Miscellaneous setting for MCUXpresso IDE
1,720 次查看
JayCao
Hello Support team,
We want to modify the Miscellaneous for our setting but it's hard to find the definition for all flags.
Therefore, I would like to ask if there are any guide documents for that.
If not, could you help to tell me the meaning of "-c" flash?
Thanks and BRs,
1,637 次查看
Hello @JayCao
Alice
4 回复数
1,615 次查看
JayCao
Hello Alice.
Thanks so much for your support!
Best regard,
1,657 次查看
JayCao
Hello Alice,
I read this so I know almost the definition.
But there is no defined meaning for '-c'?
Do you know what is does?
Thanks and BRs,
1,638 次查看
Hello @JayCao
Alice
1,680 次查看
Hello @JayCao
How about have a look at: https://stackoverflow.com/questions/4274804/query-on-ffunction-section-fdata-sections-options-of-gcc
There are GCC compiler command, you can also check from GCC compiler user manual.
Alice
