Unable to sprintf float value with redlib(semihost-nf)
akimata
I'm struggling to sprintf a float value with redlib(semihost-nf). What i've done:
- set PRINTF_FLOAT_ENABLE=1
- set SCANF_FLOAT_ENABLE=1
- removed CR_INTEGER_PRINTF
Example code:
char text_buffer[64]
snprintf(text_buffer, sizeof(text_buffer), "declination: %.2f\r\n" , 5.25);
Any ideas what else might be wrong?
It's working on newlib(semihost) but semihosting on that lib is just too slow and i would rather to stay on redlib.
georgeliolidis
I had the same problem and i solved it after correcting the preprocess  symbol:
CR_INTEGER_PRINTF  to _CR_INTEGER_PRINTF.
(was missing the preceding underscore)
akimata
That's what i got in the settings. The weirdest part is that i created new project and it's working just fine there, but i cannot get it to work on my project so i just generated whole new project and copied files there and problem solved!. Still have no clue why didn't it work on my last project tho.
zhiqunhu
Try to remove CR_INTEGER_PRINTF in Preprocessor configuration.
ErichStyger
Specialist I
could it be that you changed something in the linker settings? I would compare those.
ErichStyger
Specialist I
choose a different redlib library. nf means 'no-float'.
ErichStyger
Specialist I
correction: nf means no-files (not no-float)
akimata
I tried also redlib(semihost) and redlib(semihost-mb) and noone of them works.
ErichStyger
Specialist I
this is what I have:
