doxygen support
doxygen support
4,251 次查看
billchadwick
Is there any way to enable autodoc (for doxygen) in MCUXpresso
That is typing /**<cr> would produce e.g. a full function header template comment block
I have the eclox plugin installed but that is just the document generator.
On Eclipse CDT this is enabled with Window->Preferences->C/C++ ->Editor->"Documentation tool"
标记 (1)
4,247 次查看
ErichStyger
Specialist I
Do you have this enabled?
This is the thing which works for me for years, see https://mcuoneclipse.com/2012/06/25/5-best-eclipse-plugins-1-eclox-with-doxygen-graphviz-and-mscgen/
I hope this helps,
Erich
4,248 次查看
ErichStyger
Specialist I
I hope this helps,
Erich
4,244 次查看
billchadwick
That works. I missed it somehow.
Many thanks,
Bill
