How use .lib static library in MCUXpresso IDE
1,004件の閲覧回数
Harshal_Kaswala
I need to add a .lib static library to the MCUXpresso project. I know that the .a static library setting is added in "MCU Linker - Libraries" > "Library search path (-L) Add". I try the same for the .lib library but I am facing a compilation error.
タグ(2)
990件の閲覧回数
ErichStyger
Specialist I
If using custom library names, I have you covered here:
https://mcuoneclipse.com/2017/07/23/how-to-use-custom-library-names-with-gnu-linker-and-eclipse/
I hope this helps,
