Introducing eRPC
Introducing eRPC
Introducing eRPC
This tutorial is introducing the eRPC (embedded remote procedure call) open-source project.
The eRPC (Embedded Remote Procedure Call) is a Remote Procedure Call (RPC) system created by NXP. An RPC is a mechanism used to invoke a software routine on a remote system using a simple local function call. The remote system may be any CPU connected by an arbitrary communications channel: a server across a network, another CPU core in a multicore system, and so on. To the client, it is just like calling a function in a library built into the application. The only difference is any latency or unreliability introduced by the communications channel.
Important links:
The eRPC is supporting multicore and multiprocessor types of applications.
Where to find eRPC examples
  • Plenty of eRPC multicore and multiprocessor examples can be found in NXP MCUXpressoSDK packages. Visit https://mcuxpresso.nxp.com to configure, build and download these packages.
    To get the board list with multicore support (eRPC included) use filtering based on Middleware and search for 'multicore' string. Once the selected package with the multicore middleware is downloaded, see
    <MCUXpressoSDK_install_dir>/boards/<board_name>/multicore_examples for eRPC multicore examples (RPMsg_Lite or Messaging Unit transports used) or
    <MCUXpressoSDK_install_dir>/boards/<board_name>/multiprocessor_examples for eRPC multiprocessor examples (UART or SPI transports used).
    eRPC examples use the 'erpc_' name prefix.
  • Another way of getting NXP MCUXpressoSDK eRPC multicore and multiprocessor examples is using the mcux-sdk Github repo. Follow the description how to use the West tool to clone and update the mcuxsdk repo in readme Overview section. Once done the armgcc eRPC examples can be found in
    mcuxsdk/examples/<board_name>/multicore_examples or in
    mcuxsdk/examples/<board_name>/multiprocessor_examples folders.
    You can use the evkmimxrt1170 as the board_name for instance. Similar to MCUXpressoSDK packages the eRPC examples use the 'erpc_' name prefix.
Comments
Sorry if i am asking basic question.
I am trying to understand how to use erpcgen tool from NXP.
I successfully ran example demo , with reference : https://github.com/EmbeddedRPC/erpc-imx-demos
My next approach  was build erpcgen  and create my own output files using same erpc_matrix_multiply.erpc and run same demo again so i get familiar to use erpcgen tool.
i got output files but even though i am using same erpc_matrix_multiply.erpc my files different than example files
the changes are :
Output files in example demo says (erpc_matrix_multiply_server.h):
erpc_status_t erpcMatrixMultiply_shim(erpc::Codec * in, erpc::Codec * out, uint32_t sequence);
my files(erpc_matrix_multiply_server.h):
erpc_status_t erpcMatrixMultiply_shim(erpc::Codec * codec, uint32_t sequence);
why files are different , Am i missing any config ?
Do i need to manually edit erpc_matrix_multiply_server.h & erpc_matrix_multiply_server.cpp
Thank you in advance
Chandini
Hi and thanks for your comment.
Example you mentioned is an older version than your erpcgen build. mareknovak also created his fork of official eRPC repository due to some minor changes which were not present in an official release at that time. If you click on eRPC reference from erpc-imx-demos repository from middleware folder, you will be redirect to his eRPC repository. You need build erpcgen from that version. We want update demo in the future.
Hope i helped you. If you have any concerns don't hesitate and ask us.
Hi Dusan
I was using  same eRPC library one which u refereed
Steps i followed are below:
Clone  erpc-imx-demos including sub module(which clone eRPC GitHub - MarekNovakNXP/erpc at 232afb209f0a0cfceb25a1be11879f7d1934e065  )
1. git clone --recursive https://github.com/EmbeddedRPC/erpc-imx-demos.git
2. go to erpc-imx-demos/middleware/erpc folder and build erpcgen like this:
  • installed required packages flex/bison and boost
  • make eprc
  • make eprcgen
  • sudo make install
successfully got erpcgen
3. Tried create my own output files using same erpc_matrix_multiply.erpc like this :
  • erpcgen -I erpc-imx-demos/MCU/example_erpc/service -o test/erpc-imx-demos/MCU/example_erpc/service erpc_matrix_multiply.erpc
successfully got below files:
erpc_matrix_multiply.h
erpc_matrix_multiply_client.cpp
4. Tried to build  MCU/example_erpc/build/armgcc/imx7d_sdb_m4/build_all.sh
failed with error :
/home/basavarajuc/test/erpc-imx-demos/MCU/example_erpc/service/erpc_matrix_multiply_server.cpp: In function 'void* create_MatrixMultiplyService_service()':
/home/basavarajuc/test/erpc-imx-demos/MCU/example_erpc/service/erpc_matrix_multiply_server.cpp:168:56: error: invalid new-expression of abstract class type 'MatrixMultiplyService_service'
return new (nothrow) MatrixMultiplyService_service();
Sorry for asking again , just to clarify my understanding .
1.if i am using eRPC library from GitHub - MarekNovakNXP/erpc at 232afb209f0a0cfceb25a1be11879f7d1934e065 then Do i need to update demo ? to run demo successfully
2. Could you please tell me  output files from erpc-imx-demos/MCU/example_erpc/service at master · EmbeddedRPC/erpc-imx-demos · GitHub  are generated by which erpcgen version ?
So that i can use old erpcgen shortly to create my own files
Thanks a lot . and sorry for disturbance
Chandini
Hi thanks for you interest. Then it looks like the erpc generated files were generated with different erpcgen then on commit Marek provided (our mistake). Best solution looks like we need updated that demo with latests stable erpc and erpcgen version. You can try this from master branch GitHub - EmbeddedRPC/erpc: Embedded RPC (and there is erpcgen prebuilt 1.4.0). But i don't know how much changes you need to do. Or you can wait for our update.
mareknovak
Could you please tell me , when are you going to update ?
Hi, not sooner than tomorrow. But i can't promise that it will be tomorrow. My colleague mareknovak is not in work today. But it should be soon.
Hi Dusan
I did fix and now i got MCU demo working properly ... Thanks for pointing out me a stable version ..
Could you please tell me How to generate python code using erpcgen tool ..  ?
Thank you
Chandini
That's cool, i can continue to work in the same stable version until update .
with couples of fixes my MCU demo build and run properly now ..Thanks for your information
Hi, great work :smileywink: If you want you can create pull request for imx demo repository to fix it. mareknovak can review it and merge it to the repository.
To generate python code: As other application you can do in command line "erpcgen --help (-h should work too)".
python -gpy idl_file -> gpy means generate python.
Thank you Dusan Smiley Happy. once i got my demo working , i will create pull request ..
Thanks again for your reply , i got python files . i will run demo and come back to u shortly .
Finally i got it working , thank a lot for you help :smileyhappy: Dusan
sorry i could not find attach option to attach my patch . so pasted below.
From 7a5b152524a3c82b5bced4a72ed396f21860b666 Mon Sep 17 00:00:00 2001
Date: Mon, 8 May 2017 11:33:05 +0100
Subject: [PATCH] fix to run eRPC_demo
erpc_c/infra/transport.h | 4 +-
erpc_c/setup/erpc_server_setup.cpp | 36 ++++-
erpc_c/setup/erpc_server_setup.h | 2 +-
erpc_c/setup/erpc_setup_rpmsg_lite_rtos_remote.cpp | 54 +++++++
erpc_c/setup/erpc_transport_setup.h | 18 ++-
erpc_c/transports/rpmsg_lite_rtos_transport.cpp | 158 ++++++++++++++++++
erpc_c/transports/rpmsg_lite_rtos_transport.h | 177 +++++++++++++++++++++
erpc_c/transports/rpmsg_rtos_transport.h | 147 +++++++++++++++++
erpc_python/erpc/transport.py | 21 +++
9 files changed, 602 insertions(+), 15 deletions(-)
create mode 100644 erpc_c/setup/erpc_setup_rpmsg_lite_rtos_remote.cpp
create mode 100644 erpc_c/transports/rpmsg_lite_rtos_transport.cpp
create mode 100644 erpc_c/transports/rpmsg_lite_rtos_transport.h
create mode 100644 erpc_c/transports/rpmsg_rtos_transport.h
diff --git a/erpc_c/infra/transport.h b/erpc_c/infra/transport.h
index eb7ec71..fd4862a 100644
--- a/erpc_c/infra/transport.h
+++ b/erpc_c/infra/transport.h
@@ -48,7 +48,7 @@
namespace erpc {
+class MessageBuffer;
* @brief Abstract interface for transport layer.
@@ -89,7 +89,7 @@ public:
* @return based on send implementation.
- virtual erpc_status_t send(MessageBuffer *message) = 0;
+ virtual erpc_status_t send(const MessageBuffer *message) = 0;
* @brief Poll for an incoming message.
diff --git a/erpc_c/setup/erpc_server_setup.cpp b/erpc_c/setup/erpc_server_setup.cpp
index 51fa799..5cd4346 100644
--- a/erpc_c/setup/erpc_server_setup.cpp
+++ b/erpc_c/setup/erpc_server_setup.cpp
@@ -33,8 +33,10 @@
#include "basic_codec.h"
#include "manually_constructed.h"
#include "simple_server.h"
-#include <assert.h>
+#include "message_buffer.h"
+#include "erpc_config_internal.h"
#include <new>
+#include <assert.h>
#if !(__embedded_cplusplus)
using namespace std;
@@ -43,6 +45,29 @@ using namespace std;
using namespace erpc;
+// Classes
+class BasicMessageBufferFactory : public MessageBufferFactory
+public:
+ virtual MessageBuffer create()
+ uint8_t *buf = new (nothrow) uint8_t[ERPC_DEFAULT_BUFFER_SIZE];
+ return MessageBuffer(buf, ERPC_DEFAULT_BUFFER_SIZE);
+ virtual void dispose(MessageBuffer *buf)
+ assert(buf);
+ if (*buf)
+ delete[] buf->get();
// Variables
@@ -50,29 +75,32 @@ using namespace erpc;
static ManuallyConstructed<SimpleServer> s_server;
SimpleServer *g_server;
+static ManuallyConstructed<BasicMessageBufferFactory> s_msgFactory;
static ManuallyConstructed<BasicCodecFactory> s_codecFactory;
// Code
-void erpc_server_init(erpc_transport_t transport, erpc_mbf_t message_buffer_factory)
+void erpc_server_init(erpc_transport_t transport)
// Init factories.
+ s_msgFactory.construct();
s_codecFactory.construct();
// Init server with the provided transport.
s_server.construct();
s_server->setTransport(reinterpret_cast<Transport *>(transport));
+ s_server->setMessageBufferFactory(s_msgFactory);
s_server->setCodecFactory(s_codecFactory);
- s_server->setMessageBufferFactory(reinterpret_cast<MessageBufferFactory *>(message_buffer_factory));
g_server = s_server;
void erpc_server_deinit()
+ s_msgFactory.destroy();
s_codecFactory.destroy();
s_server.destroy();
void erpc_add_service_to_server(void *service)
diff --git a/erpc_c/setup/erpc_server_setup.h b/erpc_c/setup/erpc_server_setup.h
index 8e6a6ef..e4e9eaa 100644
--- a/erpc_c/setup/erpc_server_setup.h
+++ b/erpc_c/setup/erpc_server_setup.h
@@ -60,7 +60,7 @@ extern "C" {
* This function initializes server with all components necessary for running server.
-void erpc_server_init(erpc_transport_t transport, erpc_mbf_t message_buffer_factory);
+void erpc_server_init(erpc_transport_t transport);
* @brief This function de-initializes server.
diff --git a/erpc_c/setup/erpc_setup_rpmsg_lite_rtos_remote.cpp b/erpc_c/setup/erpc_setup_rpmsg_lite_rtos_remote.cpp
new file mode 100644
index 0000000..b480d42
--- /dev/null
+++ b/erpc_c/setup/erpc_setup_rpmsg_lite_rtos_remote.cpp
@@ -0,0 +1,54 @@
+ * Copyright (c) 2014-2016, Freescale Semiconductor, Inc.
+ * Redistribution and use in source and binary forms, with or without modification,
+ * are permitted provided that the following conditions are met:
+ * o Redistributions of source code must retain the above copyright notice, this list
+ * of conditions and the following disclaimer.
+ * o Redistributions in binary form must reproduce the above copyright notice, this
+ * list of conditions and the following disclaimer in the documentation and/or
+ * other materials provided with the distribution.
+ * o Neither the name of Freescale Semiconductor, Inc. nor the names of its
+ * contributors may be used to endorse or promote products derived from this
+ * software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
+ * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
+ * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
+ * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
+ * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+ * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include "manually_constructed.h"
+#include "rpmsg_lite_rtos_transport.h"
+#include "erpc_transport_setup.h"
+using namespace erpc;
+// Variables
+static ManuallyConstructed<RPMsgRTOSTransport> s_transport;
+// Code
+erpc_transport_t erpc_transport_rpmsg_lite_rtos_remote_init(
+ unsigned long src_addr, unsigned long dst_addr, void *start_address, int rpmsg_link_id, void (*ready_cb)(void), bool send_nameservice)
+ s_transport.construct();
+ s_transport->init(src_addr, dst_addr, start_address, rpmsg_link_id, ready_cb, send_nameservice);
+ return reinterpret_cast<erpc_transport_t>(s_transport.get());
diff --git a/erpc_c/setup/erpc_transport_setup.h b/erpc_c/setup/erpc_transport_setup.h
index 798d92f..6c3959e 100644
--- a/erpc_c/setup/erpc_transport_setup.h
+++ b/erpc_c/setup/erpc_transport_setup.h
@@ -34,6 +34,7 @@
#include "erpc_version.h"
#include <stdint.h>
+#include <stdbool.h>
* @addtogroup transport_setup
@@ -48,7 +49,7 @@
//! @brief Opaque transport object type.
typedef struct ErpcTransport *erpc_transport_t;
//! @brief Ready callback object type for RPMsg-Lite transport.
-typedef void (*rpmsg_ready_cb)(void);
+//typedef void (*rpmsg_ready_cb)(void);
// API
@@ -106,21 +107,21 @@ erpc_transport_t erpc_transport_rpmsg_lite_master_init(unsigned long src_addr,
* @brief Create an RPMsg-Lite zero copy transport.
-erpc_transport_t erpc_transport_rpmsg_lite_zc_master_init(unsigned long src_addr,
- unsigned long dst_addr,
- int rpmsg_link_id);
+//erpc_transport_t erpc_transport_rpmsg_lite_zc_master_init(unsigned long src_addr,
+// unsigned long dst_addr,
+// int rpmsg_link_id);
* @brief Create an RPMsg-Lite transport.
erpc_transport_t erpc_transport_rpmsg_lite_remote_init(
- unsigned long src_addr, unsigned long dst_addr, void *start_address, int rpmsg_link_id, rpmsg_ready_cb ready);
+ unsigned long src_addr, unsigned long dst_addr, void *start_address, int rpmsg_link_id, void (*ready_cb)(void), bool send_nameservice);
-erpc_transport_t erpc_transport_rpmsg_lite_zc_remote_init(
+//erpc_transport_t erpc_transport_rpmsg_lite_zc_remote_init(
+// unsigned long src_addr, unsigned long dst_addr, void *start_address, int rpmsg_link_id, rpmsg_ready_cb ready);
* @brief Create an RPMsg-Lite RTOS transport.
@@ -133,7 +134,8 @@ erpc_transport_t erpc_transport_rpmsg_lite_rtos_master_init(unsigned long src_ad
diff --git a/erpc_c/transports/rpmsg_lite_rtos_transport.cpp b/erpc_c/transports/rpmsg_lite_rtos_transport.cpp
index 0000000..e04ae91
--- /dev/null
+++ b/erpc_c/transports/rpmsg_lite_rtos_transport.cpp
@@ -0,0 +1,158 @@
+ * Copyright (c) 2015, Freescale Semiconductor, Inc.
+#include <cassert>
+#if !(__embedded_cplusplus)
+using namespace std;
+#endif
+// Variables
+uint8_t RPMsgRTOSTransport::s_initialized = 0;
+struct rpmsg_lite_instance *RPMsgRTOSTransport::s_rpmsg;
+// Code
+RPMsgRTOSTransport::RPMsgRTOSTransport()
+: Transport()
+, m_dst_addr(0)
+RPMsgRTOSTransport::~RPMsgRTOSTransport()
+ rpmsg_lite_deinit(s_rpmsg);
+ s_initialized = 0;
+erpc_status_t RPMsgRTOSTransport::init(
+ unsigned long src_addr, unsigned long dst_addr, void *base_address, unsigned long length, int rpmsg_link_id)
+ if (!s_initialized)
+ s_rpmsg = rpmsg_lite_master_init(base_address, length, rpmsg_link_id, RL_NO_FLAGS);
+ s_initialized = 1;
+ m_rpmsg_queue = rpmsg_queue_create(s_rpmsg);
+ m_rpmsg_ept = rpmsg_lite_create_ept(s_rpmsg, src_addr, rpmsg_queue_rx_cb, m_rpmsg_queue);
+ m_dst_addr = dst_addr;
+ return m_rpmsg_ept == RL_NULL ? kErpcStatus_InitFailed : kErpcStatus_Success;
+ unsigned long src_addr, unsigned long dst_addr, void *base_address, int rpmsg_link_id, void (*ready_cb)(void), bool send_nameservice)
+ s_rpmsg = rpmsg_lite_remote_init(base_address, rpmsg_link_id, RL_NO_FLAGS);
+ /* Signal the other core we are ready */
+ if (ready_cb != NULL)
+ ready_cb();
+ while (!rpmsg_lite_is_link_up(s_rpmsg))
+ if(send_nameservice)
+ rpmsg_ns_announce(s_rpmsg, m_rpmsg_ept,
+ "rpmsg-openamp-demo-channel",
+ 0);
+erpc_status_t RPMsgRTOSTransport::receive(MessageBuffer *message)
+ int ret_val = rpmsg_queue_recv(s_rpmsg, m_rpmsg_queue, &m_dst_addr, (char *)message->get(), kRpmsgMessageBufferSize,
+ NULL, RL_BLOCK);
+ return ret_val != RL_SUCCESS ? kErpcStatus_ReceiveFailed : kErpcStatus_Success;
+erpc_status_t RPMsgRTOSTransport::send(const MessageBuffer *message)
+ int ret_val =
+ rpmsg_lite_send(s_rpmsg, m_rpmsg_ept, m_dst_addr, (char *)message->get(), message->getUsed(), RL_BLOCK);
+ return ret_val != RL_SUCCESS ? kErpcStatus_SendFailed : kErpcStatus_Success;
+MessageBuffer RPMsgMessageBufferFactory::create()
+ uint8_t idx = 0;
+ while (((m_freeBufferBitmap & idx) == 0) && (idx < kInitCountMessageBuffers))
+ idx++;
+ assert(idx < kInitCountMessageBuffers);
+ m_freeBufferBitmap &= ~(1 << idx);
+ uint8_t *buf;
+ buf = m_buffers[idx];
+ assert(NULL != buf);
+ return MessageBuffer(buf, kRpmsgMessageBufferSize);
+void RPMsgMessageBufferFactory::dispose(MessageBuffer *buf)
+ assert(buf);
+ uint8_t *tmp = buf->get();
+ if (tmp)
+ uint8_t idx = 0;
+ while ((tmp != m_buffers[idx]) && (idx < kInitCountMessageBuffers))
+ ++idx;
+ m_freeBufferBitmap |= 1 << idx;
diff --git a/erpc_c/transports/rpmsg_lite_rtos_transport.h b/erpc_c/transports/rpmsg_lite_rtos_transport.h
index 0000000..f1aec8a
--- /dev/null
+++ b/erpc_c/transports/rpmsg_lite_rtos_transport.h
@@ -0,0 +1,177 @@
+ * Copyright (c) 2015-2016, Freescale Semiconductor, Inc.
+#ifndef _EMBEDDED_RPC__RPMSG_LITE_RTOS_TRANSPORT_H_
+#define _EMBEDDED_RPC__RPMSG_LITE_RTOS_TRANSPORT_H_
+#include "transport.h"
+#include "rpmsg_lite.h"
+#include "rpmsg_queue.h"
+#include "rpmsg_ns.h"
+ * @addtogroup rpmsg_lite_rtos_transport
+ * @file
+// Definitions
+enum
+ kRpmsgMessageBufferSize = RPMSG_BUFFER_SIZE,
+ kInitCountMessageBuffers = 2,
+// Classes
+namespace erpc
+ * @brief Transport that uses RPMsg RTOS API for interprocessor messaging.
+ * @ingroup rpmsg_lite_rtos_transport
+class RPMsgRTOSTransport : public Transport
+public:
+ * @brief Constructor.
+ * This function initializes object attributes.
+ RPMsgRTOSTransport();
+ * @brief RPMsgRTOSTransport destructor
+ virtual ~RPMsgRTOSTransport();
+ * @brief This function call RPMsg rtos init function - as RPMsg master
+ * @param[in] src_addr Source address.
+ * @param[in] dst_addr Destination address.
+ * @param[in] base_address RPMsg base address in the shared memory.
+ * @param[in] length RPMsg shared memory region length.
+ * @param[in] rpmsg_link_id Selection between what cores the communication will occur.
+ * @retval kErpcStatus_Success When rpmsg init function was executed successfully.
+ * @retval kErpcStatus_InitFailed When rpmsg init function wasn't executed successfully.
+ virtual erpc_status_t init(
+ unsigned long src_addr, unsigned long dst_addr, void *base_address, unsigned long length, int rpmsg_link_id);
+ * @brief This function call RPMsg rtos init function - as RPMsg remote
+ * @param[in] ready_cb Callback called after RPMsg init is done and the core is ready.
+ * @param[in] send_nameservice If true, RPMsg master notified by nameservice.
+ unsigned long src_addr, unsigned long dst_addr, void *base_address, int rpmsg_link_id, void (*ready_cb)(void), bool send_nameservice);
+ * @brief Store incoming message to message buffer.
+ * In loop while no message come.
+ * @param[in] message Message buffer, to which will be stored incoming message.
+ * @retval kErpcStatus_ReceiveFailed Failed to receive message buffer.
+ * @retval kErpcStatus_Success Successfully received all data.
+ virtual erpc_status_t receive(MessageBuffer *message);
+ * @brief Function to send prepared message.
+ * @param[in] message Pass message buffer to send.
+ * @retval kErpcStatus_SendFailed Failed to send message buffer.
+ * @retval kErpcStatus_Success Successfully sent all data.
+ virtual erpc_status_t send(const MessageBuffer *message);
+protected:
+ /* Remote device */
+ struct remote_device *m_rdev; /*!< Device which represent the second core. */
+ struct rpmsg_channel *m_app_rp_chnl; /*!< Represent connection between two device (two cores). */
+ unsigned long m_dst_addr; /*!< Destination address used by rpmsg. */
+ rpmsg_queue_handle m_rpmsg_queue; /*!< Handle of RPMsg queue. */
+ struct rpmsg_lite_endpoint *m_rpmsg_ept; /*!< Pointer to RPMsg Lite Endpoint structure. */
+ static struct rpmsg_lite_instance *s_rpmsg; /*!< Pointer to instance of RPMSG lite. */
+ static uint8_t s_initialized; /*!< Represent information if the rpmsg-lite was initialized. */
+class RPMsgMessageBufferFactory : public MessageBufferFactory
+ uint8_t m_freeBufferBitmap;
+ uint8_t m_buffers[kInitCountMessageBuffers][kRpmsgMessageBufferSize];
+public:
+ RPMsgMessageBufferFactory()
+ : m_freeBufferBitmap(0xFF)
+ * @brief RPMsgMessageBufferFactory destructor
+ virtual ~RPMsgMessageBufferFactory() {}
+ * @brief This function create message buffer used for communication between devices.
+ virtual MessageBuffer create();
+ * @brief This function dispose message buffer used for communication between devices.
+ virtual void dispose(MessageBuffer *buf);
+} // namespace erpc
+#endif // _EMBEDDED_RPC__RPMSG_LITE_RTOS_TRANSPORT_H_
diff --git a/erpc_c/transports/rpmsg_rtos_transport.h b/erpc_c/transports/rpmsg_rtos_transport.h
index 0000000..ad1d229
--- /dev/null
+++ b/erpc_c/transports/rpmsg_rtos_transport.h
@@ -0,0 +1,147 @@
+#ifndef _EMBEDDED_RPC__RPMSG_RTOS_TRANSPORT_H_
+#define _EMBEDDED_RPC__RPMSG_RTOS_TRANSPORT_H_
+extern "C" {
+#include "rpmsg.h"
+#include "rpmsg_rtos.h"
+#include "rpmsg.h"
+ * @addtogroup rpmsg_rtos_transport
+ * @file
+// Definitions
+enum
+// Classes
+namespace erpc
+ * @ingroup rpmsg_rtos_transport
+public:
+ * @brief This function call rpmsg rtos init function.
+ * @param[in] dev_id Device id number.
+ * @param[in] role Device role number.
+ virtual erpc_status_t init(int dev_id, int role);
+protected:
+ static struct remote_device *m_rdev; /*!< Device which represent the second core. */
+ static struct rpmsg_channel *m_app_rp_chnl; /*!< Represent connection between two device (two cores). */
+public:
+ RPMsgMessageBufferFactory() {}
+#endif // _EMBEDDED_RPC__RPMSG_RTOS_TRANSPORT_H_
diff --git a/erpc_python/erpc/transport.py b/erpc_python/erpc/transport.py
index 0765e9f..c335943 100644
--- a/erpc_python/erpc/transport.py
+++ b/erpc_python/erpc/transport.py
@@ -31,6 +31,8 @@
import struct
import serial
+from rpmsg.sysfs import RpmsgEndpoint
+import time
import socket
import threading
from .crc16 import crc16
@@ -107,6 +109,25 @@ class SerialTransport(FramedTransport):
class ConnectionClosed(Exception):
pass
+class RpmsgTransport(Transport):
+ def __init__(self):
+ self.ept = RpmsgEndpoint(
+ RpmsgEndpoint.rpmsg_openamp_channel,
+ RpmsgEndpoint.LOCAL_DEFAULT_ADDRESS,
+ RpmsgEndpoint.Types.DATAGRAM)
+ def send(self, message):
+ self.ept.send(message, RpmsgEndpoint.REMOTE_DEFAULT_ADDRESS)
+ def receive(self):
+ while True:
+ ret = self.ept.recv(2048)
+ if len(ret[1]) != 0:
+ return ret[1]
+ else:
+ time.sleep(0.001)
+ return ret[1]
class TCPTransport(FramedTransport):
def __init__(self, host, port, isServer):
super(TCPTransport, self).__init__()
2.7.4
Hi Dusan
Could you please tell me , do u have any client application c example instead of python .? or Do you guys are planning to write one ?it will be so useful and helpful, if you have one already.
Chandini
Hi, we don't have currently example on github repository. But we have C(c++) test there. If you are familiar with Linux or Mac you can use that as a example. Other options are as described above:
1. Download sdk for supported board -> multicore/multiprocessor c/python examples.
2. Read this article: Getting Started · EmbeddedRPC/erpc Wiki · GitHub
Hi Chandini Indavara Basavaraju,
I have just updated the GitHub - EmbeddedRPC/erpc-imx-demos: eRPC demos for i.MX devices  repository to use eRPC 1.4.0 and RPMSg-Lite 1.1.0.
You can download a pre-built erpcgen application, which is used for code generation here: Release v1.4 · EmbeddedRPC/erpc · GitHub  in the downloads section, just choose your architecture.
Then you invoke it like this: ./erpcgen -gpy nameOfInterfaceDefinitionLanguageFile.erpc, this will generate Python serialization and deserialization shim code for you. If you omit -gpy or specify -gc, you will get C shim code.
The ser/des shim code was also update in the latest commit in the erpc-imx-demos repository, so feel free to use it.
Feel free to submit your changes in form of a pull-request,
Regards and thank you for using eRPC & RPMsg-Lite!
Marek
Thank you for reply Dusan
 that was the information i was looking for, i have created C wrapper for TCP  , after couple of fixes in erpc,  it works fine .
My next step is to replace TCP layer with rpmsg .
Thank you again
Chandini
I am happy that you are progressing independently with your issue (for us it means it is not too much complicated for developers). Also mareknovak already updated his imx demo application inside the repository as he mentioned in few comments above. Your next step can be used that version because it is using new rpc features :smileywink:
Hi Dusan ,
thank you for letting me know about update.
I thiink now i am ok with erpc what i have shortly , once i got rpmsg Client application working then i can update erpc version as well.
I was started looking rpmsg-lite , that got M4 platform files .
i wonder do have anything for A7 platform ? or any information will be so helpful. my main aim is to get Client  Application using C with RPMSg as Transport layer
Thank you
Chandini
Hi, i am not sure if we have what you need (c transport for Linux side). But it should be easy to create new one. You can read and write from/to /dev/ttyRPMSG (if it is present in system).
for example:
init can looks like: int fd = open("/dev/ttyRPMSG", O_RDWR);
send : write(fd, buffer, buffer_size);
read: size_t size = read(fd, buffer, expected size);
mareknovak can brings more sun into this issue.
Hi Dusan , Marek
What i am planning :
use rpmsg-lite on both M4(freertos) and A7(Linux)
What i need:
RPMSG C warrper (under erpc_c/setup) which can be use on both M4 and A7 side
RPMSG Transport Layer (under erpc_c/transports) which can be use on both M4 and A7 side
Questions i have:
Could please tell me , Do you have any transport layer for that ?
   or
Do we need to refer rpmsg-python and write similar like that ?
Any suggestions will be so helpful
Thank you guys
Chandini
Hi, i understand you.
You need create new one (and with pull request on github you can add it to our repository if you want).
On Linux side you can use /dev/ttyRPMSG (if it is present in system).
for example create new transport here erpc_c/transports with:
If there is no device named like this, you can be inspired from python code. RPMSG is not my cup of tea. I don't know how it should be used on Linux. I will forward your question to Marek.
Hi Marek
Some how i have missed your message , sorry for that
thanks a lot:smileyhappy: . i will try your new version soon.
Could you please answer my last question regarding RPMSG transport layer ?
Thank you
Chandini
RPMSg-Lite is implementation of RPMsg protocol and is intended only for the M4 side running FreeRTOS or baremetal.
On the Linux/A7 side, you should be fine with the RPMsg implementation in kernel. (like here: GitHub - EmbeddedRPC/erpc-imx-demos: eRPC demos for i.MX devices  )
Or are you planning to run FreeRTOS on both M4 and A7 cores? In that case it would work, but this is not a standard use-case. It would require you to create a porting layer for the A core and to make FreeRTOS run there.
I hope this gives you some direction,
Marek
Hi Marek
Thank you for your reply , it cleared few of my doubts.
We are not planning to use freeRTOS on both side.
Our plan is
M4- FreeRTOS ----This we have it in your Demo
A7-Linux -----Your Demo got python code , to make use of kernel RPMSG implemenation
All we need is instead of python either C or C++.
I think  we can port  python code to C or C++ , easily right ?
Thank you
Chandini
Yes, you are right.
All the Python does are just IO operations on the files (read/write). This is doable in any language, including C/C++.
Python was selected to show how it can be done due to its popularity in Linux user-space, but you can certainly port it to C.
I think we are on the same wavelenght now,
Good luck!
Marek
Hi Marek
I have question again .
Currently my working status  :
  • i got RpmsgEndpoint class in c++
  • I am working on how to make my client application working now.
Python  example.py in erpc-imx-demos/MPU/example_erpc at master · EmbeddedRPC/erpc-imx-demos · GitHub  call  RpmsgTransport which inherited from Transport class.
Question i have is , shall i use transport.h which is inside /erpc-imx-demos/middleware/erpc/erpc_c/infra  to make my application work.
So that i can create my RpmsgTransport class and call it my client application .
Am i thinking correctly ?
Chandini
Hi Chandini. You are right. That are correct steps. You need create your class which is inheriting class from transport.h
Thanks a lot Dusan for quick replySmiley Happy , i will continue in the same path then and come back to u shortly .
You are welcome. You can get inspirations in /erpc-imx-demos/middleware/erpc/transport/ folder. There is several transports.
Dusan , Marek
Ya i am referring those files as well , but
i am using trasport.h to create my transport layer. but facing argument miss-match  problem
  • send and receive functions in transport.h , take Messagebuffer as argument,
         virtual erpc_status_t receive(MessageBuffer *message) = 0;
  • As per example.py i have created my RpmsgEndpoint class which need below arguments
      RpmsgEndpoint::receive(int maxlen)
      RpmsgEndpoint::send(char *buffer,int dst)
As per my understanding, we are just need to read and write /dev/rpmsg_ept1024.1 device from Linux .
So i think instead of using transport.h , i think should i need to create my own transport.h version ,?
Thank you guys
Chandini
Hi chanidi, well you need do it in diferent way :/ You have to use transport.h. It will not work if you will not use that.
Maybe you can use ioctl commands as i mentioned above:
{int fd = open("/dev/rpmsg_ept1024.1", O_RDWR);}
send :erpc_status_t send(MessageBuffer *message) { write(fd, message->getBuffer(), message->getUsed())};
read: erpc_status_t receive(MessageBuffer *message){size_t size = read(fd, message->getBuffer(), 500);
message->setUsed(size)};
novakma7 Can you confirm steps?
Hi Dusan
Thank you for your reply :
I can see getused function in  erpc/message_buffer.h at 9e18d069aeae19a6e80a5e8783903bc63bd9b567 · EmbeddedRPC/erpc · GitHub  but could not find getbuffer function.
I think i have to use below function to get my buffer ? is that right ?
* @brief This function returns pointer to buffer to read/write.
* @return Pointer to buffer to read/write.
uint8_t *get() { return m_buf; }
so my functions becomes like this:
send :erpc_status_t send(MessageBuffer *message) { write(fd, message->get, message->getUsed())};
Thank you
chandini
Hi Chandini, yes that is correct. I was outside of company, so i didn't know exact names for functions. Is it working for you?
HI Dusan ,
As i was busy in some other task , Yesterday i could not try anything . today i will try and let you know .
I think i have to change my functions little bit and need to try . because till now i was passing just char* to my send and receive functions.
Come back to you soon.:smileyhappy:
Thank you
Chandini
Hi dusancervenka-b51352 , b50844 , novakma7
Finally got it working , now demo working fine with my c++ code in Linux .
Thanks a lot guys for answering all my questions.:smileyhappy:
Special thanks to Dusan :smileyhappy:
Thank you
Chandini
Hi Chandini. We are glad you have succeeded. If i can have one special proposal for you, could you send pull request on develop branch on eRPC github with your newly created transport layer (on develop branch). Maybe there will be some work to get it working with newer eRPC. But if you not want updated it i can do that :smileywink: With pull request on github you will be valuable contributor always seen in contributor's history.
I hope eRPC will be good solution for you. And we are always here/ or on github for you :smileywink:
Hi Dusan ,
Sure , i will talk to my seniors and create pull request  . currently i am on holiday .Sorry for the late reply.
Thank you
Chandini
Hi Dusan ,
Very sorry for late response , i was on long holiday . came back now . spoke with my everyone here .  could you please send me your email id so that we will forward stuff for you . according to our company we cant put anything directly to your github .
Thank you
Chandini
Hi Chandini,
It is ok. I was on long holiday too. I hope you enjoyed it well.
I sent you email through community messaging system (private message).
We can discuss details through emails. Basically you ned create fork on github, checkout to develop branch, apply your changes, create commit, create pull request. We will review your changes, suggest changes and merge to develop branch.
Hi dusancervenka-b51352,
I am considering using the erpc framework for a new product i am working on, that uses multiple nxp kinetis devices. I see that last updates to erpc github were made 6 months ago. My question is, is it still being maintained/fixed/developed? I tried the example from github:
erpcgen.exe smac.erpc
And it failed to generate the cpp source code with an error.
The erpcgen executable is from the SDK for MCUXpresso.
Evgeny
Hi evgenyerlihman‌,
Actually we are doing updates more frequently. You need switch to develop branch. GitHub - EmbeddedRPC/erpc at develop. Last code update was yesterday. But you need build erpcgen application there. With that smac IDL should works.
Hey dusancervenka-b51352,
Thank you for the quick reply! I cloned the dev branch. I see that the erpc_c directory structure is way different than the example provided with the Kinetis SDK. Which one is preferable?
Evgeny
Hi evgenyerlihman‌,
Prefered code is always on github on develop branch. Once this code will meet our requirements for new release we will merge it into master branch and we will provide also binaries of application. These updates on develop branch are more often than releases of Kinetis SDK. If some existing eRPC transport will not met version with transport used in Kinetis SDK you can compare old eRPC transport with newer one, or look on file changes in git repository.
Hey Dusan,
When i use the erpcgen.exe that i built, i get the same error on the smac.erpc example:
error: file smac.erpc:135:5: syntax error, unexpected identifier, expecting '}'
The directory structure that i was referring to is the erpc_c from the repository and:
From the SDK example. Which directory structure is the "right" one? Would it be safe to use the newly generated files (by me) with the SDK example code?
Evgeny
Hi Evgeny,
first of all: Are you using smac.erpc from develop branch (and app built from that branch)? For me is this version working.
Right now version of erpcgen app and rest of eRPC code is connected. That means if you want use newer erpcgen app you built from github, you should and have to copy github erpc_c/* files from github into your example. After than you can regenerate code with newer erpcgen app, update application (erpc init + transport) functions and everything else should work. Otherwise if you will not update erpc_c files you have to use provided erpcgen app.
Look at the bottom of this page: Getting Started · EmbeddedRPC/erpc Wiki · GitHub  Should be pretty up to date for newer erpcgen version.
I am not sure but on newest commit spi could get changed so you can use older implementation instead.
Hi Dusan,
I see that the erpc uses a lot of dynamic memory allocation at run-time. Is there a plan to make it more embedded friendly and add a static memory allocation scheme?
EDIT:
I am sorry for the first question, i do see the erpc_setup_mbf_static.cpp in the repository. The thing is that i am basing  my code on the examples provided in the MCUXpresso SDK - frdmk66f_multiprocessor_examples_erpc_server_matrix_multiply_spi & frdmk66f_multiprocessor_examples_erpc_client_matrix_multiply_spi. Which have a very different directories structure from the code in the repository.
So my question is, again, should the SDK examples directories structure should be used or the repositories? ANd why are they so different?
Evgeny
Hi Evgeny, this looks like MCUExpresso project files/IDE issue. Top layer of folder names should be virtual directories, which will be not presented there in future. In your package on your disk should eRPC have similar directory structure as on github. Github directory structure is preferred.
Hi Dusan,
Are there plans to add more static memory allocation to additional parts, such as generated equivalents of erpcMatrixMultiply_shim? Where every input argument gets dynamically allocated before filling it up with data from the codec and then freed after the function invocation?
Something like passing pre-allocated memory (statically by user app) to the framework?
Evgeny
Hi Evgeny, currently we have no estimation for that. But i think you can write/use your own allocator by writing your own implementation of erpc_malloc/erpc_free functions.
Can eRPC communication be protected using some cryptographic transport (e.g. TLS)?
Vakul
Hi Vakul,
sorry i miss your comment. Currently we don't have any cryptographic transport supported. But because of eRPC is modular, i think you can easily add this feature to your eRPC project.
%3CLINGO-SUB%20id%3D%22lingo-sub-1099139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EeRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81eRPC%EF%BC%88%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BF%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%B7%E3%83%BC%E3%82%B8%E3%83%A3%E3%82%B3%E3%83%BC%E3%83%AB%EF%BC%89%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EeRPC%EF%BC%88Embedded%20Remote%20Procedure%20Call%EF%BC%89%E3%81%AF%E3%80%81NXP%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%B7%E3%83%BC%E3%82%B8%E3%83%A3%E3%82%B3%E3%83%BC%E3%83%AB%EF%BC%88RPC%EF%BC%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%99%E3%80%82RPC%20%E3%81%AF%E3%80%81%E5%8D%98%E7%B4%94%E3%81%AA%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E9%96%A2%E6%95%B0%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E4%B8%8A%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%9F%E3%82%81%E3%81%AE%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%81%A7%E3%81%99%E3%80%82%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E7%B5%8C%E7%94%B1%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%86%85%E3%81%AE%E5%88%A5%E3%81%AE%20CPU%20%E3%82%B3%E3%82%A2%E3%81%AA%E3%81%A9%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E9%80%9A%E4%BF%A1%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E4%BB%BB%E6%84%8F%E3%81%AE%20CPU%20%E3%81%A7%E3%81%99%E3%80%82%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E5%94%AF%E4%B8%80%E3%81%AE%E9%81%95%E3%81%84%E3%81%AF%E3%80%81%E9%80%9A%E4%BF%A1%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E3%81%98%E3%82%8B%E9%81%85%E5%BB%B6%E3%82%84%E4%BF%A1%E9%A0%BC%E6%80%A7%E3%81%AE%E4%BD%8E%E4%B8%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%3CSTRONG%3E%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%AA%E3%83%B3%E3%82%AF%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%0A%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%3EeRPC%20%E9%96%8B%E7%99%BA%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AF%3CA%20style%3D%22color%3A%20%232989c5%3B%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EGitHub%20-%20eRPC%20base%3C%2FA%3E%E3%81%AB%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%3EeRPC%E9%96%8B%E7%99%BA%E3%81%AF%3CA%20style%3D%22color%3A%20%232989c5%3B%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EGitHub%20-%20eRPC%E9%96%8B%E7%99%BA%3C%2FA%3E%E3%81%AB%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%3EeRPC%20%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%3CA%20style%3D%22color%3A%20%232989c5%3B%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Freleases%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Freleases%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EGitHub%20-%20eRPC%20Releases%3C%2FA%3E%E3%81%AB%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%3EeRPC%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%3CA%20style%3D%22color%3A%20%232989c5%3B%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Fwiki%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Fwiki%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EGitHub%20-%20eRPC%20wiki%3C%2FA%3E%E3%81%AB%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%3Epypi%E3%81%A7%E3%81%AEeRPC%20%3CA%20style%3D%22color%3A%20%232989c5%3B%22%20title%3D%22https%3A%2F%2Fpypi.python.org%2Fpypi%2Ferpc%22%20href%3D%22https%3A%2F%2Fpypi.python.org%2Fpypi%2Ferpc%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EPython%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%3C%2FA%3E%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AEeRPC%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EeRPC%20%E3%81%AF%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%81%8A%E3%82%88%E3%81%B3%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%3CSTRONG%3EeRPC%E3%81%AE%E4%BE%8B%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8B%E5%A0%B4%E6%89%80%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3ENXP%20MCUXpressoSDK%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%AF%E3%80%81eRPC%20%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%81%8A%E3%82%88%E3%81%B3%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E4%BE%8B%E3%81%8C%E8%B1%8A%E5%AF%8C%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E6%88%90%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fmcuxpresso.nxp.com%3C%2FA%3E%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%EF%BC%88eRPC%E3%82%92%E5%90%AB%E3%82%80%EF%BC%89%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%89%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%80%8Cmulticore%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E6%96%87%E5%AD%97%E5%88%97%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%90%AB%E3%82%80%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%3CBR%20%2F%3E%3CEM%3E%3CMCUXPRESSOSDK_INSTALL_DIR%3E%2Fboards%2F%3CBOARD_NAME%3E%2Fmulticore_examples%3C%2FBOARD_NAME%3E%3C%2FMCUXPRESSOSDK_INSTALL_DIR%3E%3C%2FEM%3E%20%E3%81%A7%20eRPC%20%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%81%AE%E4%BE%8B%20(RPMsg_Lite%20%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8)%20%E3%81%BE%E3%81%9F%E3%81%AF%20%3CBR%20%2F%3E%3CEM%3E%3CMCUXPRESSOSDK_INSTALL_DIR%3E%2Fboards%2F%3CBOARD_NAME%3E%2Fmultiprocessor_examples%3C%2FBOARD_NAME%3E%3C%2FMCUXPRESSOSDK_INSTALL_DIR%3E%3C%2FEM%3E%20%E3%81%A7%20eRPC%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E4%BE%8B%20(UART%20%E3%81%BE%E3%81%9F%E3%81%AF%20SPI%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8)%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EeRPC%20%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%80%8Cerpc_%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%0A%3CLI%3ENXP%20MCUXpressoSDK%20eRPC%20%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%81%8A%E3%82%88%E3%81%B3%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E4%BE%8B%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%82%82%E3%81%861%E3%81%A4%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcux-sdk%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Emcux-sdk%3C%2FA%3E%20Github%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82West%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20mcuxsdk%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E8%A4%87%E8%A3%BD%E3%81%8A%E3%82%88%E3%81%B3%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcux-sdk%23overview%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ereadme%20%E3%81%AE%E3%80%8C%E6%A6%82%E8%A6%81%E3%80%8D%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FA%3E%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81armgcc%20eRPC%E3%81%AE%E4%BE%8B%E3%81%AF%3CBR%20%2F%3E%3CEM%3Emcuxsdk%2Fexamples%2F%3CBOARD_NAME%3E%2Fmulticore_examples%3C%2FBOARD_NAME%3E%3C%2FEM%3E%20%E3%81%BE%E3%81%9F%E3%81%AF%3CBR%20%2F%3E%3CEM%3Emcuxsdk%2Fexamples%2F%3CBOARD_NAME%3E%2Fmultiprocessor_examples%3C%2FBOARD_NAME%3E%3C%2FEM%3E%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81board_name%20%E3%81%A8%E3%81%97%E3%81%A6%20evkmimxrt1170%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82MCUXpressoSDK%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81eRPC%20%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%8Cerpc_%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EKunal%E6%A7%98%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%93%E3%81%A1%E3%82%89%E3%81%A7%E5%8F%96%E3%82%8A%E4%B8%8A%E3%81%92%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%2Fissues%2F5%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%2Fissues%2F5%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EeRPC%E3%82%92iMx6sx%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%90%E3%82%A4%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%20%C2%B7%20%E5%95%8F%E9%A1%8C%20%235%20%C2%B7%20EmbeddedRPC%2Ferpc-imx-demos%20%C2%B7%20GitHub%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%26nbsp%3B%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fcccheng914%40gmail.com%22%20target%3D%22_blank%22%3Ecccheng914%40gmail.com%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EMPC5748G%E3%81%A7%E3%81%AEeRPC%E3%81%AE%E5%85%AC%E5%BC%8F%E3%81%AA%E4%BD%BF%E7%94%A8%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%BF%B5%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E8%A8%80%E3%81%A3%E3%81%A6%E3%81%8A%E3%81%8F%E3%81%A8%E3%80%81eRPC%E3%81%AF%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E8%A8%80%E8%AA%9E%E3%80%81OS%E3%80%81%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E5%B1%A4%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E5%9B%BA%E6%9C%89%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81Freertos%E3%81%A8C%E8%A8%80%E8%AA%9E%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BB%E3%81%BC%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%AF%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%EF%BC%88%E3%81%BE%E3%81%A0%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EHi%20Dusan%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EeRPC%E3%81%AFNXP%20MPC5748G%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EAlex%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Flee.baker%40cubic.com%22%20target%3D%22_blank%22%3Elee.baker%40cubic.com%3C%2FA%3E%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E5%88%86%E9%87%8E%E3%81%A7%E3%81%AE%E7%B5%8C%E9%A8%93%E3%81%8C%E3%81%82%E3%81%BE%E3%82%8A%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%80%E8%BF%91%E3%80%81%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8B%E3%82%89%E8%A4%87%E6%95%B0%E3%81%AEerpc%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%9F%E9%9A%9B%E3%81%AB%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%9F%E3%83%A5%E3%83%BC%E3%83%86%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A7%E3%82%82%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E6%B0%97%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%90%E3%81%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%20RPSMG%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20Mcore%20%E3%81%A8%20iMX%20Linux%20%E3%81%AE%E3%81%A9%E3%81%A1%E3%82%89%E3%81%8C%E5%84%AA%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%A8%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AB%E3%83%9F%E3%83%A5%E3%83%BC%E3%83%86%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%EF%BC%88%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81eRPC%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82performRequest%20%E9%96%A2%E6%95%B0%E3%81%AE%E3%81%A9%E3%81%93%E3%81%8B%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%EF%BC%89%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%94%E3%81%A8%E3%81%AB%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E8%89%AF%E3%81%95%E3%81%9D%E3%81%86%E3%81%AB%E8%81%9E%E3%81%93%E3%81%88%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%BE%E3%81%A0%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%88%E3%82%8A%E5%B0%8F%E3%81%95%E3%81%AA%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E5%88%9D%E6%9C%9F%E5%8C%96%E9%96%A2%E6%95%B0%E3%81%AF%EF%BC%88%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%95%B0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%EF%BC%89%E3%82%88%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%80%81%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E5%81%B4%E3%81%AEeRPC%20rpmsg%E9%80%81%E5%8F%97%E4%BF%A1%E6%A9%9F%E8%83%BD%E3%82%92%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E9%80%81%E4%BF%A1%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%3CSPAN%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AEeRPC%20rpmsg%E5%8F%97%E4%BF%A1%E6%A9%9F%E8%83%BD%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A7%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%BE%85%E3%81%A4%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%93%E3%82%8C%E3%81%8C%E7%B0%A1%E5%8D%98%E3%81%AA%E4%BD%9C%E6%A5%AD%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%82%82%E3%81%A3%E3%81%A8%E8%A4%87%E9%9B%91%E3%81%AA%E4%BD%9C%E6%A5%AD%E3%81%AA%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E5%BF%83%E9%85%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dusan%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%93Cubic%E3%81%A7%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E5%83%8D%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%8B%E3%82%89%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81eRPC%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%BF%BD%E5%8A%A0%E6%83%85%E5%A0%B1%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E5%8D%98%E4%B8%80%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%AC%A1%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%92%E8%A1%8C%E3%81%86%E5%89%8D%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E4%B8%80%E5%BA%A6%E9%99%90%E3%82%8A%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%AB%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%8B%E3%82%89%E8%A4%87%E6%95%B0%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%92%E8%A1%8C%E3%81%86%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E6%9C%80%E5%96%84%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%9F%E9%9A%9B%E3%80%81%E7%A7%81%E3%81%AE%E7%9F%A5%E8%AD%98%E4%B8%8D%E8%B6%B3%E3%81%8B%E3%82%89%E3%80%81%E5%90%8C%E6%99%82%E3%81%AB%E4%BB%96%E3%81%AE%E9%9B%BB%E8%A9%B1%E3%82%92%E3%81%8B%E3%81%91%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%9D%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81eRPC%E3%81%8B%E3%82%89%E9%80%9A%E4%BF%A1%E5%A4%B1%E6%95%97%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E5%8D%98%E4%B8%80%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E5%81%B4%E3%81%A7%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%BB%E3%83%BC%E3%83%95%E3%81%AB%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%94%E3%81%A8%E3%81%AB%E5%88%A5%E3%80%85%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E4%BD%95%E3%81%8B%E4%BB%96%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fsasicsepsg%40gmail.com%22%20target%3D%22_blank%22%3Esasicsepsg%40gmail.com%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E9%9D%A2%E7%99%BD%E3%81%84%E3%81%A7%E3%81%99%E3%81%AD%E3%80%81%E4%BB%8A%E6%97%A5%E3%81%AF%E5%88%A5%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%93%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%AA%AD%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E7%AC%91%E9%A1%94%E3%81%AE%E9%A1%94%E6%96%87%E5%AD%97%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dusan%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%85%E9%80%9F%E3%81%AA%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%A8%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%20API%20%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Nagle%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81TCP%20%E3%81%A7%E3%82%88%E3%82%8A%E8%89%AF%E3%81%84%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%EF%BC%88%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E7%A7%92%E5%8D%98%E4%BD%8D%E3%81%AE%E5%BF%9C%E7%AD%94%EF%BC%89%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23EFF0F1%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23242729%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20background%3A%20%23EFF0F1%3B%22%3Eint%20result%20%3D%20setsockopt(sock%2C%20%2F*%20%E5%BD%B1%E9%9F%BF%E3%82%92%E5%8F%97%E3%81%91%E3%82%8B%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23EFF0F1%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23242729%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20background%3A%20%23EFF0F1%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20IPPROTO_TCP%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20TCP%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23EFF0F1%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23242729%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20background%3A%20%23EFF0F1%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20TCP_NODELAY%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%90%8D%E5%89%8D%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23EFF0F1%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23242729%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20background%3A%20%23EFF0F1%3B%22%3E(char%20*)%20%26amp%3Bflag%E3%80%81%2F*%20%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%81%AF%E6%AD%B4%E5%8F%B2%E7%9A%84%E3%81%AA%E5%90%8D%E6%AE%8B%E3%81%A7%E3%81%99%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23EFF0F1%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23242729%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20background%3A%20%23EFF0F1%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sizeof(int))%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E5%80%A4%E3%81%AE%E9%95%B7%E3%81%95%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E8%B3%87%E6%96%99%EF%BC%9A%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.extrahop.com%2Fcompany%2Fblog%2F2016%2Ftcp-nodelay-nagle-quickack-best-practices%2F%22%20title%3D%22https%3A%2F%2Fwww.extrahop.com%2Fcompany%2Fblog%2F2016%2Ftcp-nodelay-nagle-quickack-best-practices%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETCP_NODELAY%3A%202018%E5%B9%B4%E3%81%AETCP%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%AE%E3%83%99%E3%82%B9%E3%83%88%E3%83%97%E3%83%A9%E3%82%AF%E3%83%86%E3%82%A3%E3%82%B9%20%7C%20ExtraHop%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B5%E3%82%B7%E3%83%80%E3%83%A9%E3%83%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fsasicsepsg%40gmail.com%22%20target%3D%22_blank%22%3Esasicsepsg%40gmail.com%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8FGitHub%E3%81%A7%EF%BC%88%E5%90%8C%E3%81%98%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%A7%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%EF%BC%89%E8%B3%AA%E5%95%8F%E3%81%99%E3%82%8B%E3%81%A8%E8%89%AF%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82TCP%20%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E4%BD%95%E3%81%8B%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%8C%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%202%20%E4%BA%BA%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20github%3A%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGitHub%20-%20EmbeddedRPC%2Ferpc%3A%20Embedded%20RPC%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%AC%E3%83%83%E3%83%891%3A%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Fissues%2F32%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Fissues%2F32%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E8%A4%87%E6%95%B0%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%20TCP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20%C2%B7%20%E5%95%8F%E9%A1%8C%20%2332%20%C2%B7%20EmbeddedRPC%2Ferpc%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%AC%E3%83%83%E3%83%892%3A%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Fissues%2F39%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Fissues%2F39%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETCP%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%2F%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%20%C2%B7%20%E5%95%8F%E9%A1%8C%20%2339%20%C2%B7%20EmbeddedRPC%2Ferpc%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%80%8B%E4%BA%BA%E7%9A%84%E3%81%AB%E3%81%93%E3%82%8C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AB%E5%BD%93%E3%81%A6%E3%81%AF%E3%81%BE%E3%82%8B%E3%81%8B%E3%80%81%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3A%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fserverfault.com%2Fquestions%2F623780%2Flow-latency-tcp-settings-on-ubuntu%22%20title%3D%22https%3A%2F%2Fserverfault.com%2Fquestions%2F623780%2Flow-latency-tcp-settings-on-ubuntu%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elinux%20-%20Ubuntu%E3%81%A7%E3%81%AE%E4%BD%8E%E9%81%85%E5%BB%B6TCP%E8%A8%AD%E5%AE%9A%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dusan%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EeRPC%E3%82%92TCP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%AE%E6%83%B3%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%EF%BC%88Linux%E5%86%85%EF%BC%89%E3%81%A7%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%EF%BC%88test_arrays%EF%BC%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AE%E5%BF%9C%E7%AD%94%E6%99%82%E9%96%93%E3%81%AF1%E3%83%9F%E3%83%AA%E7%A7%92%E6%9C%AA%E6%BA%80%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%8C%E3%81%98%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92TCP%E7%B5%8C%E7%94%B1%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81TCP%E3%81%AE%E5%BF%9C%E7%AD%94%E6%99%82%E9%96%93%E3%81%AF%E7%B4%8490%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%81%85%E5%BB%B6%E3%82%92%E6%B8%9B%E3%82%89%E3%81%97%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%20TCP%20%E4%B8%8A%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%92%E5%90%91%E4%B8%8A%E3%81%95%E3%81%9B%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B5%E3%82%B7%E3%83%80%E3%83%A9%E3%83%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Dusan.%3C%2FP%3E%3CP%3E%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E4%BE%8B%E3%81%8C%E6%8C%99%E3%81%92%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EA9%20%E3%81%8B%E3%82%89%E3%81%AE%E9%96%A2%E6%95%B0%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%80%81M4%20%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AFM4%E3%81%8C%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%A8%E3%81%8D%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8CA9%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CMU%E9%80%81%E4%BF%A1%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E7%A9%BA%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%86%E3%83%BC%E3%82%93%E3%80%81imx_mu_rpmsg_send()%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A-5%E3%80%8D%E3%80%82%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E5%BE%8C%E3%80%81%E4%BB%96%E3%81%AE%E5%81%B4%E3%81%A7%E3%82%82%E3%83%87%E3%83%BC%E3%82%BF%E9%96%A2%E6%95%B0%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3A%20%E3%80%8Crpmsg_multiept%20rpmsg0%3A%20virtqueue_add_outbuf%20failed%3A%20-5%E3%80%8D%3C%2FP%3E%3CP%3E%E4%BD%95%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Vadim%2C%3C%2FP%3E%3CP%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E3%81%AF2%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%821%E3%81%A4%E3%81%AF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E7%94%A8%E3%80%81%E3%82%82%E3%81%861%E3%81%A4%E3%81%AF%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E7%94%A8%E3%81%A7%E3%81%99%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81erpc_arbitrated_client_init%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSTRONG%3E%3C%2FSTRONG%3E%3CSTRONG%3Einit%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%3C%2FSTRONG%3E%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%89%E3%82%A5%E3%82%B7%E3%83%A3%E3%83%B3%E3%81%95%E3%82%93%E3%80%81%E3%83%9E%E3%83%AC%E3%82%AF%E3%81%95%E3%82%93%E3%80%81%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%82%3C%2FP%3E%3CP%3EeRPC%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82M4%EF%BC%88%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%EF%BC%89-A9%EF%BC%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%EF%BC%89%E3%81%BE%E3%81%9F%E3%81%AF%20M4%EF%BC%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%EF%BC%89-A9%EF%BC%88%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%EF%BC%89%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%90%84%E5%81%B4%E3%81%A7%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%2F%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%8A%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%8A%E3%82%89%E3%81%9A%E3%80%81%E7%89%87%E5%81%B4%E3%81%8B%E3%82%89%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C1%E5%9B%9E%E3%81%97%E3%81%8B%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%85%A8%E4%BD%93%E7%9A%84%E3%81%AA%E6%A7%8B%E9%80%A0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3CBR%20%2F%3EM4%E4%B8%8A%E3%81%A7%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%A8%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB2%E3%81%A4%E3%81%AE%E5%88%A5%E3%80%85%E3%81%AEFreeRTOS%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3EM4%3C%2FP%3E%3CP%3E.%3CBR%20%2F%3E.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Eerpc_transport_t%20transport%20%3D%20erpc_transport_rpmsg_lite_rtos_remote_init(.....)%3B%3CBR%20%2F%3Eerpc_mbf_t%20message_buffer_factory%20%3D%20erpc_mbf_rpmsg_init(transport)%3B%3CBR%20%2F%3Eerpc_server_init(transport%2C%20message_buffer_factory)%3B%3CBR%20%2F%3Eerpc_add_service_to_server(create_TEST_service())%3B%3CBR%20%2F%3Eerpc_arbitrated_client_init(transport%2C%20message_buffer_factory)%3B%3C%2FP%3E%3CP%3Ewhile%20(true)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20erpc_server_poll()%3B%3CBR%20%2F%3E%20function1(....)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3EA9%3C%2FP%3E%3CP%3E.%3CBR%20%2F%3E.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Eerpc_transport_t%20transport%20%3D%20erpc_transport_rpmsg_linux_init(......)%3B%3CBR%20%2F%3Eerpc_mbf_t%20message_buffer_factory%20%3D%20erpc_mbf_dynamic_init()%3B%3CBR%20%2F%3Eerpc_server_init(transport%2C%20message_buffer_factory)%3B%3CBR%20%2F%3Eerpc_add_service_to_server(create_TEST_service())%3B%3CBR%20%2F%3Eerpc_arbitrated_client_init(transport%2C%20message_buffer_factory)%3B%3C%2FP%3E%3CP%3Ewhile%20(true)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20erpc_server_poll()%3B%3CBR%20%2F%3E%20function2(....)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fvadimfilippenko%22%20target%3D%22_blank%22%3Evadimfilippenko%3C%2FA%3E%E6%A7%98%E3%80%81Python%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E3%81%BE%E3%81%A0%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%2Fissues%2F2%23issuecomment-375847700%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%2Fissues%2F2%23issuecomment-375847700%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%80%8CMPU%20%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%20-%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20%C2%B7%20%E5%95%8F%E9%A1%8C%20%232%20%C2%B7%20EmbeddedRPC%2Ferpc-imx-demos%20%C2%B7%20GitHub%E3%80%8D%3C%2FA%3E%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CSTRONG%20style%3D%22font-weight%3A%20600%3B%22%3E%3CA%20data-hovercard-user-id%3D%222257779%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fmhanuel26%22%20style%3D%22color%3A%20%23586069%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emhanuel26%3C%2FA%3E%E3%81%AE%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E6%9C%80%E5%BE%8C%E3%81%AE2%E3%81%A4%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%E3%81%A7%E3%81%AF%E3%80%81Python%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E5%86%85%E5%AE%B9%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDusan%2C%20Marek%2C%3C%2FP%3E%3CP%3E%E3%81%A4%E3%81%84%E3%81%AB%E3%80%81%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%9FeRPC%E3%81%AE%E4%BE%8B%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81Linux%E5%81%B4%E3%81%A7%E3%81%AFC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81M4%E3%81%A7%E3%81%AF6%E3%81%A4%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E6%8C%81%E3%81%A4erpc%201.5.0%E3%81%AErpmsg%E5%88%9D%E6%9C%9F%E5%8C%96%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%886%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8BDusan%E3%81%AE%E3%83%92%E3%83%B3%E3%83%88%E3%81%AFGitHub%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%A0%E8%B3%AA%E5%95%8F%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EPython%20%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AE%E5%89%8D%E3%81%AB%20M4%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Vadim%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%A1%E3%82%89%E3%81%AB%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9Als%20%3CSPAN%20style%3D%22color%3A%20%23032f62%3B%20background-color%3A%20%23ffffff%3B%22%3E%2Fsys%2Fclass%2Frpmsg%3C%2FSPAN%3E%3CBR%20%2F%3E%E3%83%8D%E3%83%BC%E3%83%A0%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%8C%20M4%20%E3%81%8B%E3%82%89%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%20(M4%20%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F)%E3%80%82%E3%81%93%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81M4%E3%81%8B%E3%82%89%E5%8B%95%E7%9A%84%E3%81%AB%E3%82%A2%E3%83%8A%E3%82%A6%E3%83%B3%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9F%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E6%8C%81%E3%81%A4%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81Python%E3%81%AFrpmsg%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93...M4%E3%82%B3%E3%82%A2%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EMarek%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Vadim%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%94%E8%A6%A7%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%97%A9%E3%81%8F%E5%9B%9E%E7%AD%94%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E5%8A%AA%E3%82%81%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BB%8A%E9%80%B1%EF%BC%88%E3%81%9D%E3%81%97%E3%81%A6%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E6%9D%A5%E9%80%B1%EF%BC%89%E3%81%AF%E5%BF%99%E3%81%97%E3%81%8F%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%9F%E3%81%A0%E3%80%81%E7%A7%81%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E8%A6%8B%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%81%AF%E3%80%81transport.py%20%E5%86%85%E3%81%AE%20RpmsgTransport%20%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%AB%E3%81%82%E3%82%8B%20%3CSTRONG%3Einit%3C%2FSTRONG%3E%20%E9%96%A2%E6%95%B0%E3%82%92%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%A1%E3%82%89%E3%82%82%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%26nbsp%3B%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%2Fblob%2Fmaster%2Fmiddleware%2Frpmsg-python%2Frpmsg%2Fsysfs.py%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%2Fblob%2Fmaster%2Fmiddleware%2Frpmsg-python%2Frpmsg%2Fsysfs.py%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eerpc-imx-demos%2Fsysfs.py%20at%20master%20%C2%B7%20EmbeddedRPC%2Ferpc-imx-demos%20%C2%B7%20GitHub%3C%2FA%3E%26nbsp%3B%20%26nbsp%3B-%20%E3%82%AF%E3%83%A9%E3%82%B9%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%236f42c1%3B%20background-color%3A%20%23ffffff%3B%22%3ERpmsgEndpoint%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGitHub%20-%20EmbeddedRPC%2Ferpc-imx-demos%3A%20eRPC%20demos%20for%20i.MX%20devices%3C%2FA%3E%20%E3%81%8C%E6%9C%80%E6%96%B0%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%82%B5%E3%83%96%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%8C%20erpc-imx-demos%20%E3%81%A8%E6%95%B4%E5%90%88%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E6%99%82%E3%81%AB%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fmareknovak%22%20target%3D%22_blank%22%3Emareknovak%3C%2FA%3E%E3%81%8C%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CTABLE%20data-tab-size%3D%228%22%20style%3D%22color%3A%20%2324292e%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20class%3D%22%22%20style%3D%22color%3A%20%2324292e%3B%20padding%3A%200px%2010px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23d73a49%3B%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23005cc5%3B%22%3Eself%3C%2FSPAN%3E.id%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23d73a49%3B%22%3E%3D%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23d73a49%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23005cc5%3B%22%3E1%3C%2FSPAN%3E%3A%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22%22%20data-line-number%3D%22116%22%20style%3D%22color%3A%20rgba(27%2C%2031%2C%2035%2C%200.3)%3B%20padding%3A%200px%2010px%3B%22%3E%3C%2FTD%3E%3CTD%20class%3D%22%22%20style%3D%22color%3A%20%2324292e%3B%20padding%3A%200px%2010px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23d73a49%3B%22%3Eraise%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23005cc5%3B%22%3EException%3C%2FSPAN%3E()%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3Eis%20returning%20-1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%81%8A%E6%89%8B%E4%BC%9D%E3%81%84%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E3%80%81iMX6COM%20%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%20erpc-imx-demos%20%E3%81%8B%E3%82%89%20eRPC%20%E3%83%87%E3%83%A2%E3%81%AE%E4%BE%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EM4%E5%81%B4%E3%81%A7%E3%83%87%E3%83%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%22%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EeRPC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EMatrixMultiply%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%E3%81%A7%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E4%B8%AD%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%22root%40imx6sxea-com%3A~%23%20modprobe%20-v%20rpmsg_multiept%3CBR%20%2F%3Einsmod%20%2Flib%2Fmodules%2F4.1.15-2.0.3%2Bgeb0b90b%2Fkernel%2Fdrivers%2Frpmsg%2Frpmsg_multiept.ko%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E(%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8B%E3%82%89%E3%80%81rpmsg%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%84%E3%80%81sys%2Fclass%2Frpmsg%E3%81%AE%E4%B8%8B%E3%81%AErpmsg%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8C%E7%A9%BA%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%E3%81%A7appl%E3%83%87%E3%83%A2%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%EF%BC%88%E6%9C%80%E5%BE%8C%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cexample.py%E3%80%8D%E3%80%81%3CMODULE%3E%E3%81%AE111%20%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3E%20transport%20%3D%20erpc.transport.RpmsgTransport()%3CBR%20%2F%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cbuild%2Fbdist.linux-armv7l%2Fegg%2Ferpc%2Ftransport.py%E3%80%8D%E3%80%81__init__%E3%81%AE199%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cbuild%2Fbdist.linux-armv7l%2Fegg%2Frpmsg%2Fsysfs.py%E3%80%8D__init__%20%E3%81%AE116%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3E%E4%BE%8B%E5%A4%96%3CBR%20%2F%3E%E4%BE%8B%E5%A4%96%E3%82%BF%E3%82%A4%E3%83%97%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%3CRPMSG.SYSFS.RPMSGENDPOINT%20instance%3D%22%22%20at%3D%22%22%200x764bde68%3D%22%22%3E%20%26gt%3B%20%E3%81%AE%20%3CBOUND%20method%3D%22%22%20rpmsgendpoint.__del__%3D%22%22%20%E3%81%AB%E3%81%82%E3%82%8B%3D%22%22%3E%3C%2FBOUND%3E%3C%2FRPMSG.SYSFS.RPMSGENDPOINT%3E%3C%2FMODULE%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%BD%E4%BC%B8%EF%BC%9A%3CBR%20%2F%3Ecmake%20%E3%81%A8%20eclipse%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6M4%20eRPC%20%E3%83%87%E3%83%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EM4%20rpmsg%20%E3%83%87%E3%83%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Vakul%2C%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A6%8B%E9%80%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81eRPC%20%E3%81%AF%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E5%BC%8F%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%20eRPC%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EeRPC%E9%80%9A%E4%BF%A1%E3%81%AF%E3%80%81%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E9%80%9A%E4%BF%A1%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E4%BF%9D%E8%AD%B7%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%88%E4%BE%8B%EF%BC%9ATLS%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EVakul%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Evgeny%E3%81%95%E3%82%93%E3%80%82%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E3%81%9D%E3%81%AE%E8%A6%8B%E7%A9%8D%E3%82%82%E3%82%8A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81erpc_malloc%2Ferpc_free%E9%96%A2%E6%95%B0%E3%81%AE%E7%8B%AC%E8%87%AA%E3%81%AE%E5%AE%9F%E8%A3%85%E3%82%92%E6%9B%B8%E3%81%8F%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%E3%82%A2%E3%83%AD%E3%82%B1%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%BE%E3%81%9F%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dusan%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EerpcMatrixMultiply_shim%20%E3%81%AE%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E5%90%8C%E7%AD%89%E7%89%A9%E3%81%AA%E3%81%A9%E3%80%81%E8%BF%BD%E5%8A%A0%E9%83%A8%E5%88%86%E3%81%AB%E9%9D%99%E7%9A%84%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%85%A5%E5%8A%9B%E5%BC%95%E6%95%B0%E3%81%8C%E3%80%81%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%8B%E3%82%89%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E5%8B%95%E7%9A%84%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%80%81%E9%96%A2%E6%95%B0%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%BE%8C%E3%81%AB%E8%A7%A3%E6%94%BE%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E6%89%80%E3%81%AE%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E4%BA%8B%E5%89%8D%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%EF%BC%88%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E9%9D%99%E7%9A%84%E3%81%AB%EF%BC%89%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E6%B8%A1%E3%81%99%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EEvgeny%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EEvgeny%E6%A7%98%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%20MCUExpresso%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%8FIDE%20%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E5%90%8D%E3%81%AE%E6%9C%80%E4%B8%8A%E4%BD%8D%E5%B1%A4%E3%81%AF%E4%BB%AE%E6%83%B3%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E5%B0%86%E6%9D%A5%E7%9A%84%E3%81%AB%E3%81%AF%E3%81%9D%E3%81%93%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E4%B8%8A%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%AF%E3%80%81eRPC%E3%81%AFGitHub%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E6%A7%8B%E9%80%A0%E3%82%92%E6%8C%81%E3%81%A4%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSTRONG%3EGithub%20%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E6%A7%8B%E9%80%A0%E3%81%8C%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dusan%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eerpc%20%E3%81%AF%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AB%E5%A4%A7%E9%87%8F%E3%81%AE%E5%8B%95%E7%9A%84%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E5%90%91%E3%81%91%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E9%9D%99%E7%9A%84%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%B9%E3%82%AD%E3%83%BC%E3%83%A0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%B7%A8%E9%9B%86%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AB%20erpc_setup_mbf_static.cpp%20%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%AF%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CSPAN%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AFMCUXpresso%20SDK-frdmk66f_multiprocessor_examples_erpc_server_matrix_multiply_spi%20%26amp%3B%20frdmk66f_multiprocessor_examples_erpc_client_matrix_multiply_spi%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E4%BE%8B%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E6%A7%8B%E9%80%A0%E3%81%8C%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%86%8D%E5%BA%A6%E7%A2%BA%E8%AA%8D%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82SDK%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E6%A7%8B%E9%80%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%8B%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E5%A4%A7%E3%81%8D%E3%81%8F%E9%81%95%E3%81%86%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EEvgeny%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Evgeny%2C%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E9%96%8B%E7%99%BA%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AEsmac.erpc%EF%BC%88%E3%81%8A%E3%82%88%E3%81%B3%E3%81%93%E3%81%93%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A2%E3%83%97%E3%83%AA%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81erpcgen%20%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E6%AE%8B%E3%82%8A%E3%81%AE%20eRPC%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A7%E3%81%99%E3%81%8B%E3%82%89%E3%80%81GitHub%E3%81%8B%E3%82%89%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84erpcgen%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81GitHub%E3%81%AEerpc_c%2F*%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92GitHub%E3%81%8B%E3%82%89%E4%BE%8B%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%20erpcgen%20%E3%82%A2%E3%83%97%E3%83%AA%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%86%8D%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%88erpc%20init%20%2B%20transport%EF%BC%89%E9%96%A2%E6%95%B0%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81erpc_c%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20erpcgen%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E4%B8%8B%E9%83%A8%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Fwiki%2FGetting-Started%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Fwiki%2FGetting-Started%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%80%8C%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%20%C2%B7%20EmbeddedRPC%2Ferpc%20Wiki%20%C2%B7%20GitHub%E3%80%8D%3C%2FA%3E%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%20erpcgen%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E6%9C%80%E6%96%B0%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A2%BA%E8%A8%BC%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%9C%80%E6%96%B0%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%81%A7%20SPI%20%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E5%8F%A4%E3%81%84%E5%AE%9F%E8%A3%85%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHey%20Dusan%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%20erpcgen.exe%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81smac.erpc%20%E3%81%AE%E4%BE%8B%E3%81%A7%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3C%2FP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20smac.erpc%3A135%3A5%3A%20%E6%A7%8B%E6%96%87%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E4%BA%88%E6%9C%9F%E3%81%97%E3%81%AA%E3%81%84%E8%AD%98%E5%88%A5%E5%AD%90%E3%80%81'%7D'%20%E3%82%92%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E6%A7%8B%E9%80%A0%E3%81%AF%E3%80%81%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%20erpc_c%20%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F31088i6EEA8A7D90842064%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ESDK%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%E3%81%A9%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E6%A7%8B%E9%80%A0%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E6%96%B0%E3%81%97%E3%81%8F%E7%94%9F%E6%88%90%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%88%E7%A7%81%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%EF%BC%89%E3%82%92%20SDK%20%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%82%E5%AE%89%E5%85%A8%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EEvgeny%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fevgenyerlihman%22%20target%3D%22_blank%22%3Eevgenyerlihman%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E5%B8%B8%E3%81%AB%20GitHub%20%E3%81%AE%20develop%20%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E6%96%B0%E8%A6%8F%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AE%E8%A6%81%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AB%E3%83%9E%E3%83%BC%E3%82%B8%E3%81%97%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%82%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%8B%E7%99%BA%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%A7%E3%81%AE%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%AF%E3%80%81Kinetis%20SDK%20%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%88%E3%82%8A%E3%82%82%E9%A0%BB%E7%B9%81%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E6%97%A2%E5%AD%98%E3%81%AE%20eRPC%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%20Kinetis%20SDK%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%8F%A4%E3%81%84%20eRPC%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A8%E6%96%B0%E3%81%97%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81git%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%A7%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHey%26nbsp%3B%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fdusancervenka-b51352%22%20target%3D%22_blank%22%3Edusancervenka-b51352%3C%2FA%3E%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%85%E9%80%9F%E3%81%AA%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82dev%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82erpc_c%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E6%A7%8B%E9%80%A0%E3%81%8C%20Kinetis%20SDK%20%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%99%E3%82%8B%E4%BE%8B%E3%81%A8%E3%81%AF%E5%A4%A7%E3%81%8D%E3%81%8F%E7%95%B0%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%A1%E3%82%89%E3%81%8C%E5%A5%BD%E3%81%BE%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EEvgeny%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fevgenyerlihman%22%20target%3D%22_blank%22%3Eevgenyerlihman%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%E5%AE%9F%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%82%88%E3%82%8A%E9%A0%BB%E7%B9%81%E3%81%AB%E6%9B%B4%E6%96%B0%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E9%96%8B%E7%99%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%26nbsp%3B%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Ftree%2Fdevelop%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Ftree%2Fdevelop%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGitHub%20-%20EmbeddedRPC%2Ferpc%20at%20develop%3C%2FA%3E.%20%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E6%9B%B4%E6%96%B0%E3%81%AF%E6%98%A8%E6%97%A5%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%9D%E3%81%93%E3%81%A7%20erpcgen%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AEsmac%E3%81%A7IDL%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fdusancervenka-b51352%22%20target%3D%22_blank%22%3Edusancervenka-b51352%3C%2FA%3E%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A4%87%E6%95%B0%E3%81%AE%20NXP%20Kinetis%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B0%E8%A3%BD%E5%93%81%E3%81%AB%20erpc%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82erpc%20GitHub%E3%81%AE%E6%9C%80%E7%B5%82%E6%9B%B4%E6%96%B0%E3%81%AF6%E3%81%8B%E6%9C%88%E5%89%8D%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%8A%E5%B0%8B%E3%81%AD%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E3%81%BE%E3%81%A0%E4%BF%9D%E5%AE%88%EF%BC%8F%E4%BF%AE%E6%AD%A3%EF%BC%8F%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%A7%E3%81%99%E3%80%82GitHub%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Eerpcgen.exe%20smac.erpc%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81cpp%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E7%94%9F%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Eerpcgen%20%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81MCUXpresso%20SDK%E3%81%8B%E3%82%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EEvgeny%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%82%82%E9%95%B7%E6%9C%9F%E4%BC%91%E6%9A%87%E4%B8%AD%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E6%A5%BD%E3%81%97%E3%82%93%E3%81%A7%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%83%BB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20(%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E3%83%BB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8)%20%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%92%E9%80%81%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%A7%E8%A9%B3%E7%B4%B0%E3%82%92%E8%A9%B1%E3%81%97%E5%90%88%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81GitHub%E3%81%A7%E3%83%95%E3%82%A9%E3%83%BC%E3%82%AF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E9%96%8B%E7%99%BA%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AB%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%80%81%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%97%E3%83%AB%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E6%8F%90%E6%A1%88%E3%81%97%E3%80%81%E9%96%8B%E7%99%BA%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AB%E3%83%9E%E3%83%BC%E3%82%B8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099176%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099176%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dusan%20%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E3%80%81%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%95%B7%E6%9C%9F%E4%BC%91%E6%9A%87%E3%82%92%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%88%BB%E3%81%A3%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E3%81%93%E3%81%93%E3%81%AB%E3%81%84%E3%82%8B%E3%83%A1%E3%83%B3%E3%83%90%E3%83%BC%E3%81%A8%E7%9B%B8%E8%AB%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E8%BB%A2%E9%80%81%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82NXP%E3%81%AE%E6%96%B9%E9%87%9D%E3%81%A7%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%20GitHub%20%E3%81%AB%E7%9B%B4%E6%8E%A5%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099175%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%20translate%3D%22no%22%3ERe%3A%20Introducing%20eRPC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099175%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%89%E3%82%A5%E3%82%B5%E3%83%B3%E3%81%95%E3%82%93%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E5%85%88%E8%BC%A9%E3%81%AB%E7%9B%B8%E8%AB%87%E3%81%97%E3%81%A6%E3%83%97%E3%83%AB%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E4%BC%91%E6%9A%87%E4%B8%AD%E3%81%A7%E3%81%99%E3%80%82%E8%BF%94%E4%BF%A1%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EChandini%E6%A7%98%E3%80%81%E3%81%94%E6%88%90%E5%8A%9F%E3%82%92%E5%8F%8E%E3%82%81%E3%82%89%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E5%AC%89%E3%81%97%E3%81%8F%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%82%E3%81%97%E7%89%B9%E5%88%A5%E3%81%AA%E6%8F%90%E6%A1%88%E3%82%92%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%AA%E3%82%89%E3%80%81%E6%96%B0%E3%81%97%E3%81%8F%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81eRPC%E3%81%AEGitHub%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AB%E3%83%97%E3%83%AB%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%20eRPC%20%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E5%A4%9A%E5%B0%91%E3%81%AE%E4%BD%9C%E6%A5%AD%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%9F%E3%81%8F%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%A7%E3%81%9D%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%EF%BC%88%E3%82%A6%E3%82%A3%E3%83%B3%E3%82%AF%E3%81%AE%E9%A1%94%E6%96%87%E5%AD%97%EF%BC%89%20GitHub%E3%81%AE%E3%83%97%E3%83%AB%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E5%B1%A5%E6%AD%B4%E3%81%AB%E5%B8%B8%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E8%B2%B4%E9%87%8D%E3%81%AA%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%80%82eRPC%20%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E8%89%AF%E3%81%84%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%A4%E3%81%A7%E3%82%82%E3%81%93%E3%81%A1%E3%82%89%EF%BC%8F%E3%81%BE%E3%81%9F%E3%81%AF%20GitHub%20%E3%82%88%E3%82%8A%E3%81%8A%E6%89%8B%E4%BC%9D%E3%81%84%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%EF%BC%88%E3%82%A6%E3%82%A4%E3%83%B3%E3%82%AF%E3%81%AE%E9%A1%94%E6%96%87%E5%AD%97%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fdusancervenka-b51352%22%20target%3D%22_blank%22%3Edusancervenka-b51352%3C%2FA%3E%26nbsp%3B%2C%26nbsp%3B%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fb50844%22%20target%3D%22_blank%22%3Eb50844%3C%2FA%3E%26nbsp%3B%2C%26nbsp%3B%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnovakma7%22%20target%3D%22_blank%22%3Enovakma7%3C%2FA%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%81%86%E3%82%84%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Linux%E3%81%A7C%2B%2B%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%83%87%E3%83%A2%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%99%E3%81%B9%E3%81%A6%E7%AD%94%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%82%8A%E3%80%81%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%EF%BC%88%E7%AC%91%E9%A1%94%E3%81%AE%E9%A1%94%E6%96%87%E5%AD%97%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDusan%E6%A7%98%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%EF%BC%88%E7%AC%91%E9%A1%94%E3%81%AE%E9%A1%94%E6%96%87%E5%AD%97%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%20Dusan%20%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AE%E4%BD%9C%E6%A5%AD%E3%81%A7%E5%BF%99%E3%81%97%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E6%98%A8%E6%97%A5%E3%81%AF%E4%BD%95%E3%82%82%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BB%8A%E6%97%A5%E3%81%AF%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%80%81%E7%B5%90%E6%9E%9C%E3%82%92%E3%82%92%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%87%AA%E5%88%86%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E5%B0%91%E3%81%97%E5%A4%89%E3%81%88%E3%81%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AF%E3%80%81%E9%80%81%E4%BF%A1%E9%96%A2%E6%95%B0%E3%81%A8%E5%8F%97%E4%BF%A1%E9%96%A2%E6%95%B0%E3%81%AB%20char*%20%E3%81%A0%E3%81%91%E3%82%92%E6%B8%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%90%E3%81%AB%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EChandini%E6%A7%98%E3%80%81%E3%81%9D%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E7%A4%BE%E5%A4%96%E3%81%AB%E3%81%84%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E6%A9%9F%E8%83%BD%E3%81%AE%E6%AD%A3%E7%A2%BA%E3%81%AA%E5%90%8D%E5%89%8D%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099170%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%20translate%3D%22no%22%3ERe%3A%20Introducing%20eRPC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099170%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%89%E3%82%A5%E3%82%B5%E3%83%B3%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%20%EF%BC%9A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3Ewrite(fd%2C%3C%2FSPAN%3E%20%3CSPAN%3Emessage-%26gt%3BgetBuffer()%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3Emessage-%26gt%3BgetUsed()%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Fblob%2F9e18d069aeae19a6e80a5e8783903bc63bd9b567%2Ferpc_c%2Finfra%2Fmessage_buffer.h%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Fblob%2F9e18d069aeae19a6e80a5e8783903bc63bd9b567%2Ferpc_c%2Finfra%2Fmessage_buffer.h%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E9e18d069aeae19a6e80a5e8783903bc63bd9b567%20%C2%B7%20EmbeddedRPC%2Ferpc%20%C2%B7%3C%2FA%3E%20%3CSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3EGitHub%20%E3%81%AE%20erpc%2F%20message_buffer.h%3CSTRONG%3E%20%E3%81%AB%20getused%3C%2FSTRONG%3E%20%E9%96%A2%E6%95%B0%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81getbuffer%20%E9%96%A2%E6%95%B0%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%20font-size%3A%2013px%3B%22%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%20font-size%3A%2013px%3B%22%3E%20%2F*!