Unable to sprintf float value with redlib(semihost-nf)
4,318 次查看
akimata
I'm struggling to sprintf a float value with redlib(semihost-nf). What i've done:
- set PRINTF_FLOAT_ENABLE=1
- set SCANF_FLOAT_ENABLE=1
- removed CR_INTEGER_PRINTF
Example code:
char text_buffer[64]
snprintf(text_buffer, sizeof(text_buffer), "declination: %.2f\r\n" , 5.25);
Any ideas what else might be wrong?
It's working on newlib(semihost) but semihosting on that lib is just too slow and i would rather to stay on redlib.
8 回复数
1,999 次查看
georgeliolidis
I had the same problem and i solved it after correcting the preprocess  symbol:
CR_INTEGER_PRINTF  to _CR_INTEGER_PRINTF.
(was missing the preceding underscore)
4,172 次查看
akimata
That's what i got in the settings. The weirdest part is that i created new project and it's working just fine there, but i cannot get it to work on my project so i just generated whole new project and copied files there and problem solved!. Still have no clue why didn't it work on my last project tho.
4,173 次查看
zhiqunhu
Try to remove CR_INTEGER_PRINTF in Preprocessor configuration.
4,173 次查看
ErichStyger
Specialist I
could it be that you changed something in the linker settings? I would compare those.
4,173 次查看
ErichStyger
Specialist I
choose a different redlib library. nf means 'no-float'.
4,173 次查看
ErichStyger
Specialist I
correction: nf means no-files (not no-float)
4,173 次查看
akimata
I tried also redlib(semihost) and redlib(semihost-mb) and noone of them works.
4,173 次查看
ErichStyger
Specialist I
this is what I have:
