Miscellaneous setting for MCUXpresso IDE
1,680件の閲覧回数
JayCao
Hello Support team,
We want to modify the Miscellaneous for our setting but it's hard to find the definition for all flags.
Therefore, I would like to ask if there are any guide documents for that.
If not, could you help to tell me the meaning of "-c" flash?
Thanks and BRs,
1,597件の閲覧回数
Hello @JayCao
Alice
4 返答(返信)
1,575件の閲覧回数
JayCao
Hello Alice.
Thanks so much for your support!
Best regard,
1,617件の閲覧回数
JayCao
Hello Alice,
I read this so I know almost the definition.
But there is no defined meaning for '-c'?
Do you know what is does?
Thanks and BRs,
1,598件の閲覧回数
Hello @JayCao
Alice
1,640件の閲覧回数
Hello @JayCao
How about have a look at: https://stackoverflow.com/questions/4274804/query-on-ffunction-section-fdata-sections-options-of-gcc
There are GCC compiler command, you can also check from GCC compiler user manual.
Alice