%3CBR%20%2F%3E%20*%20%40brief%20%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E7%94%A8%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%B8%E3%81%AE%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20%40return%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%99%E3%82%8B%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%B8%E3%81%AE%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%80%82%3CBR%20%2F%3E%20*%2F%3CBR%20%2F%3E%20uint8_t%20*get()%20%7B%20m_buf%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3B%20%7D%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%81%9D%E3%81%97%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%3Esend%20%3Aerpc_status_t%20send(MessageBuffer%20*message)%20%7B%20write(fd%2C%20%3C%2FSPAN%3E%3CSPAN%3Emessage-%26gt%3Bget%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Emessage-%26gt%3BgetUsed()%3C%2FSPAN%3E%3CSPAN%3E)%7D%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81chanidi%20%E3%81%95%E3%82%93%E3%80%82%E5%88%A5%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82transport.h%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%82%8C%E3%82%92%E4%BD%BF%E3%82%8F%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E5%89%8D%E8%BF%B0%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%20ioctl%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CCODE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2013px%3B%22%3Eerpc_status_t%20receive(MessageBuffer%20*message)%3CBR%20%2F%3E%7Bint%20fd%20%3D%20open(%22%3CSTRONG%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2015px%3B%22%3E%2Fdev%2Frpmsg_ept1024.1%3C%2FSTRONG%3E%22%2C%20O_RDWR)%3B%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FCODE%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CCODE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2013px%3B%22%3E%E9%80%81%E4%BF%A1%20%3Aerpc_status_t%20send(MessageBuffer%20*message)%20%7B%20write(fd%2C%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3Emessage-%26gt%3BgetBuffer()%3C%2FSPAN%3E%2C%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3Emessage-%26gt%3BgetUsed()%3C%2FSPAN%3E)%7D%3B%3C%2FCODE%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CCODE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2013px%3B%22%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3A%20erpc_status_t%20receive(MessageBuffer%20*message)%7Bsize_t%20size%20%3D%20read(fd%2C%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3Emessage-%26gt%3BgetBuffer()%3C%2FSPAN%3E%2C%20500)%3Bmessage-%26gt%3BsetUsed(%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3Esize%3C%2FSPAN%3E)%7D%3B%3CBR%20%2F%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnovakma7%22%20target%3D%22_blank%22%3Enovakma7%3C%2FA%3E%20%E6%89%8B%E9%A0%86%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FCODE%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDusan%20%2C%20Marek%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E7%A7%81%E3%82%82%E3%81%9D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Etrasport.h%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%BC%95%E6%95%B0%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3E%3CSTRONG%3Etransport.h%20%E3%81%AE%3C%2FSTRONG%3E%3CSTRONG%3E%20send%20%E9%96%A2%E6%95%B0%E3%81%A8%20receive%20%E9%96%A2%E6%95%B0%3C%2FSTRONG%3E%E3%81%AF%3CSTRONG%3EMessagebuffer%3C%2FSTRONG%3E%E3%82%92%E5%BC%95%E6%95%B0%E3%81%A8%E3%81%97%E3%81%A6%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3CSTRONG%3E%26nbsp%3Bvirtual%20erpc_status_t%20receive(MessageBuffer%20*message)%20%3D%200%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bvirtual%20erpc_status_t%20send(MessageBuffer%20*message)%20%3D%200%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3E%3CSTRONG%3Eexample.py%3C%2FSTRONG%3E%20%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%BC%95%E6%95%B0%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%20%3CSTRONG%3ERPMSGendPoint%3C%2FSTRONG%3E%20%E3%82%AF%E3%83%A9%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSTRONG%3E%26nbsp%3B%26nbsp%3BRpmsgEndpoint%3A%3Areceive(int%20maxlen)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ERpmsgEndpoint%3A%3Asend(char%20*buffer%2Cint%20dst)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%AF%E3%80%81Linux%E3%81%8B%E3%82%89%3CSTRONG%3E%20%2Fdev%2Frpmsg_ept1024.1%3C%2FSTRONG%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%82%88%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%81%A7%E3%81%99%E3%81%8B%E3%82%89%E3%80%81transport.h%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%20transport.h%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9A%86%E6%A7%98%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A9%E3%81%86%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%A6%E3%80%82%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3E%3CSTRONG%3E%2Ferpc-imx-demos%2Fmiddleware%2Ferpc%2Ftransport%2F%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8B%E3%82%89%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E5%BE%97%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E6%89%8B%E6%AE%B5%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099166%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%20translate%3D%22no%22%3ERe%3A%20Introducing%20eRPC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099166%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%E3%83%89%E3%82%A5%E3%82%B5%E3%83%B3%E3%81%95%E3%82%93%E3%80%81%E6%97%A9%E9%80%9F%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22%E3%82%B9%E3%83%9E%E3%82%A4%E3%83%AA%E3%83%BC%E3%83%BB%E3%83%8F%E3%83%83%E3%83%94%E3%83%BC%22%20title%3D%22%E3%82%B9%E3%83%9E%E3%82%A4%E3%83%AA%E3%83%BC%E3%83%BB%E3%83%8F%E3%83%83%E3%83%94%E3%83%BC%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AF%E5%90%8C%E3%81%98%E9%81%93%E3%82%92%E9%80%B2%E3%81%BF%E7%B6%9A%E3%81%91%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E6%88%BB%E3%81%A3%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CP%3E%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EChandini%E6%A7%98%E3%80%81%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%82%8B%E9%80%9A%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E6%89%8B%E9%A0%86%E3%81%A7%E3%81%99%E3%80%82transport.h%20%E3%81%8B%E3%82%89%E3%82%AF%E3%83%A9%E3%82%B9%E3%82%92%E7%B6%99%E6%89%BF%E3%81%99%E3%82%8B%E3%82%AF%E3%83%A9%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Marek%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E5%86%8D%E3%81%B3%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%AE%E4%BD%9C%E6%A5%AD%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3EC%2B%2B%E3%81%A7RpmsgEndpoint%E3%82%AF%E3%83%A9%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLI%3E%3CLI%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%2Ftree%2Fmaster%2FMPU%2Fexample_erpc%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%2Ftree%2Fmaster%2FMPU%2Fexample_erpc%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eerpc-imx-demos%2FMPU%2Fexample_erpc%20at%20master%20%C2%B7%20EmbeddedRPC%2Ferpc-imx-demos%20%C2%B7%20GitHub%3C%2FA%3E%20%E3%81%AE%20Python%20example.py%20%E3%81%A7%E3%80%81Transport%20%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%8B%E3%82%89%E7%B6%99%E6%89%BF%E3%81%95%E3%82%8C%E3%81%9F%20RpmsgTransport%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Etransport.h%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%AE%E3%81%8C%E8%B3%AA%E5%95%8F%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%3CSTRONG%3E%2Ferpc-imx-demos%2Fmiddleware%2Ferpc%2Ferpc_c%2Finfra%3C%2FSTRONG%3E%20%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%86%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81RpmsgTransport%20%E3%82%AF%E3%83%A9%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E5%91%BC%E3%81%B6%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E8%80%83%E3%81%88%E6%96%B9%E3%81%A7%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099163%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099163%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%9D%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3EPython%20%E3%81%8C%E8%A1%8C%E3%81%86%E3%81%AE%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%20IO%20%E6%93%8D%E4%BD%9C%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%EF%BC%89%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%20C%2FC%2B%2B%20%E3%82%92%E5%90%AB%E3%82%80%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%E8%A8%80%E8%AA%9E%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82Python%20%E3%81%AF%E3%80%81Linux%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AE%E4%BA%BA%E6%B0%97%E3%81%8B%E3%82%89%E3%80%81%E5%AE%9F%E8%A1%8C%E6%96%B9%E6%B3%95%E3%82%92%E3%82%92%E7%A4%BA%E3%81%99%E3%81%9F%E3%82%81%E3%81%AB%E9%81%B8%E3%81%B0%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%20C%20%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%A7%E8%AA%8D%E8%AD%98%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%B9%B8%E9%81%8B%E3%82%92%E7%A5%88%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%8B%E3%82%89%E3%82%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EMarek%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099162%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%20translate%3D%22no%22%3ERe%3A%20Introducing%20eRPC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099162%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%9E%E3%83%AC%E3%82%AF%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%96%91%E5%95%8F%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%A7%A3%E6%B6%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3EfreeRTOS%E3%82%92%E4%B8%A1%E6%96%B9%E4%BD%BF%E3%81%86%E4%BA%88%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%97%E3%83%A9%E3%83%B3%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EM4-FreeRTOS%20----%E3%81%93%E3%82%8C%E3%81%AF%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E3%83%87%E3%83%A2%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3EA7-Linux%20-----%E3%83%87%E3%83%A2%E3%81%AB%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABRPMSG%E5%AE%9F%E8%A3%85%E3%82%92%E5%88%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEPython%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%AF%E3%80%81Python%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8FC%E3%81%BE%E3%81%9F%E3%81%AFC%2B%2B%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3EPython%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AFC%E3%81%BE%E3%81%9F%E3%81%AFC%2B%2B%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%82%88%E3%81%AD%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099161%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099161%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%E3%83%BB%E3%82%A4%E3%83%B3%E3%83%80%E3%83%90%E3%83%A9%E3%83%BB%E3%83%90%E3%82%B5%E3%83%B4%E3%82%A1%E3%83%A9%E3%82%B8%E3%83%A5%E3%81%95%E3%82%93%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERPMSg-Lite%20%E3%81%AF%20RPMsg%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81FreeRTOS%20%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%20M4%20%E5%81%B4%E3%81%AE%E3%81%BF%E3%82%92%E5%AF%BE%E8%B1%A1%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Linux%2FA7%20%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E5%86%85%E3%81%AE%20RPMsg%20%E5%AE%9F%E8%A3%85%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%EF%BC%88%E3%81%93%E3%81%A1%E3%82%89%E3%81%AB%E3%81%82%E3%82%8B%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%EF%BC%9A%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%2F%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGitHub%20-%20EmbeddedRPC%2Ferpc-imx-demos%3A%20i.MX%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%94%A8%E3%81%AE%20eRPC%20%E3%83%87%E3%83%A2%3C%2FA%3E%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81M4%E3%82%B3%E3%82%A2%E3%81%A8A7%E3%82%B3%E3%82%A2%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7FreeRTOS%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E6%A8%99%E6%BA%96%E7%9A%84%E3%81%AA%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82A%E3%82%B3%E3%82%A2%E7%94%A8%E3%81%AE%E7%A7%BB%E6%A4%8D%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%81%9D%E3%81%93%E3%81%A7FreeRTOS%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%A7%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E6%96%B9%E5%90%91%E6%80%A7%E3%81%8C%E8%A6%8B%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EMarek%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Marek%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E3%82%8F%E3%81%91%E3%81%8B%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E8%A6%8B%E9%80%83%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%EF%BC%88%E7%AC%91%E9%A1%94%E3%81%AE%E9%A1%94%E6%96%87%E5%AD%97%EF%BC%89%E3%81%99%E3%81%90%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERPMSG%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E5%B1%A4%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%9C%80%E5%BE%8C%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%8A%E7%AD%94%E3%81%88%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88%E3%81%BE%E3%81%9F%E3%80%81GitHub%E3%81%AE%E3%83%97%E3%83%AB%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3ELinux%20%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81%2Fdev%2FttyRPMSG%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%EF%BC%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%AE%20%3CSPAN%3Eerpc_c%2Ftransports%3C%2FSPAN%3E%20%E3%81%A7%E6%96%B0%E3%81%97%E3%81%84%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3Einit%20%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%9A%20%3CCODE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2013px%3B%22%3Eint%20fd%20%3D%20open(%22%2Fdev%2FttyRPMSG%22%2C%20O_RDWR)%3B%3C%2FCODE%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CCODE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2013px%3B%22%3E%E9%80%81%E4%BF%A1%EF%BC%9Awrite(fd%2C%20buffer%2C%20buffer_size)%3B%3C%2FCODE%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CCODE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2013px%3B%22%3Eread%3A%20size_t%20size%20%3D%20read(fd%2C%20buffer%2C%20%E4%BA%88%E6%83%B3%E3%82%B5%E3%82%A4%E3%82%BA)%3B%3C%2FCODE%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CCODE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2013px%3B%22%3E%3C%2FCODE%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CCODE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2013px%3B%22%3E%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%90%8D%E5%89%8D%E3%81%8C%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81Python%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E5%BE%97%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82RPMSG%E3%81%AF%E7%A7%81%E3%81%AE%E5%A5%BD%E3%81%BF%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82Linux%E3%81%A7%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%94%E8%B3%AA%E5%95%8F%E3%82%92Marek%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FCODE%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dusan%20%2C%20Marek%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%A7%81%E3%81%8C%E8%A8%88%E7%94%BB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EM4(freertos)%E3%81%8A%E3%82%88%E3%81%B3A7(Linux)%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%3CSTRONG%3Erpmsg-lite%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%82%E3%81%AE%3C%2FSTRONG%3E%3CBR%20%2F%3EM4%E3%81%A8A7%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8BRPMSG%20C%E3%83%A9%E3%83%83%E3%83%91%E3%83%BC%EF%BC%88erpc_c%2Fsetup%E5%86%85%EF%BC%89%3CBR%20%2F%3EM4%E3%81%A8A7%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8BRPMSG%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%EF%BC%88erpc_c%2Ftransports%E5%86%85%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E5%B1%A4%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Erpmsg-python%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E5%90%8C%E6%A7%98%E3%81%AB%E8%A8%98%E8%BF%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%A9%E3%82%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%81%94%E6%8F%90%E6%A1%88%E3%81%A7%E3%82%82%E3%81%A8%E3%81%A6%E3%82%82%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CSTRONG%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%9A%86%E6%A7%98%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%82%E3%81%AE%EF%BC%88Linux%E5%81%B4%E7%94%A8%E3%81%AEC%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%EF%BC%89%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E7%B0%A1%E5%8D%98%E3%81%AA%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%2Fdev%2FttyRPMSG%20%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A8%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%EF%BC%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%81%9D%E3%81%AE%E4%BE%8B%E3%82%92%E3%81%94%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Einit%20%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%3A%20%3CCODE%20style%3D%22border%3A%200px%3B%20font-size%3A%2013px%3B%22%3Eint%20fd%20%3D%20open(%22%2Fdev%2FttyRPMSG%22%2C%20O_RDWR)%3B%3C%2FCODE%3E%3C%2FP%3E%3CP%3E%3CCODE%20style%3D%22border%3A%200px%3B%20font-size%3A%2013px%3B%22%3E%E9%80%81%E4%BF%A1%EF%BC%9Awrite(fd%2C%20buffer%2C%20buffer_size)%3B%20%3C%2FCODE%3E%3C%2FP%3E%3CP%3E%3CCODE%20style%3D%22border%3A%200px%3B%20font-size%3A%2013px%3B%22%3Eread%3A%20size_t%20size%20%3D%20read(fd%2C%20buffer%2C%20expected%20size)%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fmareknovak%22%20target%3D%22_blank%22%3Emareknovak%3C%2FA%3E%E3%81%8C%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%95%E3%82%89%E3%81%AB%E7%AD%94%E3%81%88%E3%82%92%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FCODE%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099156%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099156%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dusan%20%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%81%AF%E6%89%8B%E5%85%83%E3%81%AB%E3%81%82%E3%82%8Berpc%E3%81%A7%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82rpmsg%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E3%82%89%E3%80%81erpc%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%82%E6%9B%B4%E6%96%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Erpmsg-lite%E3%80%81M4%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%90%AB%E3%82%80%E3%82%82%E3%81%AE%3C%2FSTRONG%3E%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EA7%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8%E3%81%AE%E8%A3%BD%E5%93%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E4%BD%95%E3%81%8B%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E5%A4%A7%E5%A4%89%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%E4%B8%BB%E3%81%AA%E7%9B%AE%E7%9A%84%E3%81%AF%E3%80%81%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6RPMSg%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81C%E8%A8%80%E8%AA%9E%E3%81%A7%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%94%E8%87%AA%E5%88%86%E3%81%A7%E5%95%8F%E9%A1%8C%E8%A7%A3%E6%B1%BA%E3%82%92%E9%80%B2%E3%82%81%E3%81%A6%E3%81%8A%E3%82%89%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%AE%E3%81%93%E3%81%A8%E3%80%81%E5%AC%89%E3%81%97%E3%81%8F%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%EF%BC%88%E9%96%8B%E7%99%BA%E8%80%85%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%9D%E3%82%8C%E3%81%BB%E3%81%A9%E8%A4%87%E9%9B%91%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%82%89%EF%BC%89%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fmareknovak%22%20target%3D%22_blank%22%3Emareknovak%3C%2FA%3E%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E8%A8%80%E5%8F%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%80%9A%E3%82%8A%E3%80%81%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%20imx%20%E3%83%87%E3%83%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%81%99%E3%81%A7%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84RPC%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%9D%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%EF%BC%88%E3%82%A6%E3%82%A3%E3%83%B3%E3%82%AF%E3%81%AE%E7%B5%B5%E6%96%87%E5%AD%97%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099154%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%20translate%3D%22no%22%3ERe%3A%20Introducing%20eRPC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099154%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%83%89%E3%82%A5%E3%82%B5%E3%83%B3%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%8C%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E6%83%85%E5%A0%B1%E3%81%A7%E3%81%99%E3%80%82TCP%E7%94%A8%E3%81%AEC%E3%83%A9%E3%83%83%E3%83%91%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81erpc%E3%81%A7%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AF%E3%80%81TCP%E5%B1%A4%E3%82%92rpmsg%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%86%8D%E5%BA%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%E3%83%BB%E3%82%A4%E3%83%B3%E3%83%80%E3%83%90%E3%83%A9%E3%83%BB%E3%83%90%E3%82%B5%E3%83%B4%E3%82%A1%E3%83%A9%E3%82%B8%E3%83%A5%E3%81%95%E3%82%93%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGitHub%20-%20EmbeddedRPC%2Ferpc-imx-demos%3A%20eRPC%20demos%20for%20i.MX%20devices%3C%2FA%3E%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%8C%20eRPC%201.4.0%20%E3%81%A8%20RPMSg-Lite%201.1.0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%B3%E3%83%BC%E3%83%89%E7%94%9F%E6%88%90%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%83%93%E3%83%AB%E3%83%89%E6%B8%88%E3%81%BF%E3%81%AE%20erpcgen%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%81%93%E3%81%A1%E3%82%89%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3A%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Freleases%2Ftag%2F1.4.0%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Freleases%2Ftag%2F1.4.0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ERelease%20v1.4%20%C2%B7%20EmbeddedRPC%2Ferpc%20%C2%B7%20GitHub%3C%2FA%3E%20%26nbsp%3B%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%80%81%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81.%2Ferpcgen-gpy%20nameOfInterfaceDefinitionLanguageFile.erpc%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82ERPC%E3%80%81Python%E3%81%AE%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E5%8C%96%E3%81%A8%E9%80%86%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E5%8C%96%E3%81%AE%E3%82%B7%E3%83%A0%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82-gpy%20%E3%82%92%E7%9C%81%E7%95%A5%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81-gc%20%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81C%20%E3%82%B7%E3%83%A0%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Eser%2Fdes%20shim%E3%82%B3%E3%83%BC%E3%83%89%E3%82%82erpc-imx-demos%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%E6%9C%80%E6%96%B0%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%81%A7%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E6%B0%97%E8%BB%BD%E3%81%AB%E3%81%94%E5%88%A9%E7%94%A8%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%97%E3%83%AB%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%81%AE%E5%BD%A2%E3%81%A7%E5%A4%89%E6%9B%B4%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82eRPC%20%26amp%3B%20RPMsg-Lite%E3%82%92%E3%81%94%E5%88%A9%E7%94%A8%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EMarek%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8github%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AB%E4%BE%8B%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81C(c%20%2B%2B)%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82Linux%20%E3%81%BE%E3%81%9F%E3%81%AF%20Mac%20%E3%81%AB%E6%85%A3%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E4%B8%8A%E8%A8%98%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AE%20SDK%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%20-%26gt%3B%20%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%83%BB%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20C%2FPython%20%E3%81%AE%E4%BE%8B%E3%80%82%3C%2FP%3E%3CP%3E2.%20%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%82%92%E3%81%8A%E8%AA%AD%E3%81%BF%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9A%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Fwiki%2FGetting-Started%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%2Fwiki%2FGetting-Started%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%20%C2%B7%20EmbeddedRPC%2Ferpc%20Wiki%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dusan%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPython%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8FC%E3%81%AE%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E4%BD%9C%E6%88%90%E3%81%AE%E4%BA%88%E5%AE%9A%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%81%99%E3%81%A7%E3%81%AB%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%A8%E3%81%A6%E3%82%82%E4%BE%BF%E5%88%A9%E3%81%A7%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%88%E3%81%86%E3%82%84%E3%81%8F%E5%8B%95%E3%81%8F%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%EF%BC%88%E7%AC%91%E9%A1%94%E3%81%AE%E9%A1%94%E6%96%87%E5%AD%97%EF%BC%89%20Dusan%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AB%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFrom%207a5b152524a3c82b5bced4a72ed396f21860b666%20Mon%20Sep%2017%2000%3A00%3A00%202001%3C%2FP%3E%3CP%3E%E6%97%A5%E4%BB%98%3A%202017%E5%B9%B45%E6%9C%888%E6%97%A5%EF%BC%88%E6%9C%88%EF%BC%8911%3A33%3A05%20%2B0100%3CBR%20%2F%3E%E4%BB%B6%E5%90%8D%3A%20%5BPATCH%5D%20eRPC_demo%E5%AE%9F%E8%A1%8C%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E4%BF%AE%E6%AD%A3%3C%2FP%3E%3CP%3E---%3CBR%20%2F%3E%20erpc_c%2Finfra%2Ftransport.h%20%7C%204%20%2B-%3CBR%20%2F%3E%20erpc_c%2Fsetup%2Ferpc_server_setup.cpp%20%7C%2036%20%2B%2B%2B%2B-%3CBR%20%2F%3E%20erpc_c%2Fsetup%2Ferpc_server_setup.h%20%7C%202%20%2B-%3CBR%20%2F%3E%20erpc_c%2Fsetup%2Ferpc_setup_rpmsg_lite_rtos_remote.cpp%20%7C%2054%20%2B%2B%2B%2B%2B%2B%2B%3CBR%20%2F%3E%20erpc_c%2Fsetup%2Ferpc_transport_setup.h%20%7C%2018%20%2B%2B-%3CBR%20%2F%3E%20erpc_c%2Ftransports%2Frpmsg_lite_rtos_transport.cpp%20%7C%20158%20%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%3CBR%20%2F%3E%20erpc_c%2Ftransports%2Frpmsg_lite_rtos_transport.h%20%7C%20177%20%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%3CBR%20%2F%3E%20erpc_c%2Ftransports%2Frpmsg_rtos_transport.h%20%7C147%20%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%20%3CBR%20%2F%3Eerpc_python%2Ferpc%2Ftransport.py%20%7C%2021%20%2B%2B%2B%20%3CBR%20%2F%3E9%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%A4%89%E6%9B%B4%E3%80%81602%20%E6%8C%BF%E5%85%A5%EF%BC%88%2B%EF%BC%89%E3%80%8115%20%E5%89%8A%E9%99%A4%EF%BC%88-%EF%BC%89%3CBR%20%2F%3E%20%E4%BD%9C%E6%88%90%E3%83%A2%E3%83%BC%E3%83%89%20100644%20erpc_c%2Fsetup%2Ferpc_setup_rpmsg_lite_rtos_remote.cpp%3CBR%20%2F%3E%E4%BD%9C%E6%88%90%E3%83%A2%E3%83%BC%E3%83%89%20100644%20erpc_c%2Ftransports%2Frpmsg_lite_rtos_transport.cpp%3CBR%20%2F%3E%E4%BD%9C%E6%88%90%E3%83%A2%E3%83%BC%E3%83%89%20100644%20erpc_c%2Ftransports%2Frpmsg_lite_rtos_transport.h%3CBR%20%2F%3E%E4%BD%9C%E6%88%90%E3%83%A2%E3%83%BC%E3%83%89%20100644%20erpc_c%2Ftransports%2Frpmsg_rtos_transport.h%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Ediff%20--git%20a%2Ferpc_c%2Finfra%2Ftransport.h%20b%2Ferpc_c%2Finfra%2Ftransport.h%3CBR%20%2F%3Eindex%20eb7ec71..fd4862a%20100644%3CBR%20%2F%3E---%20a%2Ferpc_c%2Finfra%2Ftransport.h%3CBR%20%2F%3E%2B%2B%2B%20b%2Ferpc_c%2Finfra%2Ftransport.h%3CBR%20%2F%3E%40%40%20-48%2C7%20%2B48%2C7%20%40%40%3CBR%20%2F%3E%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20namespace%20erpc%20%7B%3CBR%20%2F%3E-%3CBR%20%2F%3E%2Bclass%20MessageBuffer%3B%3CBR%20%2F%3E%20%2F*!%3CBR%20%2F%3E%20*%20%40brief%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AE%E6%8A%BD%E8%B1%A1%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%40%40%20-89%2C7%20%2B89%2C7%20%40%40%20public%3A%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20%40return%20%E9%80%81%E4%BF%A1%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%2F%3CBR%20%2F%3E-%20virtual%20erpc_status_t%20send(MessageBuffer%20*message)%20%3D%200%3B%3CBR%20%2F%3E%2B%20virtual%20erpc_status_t%20send(const%20MessageBuffer%20*message)%20%3D%200%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F*!%3CBR%20%2F%3E%20*%20%40brief%20%E5%8F%97%E4%BF%A1%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Ediff%20--git%20a%2Ferpc_c%2Fsetup%2Ferpc_server_setup.cpp%20b%2Ferpc_c%2Fsetup%2Ferpc_server_setup.cpp%3CBR%20%2F%3Eindex%2051fa799..5cd4346%20100644%3CBR%20%2F%3E---%20a%2Ferpc_c%2Fsetup%2Ferpc_server_setup.cpp%3CBR%20%2F%3E%2B%2B%2B%20b%2Ferpc_c%2Fsetup%2Ferpc_server_setup.cpp%3CBR%20%2F%3E%40%40%20-33%2C8%20%2B33%2C10%20%40%40%3CBR%20%2F%3E%20%23include%20%22basic_codec.h%22%3CBR%20%2F%3E%20%23include%20%22manually_constructed.h%22%3CBR%20%2F%3E%20%23include%20%22simple_server.h%22%3CBR%20%2F%3E-%23include%20%3CASSERT.H%3E%3CBR%20%2F%3E%2B%23include%20%22message_buffer.h%22%3CBR%20%2F%3E%2B%23include%20%22erpc_config_internal.h%22%3CBR%20%2F%3E%20%23include%20%3CNEW%3E%3CBR%20%2F%3E%2B%23include%20%3CASSERT.H%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%23if%20!(__embedded_cplusplus)%3CBR%20%2F%3E%20using%20namespace%20std%3B%3CBR%20%2F%3E%40%40%20-43%2C6%20%2B45%2C29%20%40%40%20using%20namespace%20std%3B%3CBR%20%2F%3E%20using%20namespace%20erpc%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%2F%2F%20Classes%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bclass%20BasicMessageBufferFactory%20%3A%20public%20MessageBufferFactory%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2Bpublic%3A%3CBR%20%2F%3E%2B%20virtual%20MessageBuffer%20create()%3CBR%20%2F%3E%2B%20%7B%3CBR%20%2F%3E%2B%20uint8_t%20*buf%20%3D%20new%20(nothrow)%20uint8_t%5BERPC_DEFAULT_BUFFER_SIZE%5D%3B%3CBR%20%2F%3E%2B%20return%20MessageBuffer(buf%2C%20ERPC_DEFAULT_BUFFER_SIZE)%3B%3CBR%20%2F%3E%2B%20%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20virtual%20void%20dispose(MessageBuffer%20*buf)%3CBR%20%2F%3E%2B%20%7B%3CBR%20%2F%3E%2B%20assert(buf)%3B%3CBR%20%2F%3E%2B%20if%20(*buf)%3CBR%20%2F%3E%2B%20%7B%3CBR%20%2F%3E%2B%20delete%5B%5D%20buf-%26gt%3Bget()%3B%3CBR%20%2F%3E%2B%20%7D%3CBR%20%2F%3E%2B%20%7D%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%20%2F%2F%20Variables%3CBR%20%2F%3E%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%20%3CBR%20%2F%3E%40%40%20-50%2C29%20%2B75%2C32%20%40%40%20using%20namespace%20erpc%3B%3CBR%20%2F%3E%20static%20ManuallyConstructed%3CSIMPLESERVER%3E%20s_server%3B%3CBR%20%2F%3E%20SimpleServer%20*g_server%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%2Bstatic%20ManuallyConstructed%3CBASICMESSAGEBUFFERFACTORY%3E%20s_msgFactory%3B%3CBR%20%2F%3E%20static%20ManuallyConstructed%3CBASICCODECFACTORY%3E%20s_codecFactory%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%20%2F%2F%20Code%3CBR%20%2F%3E%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%20%3CBR%20%2F%3E-void%20erpc_server_init(erpc_transport_t%20transport%2C%20erpc_mbf_t%20message_buffer_factory)%3CBR%20%2F%3E%2Bvoid%20erpc_server_init(erpc_transport_t%20transport)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%2F%2F%20%E3%83%95%E3%82%A1%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20s_msgFactory.construct()%3B%3CBR%20%2F%3E%20s_codecFactory.construct()%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F%2F%20%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSTRONG%3E%3C%2FSTRONG%3Es_server.construct()%3B%3CBR%20%2F%3E%20s_server-%26gt%3BsetTransport(reinterpret_cast%3CTRANSPORT%3E(transport))%3B%3CBR%20%2F%3E%2B%20s_server-%26gt%3BsetMessageBufferFactory(s_msgFactory)%3B%3CBR%20%2F%3E%20s_server-%26gt%3BsetCodecFactory(s_codecFactory)%3B%3CBR%20%2F%3E-%20s_server-%26gt%3BsetMessageBufferFactory(reinterpret_cast%3CMESSAGEBUFFERFACTORY%3E(message_buffer_factory))%3B%3CBR%20%2F%3E%20g_server%20%3D%20s_server%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E-%3CBR%20%2F%3E%20void%20erpc_server_deinit()%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%2B%20s_msgFactory.destroy()%3B%3CBR%20%2F%3E%20s_codecFactory.destroy()%3B%3CBR%20%2F%3E%20s_server.destroy()%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20void%20erpc_add_service_to_server(void%20*service)%3CBR%20%2F%3Ediff%20--git%20a%2Ferpc_c%2Fsetup%2Ferpc_server_setup.h%20b%2Ferpc_c%2Fsetup%2Ferpc_server_setup.h%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%208e6a6ef..e4e9eaa%20100644%3CBR%20%2F%3E---%20a%2Ferpc_c%2Fsetup%2Ferpc_server_setup.h%3CBR%20%2F%3E%2B%2B%2B%20b%2Ferpc_c%2Fsetup%2Ferpc_server_setup.h%3CBR%20%2F%3E%40%40%20-60%2C7%20%2B60%2C7%20%40%40%20extern%20%22C%22%20%7B%3CBR%20%2F%3E%20*%20%3CBR%20%2F%3E*%20%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%2F%3CBR%20%2F%3E-void%20erpc_server_init(erpc_transport_t%20transport%2C%20erpc_mbf_t%20message_buffer_factory)%3B%3CBR%20%2F%3E%2Bvoid%20erpc_server_init(erpc_transport_t%20transport)%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F*!%3CBR%20%2F%3E%20*%20%40brief%20%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Ediff%20--git%20a%2Ferpc_c%2Fsetup%2Ferpc_setup_rpmsg_lite_rtos_remote.cpp%20b%2Ferpc_c%2Fsetup%2Ferpc_setup_rpmsg_lite_rtos_remote.cpp%3CBR%20%2F%3Enew%20file%20mode%20100644%3CBR%20%2F%3Eindex%200000000..b480d42%3CBR%20%2F%3E---%20%2Fdev%2Fnull%3CBR%20%2F%3E%2B%2B%2B%20b%2Ferpc_c%2Fsetup%2Ferpc_setup_rpmsg_lite_rtos_remote.cpp%3CBR%20%2F%3E%40%40%20-0%2C0%20%2B1%2C54%20%40%40%3CBR%20%2F%3E%2B%20%2F*%3CBR%20%2F%3E%2B%20*%20Copyright%20(c)%202014-2016%2C%20Freescale%20Semiconductor%2C%20Inc.%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8A%E3%82%88%E3%81%B3%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%AE%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%8A%E3%82%88%E3%81%B3%E4%BD%BF%E7%94%A8%E3%81%AF%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%AE%E6%9C%89%E7%84%A1%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%2B%3CBR%20%2F%3E%20*%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E9%99%90%E3%82%8A%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%20*%2B%20*%20o%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%AB%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%E8%A1%A8%E7%A4%BA%E3%80%81%E3%81%93%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AE%E4%B8%80%E8%A6%A7%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%3CBR%20%2F%3E%2B%20*%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%85%8D%E8%B2%AC%E4%BA%8B%E9%A0%85%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%20%3CBR%20%2F%3E%20%2B%20*%20o%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%AE%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%A7%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%E8%A1%A8%E7%A4%BA%E3%80%81%E3%81%93%E3%81%AE%3CBR%20%2F%3E%20%2B%20*%20%E6%9D%A1%E4%BB%B6%E3%83%AA%E3%82%B9%E3%83%88%E3%80%81%3CBR%20%2F%3E%E3%81%8A%E3%82%88%E3%81%B3%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%85%8D%E8%B2%AC%E4%BA%8B%E9%A0%85%E3%82%92%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%2F%E3%81%BE%E3%81%9F%E3%81%AF%3CBR%20%2F%3E%E9%85%8D%E5%B8%83%E7%89%A9%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%99%E3%82%8B%E4%BB%96%E3%81%AE%E8%B3%87%E6%96%99%E3%81%AB%E8%A4%87%E8%A3%BD%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%2B%20*%3CBR%20%2F%3E%2B%20*%20o%20Freescale%20Semiconductor%2C%20Inc.%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%82%E3%81%9D%E3%81%AE%3CBR%20%2F%3E%2B%20*%20%E8%B2%A2%E7%8C%AE%E8%80%85%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%82%E3%80%81%E3%81%93%E3%81%AE%3CBR%20%2F%3E%2B%20*%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8B%E3%82%89%E6%B4%BE%E7%94%9F%E3%81%97%E3%81%9F%E8%A3%BD%E5%93%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%81%BE%E3%81%9F%E3%81%AF%E5%AE%A3%E4%BC%9D%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%E6%9B%B8%E9%9D%A2%E3%81%AB%E3%82%88%E3%82%8B%E4%BA%8B%E5%89%8D%E3%81%AE%E7%89%B9%E5%88%A5%E3%81%AA%E8%A8%B1%E5%8F%AF%E3%81%AA%E3%81%97%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%20%2B%20*%20%E3%81%93%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E8%91%97%E4%BD%9C%E6%A8%A9%E6%89%80%E6%9C%89%E8%80%85%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%80%8C%E7%8F%BE%E7%8A%B6%E3%81%AE%E3%81%BE%E3%81%BE%E3%80%8D%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%80%81%20%3CBR%20%2F%3E%2B%20*%20%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%BE%E3%81%9F%E3%81%AF%E9%BB%99%E7%A4%BA%E7%9A%84%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E5%95%86%E5%93%81%E6%80%A7%E3%81%8A%E3%82%88%E3%81%B3%E7%89%B9%E5%AE%9A%E7%9B%AE%E7%9A%84%E3%81%B8%E3%81%AE%E9%81%A9%E5%90%88%E6%80%A7%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E9%BB%99%E7%A4%BA%E3%81%AE%3CBR%20%2F%3E%2B%20*%20%E4%BF%9D%E8%A8%BC%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%81%93%E3%82%8C%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%80%81%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E4%BF%9D%E8%A8%BC%E3%82%82%3CBR%20%2F%3E%20%2B%20*%20%E5%90%A6%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%82%E3%80%81%E8%91%97%E4%BD%9C%E6%A8%A9%E8%80%85%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AF%E3%80%81%20%3CBR%20%2F%3E%2B%20*%20%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%80%81%E9%96%93%E6%8E%A5%E7%9A%84%E3%80%81%E4%BB%98%E9%9A%8F%E7%9A%84%E3%80%81%E7%89%B9%E5%88%A5%E3%80%81%E4%BE%8B%E7%A4%BA%E7%9A%84%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E7%B5%90%E6%9E%9C%E7%9A%84%E3%81%AA%E6%90%8D%E5%AE%B3%3CBR%20%2F%3E%20%2B%20*%EF%BC%88%E4%BB%A3%E6%9B%BF%E3%81%AE%E5%95%86%E5%93%81%E3%82%84%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AE%E8%AA%BF%E9%81%94%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%80%81%3CBR%20%2F%3E%20%2B%20*%20%E4%BD%BF%E7%94%A8%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E5%88%A9%E7%9B%8A%E3%81%AE%E5%96%AA%E5%A4%B1%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E4%BA%8B%E6%A5%AD%E3%81%AE%E4%B8%AD%E6%96%AD%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%EF%BC%89%3CBR%20%2F%3E%20%2B%20*%20%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%E8%B2%AC%E4%BB%BB%E7%90%86%E8%AB%96%EF%BC%88%E5%A5%91%E7%B4%84%E3%80%81%E5%8E%B3%E6%A0%BC%E8%B2%AC%E4%BB%BB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%8D%E6%B3%95%E8%A1%8C%E7%82%BA%E3%82%92%E5%90%AB%E3%82%80%EF%BC%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%3CBR%20%2F%3E%20%2B%20*%EF%BC%88%E9%81%8E%E5%A4%B1%E3%82%92%E5%90%AB%E3%82%80%E3%81%8B%E5%90%A6%E3%81%8B%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%EF%BC%89%E3%81%93%E3%81%AE%3CBR%20%2F%3E%2B%20*%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8B%E3%82%89%E7%94%9F%E3%81%98%E3%82%8B%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%BD%A2%E3%81%A7%E3%82%82%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%90%8D%E5%AE%B3%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%9F%A5%E3%82%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A8%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E8%B2%AC%E4%BB%BB%E3%82%92%E8%B2%A0%E3%82%8F%E3%81%AA%E3%81%84%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%2B%20*%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%23include%20%22manually_constructed.h%22%3CBR%20%2F%3E%2B%23include%20%22rpmsg_lite_rtos_transport.h%22%3CBR%20%2F%3E%2B%23include%20%22erpc_transport_setup.h%22%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Busing%20namespace%20erpc%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%2F%2F%20Variables%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bstatic%20ManuallyConstructed%3CRPMSGRTOSTRANSPORT%3E%20s_transport%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%2F%2F%20Code%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Berpc_transport_t%20erpc_transport_rpmsg_lite_rtos_remote_init(%3CBR%20%2F%3E%2B%20unsigned%20long%20src_addr%2C%20unsigned%20long%20dst_addr%2C%20void%20*start_address%2C%20int%20rpmsg_link_id%2C%20void%20(*ready_cb)(void)%2C%20bool%20send_nameservice)%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%20s_transport.construct()%3B%3CBR%20%2F%3E%2B%20s_transport-%26gt%3Binit(src_addr%2C%20dst_addr%2C%20start_address%2C%20rpmsg_link_id%2C%20ready_cb%2C%20send_nameservice)%3B%3CBR%20%2F%3E%2B%20return%20reinterpret_cast%3CERPC_TRANSPORT_T%3E(s_transport.get())%3B%3CBR%20%2F%3E%2B%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%3CBR%20%2F%3Ediff%20--git%20a%2Ferpc_c%2Fsetup%2Ferpc_transport_setup.h%20b%2Ferpc_c%2Fsetup%2Ferpc_transport_setup.h%3CBR%20%2F%3Eindex%20798d92f..6c3959e%20100644%3CBR%20%2F%3E---%20a%2Ferpc_c%2Fsetup%2Ferpc_transport_setup.h%3CBR%20%2F%3E%2B%2B%2B%20b%2Ferpc_c%2Fsetup%2Ferpc_transport_setup.h%3CBR%20%2F%3E%40%40%20-34%2C6%20%2B34%2C7%20%40%40%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%23include%20%22erpc_version.h%22%3CBR%20%2F%3E%20%23include%20%3CSTDINT.H%3E%3CBR%20%2F%3E%2B%23include%20%3CSTDBOOL.H%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F*!%3CBR%20%2F%3E%20*%20%40addtogroup%20transport_setup%3CBR%20%2F%3E%40%40%20-48%2C7%20%2B49%2C7%20%40%40%3CBR%20%2F%3E%20%2F%2F!%20%40brief%20%E4%B8%8D%E9%80%8F%E6%98%8E%E3%81%AA%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%BF%E3%82%A4%E3%83%97%E3%80%82%3CBR%20%2F%3E%20typedef%20struct%20ErpcTransport%20*erpc_transport_t%3B%3CBR%20%2F%3E%20%2F%2F!%20%40brief%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%BF%E3%82%A4%E3%83%97%E3%80%82%3CBR%20%2F%3E-typedef%20void%20(*rpmsg_ready_cb)(void)%3B%3CBR%20%2F%3E%2B%2F%2Ftypedef%20void%20(*rpmsg_ready_cb)(void)%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%20%2F%2F%20API%3CBR%20%2F%3E%40%40%20-106%2C21%20%2B107%2C21%20%40%40%20erpc_transport_t%20erpc_transport_rpmsg_lite_master_init(unsigned%20long%20src_addr%2C%3CBR%20%2F%3E%20%2F*!%3CBR%20%2F%3E%20*%20%40brief%20RPMsg-Lite%20%E3%82%BC%E3%83%AD%E3%82%B3%E3%83%94%E3%83%BC%E8%BB%A2%E9%80%81%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20*%2F%3CBR%20%2F%3E-erpc_transport_t%20erpc_transport_rpmsg_lite_zc_master_init(unsigned%20long%20src_addr%2C%3CBR%20%2F%3E-%20unsigned%20long%20dst_addr%2C%3CBR%20%2F%3E-%20int%20rpmsg_link_id)%3B%3CBR%20%2F%3E%2B%2F%2Ferpc_transport_t%20erpc_transport_rpmsg_lite_zc_master_init(unsigned%20long%20src_addr%2C%3CBR%20%2F%3E%2B%2F%2F%20unsigned%20long%20dst_addr%2C%3CBR%20%2F%3E%2B%2F%2F%20int%20rpmsg_link_id)%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F*!%3CBR%20%2F%3E%20*%20%40brief%20RPMsg-Lite%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20*%2F%3CBR%20%2F%3E%20erpc_transport_t%20erpc_transport_rpmsg_lite_remote_init(%3CBR%20%2F%3E-%20unsigned%20long%20src_addr%2C%20unsigned%20long%20dst_addr%2C%20void%20*start_address%2C%20int%20rpmsg_link_id%2C%20rpmsg_ready_cb%20ready)%3B%3CBR%20%2F%3E%2B%20unsigned%20long%20src_addr%2C%20unsigned%20long%20dst_addr%2C%20void%20*start_address%2C%20int%20rpmsg_link_id%2C%20void%20(*ready_cb)(void)%2C%20bool%20send_nameservice)%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F*!%3CBR%20%2F%3E%20*%20%40brief%20RPMsg-Lite%20%E3%82%BC%E3%83%AD%E3%82%B3%E3%83%94%E3%83%BC%E3%83%BB%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20*%2F%3CBR%20%2F%3E-erpc_transport_t%20erpc_transport_rpmsg_lite_zc_remote_init(%3CBR%20%2F%3E-%20unsigned%20long%20src_addr%2C%20unsigned%20long%20dst_addr%2C%20void%20*start_address%2C%20int%20rpmsg_link_id%2C%20rpmsg_ready_cb%20ready)%3B%3CBR%20%2F%3E%2B%2F%2Ferpc_transport_t%20erpc_transport_rpmsg_lite_zc_remote_init(%3CBR%20%2F%3E%2B%2F%2F%20unsigned%20long%20src_addr%2C%20unsigned%20long%20dst_addr%2C%20void%20*start_address%2C%20int%20rpmsg_link_id%2C%20rpmsg_ready_cb%20ready)%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F*!%3CBR%20%2F%3E%20*%20%40brief%20RPMsg-Lite%20RTOS%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%40%40%20-133%2C7%20%2B134%2C8%20%40%40%20erpc_transport_t%20erpc_transport_rpmsg_lite_rtos_master_init%20(unsigned%20long%20src_ad%20*%20%40brief)%20RPMsg-Lite%20RTOS%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82*%2F%3CBR%20%2F%3E%20erpc_transport_t%20erpc_transport_rpmsg_lite_rtos_remote_init(%3CBR%20%2F%3E-%20unsigned%20long%20src_addr%2C%20unsigned%20long%20dst_addr%2C%20void%20*start_address%2C%20int%20rpmsg_link_id%2C%20rpmsg_ready_cb%20ready)%3B%3CBR%20%2F%3E%2B%20unsigned%20long%20src_addr%2C%20unsigned%20long%20dst_addr%2C%20void%20*start_address%2C%20int%20rpmsg_link_id%2C%20void%20(*ready_cb)(void)%2C%20bool%20send_nameservice)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F%2F%40%7D%3CBR%20%2F%3E%20%3CBR%20%2F%3Ediff%20--git%20a%2Ferpc_c%2Ftransports%2Frpmsg_lite_rtos_transport.cpp%20b%2Ferpc_c%2Ftransports%2Frpmsg_lite_rtos_transport.cpp%3CBR%20%2F%3Enew%20file%20mode%20100644%3CBR%20%2F%3Eindex%200000000..e04ae91%3CBR%20%2F%3E---%20%2Fdev%2Fnull%3CBR%20%2F%3E%2B%2B%2B%20b%2Ferpc_c%2Ftransports%2Frpmsg_lite_rtos_transport.cpp%3CBR%20%2F%3E%40%40-0%2C0%20%2B1%2C158%20%40%40%3CBR%20%2F%3E%2B%2F*%3CBR%20%2F%3E%2B%20*%20Copyright%20(c)%202015%2C%20Freescale%20Semiconductor%2C%20Inc.%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%E3%82%BD%E3%83%BC%E3%82%B9%E5%BD%A2%E5%BC%8F%E3%81%8A%E3%82%88%E3%81%B3%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%AE%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%8A%E3%82%88%E3%81%B3%E4%BD%BF%E7%94%A8%E3%81%AF%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%AE%E6%9C%89%E7%84%A1%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%3CBR%20%2F%3E%2B%20*%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E9%99%90%E3%82%8A%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20o%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%AB%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%E8%A1%A8%E7%A4%BA%E3%80%81%E3%81%93%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AE%E4%B8%80%E8%A6%A7%3CBR%20%2F%3E%2B%20*%20%E3%81%8A%E3%82%88%E3%81%B3%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%85%8D%E8%B2%AC%E4%BA%8B%E9%A0%85%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%20%3CBR%20%2F%3E%20%2B%20*%20o%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%AE%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%A7%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%E8%A1%A8%E7%A4%BA%E3%80%81%E3%81%93%E3%81%AE%3CBR%20%2F%3E%20%2B%20*%20%E6%9D%A1%E4%BB%B6%E3%83%AA%E3%82%B9%E3%83%88%E3%80%81%3CBR%20%2F%3E%E3%81%8A%E3%82%88%E3%81%B3%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%85%8D%E8%B2%AC%E4%BA%8B%E9%A0%85%E3%82%92%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%2F%E3%81%BE%E3%81%9F%E3%81%AF%3CBR%20%2F%3E%E9%85%8D%E5%B8%83%E7%89%A9%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%99%E3%82%8B%E4%BB%96%E3%81%AE%E8%B3%87%E6%96%99%E3%81%AB%E8%A4%87%E8%A3%BD%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20o%20Freescale%20Semiconductor%2C%20Inc.%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%82%E3%81%9D%E3%81%AE%3CBR%20%2F%3E%2B%20*%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%82%E3%80%81%E3%81%93%E3%81%AE%3CBR%20%2F%3E%2B%20*%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8B%E3%82%89%E6%B4%BE%E7%94%9F%E3%81%97%E3%81%9F%E8%A3%BD%E5%93%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%81%BE%E3%81%9F%E3%81%AF%E5%AE%A3%E4%BC%9D%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%E6%9B%B8%E9%9D%A2%E3%81%AB%E3%82%88%E3%82%8B%E4%BA%8B%E5%89%8D%E3%81%AE%E7%89%B9%E5%88%A5%E3%81%AA%E8%A8%B1%E5%8F%AF%E3%81%AA%E3%81%97%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%E3%81%93%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E8%91%97%E4%BD%9C%E6%A8%A9%E6%89%80%E6%9C%89%E8%80%85%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%80%8C%E7%8F%BE%E7%8A%B6%E3%81%AE%E3%81%BE%E3%81%BE%E3%80%8D%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%80%81%20%3CBR%20%2F%3E%2B%20*%20%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%BE%E3%81%9F%E3%81%AF%E9%BB%99%E7%A4%BA%E7%9A%84%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E5%95%86%E5%93%81%E6%80%A7%E3%81%8A%E3%82%88%E3%81%B3%E7%89%B9%E5%AE%9A%E7%9B%AE%E7%9A%84%E3%81%B8%E3%81%AE%E9%81%A9%E5%90%88%E6%80%A7%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E9%BB%99%E7%A4%BA%E3%81%AE%3CBR%20%2F%3E%2B%20*%20%E4%BF%9D%E8%A8%BC%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%81%93%E3%82%8C%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%80%81%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E4%BF%9D%E8%A8%BC%E3%82%82%3CBR%20%2F%3E%2B%20*%20%E5%90%A6%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%82%E3%80%81%E8%91%97%E4%BD%9C%E6%A8%A9%E8%80%85%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AF%E3%80%81%20%3CBR%20%2F%3E%2B%20*%20%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%80%81%E9%96%93%E6%8E%A5%E7%9A%84%E3%80%81%E4%BB%98%E9%9A%8F%E7%9A%84%E3%80%81%E7%89%B9%E5%88%A5%E3%80%81%E4%BE%8B%E7%A4%BA%E7%9A%84%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E7%B5%90%E6%9E%9C%E7%9A%84%E3%81%AA%E6%90%8D%E5%AE%B3%20%3CBR%20%2F%3E%2B%20*%EF%BC%88%E4%BB%A3%E6%9B%BF%E3%81%AE%E5%95%86%E5%93%81%E3%82%84%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AE%E8%AA%BF%E9%81%94%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%80%81%3CBR%20%2F%3E%20%2B%20*%20%E4%BD%BF%E7%94%A8%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E5%88%A9%E7%9B%8A%E3%81%AE%E5%96%AA%E5%A4%B1%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E4%BA%8B%E6%A5%AD%E3%81%AE%E4%B8%AD%E6%96%AD%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%EF%BC%89%3CBR%20%2F%3E%20%2B%20*%20%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%E8%B2%AC%E4%BB%BB%E7%90%86%E8%AB%96%EF%BC%88%E5%A5%91%E7%B4%84%E3%80%81%E5%8E%B3%E6%A0%BC%E8%B2%AC%E4%BB%BB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%8D%E6%B3%95%E8%A1%8C%E7%82%BA%E3%82%92%E5%90%AB%E3%82%80%EF%BC%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%3CBR%20%2F%3E%20%2B%20*%EF%BC%88%E9%81%8E%E5%A4%B1%E3%82%92%E5%90%AB%E3%82%80%E3%81%8B%E5%90%A6%E3%81%8B%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E3%81%93%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8B%E3%82%89%E7%94%9F%E3%81%98%E3%82%8B%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%BD%A2%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%90%8D%E5%AE%B3%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%9F%A5%E3%82%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A8%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E8%B2%AC%E4%BB%BB%E3%82%92%E8%B2%A0%E3%82%8F%E3%81%AA%E3%81%84%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%23include%20%22rpmsg_lite_rtos_transport.h%22%3CBR%20%2F%3E%2B%23include%20%3CCASSERT%3E%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%23if%20!