change default sdk location
11,282件の閲覧回数
wilcovm
I start using the MCUXpresso. When importing a SDK it will be stored in the <default location> which is the c:\users\...
How can I change this default location?
Adding an additional location in the preferences -> MCUXpresso IDE -> SDK Option and deleting the default will not help. The default comes back.
10,580件の閲覧回数
BlackNight
Hi Wilco,
I believe the default location is re-added by design, I'll check.
What I would suggest is that you do not put the SDKs into the default folder, but into the user/added folder location (you can simply put the zip files there), that way you can keep things separate too.
Erich
9 返答(返信)
10,580件の閲覧回数
jan_harman
Unfortunatelly, problem is that my default location is:
c:\Users\Ján Harman\mcuxpresso\
... so the exception is raised if I select "New project..." even if SDK is in my not default location with valid path.
What to do?
Jan
10,580件の閲覧回数
lpcxpresso_supp
Hi Jan,
Could you please let me know which IDE version are you using?
Moreover, could you please attach the whole error log (when that exception happened)?
You can find the error log in <your workspace path>/.metadata/.log.
Ciao
MCUXpresso support
10,580件の閲覧回数
jan_harman
Version:
MCUXpressoIDE_10.0.2_411
Log:
!SESSION 2017-08-09 14:29:42.988 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_111
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=cs_CZ
Command-line arguments: -os win32 -ws win32 -arch x86 -data D:\NXP_WS1
!ENTRY org.eclipse.ui 4 4 2017-08-09 14:29:46.844
!MESSAGE Plugin org.eclipse.cdt.ui, extension org.eclipse.ui.decorators, id org.eclipse.cdt.internal.ui.CustomBuildSettingsDecorator: Duplicate id found: org.eclipse.cdt.internal.ui.CustomBuildSettingsDecorator
!ENTRY org.eclipse.ui 4 4 2017-08-09 14:29:46.850
!MESSAGE Plugin org.eclipse.cdt.ui, extension org.eclipse.ui.decorators, id org.eclipse.cdt.internal.ui.CustomBuildSettingsDecorator: Unknown extension tag found: decorator
!ENTRY org.eclipse.egit.ui 2 0 2017-08-09 14:29:48.190
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\Ján Harman'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2017-08-09 14:29:48.443
!MESSAGE Recreating part suppport. No part support available.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2017-08-09 15:38:04.561
!MESSAGE The device 'MKV10Z32xxx7' (version='1.0.0') from SDK 'SDK_2.x_MKV10Z32xxx7' (version='2.2.0', build='') will be installed.
!ENTRY com.crt.utils 4 -1 2017-08-09 15:43:50.365
!MESSAGE Path contains invalid character: á
!STACK 0
com.sun.org.apache.xerces.internal.util.URI$MalformedURIException: Path contains invalid character: á
at com.sun.org.apache.xerces.internal.util.URI.initializePath(URI.java:1109)
at com.sun.org.apache.xerces.internal.util.URI.initialize(URI.java:582)
at com.sun.org.apache.xerces.internal.util.URI.<init>(URI.java:335)
at com.sun.org.apache.xerces.internal.util.URI.<init>(URI.java:298)
at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.expandSystemIdStrictOff1(XMLEntityManager.java:2221)
at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.expandSystemId(XMLEntityManager.java:2053)
at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.resolveEntityAsPerStax(XMLEntityManager.java:968)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$DTDDriver.dispatch(XMLDocumentScannerImpl.java:1152)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$DTDDriver.next(XMLDocumentScannerImpl.java:1045)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:959)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:112)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:841)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:770)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at org.xml.sax.helpers.XMLFilterImpl.parse(XMLFilterImpl.java:357)
at com.crt.utils.xmlparser.XMLParser.parse(XMLParser.java:301)
at com.crt.utils.xmlparser.XMLParser.parse(XMLParser.java:347)
at com.crt.utils.xmlparser.XMLParser.parseXML(XMLParser.java:502)
at com.crt.config.info.InfolistDB.parseTheXML(InfolistDB.java:409)
at com.crt.config.info.InfolistDBCache.getCachedDB(InfolistDBCache.java:100)
at com.crt.config.info.InfolistDB.createFromURL(InfolistDB.java:192)
at com.crt.config.database.TargetConfig.getInfoFromPackage(TargetConfig.java:868)
at com.crt.config.database.TargetConfig.modifiedVendorPackage(TargetConfig.java:1319)
at com.crt.config.database.TargetConfig.setVendorPackage(TargetConfig.java:1665)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.updateDescription(BoardDeviceSelectionPage.java:674)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage$2.selectionChanged(BoardDeviceSelectionPage.java:341)
at com.crt.config.database.VendorPackageSelector.notifySelectionChangedListeners(VendorPackageSelector.java:586)
at com.crt.config.database.VendorPackageSelector.access$3(VendorPackageSelector.java:583)
at com.crt.config.database.VendorPackageSelector$1.selectionChanged(VendorPackageSelector.java:361)
at org.eclipse.jface.viewers.Viewer$1.run(Viewer.java:158)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:155)
at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2191)
