not able to debug with j-link
已解决
跳至解决方案
2,898 次查看
RRD101
I have the following problem.
With the latest version of mcuxpresso and the LPC55s16-EVK and the onboard debug-probe everything works fine. With an own pcb with the LPC55S16JBD64 and an J-Link EDU with the latest drivers, it compiles, seems to transfer the image on the MCU. But i have no resume button. only suspend, terminate and restart. sometimes on start of debugsession, ResetISR() from startup_lpc55s16.c gets opened an in the debug view is shown: Thread #1 57005(Running: User Request) and arm-none-eabi-gdb (10.1.90.20201028)
what i'm doing wrong, that debugging does not work?
the J-Link Web Control shows that target is connected
1 解答
2,817 次查看
RRD101
problem solved. PIO0_5 was in the wrong state
在原帖中查看解决方案
1 回复
2,818 次查看
RRD101
