How to reduce title bar size in Ubuntu 22.04?
5,130 次查看
MateoSegura
I am trying to run the MCUXpresso IDE under Ubuntu 22.04. Although not major issues, I wanted to report/ask a couple of inconveniences I'm experiencing.
1. The icon for the IDE does not show, instead it's a "settings" gear
2. The title bar for the IDE is MASSIVE, Like 2-3 times bigger than all other applications, and the exit, expand and minimize buttons also look awkward. (This takes up some coding space, but not significant
Maybe it's just me being picky about it, but if someone out there knows how to minimize the title bar size I'd really like to know.
Thanks!
5,077 次查看
CarlosGarabito
Hi, I have an Ubuntu 22.04 LTS and I haven't this problem, look
So, maybe the problem is with the configuration with your Linux, or with graphics driver.
What window are you using? What of graphics card did you have? Is this driver correct configuration?