at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1229)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1258)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:242)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:236)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:405)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at com.crt.quickstart.views.links.AbstractQSLink.runWizard(AbstractQSLink.java:444)
at com.nxp.mcuxpresso.core.datamodels.ui.links.QSSDKImportWizard.linkSelected(QSSDKImportWizard.java:77)
at com.crt.quickstart.views.links.ui.QSLinkAction$2.run(QSLinkAction.java:134)
at com.crt.quickstart.views.links.ui.QSExpandBarSection$2.linkActivated(QSExpandBarSection.java:173)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleActivate(AbstractHyperlink.java:228)
at org.eclipse.ui.forms.widgets.ImageHyperlink.handleActivate(ImageHyperlink.java:202)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleMouseUp(AbstractHyperlink.java:322)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.access$2(AbstractHyperlink.java:306)
at org.eclipse.ui.forms.widgets.AbstractHyperlink$4.handleEvent(AbstractHyperlink.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
!ENTRY com.crt.utils 4 4 2017-08-09 15:43:50.394
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 15:43:50.394
!MESSAGE at com.sun.org.apache.xerces.internal.util.URI.initializePath(URI.java:1109)
!MESSAGE at com.sun.org.apache.xerces.internal.util.URI.initialize(URI.java:582)
!MESSAGE at com.sun.org.apache.xerces.internal.util.URI.<init>(URI.java:335)
!MESSAGE at com.sun.org.apache.xerces.internal.util.URI.<init>(URI.java:298)
!MESSAGE at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.expandSystemIdStrictOff1(XMLEntityManager.java:2221)
!MESSAGE at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.expandSystemId(XMLEntityManager.java:2053)
!MESSAGE at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.resolveEntityAsPerStax(XMLEntityManager.java:968)
!MESSAGE at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$DTDDriver.dispatch(XMLDocumentScannerImpl.java:1152)
!MESSAGE at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$DTDDriver.next(XMLDocumentScannerImpl.java:1045)
!MESSAGE at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:959)
!MESSAGE at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
!MESSAGE at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:112)
!MESSAGE at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
!MESSAGE at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:841)
!MESSAGE at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:770)
!MESSAGE at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
!MESSAGE at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
!MESSAGE at org.xml.sax.helpers.XMLFilterImpl.parse(XMLFilterImpl.java:357)
!MESSAGE at com.crt.utils.xmlparser.XMLParser.parse(XMLParser.java:301)
!MESSAGE at com.crt.utils.xmlparser.XMLParser.parse(XMLParser.java:347)
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 15:43:50.395
!MESSAGE at com.crt.utils.xmlparser.XMLParser.parseXML(XMLParser.java:502)
!MESSAGE at com.crt.config.info.InfolistDB.parseTheXML(InfolistDB.java:409)
!MESSAGE at com.crt.config.info.InfolistDBCache.getCachedDB(InfolistDBCache.java:100)
!MESSAGE at com.crt.config.info.InfolistDB.createFromURL(InfolistDB.java:192)
!MESSAGE at com.crt.config.database.TargetConfig.getInfoFromPackage(TargetConfig.java:868)
!MESSAGE at com.crt.config.database.TargetConfig.modifiedVendorPackage(TargetConfig.java:1319)
!MESSAGE at com.crt.config.database.TargetConfig.setVendorPackage(TargetConfig.java:1665)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.updateDescription(BoardDeviceSelectionPage.java:674)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage$2.selectionChanged(BoardDeviceSelectionPage.java:341)
!MESSAGE at com.crt.config.database.VendorPackageSelector.notifySelectionChangedListeners(VendorPackageSelector.java:586)
!MESSAGE at com.crt.config.database.VendorPackageSelector.access$3(VendorPackageSelector.java:583)
!MESSAGE at com.crt.config.database.VendorPackageSelector$1.selectionChanged(VendorPackageSelector.java:361)
!MESSAGE at org.eclipse.jface.viewers.Viewer$1.run(Viewer.java:158)
!MESSAGE at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
!MESSAGE at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
!MESSAGE at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
!MESSAGE at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:155)
!MESSAGE at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2191)
!MESSAGE at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1229)
!MESSAGE at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1258)
!MESSAGE at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:242)
!MESSAGE at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:236)
!MESSAGE at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:405)
!MESSAGE at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
!MESSAGE at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
!MESSAGE at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
!MESSAGE at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
!MESSAGE at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
!MESSAGE at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
!MESSAGE at org.eclipse.jface.window.Window.open(Window.java:794)
!MESSAGE at com.crt.quickstart.views.links.AbstractQSLink.runWizard(AbstractQSLink.java:444)