(__embedded_cplusplus)%3CBR%20%2F%3E%2Busing%20namespace%20std%3B%3CBR%20%2F%3E%2B%23endif%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Busing%20namespace%20erpc%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%2F%2F%20Variables%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2Buint8_t%20RPMsgRTOSTransport%3A%3As_initialized%20%3D%200%3B%3CBR%20%2F%3E%2Bstruct%20rpmsg_lite_instance%20*RPMsgRTOSTransport%3A%3As_rpmsg%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%2F%2F%20Code%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2BRPMsgRTOSTransport%3A%3ARPMsgRTOSTransport()%3CBR%20%2F%3E%2B%3A%20Transport()%3CBR%20%2F%3E%2B%2C%20m_dst_addr(0)%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2BRPMsgRTOSTransport%3A%3A~RPMsgRTOSTransport()%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%20rpmsg_lite_deinit(s_rpmsg)%3B%3CBR%20%2F%3E%2B%20s_initialized%20%3D%200%3B%3CBR%20%2F%3E%2B%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Berpc_status_t%20RPMsgRTOSTransport%3A%3Ainit(%3CBR%20%2F%3E%2B%20unsigned%20long%20src_addr%2C%20unsigned%20long%20dst_addr%2C%20void%20*base_address%2C%20unsigned%20long%20length%2C%20int%20rpmsg_link_id)%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%20if%20(!s_initialized)%3CBR%20%2F%3E%2B%20%7B%3CBR%20%2F%3E%2B%20s_rpmsg%20%3D%20rpmsg_lite_master_init(base_address%2C%20length%2C%20rpmsg_link_id%2C%20RL_NO_FLAGS)%3B%3CBR%20%2F%3E%2B%20s_initialized%20%3D%201%3B%3CBR%20%2F%3E%2B%20%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20m_rpmsg_queue%20%3D%20rpmsg_queue_create(s_rpmsg)%3B%3CBR%20%2F%3E%2B%20m_rpmsg_ept%20%3D%20rpmsg_lite_create_ept(s_rpmsg%2C%20src_addr%2C%20rpmsg_queue_rx_cb%2C%20m_rpmsg_queue)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20m_dst_addr%20%3D%20dst_addr%3B%3CBR%20%2F%3E%2B%20return%20m_rpmsg_ept%20%3D%3D%20RL_NULL%20%3F%20kErpcStatus_InitFailed%20%3A%20kErpcStatus_Success%3B%3CBR%20%2F%3E%2B%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Berpc_status_t%20RPMsgRTOSTransport%3A%3Ainit(%3CBR%20%2F%3E%2B%20unsigned%20long%20src_addr%2C%20unsigned%20long%20dst_addr%2C%20void%20*base_address%2C%20int%20rpmsg_link_id%2C%20void%20(*ready_cb)(void)%2C%20bool%20send_nameservice)%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%20if%20(!s_initialized)%3CBR%20%2F%3E%2B%20%7B%3CBR%20%2F%3E%2B%20s_rpmsg%20%3D%20rpmsg_lite_remote_init(base_address%2C%20rpmsg_link_id%2C%20RL_NO_FLAGS)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20%2F*%20%E4%BB%96%E3%81%AE%E3%82%B3%E3%82%A2%E3%81%AB%E6%BA%96%E5%82%99%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%2B%20if%20(ready_cb%20!%3D%20NULL)%3CBR%20%2F%3E%2B%20%7B%3CBR%20%2F%3E%2B%20ready_cb()%3B%3CBR%20%2F%3E%2B%20%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20while%20(!rpmsg_lite_is_link_up(s_rpmsg))%3CBR%20%2F%3E%2B%20%7B%3CBR%20%2F%3E%2B%20%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20s_initialized%20%3D%201%3B%3CBR%20%2F%3E%2B%20%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20m_rpmsg_queue%20%3D%20rpmsg_queue_create(s_rpmsg)%3B%3CBR%20%2F%3E%2B%20m_rpmsg_ept%20%3D%20rpmsg_lite_create_ept(s_rpmsg%2C%20src_addr%2C%20rpmsg_queue_rx_cb%2C%20m_rpmsg_queue)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20if(send_nameservice)%3CBR%20%2F%3E%2B%20%7B%3CBR%20%2F%3E%2B%20rpmsg_ns_announce(s_rpmsg%2C%20m_rpmsg_ept%2C%3CBR%20%2F%3E%2B%20%22rpmsg-openamp-demo-channel%22%2C%3CBR%20%2F%3E%2B%200)%3B%3CBR%20%2F%3E%2B%20%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20m_dst_addr%20%3D%20dst_addr%3B%3CBR%20%2F%3E%2B%20return%20m_rpmsg_ept%20%3D%3D%20RL_NULL%20%3F%20kErpcStatus_InitFailed%20%3A%20kErpcStatus_Success%3B%3CBR%20%2F%3E%2B%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Berpc_status_t%20RPMsgRTOSTransport%3A%3Areceive(MessageBuffer%20*message)%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%20int%20ret_val%20%3D%20rpmsg_queue_recv(s_rpmsg%2C%20m_rpmsg_queue%2C%20%26amp%3Bm_dst_addr%2C%20(char%20*)message-%26gt%3Bget()%2C%20kRpmsgMessageBufferSize%2C%3CBR%20%2F%3E%2B%20NULL%2C%20RL_BLOCK)%3B%3CBR%20%2F%3E%2B%20return%20ret_val%20!%3D%20RL_SUCCESS%20%3F%20kErpcStatus_ReceiveFailed%20%3A%20kErpcStatus_Success%3B%3CBR%20%2F%3E%2B%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Berpc_status_t%20RPMsgRTOSTransport%3A%3Asend(const%20MessageBuffer%20*message)%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%20int%20ret_val%20%3D%3CBR%20%2F%3E%2B%20rpmsg_lite_send(s_rpmsg%2C%20m_rpmsg_ept%2C%20m_dst_addr%2C%20(char%20*)message-%26gt%3Bget()%2C%20message-%26gt%3BgetUsed()%2C%20RL_BLOCK)%3B%3CBR%20%2F%3E%2B%20return%20ret_val%20!%3D%20RL_SUCCESS%20%3F%20kErpcStatus_SendFailed%20%3A%20kErpcStatus_Success%3B%3CBR%20%2F%3E%2B%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2BMessageBuffer%20RPMsgMessageBufferFactory%3A%3Acreate()%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%20uint8_t%20idx%20%3D%200%3B%3CBR%20%2F%3E%2B%20while%20(((m_freeBufferBitmap%20%26amp%3B%20idx)%20%3D%3D%200)%20%26amp%3B%26amp%3B%20(idx%20%26lt%3B%20kInitCountMessageBuffers))%3CBR%20%2F%3E%2B%20%7B%3CBR%20%2F%3E%2B%20idx%2B%2B%3B%3CBR%20%2F%3E%2B%20%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20assert(idx%20%26lt%3B%20kInitCountMessageBuffers)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20m_freeBufferBitmap%20%26amp%3B%3D%20~(1%20%26lt%3B%26lt%3B%20idx)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20uint8_t%20*buf%3B%3CBR%20%2F%3E%2B%20buf%20%3D%20m_buffers%5Bidx%5D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20assert(NULL%20!%3D%20buf)%3B%3CBR%20%2F%3E%2B%20return%20MessageBuffer(buf%2C%20kRpmsgMessageBufferSize)%3B%3CBR%20%2F%3E%2B%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bvoid%20RPMsgMessageBufferFactory%3A%3Adispose(MessageBuffer%20*buf)%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%20assert(buf)%3B%3CBR%20%2F%3E%2B%20uint8_t%20*tmp%20%3D%20buf-%26gt%3Bget()%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20if%20(tmp)%3CBR%20%2F%3E%2B%20%7B%3CBR%20%2F%3E%2B%20uint8_t%20idx%20%3D%200%3B%3CBR%20%2F%3E%2B%20while%20((tmp%20!%3D%20m_buffers%5Bidx%5D)%20%26amp%3B%26amp%3B%20(idx%20%26lt%3B%20kInitCountMessageBuffers))%3CBR%20%2F%3E%2B%20%7B%3CBR%20%2F%3E%2B%20%2B%2Bidx%3B%3CBR%20%2F%3E%2B%20%7D%3CBR%20%2F%3E%2B%20m_freeBufferBitmap%20%7C%3D%201%20%26lt%3B%26lt%3B%20idx%3B%3CBR%20%2F%3E%2B%20%7D%3CBR%20%2F%3E%2B%7D%3CBR%20%2F%3Ediff%20--git%20a%2Ferpc_c%2Ftransports%2Frpmsg_lite_rtos_transport.h%20b%2Ferpc_c%2Ftransports%2Frpmsg_lite_rtos_transport.h%3CBR%20%2F%3Enew%20file%20mode%20100644%3CBR%20%2F%3Eindex%200000000..f1aec8a%3CBR%20%2F%3E---%20%2Fdev%2Fnull%3CBR%20%2F%3E%2B%2B%2B%20b%2Ferpc_c%2Ftransports%2Frpmsg_lite_rtos_transport.h%3CBR%20%2F%3E%40%40%20-0%2C0%20%2B1%2C177%20%40%40%3CBR%20%2F%3E%2B%2F*%3CBR%20%2F%3E%2B%20*%20Copyright%20(c)%202015-2016%2C%20Freescale%20Semiconductor%2C%20Inc.%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8A%E3%82%88%E3%81%B3%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%AE%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%8A%E3%82%88%E3%81%B3%E4%BD%BF%E7%94%A8%E3%81%AF%E3%80%81%E4%BF%AE%E6%AD%A3%E3%81%AE%E6%9C%89%E7%84%A1%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%3CBR%20%2F%3E%2B%20*%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%8C%E6%BA%80%E3%81%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20o%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%AB%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%E8%A1%A8%E7%A4%BA%E3%80%81%E3%81%93%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%80%81%3CBR%20%2F%3E%2B%20*%20%E3%81%8A%E3%82%88%E3%81%B3%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%85%8D%E8%B2%AC%E4%BA%8B%E9%A0%85%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%20%3CBR%20%2F%3E%20%2B%20*%20o%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%AE%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%A7%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%E8%A1%A8%E7%A4%BA%E3%80%81%E3%81%93%E3%81%AE%3CBR%20%2F%3E%20%2B%20*%20%E6%9D%A1%E4%BB%B6%E3%83%AA%E3%82%B9%E3%83%88%E3%80%81%3CBR%20%2F%3E%E3%81%8A%E3%82%88%E3%81%B3%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%85%8D%E8%B2%AC%E4%BA%8B%E9%A0%85%E3%82%92%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%2F%E3%81%BE%E3%81%9F%E3%81%AF%3CBR%20%2F%3E%E9%85%8D%E5%B8%83%E7%89%A9%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%99%E3%82%8B%E4%BB%96%E3%81%AE%E8%B3%87%E6%96%99%E3%81%AB%E8%A4%87%E8%A3%BD%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20o%20Freescale%20Semiconductor%2C%20Inc.%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%82%E3%81%9D%E3%81%AE%3CBR%20%2F%3E%2B%20*%E8%B2%A2%E7%8C%AE%E8%80%85%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%82%E3%80%81%E3%81%93%E3%81%AE%3CBR%20%2F%3E%2B%20*%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8B%E3%82%89%E6%B4%BE%E7%94%9F%E3%81%97%E3%81%9F%E8%A3%BD%E5%93%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%81%BE%E3%81%9F%E3%81%AF%E5%AE%A3%E4%BC%9D%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%E6%9B%B8%E9%9D%A2%E3%81%AB%E3%82%88%E3%82%8B%E4%BA%8B%E5%89%8D%E3%81%AE%E7%89%B9%E5%88%A5%E3%81%AA%E8%A8%B1%E5%8F%AF%E3%81%AA%E3%81%97%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%20%2B%20*%20%E3%81%93%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E8%91%97%E4%BD%9C%E6%A8%A9%E6%89%80%E6%9C%89%E8%80%85%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%80%8C%E7%8F%BE%E7%8A%B6%E3%81%AE%E3%81%BE%E3%81%BE%E3%80%8D%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%20%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%BE%E3%81%9F%E3%81%AF%E9%BB%99%E7%A4%BA%E7%9A%84%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%3CBR%20%2F%3E%2B%20*%20%E5%95%86%E5%93%81%E6%80%A7%E3%81%8A%E3%82%88%E3%81%B3%E7%89%B9%E5%AE%9A%E7%9B%AE%E7%9A%84%E3%81%B8%E3%81%AE%E9%81%A9%E5%90%88%E6%80%A7%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E9%BB%99%E7%A4%BA%E3%81%AE%E4%BF%9D%E8%A8%BC%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%81%93%E3%82%8C%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%80%81%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E4%BF%9D%E8%A8%BC%E3%82%82%3CBR%20%2F%3E%2B%20*%20%E5%90%A6%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%82%E3%80%81%E8%91%97%E4%BD%9C%E6%A8%A9%E8%80%85%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20%2B%20*%20%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%80%81%E9%96%93%E6%8E%A5%E7%9A%84%E3%80%81%E4%BB%98%E9%9A%8F%E7%9A%84%E3%80%81%E7%89%B9%E5%88%A5%E3%80%81%E4%BE%8B%E7%A4%BA%E7%9A%84%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E7%B5%90%E6%9E%9C%E7%9A%84%E3%81%AA%E6%90%8D%E5%AE%B3%E3%80%81%2B%20*%EF%BC%88%E4%BB%A3%E6%9B%BF%E3%81%AE%E5%95%86%E5%93%81%E3%82%84%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AE%E8%AA%BF%E9%81%94%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%80%81%3CBR%20%2F%3E%2B%20*%20%E4%BD%BF%E7%94%A8%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E5%88%A9%E7%9B%8A%E3%81%AE%E5%96%AA%E5%A4%B1%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E4%BA%8B%E6%A5%AD%E3%81%AE%E4%B8%AD%E6%96%AD%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%EF%BC%89%2B%20*%20%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%E8%B2%AC%E4%BB%BB%E7%90%86%E8%AB%96%EF%BC%88%E5%A5%91%E7%B4%84%E3%80%81%E5%8E%B3%E6%A0%BC%E8%B2%AC%E4%BB%BB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%8D%E6%B3%95%E8%A1%8C%E7%82%BA%E3%82%92%E5%90%AB%E3%82%80%EF%BC%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%3CBR%20%2F%3E%2B%20*%EF%BC%88%E9%81%8E%E5%A4%B1%E3%82%92%E5%90%AB%E3%82%80%E3%81%8B%E5%90%A6%E3%81%8B%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%EF%BC%89%E3%81%93%E3%81%AE%3CBR%20%2F%3E%2B%20*%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8B%E3%82%89%E7%94%9F%E3%81%98%E3%82%8B%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%BD%A2%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%90%8D%E5%AE%B3%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%9F%A5%E3%82%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A8%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E8%B2%AC%E4%BB%BB%E3%82%92%E8%B2%A0%E3%82%8F%E3%81%AA%E3%81%84%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%2B%2B%23ifndef%20_EMBEDDED_RPC__RPMSG_LITE_RTOS_TRANSPORT_H_%2B%23define%20_EMBEDDED_RPC__RPMSG_LITE_RTOS_TRANSPORT_H_%2B%2B%23include%20%22transport.h%22%2B%23include%20%22message_buffer.h%22%2B%23include%20%22rpmsg_lite.h%22%2B%23include%20%22rpmsg_queue.h%22%2B%23include%20%E3%80%8Crpmsg_ns.h%E3%80%8D%2B%3CBR%20%2F%3E%2B%2F*!%3CBR%20%2F%3E%2B%20*%20%40addtogroup%20rpmsg_lite_rtos_transport%3CBR%20%2F%3E%2B%20*%20%40%7B%3CBR%20%2F%3E%2B%20*%20%40file%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%2F%2F%20Definitions%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Benum%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%20kRpmsgMessageBufferSize%20%3D%20RPMSG_BUFFER_SIZE%2C%3CBR%20%2F%3E%2B%20kInitCountMessageBuffers%20%3D%202%2C%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%2F%2F%20Classes%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bnamespace%20erpc%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E9%96%93%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%E3%81%AB%20RPMsg%20RTOS%20API%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%40ingroup%20rpmsg_lite_rtos_transport%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2Bclass%20RPMsgRTOSTransport%20%3A%20public%20Transport%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2Bpublic%3A%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E3%82%B3%E3%83%B3%E3%82%B9%E3%83%88%E3%83%A9%E3%82%AF%E3%82%BF%E3%80%82%3CBR%20%2F%3E%2B%20*%2B%20*%20%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E5%B1%9E%E6%80%A7%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%2B%20*%2F%2B%20RPMsgRTOSTransport()%3B%2B%2B%20%2F*!%2B%20*%20%40brief%20RPMsgRTOSTransport%20%E3%83%87%E3%82%B9%E3%83%88%E3%83%A9%E3%82%AF%E3%82%BF%2B%20*%2F%2B%20virtual%20~RPMsgRTOSTransport()%3B%2B%2B%20%2F*!%2B%20*%20%40brief%20%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81RPMsg%20RTOS%20%E5%88%9D%E6%9C%9F%E5%8C%96%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%20-%20RPMsg%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%2B%20*%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20src_addr%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%82%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20dst_addr%20%E5%AE%9B%E5%85%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%82%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20base_address%20%E5%85%B1%E6%9C%89%E3%83%A1%E3%83%A2%E3%83%AA%E5%86%85%E3%81%AE%20RPMsg%20%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%82%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20length%20RPMsg%20%E5%85%B1%E6%9C%89%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%E3%81%AE%E9%95%B7%E3%81%95%E3%80%82%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20rpmsg_link_id%20%E3%81%A9%E3%81%AE%E3%82%B3%E3%82%A2%E9%96%93%E3%81%A7%E9%80%9A%E4%BF%A1%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%AE%E9%81%B8%E6%8A%9E%E3%80%82%3CBR%20%2F%3E%2B%20*%2B%20*%20%40retval%20kErpcStatus_Success%20rpmsg%20init%20%E9%96%A2%E6%95%B0%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%82%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_InitFailed%20rpmsg%20init%20%E9%96%A2%E6%95%B0%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20erpc_status_t%20init(%3CBR%20%2F%3E%2B%20unsigned%20long%20src_addr%2C%20unsigned%20long%20dst_addr%2C%20void%20*base_address%2C%20unsigned%20long%20length%2C%20int%20rpmsg_link_id)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%20RPMsg%20RTOS%20%E5%88%9D%E6%9C%9F%E5%8C%96%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%20-%20RPMsg%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20src_addr%20%E9%80%81%E4%BF%A1%E5%85%83%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%82%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20dst_addr%20%E5%AE%9B%E5%85%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%82%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20base_address%20%E5%85%B1%E6%9C%89%E3%83%A1%E3%83%A2%E3%83%AA%E5%86%85%E3%81%AE%20RPMsg%20%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%82%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20rpmsg_link_id%20%E3%81%A9%E3%81%AE%E3%82%B3%E3%82%A2%E9%96%93%E3%81%A7%E9%80%9A%E4%BF%A1%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%AE%E9%81%B8%E6%8A%9E%E3%80%82%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20ready_cb%20RPMsg%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%80%81%E3%82%B3%E3%82%A2%E3%81%AE%E6%BA%96%E5%82%99%E3%81%8C%E6%95%B4%E3%81%A3%E3%81%9F%E5%BE%8C%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%80%82%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20send_nameservice%20true%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81RPMsg%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%AF%E3%83%8D%E3%83%BC%E3%83%A0%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E9%80%9A%E7%9F%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_Success%20rpmsg%20init%20%E9%96%A2%E6%95%B0%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%82%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_InitFailed%20rpmsg%20init%20%E9%96%A2%E6%95%B0%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20erpc_status_t%20init(%3CBR%20%2F%3E%2B%20unsigned%20long%20src_addr%2C%20unsigned%20long%20dst_addr%2C%20void%20*base_address%2C%20int%20rpmsg_link_id%2C%20void%20(*ready_cb)(void)%2C%20bool%20send_nameservice)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E5%8F%97%E4%BF%A1%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E6%9D%A5%E3%81%AA%E3%81%84%E9%96%93%E3%80%81%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20message%20%E5%8F%97%E4%BF%A1%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%82%8B%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_ReceiveFailed%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E5%8F%97%E4%BF%A1%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_Success%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20erpc_status_t%20receive(MessageBuffer%20*message)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E7%94%A8%E6%84%8F%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E9%96%A2%E6%95%B0%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20message%20%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E6%B8%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_SendFailed%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E9%80%81%E4%BF%A1%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_Success%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20erpc_status_t%20send(const%20MessageBuffer%20*message)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bprotected%3A%3CBR%20%2F%3E%2B%20%2F*%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20*%2F%3CBR%20%2F%3E%2B%20struct%20remote_device%20*m_rdev%3B%20%2F*!%26lt%3B%202%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%82%B3%E3%82%A2%E3%82%92%E8%A1%A8%E3%81%99%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%82*%2F%3CBR%20%2F%3E%2B%20struct%20rpmsg_channel%20*m_app_rp_chnl%3B%20%2F*!%26lt%3B%202%E3%81%A4%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%882%E3%81%A4%E3%81%AE%E3%82%B3%E3%82%A2%EF%BC%89%E9%96%93%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82*%2F%3CBR%20%2F%3E%2B%20unsigned%20long%20m_dst_addr%3B%20%2F*!%26lt%3B%20rpmsg%20%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%AE%9B%E5%85%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%82*%2F%3CBR%20%2F%3E%2B%20rpmsg_queue_handle%20m_rpmsg_queue%3B%20%2F*!%26lt%3B%20RPMsg%20%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%E3%80%82*%2F%3CBR%20%2F%3E%2B%20struct%20rpmsg_lite_endpoint%20*m_rpmsg_ept%3B%20%2F*!%26lt%3B%20RPMsg%20Lite%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E6%A7%8B%E9%80%A0%E4%BD%93%E3%81%B8%E3%81%AE%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%80%82*%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20static%20struct%20rpmsg_lite_instance%20*s_rpmsg%3B%20%2F*!%26lt%3B%20RPMSG%20lite%20%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%B8%E3%81%AE%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%80%82*%2F%3CBR%20%2F%3E%2B%20static%20uint8_t%20s_initialized%3B%20%2F*!%26lt%3B%20rpmsg-lite%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E8%A1%A8%E3%81%99%E6%83%85%E5%A0%B1%E3%80%82*%2F%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bclass%20RPMsgMessageBufferFactory%20%3A%20public%20MessageBufferFactory%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%20uint8_t%20m_freeBufferBitmap%3B%3CBR%20%2F%3E%2B%20uint8_t%20m_buffers%5BkInitCountMessageBuffers%5D%5BkRpmsgMessageBufferSize%5D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bpublic%3A%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E3%82%B3%E3%83%B3%E3%82%B9%E3%83%88%E3%83%A9%E3%82%AF%E3%82%BF%E3%83%BC%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20RPMsgMessageBufferFactory()%3CBR%20%2F%3E%2B%20%3A%20m_freeBufferBitmap(0xFF)%3CBR%20%2F%3E%2B%20%7B%3CBR%20%2F%3E%2B%20%7D%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20RPMsgMessageBufferFactory%20destructor%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20~RPMsgMessageBufferFactory()%20%7B%7D%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E9%96%93%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20MessageBuffer%20create()%3B%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E9%96%93%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E7%A0%B4%E6%A3%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20void%20dispose(MessageBuffer%20*buf)%3B%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%7D%20%2F%2F%20namespace%20erpc%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2F*!%20%40%7D%20*%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%23endif%20%2F%2F%20_EMBEDDED_RPC__RPMSG_LITE_RTOS_TRANSPORT_H_%3CBR%20%2F%3Ediff%20--git%20a%2Ferpc_c%2Ftransports%2Frpmsg_rtos_transport.h%20b%2Ferpc_c%2Ftransports%2Frpmsg_rtos_transport.h%3CBR%20%2F%3Enew%20file%20mode%20100644%3CBR%20%2F%3Eindex%200000000..ad1d229%3CBR%20%2F%3E---%20%2Fdev%2Fnull%3CBR%20%2F%3E%2B%2B%2B%20b%2Ferpc_c%2Ftransports%2Frpmsg_rtos_transport.h%3CBR%20%2F%3E%40%40-0%2C0%20%2B1%2C147%20%40%40%2B%2F*%2B%20*%20Copyright%20(c)%202015%2C%20Freescale%20Semiconductor%2C%20Inc.%2B%20*%2B%20*%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8A%E3%82%88%E3%81%B3%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%AE%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%8A%E3%82%88%E3%81%B3%E4%BD%BF%E7%94%A8%E3%81%AF%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%AE%E6%9C%89%E7%84%A1%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%2B%20*%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E5%A0%B4%E5%90%88%E3%81%AB%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%2B%20*%2B%20*%20o%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%AB%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%E8%A1%A8%E7%A4%BA%E3%80%81%E3%81%93%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%2B%20*%20%E3%81%8A%E3%82%88%E3%81%B3%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%85%8D%E8%B2%AC%E4%BA%8B%E9%A0%85%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%2B%20*%20%3CBR%20%2F%3E%20%2B%20*%20o%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%AE%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%A7%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%E8%A1%A8%E7%A4%BA%E3%80%81%E3%81%93%E3%81%AE%3CBR%20%2F%3E%20%2B%20*%20%E6%9D%A1%E4%BB%B6%E3%83%AA%E3%82%B9%E3%83%88%E3%80%81%3CBR%20%2F%3E%E3%81%8A%E3%82%88%E3%81%B3%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%85%8D%E8%B2%AC%E4%BA%8B%E9%A0%85%E3%82%92%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%2F%E3%81%BE%E3%81%9F%E3%81%AF%3CBR%20%2F%3E%E9%85%8D%E5%B8%83%E7%89%A9%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%99%E3%82%8B%E4%BB%96%E3%81%AE%E8%B3%87%E6%96%99%E3%81%AB%E8%A4%87%E8%A3%BD%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20o%20Freescale%20Semiconductor%2C%20Inc.