Error in final launch sequence No debugger path for breakpoint
2,943件の閲覧回数
jren68
I am using MCUXpresso and ALL of my previously working projects suddenly are having this error upon clicking 'debug'
(build is still fine, I don't remember messing up any configuration)
So far I've tried
disconnect USB + restart MCUXpresso
ISP the board
restart laptop
uninstall and reinstall MCUXpresso
and this error still persists.
Any advice on how to fix it?
2,743件の閲覧回数
lpcxpresso_supp
It sounds like there’s a breakpoint entry for a file that’s not in any project under debug. You can look through the break list to see if this is the case, and delete the entry, or entries, or remove all breaks and add back what you need. If that doesn’t work, create a new workspace to import your projects into.
Thanks and regards,
MCUXpresso Support
2,744件の閲覧回数
lpcxpresso_supp
Thanks and regards,
MCUXpresso Support