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 15:43:50.396
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.links.QSSDKImportWizard.linkSelected(QSSDKImportWizard.java:77)
!MESSAGE at com.crt.quickstart.views.links.ui.QSLinkAction$2.run(QSLinkAction.java:134)
!MESSAGE at com.crt.quickstart.views.links.ui.QSExpandBarSection$2.linkActivated(QSExpandBarSection.java:173)
!MESSAGE at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleActivate(AbstractHyperlink.java:228)
!MESSAGE at org.eclipse.ui.forms.widgets.ImageHyperlink.handleActivate(ImageHyperlink.java:202)
!MESSAGE at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleMouseUp(AbstractHyperlink.java:322)
!MESSAGE at org.eclipse.ui.forms.widgets.AbstractHyperlink.access$2(AbstractHyperlink.java:306)
!MESSAGE at org.eclipse.ui.forms.widgets.AbstractHyperlink$4.handleEvent(AbstractHyperlink.java:129)
!MESSAGE at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
!MESSAGE at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
!MESSAGE at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
!MESSAGE at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
!MESSAGE at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
!MESSAGE at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
!MESSAGE at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
!MESSAGE at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
!MESSAGE at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
!MESSAGE at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
!MESSAGE at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
!MESSAGE at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
!MESSAGE at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
!MESSAGE at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
!MESSAGE at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
!MESSAGE at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
!MESSAGE at java.lang.reflect.Method.invoke(Method.java:498)
!MESSAGE at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
!MESSAGE at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
!MESSAGE at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
!ENTRY MCUXpresso IDE SDK import 4 -1 2017-08-09 15:45:33.716
!MESSAGE The following items are not supported or not valid SDKs
[C:\Downloads\hello_world.zip]
!ENTRY com.crt.utils 4 -1 2017-08-09 15:49:56.983
!STACK 0
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.createControl(BoardDeviceSelectionPage.java:542)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:175)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:696)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog.java:1144)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1197)
at org.eclipse.jface.wizard.WizardDialog.lambda$2(WizardDialog.java:1185)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1185)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:876)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:419)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:618)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction.java:115)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
!ENTRY com.crt.utils 4 4 2017-08-09 15:49:56.989
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 15:49:56.989
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 15:49:56.990
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.createControl(BoardDeviceSelectionPage.java:542)
!MESSAGE at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:175)
!MESSAGE at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:696)
!MESSAGE at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog.java:1144)
!MESSAGE at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1197)
!MESSAGE at org.eclipse.jface.wizard.WizardDialog.lambda$2(WizardDialog.java:1185)
!MESSAGE at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
!MESSAGE at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1185)
!MESSAGE at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:876)
!MESSAGE at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:419)
!MESSAGE at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:618)
!MESSAGE at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
!MESSAGE at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction.java:115)
!MESSAGE at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
!MESSAGE at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
!MESSAGE at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 15:49:56.991
!ENTRY com.crt.utils 4 -1 2017-08-09 16:02:32.077
!STACK 0
!ENTRY com.crt.utils 4 4 2017-08-09 16:02:32.093
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 16:02:32.094
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 16:02:32.095
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 16:02:32.096
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 16:02:32.097
!ENTRY com.crt.utils 4 -1 2017-08-09 16:03:02.586
!STACK 0
at org.eclipse.jface.viewers.StructuredViewer.setSelection(StructuredViewer.java:1728)
at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:1077)
at org.eclipse.jface.viewers.Viewer.setSelection(Viewer.java:383)
at com.crt.config.database.VendorPackageSelector.setSelection(VendorPackageSelector.java:645)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.getDBChip(BoardDeviceSelectionPage.java:1139)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.doFilterDevice(BoardDeviceSelectionPage.java:1126)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.checkDialog(BoardDeviceSelectionPage.java:994)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.selectBoard(BoardDeviceSelectionPage.java:1538)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.access$33(BoardDeviceSelectionPage.java:1509)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage$15$1$1.run(BoardDeviceSelectionPage.java:1299)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage$15$1.run(BoardDeviceSelectionPage.java:1295)
at org.eclipse.swt.widgets.Display.runTimer(Display.java:4337)
at org.eclipse.swt.widgets.Display.messageProc(Display.java:3426)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2552)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3822)
!ENTRY com.crt.utils 4 4 2017-08-09 16:03:02.596
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 16:03:02.596
!MESSAGE at org.eclipse.jface.viewers.StructuredViewer.setSelection(StructuredViewer.java:1728)
!MESSAGE at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:1077)
!MESSAGE at org.eclipse.jface.viewers.Viewer.setSelection(Viewer.java:383)
!MESSAGE at com.crt.config.database.VendorPackageSelector.setSelection(VendorPackageSelector.java:645)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.getDBChip(BoardDeviceSelectionPage.java:1139)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.doFilterDevice(BoardDeviceSelectionPage.java:1126)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.checkDialog(BoardDeviceSelectionPage.java:994)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.selectBoard(BoardDeviceSelectionPage.java:1538)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.access$33(BoardDeviceSelectionPage.java:1509)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage$15$1$1.run(BoardDeviceSelectionPage.java:1299)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage$15$1.run(BoardDeviceSelectionPage.java:1295)
!MESSAGE at org.eclipse.swt.widgets.Display.runTimer(Display.java:4337)
!MESSAGE at org.eclipse.swt.widgets.Display.messageProc(Display.java:3426)
!MESSAGE at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
!MESSAGE at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2552)
!MESSAGE at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3822)
!ENTRY com.crt.utils 4 -1 2017-08-09 16:03:09.938
!STACK 0
!ENTRY com.crt.utils 4 4 2017-08-09 16:03:09.943
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 16:03:09.943
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 16:03:09.948
!ENTRY com.crt.utils 4 -1 2017-08-09 16:19:26.269
!STACK 0
at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:588)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1095)
at com.crt.quickstart.views.links.AbstractQSLink.runWizard(AbstractQSLink.java:440)
at com.nxp.mcuxpresso.core.datamodels.ui.links.QSSDKWizard.linkSelected(QSSDKWizard.java:77)
!ENTRY com.crt.utils 4 4 2017-08-09 16:19:26.285
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 16:19:26.285
!MESSAGE at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:588)
!MESSAGE at org.eclipse.jface.window.Window.create(Window.java:426)
!MESSAGE at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1095)
!MESSAGE at com.crt.quickstart.views.links.AbstractQSLink.runWizard(AbstractQSLink.java:440)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.links.QSSDKWizard.linkSelected(QSSDKWizard.java:77)
!ENTRY com.crt.utils 4 -1 2017-08-09 16:19:45.909
!STACK 0
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.drawBoards(BoardDeviceSelectionPage.java:1381)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.refresh(BoardDeviceSelectionPage.java:973)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.createControl(BoardDeviceSelectionPage.java:544)
!ENTRY com.crt.utils 4 4 2017-08-09 16:19:45.924
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 16:19:45.924
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.drawBoards(BoardDeviceSelectionPage.java:1381)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.refresh(BoardDeviceSelectionPage.java:973)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.createControl(BoardDeviceSelectionPage.java:544)
!ENTRY com.crt.utils 4 -1 2017-08-09 16:19:48.715
!STACK 0
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.SDKAdvancedPage.refresh(SDKAdvancedPage.java:1431)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.SDKAdvancedPage.createControl(SDKAdvancedPage.java:274)
!ENTRY com.crt.utils 4 4 2017-08-09 16:19:48.715
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 16:19:48.715
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.SDKAdvancedPage.refresh(SDKAdvancedPage.java:1431)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.SDKAdvancedPage.createControl(SDKAdvancedPage.java:274)
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2017-08-09 16:28:27.519
!ENTRY com.nxp.mcuxpresso.core.datamodels 2 0 2017-08-09 16:28:35.552
!MESSAGE The device 'MKV10Z32xxx7' (version='1.0.0') from SDK 'SDK_2.x_MKV10Z32xxx7' (version='2.2.0', build='') has not been imported because a newer/existing device has been already installed.
!SESSION 2017-08-09 16:31:07.748 -----------------------------------------------
!ENTRY org.eclipse.ui 4 4 2017-08-09 16:31:20.982
!ENTRY org.eclipse.ui 4 4 2017-08-09 16:31:20.997
!ENTRY org.eclipse.egit.ui 2 0 2017-08-09 16:31:22.340
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2017-08-09 16:31:22.372
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2017-08-09 16:32:22.883
!ENTRY com.nxp.mcuxpresso.core.datamodels 2 0 2017-08-09 16:32:53.511
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2017-08-09 16:33:13.960
!ENTRY com.crt.utils 4 -1 2017-08-09 16:33:32.758
!STACK 0
at com.crt.config.database.TargetConfig.init(TargetConfig.java:1188)
at com.crt.config.database.TargetConfig.<init>(TargetConfig.java:604)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.updateDescription(BoardDeviceSelectionPage.java:673)
!ENTRY com.crt.utils 4 4 2017-08-09 16:33:32.758
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 16:33:32.758
!MESSAGE at com.crt.config.database.TargetConfig.init(TargetConfig.java:1188)
!MESSAGE at com.crt.config.database.TargetConfig.<init>(TargetConfig.java:604)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.BoardDeviceSelectionPage.updateDescription(BoardDeviceSelectionPage.java:673)
!ENTRY com.crt.utils 4 -1 2017-08-09 16:34:04.794
!STACK 0
!ENTRY com.crt.utils 4 4 2017-08-09 16:34:04.809
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 16:34:04.809
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2017-08-09 17:01:51.024
!ENTRY com.crt.utils 4 -1 2017-08-09 17:01:56.864
!STACK 0
!ENTRY com.crt.utils 4 4 2017-08-09 17:01:56.864
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:01:56.864
!ENTRY com.crt.utils 4 -1 2017-08-09 17:03:13.507
!STACK 0
!ENTRY com.crt.utils 4 4 2017-08-09 17:03:13.516
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:03:13.516
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:03:13.517
!ENTRY com.crt.utils 4 -1 2017-08-09 17:03:16.567
!STACK 0
!ENTRY com.crt.utils 4 4 2017-08-09 17:03:16.574
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:03:16.574
!ENTRY com.crt.utils 4 -1 2017-08-09 17:03:59.517
!STACK 0
!ENTRY com.crt.utils 4 4 2017-08-09 17:03:59.517
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:03:59.517
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:03:59.533
!ENTRY com.crt.utils 4 -1 2017-08-09 17:04:04.058
!STACK 0
!ENTRY com.crt.utils 4 4 2017-08-09 17:04:04.062
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:04:04.062
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:04:04.063
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:04:04.064
!ENTRY com.crt.utils 4 -1 2017-08-09 17:06:52.027
!STACK 0
!ENTRY com.crt.utils 4 4 2017-08-09 17:06:52.027
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:06:52.027
!ENTRY com.crt.utils 4 -1 2017-08-09 17:06:55.189
!STACK 0
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.SDKAdvancedPage.refresh(SDKAdvancedPage.java:1430)
!ENTRY com.crt.utils 4 4 2017-08-09 17:06:55.194
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:06:55.194
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.SDKAdvancedPage.refresh(SDKAdvancedPage.java:1430)
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:06:55.195
!ENTRY com.crt.utils 4 -1 2017-08-09 17:06:56.276
!STACK 0
!ENTRY com.crt.utils 4 4 2017-08-09 17:06:56.276
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:06:56.276
!ENTRY org.eclipse.cdt.core 1 0 2017-08-09 17:09:13.454
!MESSAGE Indexed 'MKV10Z32xxx7_Project' (0 sources, 0 headers) in 0,003 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0 %)
!ENTRY com.crt.utils 4 -1 2017-08-09 17:09:15.275