%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%82%E3%81%9D%E3%81%AE%3CBR%20%2F%3E%2B%20*%E8%B2%A2%E7%8C%AE%E8%80%85%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%82%E3%80%81%E3%81%93%E3%81%AE%3CBR%20%2F%3E%2B%20*%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8B%E3%82%89%E6%B4%BE%E7%94%9F%E3%81%97%E3%81%9F%E8%A3%BD%E5%93%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%81%BE%E3%81%9F%E3%81%AF%E5%AE%A3%E4%BC%9D%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%E6%9B%B8%E9%9D%A2%E3%81%AB%E3%82%88%E3%82%8B%E4%BA%8B%E5%89%8D%E3%81%AE%E7%89%B9%E5%88%A5%E3%81%AA%E8%A8%B1%E5%8F%AF%E3%81%AA%E3%81%97%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%E3%81%93%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E8%91%97%E4%BD%9C%E6%A8%A9%E6%89%80%E6%9C%89%E8%80%85%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%80%8C%E7%8F%BE%E7%8A%B6%E3%81%AE%E3%81%BE%E3%81%BE%E3%80%8D%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%80%81%3CBR%20%2F%3E%20%2B%20*%20%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%BE%E3%81%9F%E3%81%AF%E9%BB%99%E7%A4%BA%E7%9A%84%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E5%95%86%E5%93%81%E6%80%A7%E3%81%8A%E3%82%88%E3%81%B3%E7%89%B9%E5%AE%9A%E7%9B%AE%E7%9A%84%E3%81%B8%E3%81%AE%E9%81%A9%E5%90%88%E6%80%A7%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E9%BB%99%E7%A4%BA%E3%81%AE%3CBR%20%2F%3E%2B%20*%20%E4%BF%9D%E8%A8%BC%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%81%93%E3%82%8C%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%80%81%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E4%BF%9D%E8%A8%BC%E3%82%82%3CBR%20%2F%3E%2B%20*%20%E5%90%A6%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%82%E3%80%81%E8%91%97%E4%BD%9C%E6%A8%A9%E8%80%85%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AF%E3%80%81%20%3CBR%20%2F%3E%2B%20*%20%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%80%81%E9%96%93%E6%8E%A5%E7%9A%84%E3%80%81%E4%BB%98%E9%9A%8F%E7%9A%84%E3%80%81%E7%89%B9%E5%88%A5%E3%80%81%E4%BE%8B%E7%A4%BA%E7%9A%84%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E7%B5%90%E6%9E%9C%E7%9A%84%E3%81%AA%E6%90%8D%E5%AE%B3%E3%80%81%3CBR%20%2F%3E%2B%20*%EF%BC%88%E4%BB%A3%E6%9B%BF%E3%81%AE%E5%95%86%E5%93%81%E3%82%84%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AE%E8%AA%BF%E9%81%94%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%80%81%3CBR%20%2F%3E%2B%20*%20%E4%BD%BF%E7%94%A8%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E5%88%A9%E7%9B%8A%E3%81%AE%E5%96%AA%E5%A4%B1%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E4%BA%8B%E6%A5%AD%E3%81%AE%E4%B8%AD%E6%96%AD%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%EF%BC%89%3CBR%20%2F%3E%2B%20*%20%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%E8%B2%AC%E4%BB%BB%E7%90%86%E8%AB%96%EF%BC%88%E5%A5%91%E7%B4%84%E3%80%81%E5%8E%B3%E6%A0%BC%E8%B2%AC%E4%BB%BB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%8D%E6%B3%95%E8%A1%8C%E7%82%BA%E3%82%92%E5%90%AB%E3%82%80%EF%BC%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%3CBR%20%2F%3E%2B%20*%EF%BC%88%E9%81%8E%E5%A4%B1%E3%82%92%E5%90%AB%E3%82%80%E3%81%8B%E5%90%A6%E3%81%8B%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%EF%BC%89%E3%81%93%E3%81%AE%3CBR%20%2F%3E%2B%20*%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8B%E3%82%89%E7%94%9F%E3%81%98%E3%82%8B%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%BD%A2%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%90%8D%E5%AE%B3%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%9F%A5%E3%82%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A8%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E8%B2%AC%E4%BB%BB%E3%82%92%E8%B2%A0%E3%82%8F%E3%81%AA%E3%81%84%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%23ifndef%20_EMBEDDED_RPC__RPMSG_RTOS_TRANSPORT_H_%3CBR%20%2F%3E%2B%23define%20_EMBEDDED_RPC__RPMSG_RTOS_TRANSPORT_H_%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%23include%20%22transport.h%22%3CBR%20%2F%3E%2B%23include%20%22message_buffer.h%22%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bextern%20%22C%22%20%7B%3CBR%20%2F%3E%2B%23include%20%22rpmsg.h%22%3CBR%20%2F%3E%2B%23include%20%22rpmsg_rtos.h%22%3CBR%20%2F%3E%2B%23include%20%22rpmsg.h%22%3CBR%20%2F%3E%2B%7D%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2F*!%3CBR%20%2F%3E%2B%20*%20%40addtogroup%20rpmsg_rtos_transport%3CBR%20%2F%3E%2B%20*%20%40%7B%3CBR%20%2F%3E%2B%20*%20%40file%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%2F%2F%20Definitions%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Benum%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%20kRpmsgMessageBufferSize%20%3D%20RPMSG_BUFFER_SIZE%2C%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%2F%2F%20Classes%3CBR%20%2F%3E%2B%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bnamespace%20erpc%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2B%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E9%96%93%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%E3%81%AB%20RPMsg%20RTOS%20API%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%40ingroup%20rpmsg_rtos_transport%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2Bclass%20RPMsgRTOSTransport%20%3A%20public%20Transport%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2Bpublic%3A%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E3%82%B3%E3%83%B3%E3%82%B9%E3%83%88%E3%83%A9%E3%82%AF%E3%82%BF%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E5%B1%9E%E6%80%A7%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20RPMsgRTOSTransport()%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20RPMsgRTOSTransport%20destructor%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20~RPMsgRTOSTransport()%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%20rpmsg%20rtos%20init%20%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20dev_id%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%E7%95%AA%E5%8F%B7%E3%80%82%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20role%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AD%E3%83%BC%E3%83%AB%E7%95%AA%E5%8F%B7%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_Success%20rpmsg%20init%20%E9%96%A2%E6%95%B0%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%82%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_InitFailed%20rpmsg%20init%20%E9%96%A2%E6%95%B0%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20erpc_status_t%20init(int%20dev_id%2C%20int%20role)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E5%8F%97%E4%BF%A1%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E9%96%93%E3%80%81%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20message%20%E5%8F%97%E4%BF%A1%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%82%8B%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_ReceiveFailed%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E5%8F%97%E4%BF%A1%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_Success%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20erpc_status_t%20receive(MessageBuffer%20*%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E7%94%A8%E6%84%8F%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E9%96%A2%E6%95%B0%E3%80%82.%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%20target%3D%22_blank%22%3E%40Param%3C%2FA%3E%5Bin%5D%20message%20%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E6%B8%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_SendFailed%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E9%80%81%E4%BF%A1%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%2B%20*%20%40retval%20kErpcStatus_Success%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20erpc_status_t%20send(const%20MessageBuffer%20*%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bprotected%3A%3CBR%20%2F%3E%2B%20%2F*%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20*%2F%3CBR%20%2F%3E%2B%20static%20struct%20remote_device%20*m_rdev%3B%20%2F*!%26lt%3B%202%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%82%B3%E3%82%A2%E3%82%92%E8%A1%A8%E3%81%99%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%82*%2F%3CBR%20%2F%3E%2B%20static%20struct%20rpmsg_channel%20*m_app_rp_chnl%3B%20%2F*!%26lt%3B%202%E3%81%A4%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%882%E3%81%A4%E3%81%AE%E3%82%B3%E3%82%A2%EF%BC%89%E9%96%93%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82*%2F%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bclass%20RPMsgMessageBufferFactory%20%3A%20public%20MessageBufferFactory%3CBR%20%2F%3E%2B%7B%3CBR%20%2F%3E%2Bpublic%3A%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E3%82%B3%E3%83%B3%E3%82%B9%E3%83%88%E3%83%A9%E3%82%AF%E3%82%BF%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20RPMsgMessageBufferFactory()%20%7B%7D%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20RPMsgMessageBufferFactory%20destructor%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20~RPMsgMessageBufferFactory()%20%7B%7D%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E9%96%93%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E9%96%A2%E6%95%B0%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20MessageBuffer%20create()%3B%3CBR%20%2F%3E%2B%20%2F*!%3CBR%20%2F%3E%2B%20*%20%40brief%20%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E9%96%93%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E7%A0%B4%E6%A3%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%2B%20*%2F%3CBR%20%2F%3E%2B%20virtual%20void%20dispose(MessageBuffer%20*buf)%3B%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%7D%20%2F%2F%20namespace%20erpc%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2F*!%20%40%7D%20*%2F%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%23endif%20%2F%2F%20_EMBEDDED_RPC__RPMSG_RTOS_TRANSPORT_H_%3CBR%20%2F%3Ediff%20--git%20a%2Ferpc_python%2Ferpc%2Ftransport.py%20b%2Ferpc_python%2Ferpc%2Ftransport.py%3CBR%20%2F%3Eindex%200765e9f..c335943%20100644%3CBR%20%2F%3E---%20a%2Ferpc_python%2Ferpc%2Ftransport.py%3CBR%20%2F%3E%2B%2B%2B%20b%2Ferpc_python%2Ferpc%2Ftransport.py%3CBR%20%2F%3E%40%40%20-31%2C6%20%2B31%2C8%20%40%40%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20import%20struct%3CBR%20%2F%3E%20import%20serial%3CBR%20%2F%3E%2Bfrom%20rpmsg.sysfs%20import%20RpmsgEndpoint%3CBR%20%2F%3E%2Bimport%20time%3CBR%20%2F%3E%20import%20socket%3CBR%20%2F%3E%20import%20threading%3CBR%20%2F%3E%20from%20.crc16%20import%20crc16%3CBR%20%2F%3E%40%40%20-107%2C6%20%2B109%2C25%20%40%40%20class%20SerialTransport(FramedTransport)%3A%3CBR%20%2F%3E%20class%20ConnectionClosed(Exception)%3A%3CBR%20%2F%3E%20pass%3CBR%20%2F%3E%20%3CBR%20%2F%3E%2Bclass%20RpmsgTransport(Transport)%3A%3CBR%20%2F%3E%2B%20def%20__init__(self)%3A%3CBR%20%2F%3E%2B%20self.ept%20%3D%20RpmsgEndpoint(%3CBR%20%2F%3E%2B%20RpmsgEndpoint.rpmsg_openamp_channel%2C%3CBR%20%2F%3E%2B%20RpmsgEndpoint.LOCAL_DEFAULT_ADDRESS%2C%3CBR%20%2F%3E%2B%20RpmsgEndpoint.Types.DATAGRAM)%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20def%20send(self%2C%20message)%3A%3CBR%20%2F%3E%2B%20self.ept.send(message%2C%20RpmsgEndpoint.REMOTE_DEFAULT_ADDRESS)%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20def%20receive(self)%3A%3CBR%20%2F%3E%2B%20while%20True%3A%3CBR%20%2F%3E%2B%20ret%20%3D%20self.ept.recv(2048)%3CBR%20%2F%3E%2B%20if%20len(ret%5B1%5D)%20!%3D%200%3A%3CBR%20%2F%3E%2B%20return%20ret%5B1%5D%3CBR%20%2F%3E%2B%20else%3A%3CBR%20%2F%3E%2B%20time.sleep(0.001)%3CBR%20%2F%3E%2B%20return%20ret%5B1%5D%20%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%20class%20TCPTransport(FramedTransport)%3A%3CBR%20%2F%3E%20def%20__init__(self%2C%20host%2C%20port%2C%20isServer)%3A%3CBR%20%2F%3E%20super(TCPTransport%2C%20self).__init__()%3CBR%20%2F%3E--%20%3CBR%20%2F%3E2.7.4%3C%2FCASSERT%3E%3C%2FSTDBOOL.H%3E%3C%2FSTDINT.H%3E%3C%2FERPC_TRANSPORT_T%3E%3C%2FRPMSGRTOSTRANSPORT%3E%3C%2FMESSAGEBUFFERFACTORY%3E%3C%2FTRANSPORT%3E%3C%2FBASICCODECFACTORY%3E%3C%2FBASICMESSAGEBUFFERFACTORY%3E%3C%2FSIMPLESERVER%3E%3C%2FASSERT.H%3E%3C%2FNEW%3E%3C%2FASSERT.H%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%89%E3%82%A5%E3%82%B7%E3%83%A3%E3%83%B3%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%20%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%E3%80%82%E3%83%87%E3%83%A2%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%83%97%E3%83%AB%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%8D%E5%BA%A6%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Python%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%83%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E8%AA%BF%E5%AD%90%E3%81%A7%E3%81%99%E3%80%82%EF%BC%88%E7%AC%91%E9%A1%94%E3%81%AE%E3%82%A6%E3%82%A3%E3%83%B3%E3%82%AF%E3%81%AE%E9%A1%94%E6%96%87%E5%AD%97%EF%BC%89%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81imx%E3%83%87%E3%83%A2%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AB%E3%83%97%E3%83%AB%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E4%BF%AE%E6%AD%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fmareknovak%22%20target%3D%22_blank%22%3Emareknovak%3C%2FA%3E%20%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AB%E3%83%9E%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPython%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%96%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%80%8Cerpcgen%20--help%20(-h%20%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99)%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3Epython%20-gpy%20idl_file%3C%2FSTRONG%3E%20-%26gt%3B%20gpy%20%E3%81%AF%20Python%20%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%AD%E3%80%82%E6%9B%B4%E6%96%B0%E3%81%BE%E3%81%A7%E5%90%8C%E3%81%98%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E4%BD%9C%E6%A5%AD%E3%82%92%E7%B6%9A%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E4%BF%AE%E6%AD%A3%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81MCU%E3%83%87%E3%83%A2%E3%81%8C%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dusan%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%9F%E3%82%89%E3%80%81MCU%E3%83%87%E3%83%A2%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%82%8A%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eerpcgen%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Python%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%2020px%200px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E6%9C%80%E7%9F%AD%E3%81%A7%E6%98%8E%E6%97%A5%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%98%8E%E6%97%A5%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%A8%E3%81%AF%E3%81%8A%E7%B4%84%E6%9D%9F%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AE%E5%90%8C%E5%83%9A%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fmareknovak%22%20target%3D%22_blank%22%3Emareknovak%3C%2FA%3E%E3%81%AF%E6%9C%AC%E6%97%A5%E5%8B%A4%E5%8B%99%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%82%E3%81%BE%E3%82%8A%E6%99%82%E9%96%93%E3%81%AF%E3%81%8B%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%84%E3%81%A4%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E9%96%A2%E5%BF%83%E3%82%92%E3%81%8A%E5%AF%84%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81erpc%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81Marek%20%E3%81%8C%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%20erpcgen%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%EF%BC%88%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%9F%E3%82%B9%E3%81%A7%E3%81%99%EF%BC%89%E3%80%82%E6%9C%80%E5%96%84%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E3%83%87%E3%83%A2%E3%82%92%E6%9C%80%E6%96%B0%E3%81%AE%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%20erpc%20%E3%81%8A%E3%82%88%E3%81%B3%20erpcgen%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGitHub%20-%20EmbeddedRPC%2Ferpc%3A%20Embedded%20RPC%3C%2FA%3E%E3%81%AE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%8B%E3%82%89%E3%81%93%E3%82%8C%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%EF%BC%88erpcgen%20%E3%83%97%E3%83%AA%E3%83%93%E3%83%AB%E3%83%89%201.4.0%20%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%89%E3%81%8C%E3%80%81%E3%81%A9%E3%82%8C%E3%81%A0%E3%81%91%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E6%9B%B4%E6%96%B0%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E3%81%93%E3%81%A8%E3%82%82%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fmareknovak%22%20target%3D%22_blank%22%3Emareknovak%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dusan%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E5%8F%82%E7%85%A7%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98eRPC%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E5%BE%93%E3%81%A3%E3%81%9F%E6%89%8B%E9%A0%86%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgithub.com%252FEmbeddedRPC%252Ferpc-imx-demos%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20text-decoration%3A%20underline%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20target%3D%22_blank%22%3Eerpc-imx-demos%3C%2FA%3E%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E4%BD%9C%E6%88%90%E3%80%81%EF%BC%88eRPC%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FMarekNovakNXP%2Ferpc%2Ftree%2F232afb209f0a0cfceb25a1be11879f7d1934e065%22%20title%3D%22https%3A%2F%2Fgithub.com%2FMarekNovakNXP%2Ferpc%2Ftree%2F232afb209f0a0cfceb25a1be11879f7d1934e065%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGitHub%20-%20232afb209f0a0cfceb25a1be11879f7d1934e065%20%E3%81%AE%20MarekNovakNXP%2Ferpc%3C%2FA%3E%26nbsp%3B%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%99%E3%82%8B%EF%BC%89%E3%82%B5%E3%83%96%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E5%90%AB%E3%82%80%3C%2FP%3E%3CP%3E1.%26nbsp%3Bgit%20clone%20--recursive%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos.git%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20erpc-imx-demos%2Fmiddleware%2Ferpc%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%3CSTRONG%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%20erpcgen%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8flex%2Fbison%E3%81%8A%E3%82%88%E3%81%B3boost%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Eeprc%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Eeprcgen%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Esudo%E3%83%A1%E3%82%A4%E3%82%AF%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%20erpcgen%20%3C%2FSTRONG%3E%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E3.%3C%2FSTRONG%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%3CSTRONG%3Eerpc_matrix_multiply.erpc%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E4%BD%9C%E6%88%90%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3Eerpcgen%20-I%20erpc-imx-demos%2FMCU%2Fexample_erpc%2Fservice%20-o%20test%2Ferpc-imx-demos%2FMCU%2Fexample_erpc%2Fservice%20erpc_matrix_multiply.erpc%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eerpc_matrix_multiply.h%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eerpc_matrix_multiply_server.cpp%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eerpc_matrix_multiply_server.h%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eerpc_matrix_multiply_client.cpp%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E4.%20MCU%2Fexample_erpc%2Fbuild%2Farmgcc%2Fimx7d_sdb_m4%2Fbuild_all.sh%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%2Fhome%2Fbasavarajuc%2Ftest%2Ferpc-imx-demos%2FMCU%2Fexample_erpc%2Fservice%2Ferpc_matrix_multiply_server.cpp%3A%20%E9%96%A2%E6%95%B0%E5%86%85%20'void*%20create_MatrixMultiplyService_service()'%3A%3CBR%20%2F%3E%2Fhome%2Fbasavarajuc%2Ftest%2Ferpc-imx-demos%2FMCU%2Fexample_erpc%2Fservice%2Ferpc_matrix_multiply_server.cpp%3A168%3A56%3A%20%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E6%8A%BD%E8%B1%A1%E3%82%AF%E3%83%A9%E3%82%B9%E5%9E%8B%20'MatrixMultiplyService_service'%20%E3%81%AE%20new-expression%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3CSTRONG%3E%20new%20(nothrow)%20MatrixMultiplyService_service()%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%86%8D%E5%BA%A6%E8%B3%AA%E5%95%8F%E3%81%97%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%8D%E3%81%A1%E3%82%93%E3%81%A8%E7%90%86%E8%A7%A3%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E1.%20GitHub%20%E3%81%AE%20eRPC%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FMarekNovakNXP%2Ferpc%2Ftree%2F232afb209f0a0cfceb25a1be11879f7d1934e065%22%20title%3D%22https%3A%2F%2Fgithub.com%2FMarekNovakNXP%2Ferpc%2Ftree%2F232afb209f0a0cfceb25a1be11879f7d1934e065%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20%EF%BC%88232afb209f0a0cfceb25a1be11879f7d1934e065%20%E3%81%AE%20MarekNovakNXP%2Ferpc%EF%BC%89%3C%2FA%3E%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%3C%2FSTRONG%3E%3CSTRONG%3E%20%E3%83%87%E3%83%A2%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%87%E3%83%A2%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2.%3C%2FSTRONG%3E%3CSTRONG%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%2Ftree%2Fmaster%2FMCU%2Fexample_erpc%2Fservice%22%20title%3D%22https%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%2Ftree%2Fmaster%2FMCU%2Fexample_erpc%2Fservice%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eerpc-imx-demos%2FMCU%2Fexample_erpc%2Fservice%20at%20master%20%C2%B7%20EmbeddedRPC%2Ferpc-imx-demos%20%C2%B7%20GitHub%3C%2FA%3E%20%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%20erpcgen%20%E3%81%A7%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%8F%A4%E3%81%84erpcgen%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E8%87%AA%E5%88%86%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%8A%E6%89%8B%E6%95%B0%E3%82%92%E3%81%8A%E3%81%8B%E3%81%91%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%A9%E3%81%86%E3%81%9E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E6%8C%87%E6%91%98%E3%81%AE%E4%BE%8B%E3%81%AF%E3%80%81%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AE%20erpcgen%20%E3%83%93%E3%83%AB%E3%83%89%E3%82%88%E3%82%8A%E3%82%82%E5%8F%A4%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fmareknovak%22%20target%3D%22_blank%22%3Emareknovak%3C%2FA%3E%20%E3%81%AF%E3%80%81%E5%BD%93%E6%99%82%E3%81%AE%E5%85%AC%E5%BC%8F%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AF%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%B0%8F%E3%81%95%E3%81%AA%E5%A4%89%E6%9B%B4%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E5%85%AC%E5%BC%8F%20eRPC%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%82%AF%E3%82%82%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%AE%3CA%20class%3D%22%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgithub.com%252FEmbeddedRPC%252Ferpc-imx-demos%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20text-decoration%3A%20underline%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20target%3D%22_blank%22%3Eerpc-imx-demos%3C%2FA%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%8B%E3%82%89eRPC%E5%8F%82%E7%85%A7%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81eRPC%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AB%E3%83%AA%E3%83%80%E3%82%A4%E3%83%AC%E3%82%AF%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8B%E3%82%89%20erpcgen%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%B0%86%E6%9D%A5%E7%9A%84%E3%81%AB%E3%81%AF%E3%83%87%E3%83%A2%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%9F%E3%81%AA%E3%82%89%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%94%E4%B8%8D%E6%98%8E%E3%81%AA%E7%82%B9%E3%81%8C%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%A9%E3%81%86%E3%81%9E%E3%81%8A%E6%B0%97%E8%BB%BD%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20eRPC%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E8%B3%AA%E5%95%8F%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENXP%20%E3%81%AE%20erpcgen%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%87%E3%83%A2%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%A1%E3%82%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgithub.com%252FEmbeddedRPC%252Ferpc-imx-demos%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FEmbeddedRPC%2Ferpc-imx-demos%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%AF%E3%80%81erpcgen%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%3CSTRONG%3E%20erpc_matrix_multiply.erpc%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%8B%AC%E8%87%AA%E3%81%AE%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%E3%83%87%E3%83%A2%E3%82%92%E5%86%8D%E5%BA%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81erpcgen%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E6%85%A3%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%20erpc_matrix_multiply.erpc%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E7%A7%81%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A4%89%E6%9B%B4%E7%82%B9%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BE%8B%E7%A4%BA%E3%83%87%E3%83%A2%E3%81%AE%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%20(erpc_matrix_multiply_server.h)%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eerpc_status_t%20erpcMatrixMultiply_shim(erpc%3A%3ACodec%20*%20in%2C%20erpc%3A%3ACodec%20*%20out%2C%20uint32_t%20sequence)%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E%E7%A7%81%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%88erpc_matrix_multiply_server.h%EF%BC%89%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Eerpc_status_t%20erpcMatrixMultiply_shim(erpc%3A%3ACodec%20*%20codec%2C%20uint32_t%20sequence)%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8B%E7%90%86%E7%94%B1%E3%80%81%E6%AC%A0%E3%81%91%E3%81%A6%E3%81%84%E3%82%8B%E8%A8%AD%E5%AE%9A%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Eerpc_matrix_multiply_server.h%20%E3%81%8A%E3%82%88%E3%81%B3%20erpc_matrix_multiply_server.cpp%20%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E7%B7%A8%E9%9B%86%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%87%E3%82%A3%E3%83%BC%E3%83%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎07-14-2023 05:31 AM
Updated by:
