Using CMSIS-DSP with MCUXpresso SDK and IDE
4,159 次查看
gustavsl
I have downloaded MCUXpresso SDK 2.2 with CMSIS-DSP to develop for the MKL25Z128 on a custom board.
Using MCUXpresso IDE, I can't figure out how to use the bundled CMSIS-DSP. I tried following the instructions for adding CMSIS-DSP to KDS, but the CMSIS-DSP libraries fails to compile at some point.
Any tips?
Thanks.
3,805 次查看
Carlos_Mendoza
Hi Gustavo,
Which error do you get while compiling? Please take a look to the following document for more information:
https://community.nxp.com/docs/DOC-335465
Hope it helps!
Carlos Mendoza
Technical Support Engineer
3,806 次查看
Carlos_Mendoza
Hi Gustavo,
Hope it helps!
Carlos Mendoza
3,805 次查看
gustavsl
Thank you for the guide! It's working now. :smileyhappy:
I guess I was messing up the include paths before.