!STACK 0
at com.crt.config.database.TargetConfig.refreshTargetCache(TargetConfig.java:1382)
at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.addTargetConfig(SDKManifestProvider.java:2851)
at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.configureBuilder(SDKManifestProvider.java:2814)
at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.doCreateProject(SDKManifestProvider.java:2036)
at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.createProject(SDKManifestProvider.java:1286)
at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.createDeviceProject(SDKManifestProvider.java:709)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.SDKWizard.doFinish(SDKWizard.java:201)
at com.nxp.mcuxpresso.core.datamodels.ui.wizards.AbstractSDKWizard$1.run(AbstractSDKWizard.java:70)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
!ENTRY com.crt.utils 4 4 2017-08-09 17:09:15.275
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:09:15.275
!MESSAGE at com.crt.config.database.TargetConfig.refreshTargetCache(TargetConfig.java:1382)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.addTargetConfig(SDKManifestProvider.java:2851)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.configureBuilder(SDKManifestProvider.java:2814)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.doCreateProject(SDKManifestProvider.java:2036)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.createProject(SDKManifestProvider.java:1286)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.createDeviceProject(SDKManifestProvider.java:709)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.SDKWizard.doFinish(SDKWizard.java:201)
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.ui.wizards.AbstractSDKWizard$1.run(AbstractSDKWizard.java:70)
!MESSAGE at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
!ENTRY com.crt.log 1 0 2017-08-09 17:09:20.706
!MESSAGE String index out of range: 4
!ENTRY com.crt.config 4 -1 2017-08-09 17:09:20.706
!MESSAGE String index out of range: -1
!STACK 0
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.AbstractStringBuilder.insert(AbstractStringBuilder.java:1032)
at java.lang.StringBuilder.insert(StringBuilder.java:291)
at com.crt.config.info.InfolistDB.setMemoryConfig(InfolistDB.java:466)
at com.crt.config.database.TargetConfig.setMemoryConfig(TargetConfig.java:1542)
at com.crt.config.database.TargetConfig.refreshTargetCache(TargetConfig.java:1390)
!ENTRY com.crt.config 4 4 2017-08-09 17:09:20.706
!STACK 0
!SUBENTRY 1 com.crt.config 4 0 2017-08-09 17:09:20.706
!MESSAGE at java.lang.AbstractStringBuilder.insert(AbstractStringBuilder.java:1032)
!MESSAGE at java.lang.StringBuilder.insert(StringBuilder.java:291)
!MESSAGE at com.crt.config.info.InfolistDB.setMemoryConfig(InfolistDB.java:466)
!MESSAGE at com.crt.config.database.TargetConfig.setMemoryConfig(TargetConfig.java:1542)
!MESSAGE at com.crt.config.database.TargetConfig.refreshTargetCache(TargetConfig.java:1390)
!ENTRY com.crt.utils 4 -1 2017-08-09 17:09:22.024
!STACK 0
at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.configureBuilder(SDKManifestProvider.java:2832)
!ENTRY com.crt.utils 4 4 2017-08-09 17:09:22.024
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-09 17:09:22.024
!MESSAGE at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.configureBuilder(SDKManifestProvider.java:2832)
!ENTRY com.crt.log 1 0 2017-08-09 17:09:23.590
!ENTRY com.crt.config 4 -1 2017-08-09 17:09:23.590
!STACK 0
!ENTRY com.crt.config 4 4 2017-08-09 17:09:23.606
!STACK 0
!SUBENTRY 1 com.crt.config 4 0 2017-08-09 17:09:23.606
!ENTRY com.crt.log 1 0 2017-08-09 17:10:29.034
!MESSAGE chipName=null is null!
