Peripherals+ view empty for LPC1788
3,162 次查看
jameso
Does the MCUXpresso IDE have Peripherals+ support for the LPC1788? My suspicion is that since there is no SDK support for the LPC1788, the Peripherals+ view will not show anything.
4 回复数
2,770 次查看
lpcxpresso_supp
Yes, the Peripherals+ view should work with pre-installed parts like LPC1788.
If you are having issues, then please tell us what version of MCUXpresso IDE you are using (the current version is v10.0.2), what host OS, what debug probe, and what actual behaviour you are seeing.
MCUXpresso IDE Support
2,770 次查看
jameso
I have MCUXpresso IDE version 10.0.0 on Windows 7, and I am using a Segger J-Link Plus on the Embedded Artists Developer's Kit board. In the screenshot below, I clicked Debug in the Quickstart Panel for the periph_blinky sample project, and the Peripherals+ view is empty. Is it possible my MCUXpresso IDE installation is missing the files needed for Peripherals+ for the LPC1788?
2,770 次查看
lpcxpresso_supp
In the first place, please install and try with MCUXpresso IDE v10.0.2 (which resolves a number of Peripheral display related issues).
Let us know whether this resolves your issue.
2,770 次查看
jameso
The Peripherals+ view seems to be working now using MCUXpresso IDE v10.0.2. Thanks.
