the sensor with internet cloud to store the readings of sensor in CSV format, some suggested to use NXP SDK tools mcuxpresso I am using I2C interface and trying to write a code using this documentation but I am not able to understand how can I design and connect the application through internet cloud which shows the reading in dashboard for by using the CSV format data of sensor stored in cloud's database
Your lead on this will be appreciated
1,525 次查看
danielchen
Hi William:
I would suggest you refer to the aws examples in the sdk installation folder. The demos demonstrates how the board work with AWS IOT.
Please download the sdk from Welcome | MCUXpresso SDK Builder
and select components freeRTOS, AWS IOT, QCA440x Wifi,  before downloading