!MESSAGE chipFamily=null is null!
!ENTRY com.crt.log 1 0 2017-08-09 17:10:29.050
!ENTRY com.crt.log 1 0 2017-08-09 17:10:29.066
!ENTRY com.crt.log 1 0 2017-08-09 17:10:38.741
!ENTRY com.crt.log 1 0 2017-08-09 17:10:38.757
!ENTRY org.eclipse.core.resources 2 10035 2017-08-09 17:53:27.867
!MESSAGE The workspace will exit with unsaved changes in this session.
!SESSION 2017-08-10 16:50:22.854 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2017-08-10 16:50:25.771
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.ui 4 4 2017-08-10 16:50:33.304
!ENTRY org.eclipse.ui 4 4 2017-08-10 16:50:33.311
!ENTRY org.eclipse.egit.ui 2 0 2017-08-10 16:50:38.483
!ENTRY com.crt.utils 4 -1 2017-08-10 16:51:00.948
!STACK 0
!ENTRY com.crt.utils 4 4 2017-08-10 16:51:00.956
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-10 16:51:00.957
!SUBENTRY 1 com.crt.utils 4 0 2017-08-10 16:51:00.958
!SUBENTRY 1 com.crt.utils 4 0 2017-08-10 16:51:00.959
!ENTRY com.crt.utils 4 -1 2017-08-10 16:51:02.941
!STACK 0
!ENTRY com.crt.utils 4 4 2017-08-10 16:51:02.946
!STACK 0
!SUBENTRY 1 com.crt.utils 4 0 2017-08-10 16:51:02.946
!SUBENTRY 1 com.crt.utils 4 0 2017-08-10 16:51:02.947
!SUBENTRY 1 com.crt.utils 4 0 2017-08-10 16:51:02.948
10,582件の閲覧回数
selectstriker2
I have a similar issue, glad to see a feature request/change has been filed. I'll use Erich's workaround for now.
Now what I ran into after copying the SDK to the non-default folder MCUXpresso did not recognize the zip file automatically and I didn't see a way to refresh the installed SDKs. What I ended up doing was dragging and dropping the SDK zip file into the Installed SDKs view, at which point it "installed" the SDK without putting it in the default folder.
10,582件の閲覧回数
lpcxpresso_supp
Hi Ken,
Basically, whilst the IDE is running if you put an SDK in one of the SDK locations (default or non-default) you need to manually click on the "Recreate" button:Screen Shot 2017-03-24 at 14.26.37.png
If your IDE is not running or you do restart the IDE, than all the SDKs are automatically refreshed.
Ciao
MCUXpresso Support
10,582件の閲覧回数
selectstriker2
I didn't even notice those options on the top right of the window. I guess I expected a "Refresh" option in the right click context menu similar to how it is done in other windows.
Now I did try restarting MCUXpresso and it did show up in the listed SDK's, but wasn't considered "installed" (didn't show up in the Project Properties>C/C++ Build>MCU Settings) until I dragged the zip file into the Installed SDK window.
10,582件の閲覧回数
lpcxpresso_supp
the actual installation of an SDK manually added to a location without using any refresh mechanism depends on a preference that forces the startup part suppor refresh/recreate:
By default, in order to speedup the IDE startup, it is disabled. You can enable it, but on every IDE startup the part support will be recreated.
In general, when you want to use another folder as SDK install location, or if you do manually add an SDK in any already existing install location, please be sure to reload the part support through the button on the "Installed SDK" view.
Ciao,
MCUXpresso support.
10,581件の閲覧回数
BlackNight
Hi Wilco,
Erich
10,580件の閲覧回数
BlackNight
Hi Wilco,
just to confirm, it is currently always using the default location by design/default. I agree that it would be good to be able to remove the default location, so a feature request/change has been filed for it, so it could be potentially part of a next release.
Erich
